    Axis camera display
    7 Posts 4 Posters 2.1k Views 4 Watching
    • A
      alex2
      has anyone been able to get axis cameras to display on their mirror? I tried with a couple of the iFrame modules and had no success. Curious if anyone has had success. Ideally I can get it to rotate between two different camera streams. I’m currently using the smartwebdisplay module and I jut get a text readout saying “updated requested at…” and then it shows the interval. The two various url options I have used are the ones listed on this page. https://www.axis.com/support/faq/FAQ30473
      I don’t get any errors, just nothing pulling up. I am considering trying the webview (https://github.com/Iketaki/MMM-WebView) or rtsp modules, but want to see if anyone has had success before I keep trying things to no avail.
      • BKeyportB
        BKeyport Module Developer @alex2
        @alex2 Sadly, with the loss of OMXplayer, camera support on the Pi is somewhat weak regardless of brand. I actually reverted to the previous OS, and use a command line OMXPlayer to bring up a camera on top of my window.
        • A
          alex2 @BKeyport
          @BKeyport
          So you’re saying this is related to the bullseye OS? Odd as in the native pi browser my links work. Also, to clarify, I do embed the user:pass into the url.
          • plainbrokeP
            plainbroke @alex2
            @alex2
            MMM-WebVeiw worked for one camera but I can not get more than one instance to run Like i do with MMM-RTSPStream but I had to go back to the OS before bullseye.
            wishmaster270W A 2 Replies Last reply Reply Quote 0
            • wishmaster270W
              wishmaster270 Module Developer @plainbroke
              @plainbroke
              Hi, if the stream works wit MMM-Webview you can use MMM-EmbedURL to either embed one ore more streams. If you want to embed the streams at different positions the module supports multi instance by default.
              • A
                alex2 @plainbroke
                @plainbroke
                Thank you. running WebView and it appears to work. Much appreciated.
                • A
                  alex2 @wishmaster270
                  @wishmaster270
                  haven’t tried EmbedURL to run two streams yet, but WebView did work, so that’s a huge plus.
