    Is there a Difference between these ???
    12 Posts 5 Posters 3.1k Views 5 Watching
    • plainbrokeP Offline
      plainbroke
      Does config.js see a difference between these?
      ipAddress: “192.168.178.31”,
      icon: “database”,
      colorStateOnline: “green”,
      colorStateOffline: “red”,
      { ipAddress: “192.168.178.31”, name: “QNAP1”, icon: database", colorStateOnline: “green”, colorStateOffline: “red” },
      I only ask because I can not get the color State’s to work.
      wishmaster270W BKeyportB E 3 Replies Last reply Reply Quote 0
      • wishmaster270W Offline
        wishmaster270 Module Developer @plainbroke
        @plainbroke Hi,
        please use the code ticks to post code.
        Yes there is a difference, you missed a " before database in the second one.
        • BKeyportB Offline
          BKeyport Module Developer @plainbroke
          @plainbroke To expand on @wishmaster270 comment - To post code, please use the button
          that looks like this: 1967f487-8ada-4dad-af09-500c3dfb3cb4-image.png
          that button puts this ``` into your text, allowing you to get code posted like this to make it readable:
          icon: “database”,
            sdetweil @BKeyport
            @BKeyport however
            if u copy/paste from outside a code block backtics
            the bad quotes(curved/slanted) are copied, as in your example
            and will not be corrected, and will cause problems in config.js
            • BKeyportB Offline
              @sdetweil (that wasn’t a copy. It was escaped. backslash ` )
                sdetweil @BKeyport
                @BKeyport your post has the bad quotes
                that’s all I was saying, even tho in code block
                • BKeyportB Offline
                  @sdetweil oh, I C&P’d that. :)
                    sdetweil @BKeyport
                    @BKeyport yes, that was my point
                      plainbroke @sdetweil
                      Ok, I get it I did not post it correctly.
                      What I am trying to get at does it matter if the line is one line of text or does it need to be several lines to make it read correctly in MM?
                        sdetweil @plainbroke
                        @plainbroke the 3backtics of the code block must be on a separate line. start and end
