    MMM-CalendarExt3
    689 Posts 82 Posters 2.9m Views 86 Watching
    • BKeyportB Offline
      BKeyport Module Developer @gonzonia
      @gonzonia
      for #6, I’m sure it’s something like this, (I use CalendarExt3Agenda, which uses common code):
      /* get rid of the icon */
      .CX3 .event .headline .symbol {
        display: none;
        MMRIZE @gonzonia
        @gonzonia said in MMM-CalendarExt3:
        In CX2 there were more icon sets available. Is CX3 limited to Font Awesome because the default calendar is?
        You are right. But I’m planning Iconify integration in the future version soon.
        Can CX3 in weekly view start from the current day vs. beginning of the week?
        From beginning of the week. (by the locale).
        For daily view, use CX3A. I think it could show more data conveniently.
        I can see there’s a module-header. How can I make the CX3 title from the config show there?
          module: 'MMM-CalendarExt3',
          header: 'whatever',
          position: 'bottom_bar',
            mode: 'month',
        When you set header in config, the module title will be shown. In mode:'month', It will be changed to the value as headerTitleOptions defined automatically. In mode:'week'. It will remain static as you wrote it.
        (Do you need more configurable properties for this?)
        1. I’m having trouble getting the Day header to show only numeric for the whole week. It shows Month Day (Jul 3) in the first two days and then numeric for the rest. (I tried cellDateOptions: “{day: ‘numeric’}” in the config for the module and it shows “7/3/2023” and “7/4/2023” in the first two days. This is what I had to do to hide it with CSS.
        Weird. cellDateOptions: {day:'numeric'} should show only the number of the day. What is your locale? or check the typo.
        I had CX2 showing like this with the title on one line and the time on the next. Can that be done?
        May possible, I remember I left the one example in this thread also. But personally I don’t like it because it is not so pretty and somehow wasting the space.
        Anyway, It needs heavy CSS tweek, I’ll try to give the example later.
          MMRIZE @gonzonia
          @gonzonia
          This might be what you want.
          // config/config.js
          	module: "MMM-CalendarExt3",
          	position: "bottom_bar",
          	header: "Whatever",
          		mode: 'month',
          		cellDateOptions: { day: 'numeric' },
          		eventHeight: '44px',
          		maxEventLines: 3,
          		displayEndTime: true,
          /* css/custom.css */
          .CX3 .event .headline {
            flex-flow: row wrap;
            justify-content: flex-end;
          .CX3 .event .headline.useSymbol .symbol {
            display: none;
          .CX3 .event .headline .title,
          .CX3 .event .headline .time {
            height: var(--fontsize);
            line-height: 100%;
            text-overflow: ellipsis;
          .CX3 .event .headline .title {
            width: 100%;
            text-align: left;
            order: 4;
            text-align: right;
            width: 40%; /* It depends on your timeFormat length */
          .CX3 .cellHeader .cellDate {
            line-height: 100%;
          But this CSS is not configured in detail. It may have some bug or ugly look with some dimensions or environment. I prove the chance only and you can test and adjust it by yourself.
          • G Offline
            gonzonia @MMRIZE
            Thanks for all the help!
            Ideally I was hoping for weekly view but where the first day is the current day, so that on Friday I can still see what’s coming up in the next week.
            I understand that CX3A shows this information but it’s not in the same format and I prefer the look of the weekly format with CX3
            @MMRIZE said in MMM-CalendarExt3:
            Weird. cellDateOptions: {day:‘numeric’} should show only the number of the day. What is your locale? or check the typo.
            Locale is en-US.
            I’m in weekly view.
            It’s only on the first of the week and the current day. I’ve worked around it in CSS but I wouldn’t have expected it to show using
            This image is without any custom CSS applied
            This is the config.
            		  position: "lower_third",
            		  classes: "SceneFamily",
            		  header: 'Family Week',
            			mode: "week",
            			instanceId: "FamilyCalendar",
            			weekIndex: 0,
            			firstDayOfWeek: 0,
            			weeksInView: 1,
            			locale: 'en-US',
            			maxEventLines: 5,
            			firstDayOfWeek: 1,
            			calendarSet: ['us_holiday', '1', '2', '3', '4', '5'],
            			useWeather: false,
            			displayWeatherTemp: false,
            			useSymbol: true,
            			fontSize: "16px",
            			displayEndTime:true,
              MMRIZE @gonzonia
              @gonzonia
              In your configuration, there is no cellDateOptions.
              see my previous post for config.js
              • G Offline
                gonzonia @MMRIZE
                @MMRIZE Ha! I swear I’d tried that! When I did it would just show it as a numeric month and add the year.
                Working now though. Thanks
                • T Offline
                  tjat
                  @MMRIZE first, thank you for your development and continued efforts on this module. It is the centerpiece of my home dashboard. I am interested in incorporating user interaction to my calendar module. For instance,is there capability to display the prior or next month based on a user swiping or hitting an arrow key on an attached keyboard? I know other modules are needed to feature event listeners for those actions but I’m not sure if cx3 can handle the notifications those would pass as is.
                  Alternatively if this would need serious coding, would running multiple instances of the module work (each for a different month) and showing/hiding as appropriate?
                  (Long term, My dream state for my dashboard is an applet to popup and let the user add/modify an event directly from the screen and update my Google calendar, but that’ll be the last item in my list!)
                    MMRIZE @tjat
                    @tjat
                    • see the “glance” by notification parts in readme.
                    • And multi-instance also be possible.
                    • T Offline
                      tjat @MMRIZE
                      @MMRIZE
                      Thanks. I was able to build a simple module to advance the month via arrow keys using glance. Let me know if that’d be useful to share anywhere.
                      This question is basic but driving me nuts, but is it possible for the calendar title to include the year? For instance, it now says “July” but I’d like it to say “July 2023”.
                        MMRIZE @tjat
                        @tjat
                        headerTitleOptions: {
                          year: 'numeric',
                          month: 'long',
                        But the order of text would be decided by locale. So this will show 2023 July or July 2023. (and comma included/not, punctuation mark included/not, … depends on the standard rules of the culture by the locale.)
                        If you want to adjust the order or composition of words, you may need CSS customization additionally.
                        BKeyportB M 2 Replies Last reply Reply Quote 0
                        • BKeyportB Offline
                          BKeyport Module Developer @MMRIZE
                          @MMRIZE hey, is there a way to increase the size of the month name header? That’s the one bit I’d like to change on my setup.
                          I’m now using your module for this month, then mine for upcoming. 😉
                            pastormingle
                            Calendarext2 to Calendarext3 cofiguration is working the same. I’ve upgraded to ext3 and complete wiped and restarted magicmirror with a clean install. Ext3 doesn’t seem to have some of the same functionality i had in ext and ext2. I am attaching a screen shot of what i am looking to achieve and needing some guidance. Can someone point me to couple of configuration files that might work to achieve the same functionality. abdc3887-1c77-4f05-b451-78a14ccf6cbf-image.png
                              MMRIZE @pastormingle
                              @pastormingle
                              What does it mean the same functionality? Maybe equivalent, but not the same.
                              And if you are satisfied with CX2, just leave it as it works. :)
                                MMRIZE @BKeyport
                                @BKeyport
                                For the special calendar, (You should assign instanceId: "specialCalendar" in config)
                                .module.MMM-CalendarExt3:has(.CX3_specialCalendar) .module-header {
                                  color: red;
                                  font-weight: bold;
                                  font-size: 2em;
                                will show;
                                If you want to apply globally or have only one instance of the module;
                                .module.MMM-CalendarExt3 .module-header {
                                will work.
                                  MMRIZE @MMRIZE
                                  @tjat
                                  This is my bad. The module header of this module is not refined to be possible to be a conjunction. So you need to set up your locale for your wish.
                                  Or if you want really that feature, I’ll consider updating it.
                                    pastormingle @MMRIZE
                                    @MMRIZE i changed due to time zones not displaying correctly. I having meetings that are at times from other countries and it wouldn’t display correctly and as Ext3 is the most current it was suggested to upgrade to it… Then my Raspberry PI SD card crashed and i lost my original configuration. So now it’s a learning curve either way.
                                      pastormingle @pastormingle
                                      @pastormingle Is there a location were i can look at more detailed instructions on Ext3 or some configuration files that i can look at?
                                        @pastormingle
                                        I will show you some examples tomorrow.
                                          @MMRIZE Thanks.
                                          • T Offline
                                            tjat @MMRIZE
                                            @MMRIZE No worries, it worked perfectly.
                                            My latest issue is that I’m struggling to refresh the calendar when I add a new event to my google calendar. I’m temporarily working on a local copy to play around with the JS and have this step currently. Would this work or is there an easier/better way that you’ve already built?
                                            forceRefresh: function() {
                                               console.log("forceRefresh called");
                                               if (this.refreshTimer) {
                                                 clearTimeout(this.refreshTimer);
                                                 this.refreshTimer = null;
                                               this.tempMoment = null;
                                               this.stepIndex = 0;
                                               this.updateDom(this.config.animationSpeed);
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 34
                                            • 35
                                            • 15 / 35
