    ReferenceError: primordials is not defined
    6 Posts 3 Posters 2.1k Views 3 Watching
      bwente
      I tried to upgrade using an upgrade script.
      evalmachine.<anonymous>:43
      } = primordials;
          at evalmachine.<anonymous>:43:5
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
          at Module._compile (node:internal/modules/cjs/loader:1233:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1287:10)
          at Module.load (node:internal/modules/cjs/loader:1091:32)
          at Module._load (node:internal/modules/cjs/loader:938:12)
          at Module.require (node:internal/modules/cjs/loader:1115:19)
          at require (node:internal/modules/helpers:130:18)
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
      Node.js v20.5.1
        sdetweil @bwente
        @bwente please upgrade to 20.8.0
        • BKeyportB Offline
          @sdetweil Running into the same thing with Node.js 20.8.0 on other platforms, to try and get around other issues.
          Confirmed on brand new Pi install - the install scripts fail as described. With the upgrade script failing too - there’s SOMETHING majorly wrong.
          Issue 69 on your github for scripts contains my install.log for that attempt.
            bwente
            I tried to do a simple update that did not work.
            This fixed it. https://github.com/nodesource/distributions/blob/master/README.md
            I also lost electron somehow, once that was installed everything is back. Thank you.
              sdetweil @bwente
              @bwente thank you
                sdetweil @BKeyport
                @BKeyport try the upgrade script again, with force instead of apply
                it will remove and and add the right version of node the right way, including on buster
                please advise your results
                • G gonzonia referenced this topic on
