    328 Posts 27 Posters 740.6k Views 24 Watching
    • chrisparkerC
      chrisparker @sdetweil
      @sdetweil Get well soon!
      • E
        ember1205
        A couple of quick questions…
        • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
        • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
          sdetweil @ember1205
          @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
          the update cycle is 90days, 1st of the month
          if u look at my upgrade-script I check the versions using curl, line 173
          • E
            ember1205 @sdetweil
            @sdetweil said in new update/upgrade script, ready for testing:
            Where’s a good place to discuss the scripts? I’m wondering how feasible and useful it might be to add to the upgrade-script.sh one.
              sdetweil @ember1205
              @ember1205 you could create an issue on the repo
              • A
                ashishtank Module Developer
                @sdetweil : Thank you for the great installer script ! it worked well on Raspberry Pi Zero W. I had issue with electron and dependencies but it did the job :)
                • N Nneuland referenced this topic on
                • G
                  gonzonia
                  Running the upgrade script to install v2.25.0 and I get the following result. The last time I hit a roadblock I screwed things up enough that I did a fresh install. What are the proper steps to correct this?
                   bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                  Reading package lists... Done
                  Building dependency tree... Done
                    libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                  Use 'sudo apt autoremove' to remove them.
                  The following packages will be REMOVED:
                    nodejs*
                  0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
                  After this operation, 919 kB disk space will be freed.
                  (Reading database ... 106969 files and directories currently installed.)
                  Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  ca-certificates is already the newest version (20210119).
                  curl is already the newest version (7.74.0-1.3+deb11u7).
                  gnupg is already the newest version (2.2.27-2+deb11u2).
                  0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
                  deb [arch=arm64  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                  Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                  Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                  Fetched 15.4 kB in 1s (15.7 kB/s)
                  Suggested packages:
                    npm
                  The following NEW packages will be installed:
                    nodejs
                  0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
                  Need to get 0 B/148 kB of archives.
                  After this operation, 919 kB of additional disk space will be used.
                  Selecting previously unselected package nodejs.
                  (Reading database ... 106907 files and directories currently installed.)
                  Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                  Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                  Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                  update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                  doing test run = false
                  Minimum Node version: v20.8.0
                  Installed Node version: v12.22.12
                  Node should be upgraded.
                  A Node process is currently running. Can't upgrade.
                  Please quit all Node processes and restart the update.
                  running process(s) are
                  pi 934 932 0 Sep14 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                  G S 2 Replies Last reply Reply Quote 0
                  • G
                    gonzonia @gonzonia
                    I rebooted, and for some reason, MM didn’t restart right away, so I ran the script . It got further but then has an issue upgrading npm
                      sdetweil @gonzonia
                      @gonzonia sheesh, SO much fun… nodejs says is works and use this process…
                      we asked for node 20 and got something which turned into node 12…
                      (but then it doesn’t)
                      I JUST tested this on the latest raspian 64bit… (june this year)
                      can you post output of these two commands
                      uname -a
                      lsb_release -a
                      • G
                        gonzonia @sdetweil
                        @sdetweil I found the this thread and I tired running with “force” but I’m getting the same issue when it tries to update npm.
                        pi@MagicMirror2:~/MagicMirror $ uname -a
                        Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                        pi@MagicMirror2:~/MagicMirror $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID:	Raspbian
                        Description:	Raspbian GNU/Linux 11 (bullseye)
                        Release:	11
                        Codename:	bullseye
                          sdetweil @gonzonia
                          @gonzonia lets try this
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
                          this should remove node
                          so node -v should fail
                          then lets manually install node20
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                          then check node version
                          node -v
                          • G
                            gonzonia @sdetweil
                            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)”
                            pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
                              nodejs*
                            After this operation, 183 MB disk space will be freed.
                            Do you want to continue? [Y/n] Y
                            (Reading database ... 112341 files and directories currently installed.)
                            Removing nodejs (20.5.1-deb-1nodesource1) ...
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar/lib' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/bin' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp/bin' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man7' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man5' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/completion' not empty so not removed
                            dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin' not empty so not removed
                            pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                            Package 'nodejs' is not installed, so not removed
                            rm: cannot remove '/etc/apt/sources.list.d/nodesource.list': No such file or directory
                            Fetched 15.4 kB in 1s (12.8 kB/s)
                            The following additional packages will be installed:
                            Suggested packages:
                              npm
                              libnode72 nodejs nodejs-doc
                            0 upgraded, 3 newly installed, 0 to remove and 20 not upgraded.
                            Need to get 0 B/9,956 kB of archives.
                            After this operation, 43.3 MB of additional disk space will be used.
                            Selecting previously unselected package libnode72:armhf.
                            (Reading database ... 106718 files and directories currently installed.)
                            Preparing to unpack .../libnode72_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                            Unpacking libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
                            Selecting previously unselected package nodejs-doc.
                            Preparing to unpack .../nodejs-doc_12.22.12~dfsg-1~deb11u4_all.deb ...
                            Unpacking nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                            Setting up libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
                            Setting up nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                            pi@MagicMirror2:~/MagicMirror $ node -v
                            v12.22.12
                            Why is it installing 12 .22.12???
                              sdetweil @gonzonia
                              @gonzonia said in new update/upgrade script, ready for testing:
                              cause somebody is confused…
                              so, lets try this
                              do the remove again
                              then do
                              sudo rm -rf /usr/lib/node_modules/npm
                              and test
                              node -v
                              npm -v
                              both should fail
                              command not found
                              please confirm, if true then do the install command again
                              otherwise don’t continue
                              • G
                                gonzonia @sdetweil
                                Same result
                                  nodejs*
                                pi@MagicMirror2:~/MagicMirror $ sudo rm -rf /usr/lib/node_modules/npm
                                -bash: /usr/bin/node: No such file or directory
                                pi@MagicMirror2:~/MagicMirror $ npm -v
                                -bash: /usr/bin/npm: No such file or directory
                                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Fetched 15.4 kB in 1s (14.2 kB/s)
                                Suggested packages:
                                  npm
                                  nodejs
                                v12.22.12
                                  sdetweil @gonzonia
                                  @gonzonia SO much fun…
                                  lets see if we can find that older version binary
                                  cd /
                                  find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                                  • G
                                    gonzonia @sdetweil
                                    I had a similar thought and ran just before you said that. I removed node and ran
                                    sudo apt-get clean
                                    Running the find after came back empty.
                                    I tried installing again. Same result.
                                    Now the find shows
                                    pi@MagicMirror2:/ $ node -v
                                    v12.22.12
                                    pi@MagicMirror2:/ $ find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                                    ./var/cache/apt/archives/nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb
                                      sdetweil @gonzonia
                                      @gonzonia ok, I am trying to flash that OS version… but I don’t see Apr 3 2023… I see feb 21 2023…
                                        sdetweil @gonzonia
                                        hm… the prior release says
                                        Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
                                        we’ll see…
                                        • G
                                          gonzonia @sdetweil
                                          @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
                                            sdetweil @gonzonia
                                            @gonzonia also, make sure you back up…
                                            https://github.com/sdetweil/MagicMirror-backup-restore
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
