    328 Posts 27 Posters 740.6k Views 24 Watching
    • E
      ember1205
      A couple of quick questions…
      • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
      • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
        sdetweil @ember1205
        @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
        the update cycle is 90days, 1st of the month
        if u look at my upgrade-script I check the versions using curl, line 173
        • E
          ember1205 @sdetweil
          @sdetweil said in new update/upgrade script, ready for testing:
          Where’s a good place to discuss the scripts? I’m wondering how feasible and useful it might be to add to the upgrade-script.sh one.
            sdetweil @ember1205
            @ember1205 you could create an issue on the repo
            • A
              ashishtank Module Developer
              @sdetweil : Thank you for the great installer script ! it worked well on Raspberry Pi Zero W. I had issue with electron and dependencies but it did the job :)
              • N Nneuland referenced this topic on
              • G
                gonzonia
                Running the upgrade script to install v2.25.0 and I get the following result. The last time I hit a roadblock I screwed things up enough that I did a fresh install. What are the proper steps to correct this?
                 bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                Reading package lists... Done
                Building dependency tree... Done
                  libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                Use 'sudo apt autoremove' to remove them.
                The following packages will be REMOVED:
                  nodejs*
                0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
                After this operation, 919 kB disk space will be freed.
                (Reading database ... 106969 files and directories currently installed.)
                Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                Processing triggers for man-db (2.9.4-2) ...
                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                ca-certificates is already the newest version (20210119).
                curl is already the newest version (7.74.0-1.3+deb11u7).
                gnupg is already the newest version (2.2.27-2+deb11u2).
                0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
                deb [arch=arm64  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                Fetched 15.4 kB in 1s (15.7 kB/s)
                Suggested packages:
                  npm
                The following NEW packages will be installed:
                  nodejs
                0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
                Need to get 0 B/148 kB of archives.
                After this operation, 919 kB of additional disk space will be used.
                Selecting previously unselected package nodejs.
                (Reading database ... 106907 files and directories currently installed.)
                Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                doing test run = false
                Minimum Node version: v20.8.0
                Installed Node version: v12.22.12
                Node should be upgraded.
                A Node process is currently running. Can't upgrade.
                Please quit all Node processes and restart the update.
                running process(s) are
                pi 934 932 0 Sep14 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                G S 2 Replies Last reply Reply Quote 0
                • G
                  gonzonia @gonzonia
                  I rebooted, and for some reason, MM didn’t restart right away, so I ran the script . It got further but then has an issue upgrading npm
                    sdetweil @gonzonia
                    @gonzonia sheesh, SO much fun… nodejs says is works and use this process…
                    we asked for node 20 and got something which turned into node 12…
                    (but then it doesn’t)
                    I JUST tested this on the latest raspian 64bit… (june this year)
                    can you post output of these two commands
                    uname -a
                    lsb_release -a
                    • G
                      gonzonia @sdetweil
                      @sdetweil I found the this thread and I tired running with “force” but I’m getting the same issue when it tries to update npm.
                      pi@MagicMirror2:~/MagicMirror $ uname -a
                      Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                      pi@MagicMirror2:~/MagicMirror $ lsb_release -a
                      No LSB modules are available.
                      Distributor ID:	Raspbian
                      Description:	Raspbian GNU/Linux 11 (bullseye)
                      Release:	11
                      Codename:	bullseye
                        sdetweil @gonzonia
                        @gonzonia lets try this
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
                        this should remove node
                        so node -v should fail
                        then lets manually install node20
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                        then check node version
                        node -v
                        • G
                          gonzonia @sdetweil
                          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)”
                          pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
                            nodejs*
                          After this operation, 183 MB disk space will be freed.
                          Do you want to continue? [Y/n] Y
                          (Reading database ... 112341 files and directories currently installed.)
                          Removing nodejs (20.5.1-deb-1nodesource1) ...
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar/lib' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/bin' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp/bin' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man7' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man5' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/completion' not empty so not removed
                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin' not empty so not removed
                          pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                          Package 'nodejs' is not installed, so not removed
                          rm: cannot remove '/etc/apt/sources.list.d/nodesource.list': No such file or directory
                          Fetched 15.4 kB in 1s (12.8 kB/s)
                          The following additional packages will be installed:
                          Suggested packages:
                            npm
                            libnode72 nodejs nodejs-doc
                          0 upgraded, 3 newly installed, 0 to remove and 20 not upgraded.
                          Need to get 0 B/9,956 kB of archives.
                          After this operation, 43.3 MB of additional disk space will be used.
                          Selecting previously unselected package libnode72:armhf.
                          (Reading database ... 106718 files and directories currently installed.)
                          Preparing to unpack .../libnode72_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                          Unpacking libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
                          Selecting previously unselected package nodejs-doc.
                          Preparing to unpack .../nodejs-doc_12.22.12~dfsg-1~deb11u4_all.deb ...
                          Unpacking nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                          Setting up libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
                          Setting up nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                          pi@MagicMirror2:~/MagicMirror $ node -v
                          v12.22.12
                          Why is it installing 12 .22.12???
                            sdetweil @gonzonia
                            @gonzonia said in new update/upgrade script, ready for testing:
                            cause somebody is confused…
                            so, lets try this
                            do the remove again
                            then do
                            sudo rm -rf /usr/lib/node_modules/npm
                            and test
                            node -v
                            npm -v
                            both should fail
                            command not found
                            please confirm, if true then do the install command again
                            otherwise don’t continue
                            • G
                              gonzonia @sdetweil
                              Same result
                                nodejs*
                              pi@MagicMirror2:~/MagicMirror $ sudo rm -rf /usr/lib/node_modules/npm
                              -bash: /usr/bin/node: No such file or directory
                              pi@MagicMirror2:~/MagicMirror $ npm -v
                              -bash: /usr/bin/npm: No such file or directory
                              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Fetched 15.4 kB in 1s (14.2 kB/s)
                              Suggested packages:
                                npm
                                nodejs
                              v12.22.12
                                sdetweil @gonzonia
                                @gonzonia SO much fun…
                                lets see if we can find that older version binary
                                cd /
                                find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                                • G
                                  gonzonia @sdetweil
                                  I had a similar thought and ran just before you said that. I removed node and ran
                                  sudo apt-get clean
                                  Running the find after came back empty.
                                  I tried installing again. Same result.
                                  Now the find shows
                                  pi@MagicMirror2:/ $ node -v
                                  v12.22.12
                                  pi@MagicMirror2:/ $ find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                                  ./var/cache/apt/archives/nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb
                                    sdetweil @gonzonia
                                    @gonzonia ok, I am trying to flash that OS version… but I don’t see Apr 3 2023… I see feb 21 2023…
                                      sdetweil @gonzonia
                                      hm… the prior release says
                                      Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
                                      we’ll see…
                                      • G
                                        gonzonia @sdetweil
                                        @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
                                          sdetweil @gonzonia
                                          @gonzonia also, make sure you back up…
                                          https://github.com/sdetweil/MagicMirror-backup-restore
                                            sdetweil @gonzonia
                                            @gonzonia so the prior version install of node20 went ok as expected.
                                            but I don’t see the ‘npm’ item in the install list
                                            Suggested packages:
                                              npm  <-------  I don't see this
                                              nodejs
                                            so lets do the uninstall again
                                            and then try
                                            sudo apt remove npm
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
