    328 Posts 27 Posters 724.4k Views 24 Watching
      ashishtank Module Developer
      @sdetweil : Thank you for the great installer script ! it worked well on Raspberry Pi Zero W. I had issue with electron and dependencies but it did the job :)
      • N Nneuland referenced this topic on
      • G Offline
        gonzonia
        Running the upgrade script to install v2.25.0 and I get the following result. The last time I hit a roadblock I screwed things up enough that I did a fresh install. What are the proper steps to correct this?
         bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        Reading package lists... Done
        Building dependency tree... Done
          libc-ares2 libjs-highlight.js libnode72 nodejs-doc
        Use 'sudo apt autoremove' to remove them.
        The following packages will be REMOVED:
          nodejs*
        0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
        After this operation, 919 kB disk space will be freed.
        (Reading database ... 106969 files and directories currently installed.)
        Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
        Processing triggers for man-db (2.9.4-2) ...
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        ca-certificates is already the newest version (20210119).
        curl is already the newest version (7.74.0-1.3+deb11u7).
        gnupg is already the newest version (2.2.27-2+deb11u2).
        0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
        deb [arch=arm64  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
        Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
        Fetched 15.4 kB in 1s (15.7 kB/s)
        Suggested packages:
          npm
        The following NEW packages will be installed:
          nodejs
        0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
        Need to get 0 B/148 kB of archives.
        After this operation, 919 kB of additional disk space will be used.
        Selecting previously unselected package nodejs.
        (Reading database ... 106907 files and directories currently installed.)
        Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
        Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
        Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
        update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
        doing test run = false
        Minimum Node version: v20.8.0
        Installed Node version: v12.22.12
        Node should be upgraded.
        A Node process is currently running. Can't upgrade.
        Please quit all Node processes and restart the update.
        running process(s) are
        pi 934 932 0 Sep14 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        G S 2 Replies Last reply Reply Quote 0
        • G Offline
          gonzonia @gonzonia
          I rebooted, and for some reason, MM didn’t restart right away, so I ran the script . It got further but then has an issue upgrading npm
            sdetweil @gonzonia
            @gonzonia sheesh, SO much fun… nodejs says is works and use this process…
            we asked for node 20 and got something which turned into node 12…
            (but then it doesn’t)
            I JUST tested this on the latest raspian 64bit… (june this year)
            can you post output of these two commands
            uname -a
            lsb_release -a
            • G Offline
              gonzonia @sdetweil
              @sdetweil I found the this thread and I tired running with “force” but I’m getting the same issue when it tries to update npm.
              pi@MagicMirror2:~/MagicMirror $ uname -a
              Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
              pi@MagicMirror2:~/MagicMirror $ lsb_release -a
              No LSB modules are available.
              Distributor ID:	Raspbian
              Description:	Raspbian GNU/Linux 11 (bullseye)
              Release:	11
              Codename:	bullseye
                sdetweil @gonzonia
                @gonzonia lets try this
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
                this should remove node
                so node -v should fail
                then lets manually install node20
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                then check node version
                node -v
                • G Offline
                  gonzonia @sdetweil
                  @sdetweil said in new update/upgrade script, ready for testing:
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)”
                  pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
                    nodejs*
                  After this operation, 183 MB disk space will be freed.
                  Do you want to continue? [Y/n] Y
                  (Reading database ... 112341 files and directories currently installed.)
                  Removing nodejs (20.5.1-deb-1nodesource1) ...
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar/lib' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/bin' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp/bin' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man7' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man5' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/completion' not empty so not removed
                  dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin' not empty so not removed
                  pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                  Package 'nodejs' is not installed, so not removed
                  rm: cannot remove '/etc/apt/sources.list.d/nodesource.list': No such file or directory
                  Fetched 15.4 kB in 1s (12.8 kB/s)
                  The following additional packages will be installed:
                  Suggested packages:
                    npm
                    libnode72 nodejs nodejs-doc
                  0 upgraded, 3 newly installed, 0 to remove and 20 not upgraded.
                  Need to get 0 B/9,956 kB of archives.
                  After this operation, 43.3 MB of additional disk space will be used.
                  Selecting previously unselected package libnode72:armhf.
                  (Reading database ... 106718 files and directories currently installed.)
                  Preparing to unpack .../libnode72_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                  Unpacking libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
                  Selecting previously unselected package nodejs-doc.
                  Preparing to unpack .../nodejs-doc_12.22.12~dfsg-1~deb11u4_all.deb ...
                  Unpacking nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                  Setting up libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
                  Setting up nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
                  Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                  pi@MagicMirror2:~/MagicMirror $ node -v
                  v12.22.12
                  Why is it installing 12 .22.12???
                    sdetweil @gonzonia
                    @gonzonia said in new update/upgrade script, ready for testing:
                    cause somebody is confused…
                    so, lets try this
                    do the remove again
                    then do
                    sudo rm -rf /usr/lib/node_modules/npm
                    and test
                    node -v
                    npm -v
                    both should fail
                    command not found
                    please confirm, if true then do the install command again
                    otherwise don’t continue
                    • G Offline
                      gonzonia @sdetweil
                      Same result
                        nodejs*
                      pi@MagicMirror2:~/MagicMirror $ sudo rm -rf /usr/lib/node_modules/npm
                      -bash: /usr/bin/node: No such file or directory
                      pi@MagicMirror2:~/MagicMirror $ npm -v
                      -bash: /usr/bin/npm: No such file or directory
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Fetched 15.4 kB in 1s (14.2 kB/s)
                      Suggested packages:
                        npm
                        nodejs
                      v12.22.12
                        sdetweil @gonzonia
                        @gonzonia SO much fun…
                        lets see if we can find that older version binary
                        cd /
                        find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                        • G Offline
                          gonzonia @sdetweil
                          I had a similar thought and ran just before you said that. I removed node and ran
                          sudo apt-get clean
                          Running the find after came back empty.
                          I tried installing again. Same result.
                          Now the find shows
                          pi@MagicMirror2:/ $ node -v
                          v12.22.12
                          pi@MagicMirror2:/ $ find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                          ./var/cache/apt/archives/nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb
                            sdetweil @gonzonia
                            @gonzonia ok, I am trying to flash that OS version… but I don’t see Apr 3 2023… I see feb 21 2023…
                              sdetweil @gonzonia
                              hm… the prior release says
                              Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
                              we’ll see…
                              • G Offline
                                gonzonia @sdetweil
                                @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
                                  sdetweil @gonzonia
                                  @gonzonia also, make sure you back up…
                                  https://github.com/sdetweil/MagicMirror-backup-restore
                                    sdetweil @gonzonia
                                    @gonzonia so the prior version install of node20 went ok as expected.
                                    but I don’t see the ‘npm’ item in the install list
                                    Suggested packages:
                                      npm  <-------  I don't see this
                                      nodejs
                                    so lets do the uninstall again
                                    and then try
                                    sudo apt remove npm
                                    • G Offline
                                      gonzonia @sdetweil
                                      After an uninstall it says npm isn’t installed. I tried the install again and it’s still installing 12.22.12
                                      I did the backup. I’m just going to rebuild. It’s annoying but it should work. :crossed_fingers_light_skin_tone:
                                        sdetweil @gonzonia
                                        @gonzonia one more try… got some feedback from node user
                                        hang on while I do a quick test
                                        do this
                                        sudo cat  /etc/apt/sources.list.d/nodesource.list
                                        I see
                                        deb [arch=arm64 Pin-Priority:600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                        • G Offline
                                          gonzonia @sdetweil
                                          pi@MagicMirror2:~ $ sudo cat  /etc/apt/sources.list.d/nodesource.list
                                            sdetweil @gonzonia
                                            @gonzonia ok, suggestion was to add the pin-priority
                                            try the node20_install.sh again from my repo
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
