    328 Posts 27 Posters 726.8k Views 24 Watching
      sdetweil @gonzonia
      @gonzonia lets try this
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
      this should remove node
      so node -v should fail
      then lets manually install node20
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
      then check node version
      node -v
      • G Offline
        gonzonia @sdetweil
        @sdetweil said in new update/upgrade script, ready for testing:
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)”
        pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
        Reading package lists... Done
        Building dependency tree... Done
          libc-ares2 libjs-highlight.js
        Use 'sudo apt autoremove' to remove them.
        The following packages will be REMOVED:
          nodejs*
        0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
        After this operation, 183 MB disk space will be freed.
        Do you want to continue? [Y/n] Y
        (Reading database ... 112341 files and directories currently installed.)
        Removing nodejs (20.5.1-deb-1nodesource1) ...
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/bin' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp/bin' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man7' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man5' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/completion' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin' not empty so not removed
        Processing triggers for man-db (2.9.4-2) ...
        pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
        Package 'nodejs' is not installed, so not removed
        0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
        rm: cannot remove '/etc/apt/sources.list.d/nodesource.list': No such file or directory
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        ca-certificates is already the newest version (20210119).
        curl is already the newest version (7.74.0-1.3+deb11u7).
        gnupg is already the newest version (2.2.27-2+deb11u2).
        deb [arch=arm64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
        Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
        Fetched 15.4 kB in 1s (12.8 kB/s)
        The following additional packages will be installed:
          libnode72 nodejs-doc
        Suggested packages:
          npm
        The following NEW packages will be installed:
          libnode72 nodejs nodejs-doc
        0 upgraded, 3 newly installed, 0 to remove and 20 not upgraded.
        Need to get 0 B/9,956 kB of archives.
        After this operation, 43.3 MB of additional disk space will be used.
        Selecting previously unselected package libnode72:armhf.
        (Reading database ... 106718 files and directories currently installed.)
        Preparing to unpack .../libnode72_12.22.12~dfsg-1~deb11u4_armhf.deb ...
        Unpacking libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
        Selecting previously unselected package nodejs.
        Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
        Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
        Selecting previously unselected package nodejs-doc.
        Preparing to unpack .../nodejs-doc_12.22.12~dfsg-1~deb11u4_all.deb ...
        Unpacking nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
        Setting up libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
        Setting up nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
        Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
        Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
        pi@MagicMirror2:~/MagicMirror $ node -v
        v12.22.12
        Why is it installing 12 .22.12???
          sdetweil @gonzonia
          @gonzonia said in new update/upgrade script, ready for testing:
          cause somebody is confused…
          so, lets try this
          do the remove again
          then do
          sudo rm -rf /usr/lib/node_modules/npm
          and test
          node -v
          npm -v
          both should fail
          command not found
          please confirm, if true then do the install command again
          otherwise don’t continue
          • G Offline
            gonzonia @sdetweil
            Same result
              libc-ares2 libjs-highlight.js libnode72 nodejs-doc
              nodejs*
            After this operation, 919 kB disk space will be freed.
            (Reading database ... 106969 files and directories currently installed.)
            Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
            pi@MagicMirror2:~/MagicMirror $ sudo rm -rf /usr/lib/node_modules/npm
            -bash: /usr/bin/node: No such file or directory
            pi@MagicMirror2:~/MagicMirror $ npm -v
            -bash: /usr/bin/npm: No such file or directory
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Fetched 15.4 kB in 1s (14.2 kB/s)
            Suggested packages:
              npm
              nodejs
            0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
            Need to get 0 B/148 kB of archives.
            After this operation, 919 kB of additional disk space will be used.
            (Reading database ... 106907 files and directories currently installed.)
            update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
            v12.22.12
              sdetweil @gonzonia
              @gonzonia SO much fun…
              lets see if we can find that older version binary
              cd /
              find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
              • G Offline
                gonzonia @sdetweil
                I had a similar thought and ran just before you said that. I removed node and ran
                sudo apt-get clean
                Running the find after came back empty.
                I tried installing again. Same result.
                Now the find shows
                pi@MagicMirror2:/ $ node -v
                v12.22.12
                pi@MagicMirror2:/ $ find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                ./var/cache/apt/archives/nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb
                  sdetweil @gonzonia
                  @gonzonia ok, I am trying to flash that OS version… but I don’t see Apr 3 2023… I see feb 21 2023…
                    sdetweil @gonzonia
                    Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                    hm… the prior release says
                    Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
                    we’ll see…
                    • G Offline
                      gonzonia @sdetweil
                      @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
                        sdetweil @gonzonia
                        @gonzonia also, make sure you back up…
                        https://github.com/sdetweil/MagicMirror-backup-restore
                          sdetweil @gonzonia
                          @gonzonia so the prior version install of node20 went ok as expected.
                          but I don’t see the ‘npm’ item in the install list
                          Suggested packages:
                            npm  <-------  I don't see this
                            nodejs
                          so lets do the uninstall again
                          and then try
                          sudo apt remove npm
                          • G Offline
                            gonzonia @sdetweil
                            After an uninstall it says npm isn’t installed. I tried the install again and it’s still installing 12.22.12
                            I did the backup. I’m just going to rebuild. It’s annoying but it should work. :crossed_fingers_light_skin_tone:
                              sdetweil @gonzonia
                              @gonzonia one more try… got some feedback from node user
                              hang on while I do a quick test
                              do this
                              sudo cat  /etc/apt/sources.list.d/nodesource.list
                              I see
                              deb [arch=arm64 Pin-Priority:600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                              • G Offline
                                gonzonia @sdetweil
                                pi@MagicMirror2:~ $ sudo cat  /etc/apt/sources.list.d/nodesource.list
                                  sdetweil @gonzonia
                                  @gonzonia ok, suggestion was to add the pin-priority
                                  try the node20_install.sh again from my repo
                                  • G Offline
                                    gonzonia @sdetweil
                                    Same thing. I feel like this line is the issue ----“Selecting previously unselected package nodejs.” How can I clear wherever it’s finding that?
                                    (I also tried the uninstall from your repo and install, same thing)
                                    pi@MagicMirror2:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                                      nodejs*
                                    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                    (Reading database ... 107017 files and directories currently installed.)
                                    Fetched 15.4 kB in 1s (16.3 kB/s)
                                    Suggested packages:
                                      npm
                                      nodejs
                                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                    (Reading database ... 106955 files and directories currently installed.)
                                      sdetweil @gonzonia
                                      @gonzonia can u cat that file again
                                      • G Offline
                                        gonzonia @sdetweil
                                        deb [arch=arm64 Pin-Priority=600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                          sdetweil @gonzonia
                                          @gonzonia hmmmm… ok, don’t know… I will post that too…
                                          best to just move to new again I guess…
                                          can u try this
                                          sudo apt-get update
                                          sudo apt-get install nodejs -y
                                          • G Offline
                                            gonzonia @sdetweil
                                            Thanks for trying. I appreciate all the support you provide the MM community.
                                            pi@MagicMirror2:~ $ sudo apt-get update
                                            Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            nodejs is already the newest version (12.22.12~dfsg-1~deb11u4).
                                            pi@MagicMirror2:~ $
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
