    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @gonzonia
      @gonzonia SO much fun…
      lets see if we can find that older version binary
      cd /
      find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
      • G
        gonzonia @sdetweil
        @sdetweil said in new update/upgrade script, ready for testing:
        I had a similar thought and ran just before you said that. I removed node and ran
        sudo apt-get clean
        Running the find after came back empty.
        I tried installing again. Same result.
        Now the find shows
        pi@MagicMirror2:/ $ node -v
        v12.22.12
        pi@MagicMirror2:/ $ find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
        ./var/cache/apt/archives/nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb
          sdetweil @gonzonia
          @gonzonia ok, I am trying to flash that OS version… but I don’t see Apr 3 2023… I see feb 21 2023…
            sdetweil @gonzonia
            @gonzonia said in new update/upgrade script, ready for testing:
            Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
            hm… the prior release says
            Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
            we’ll see…
            • G
              gonzonia @sdetweil
              @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
                sdetweil @gonzonia
                @gonzonia also, make sure you back up…
                https://github.com/sdetweil/MagicMirror-backup-restore
                  sdetweil @gonzonia
                  @gonzonia so the prior version install of node20 went ok as expected.
                  but I don’t see the ‘npm’ item in the install list
                  Suggested packages:
                    npm  <-------  I don't see this
                  The following NEW packages will be installed:
                    nodejs
                  0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
                  so lets do the uninstall again
                  and then try
                  sudo apt remove npm
                  • G
                    gonzonia @sdetweil
                    After an uninstall it says npm isn’t installed. I tried the install again and it’s still installing 12.22.12
                    I did the backup. I’m just going to rebuild. It’s annoying but it should work. :crossed_fingers_light_skin_tone:
                      sdetweil @gonzonia
                      @gonzonia one more try… got some feedback from node user
                      hang on while I do a quick test
                      do this
                      sudo cat  /etc/apt/sources.list.d/nodesource.list
                      I see
                      deb [arch=arm64 Pin-Priority:600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                      • G
                        gonzonia @sdetweil
                        pi@MagicMirror2:~ $ sudo cat  /etc/apt/sources.list.d/nodesource.list
                        deb [arch=arm64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                          sdetweil @gonzonia
                          @gonzonia ok, suggestion was to add the pin-priority
                          try the node20_install.sh again from my repo
                          • G
                            gonzonia @sdetweil
                            Same thing. I feel like this line is the issue ----“Selecting previously unselected package nodejs.” How can I clear wherever it’s finding that?
                            (I also tried the uninstall from your repo and install, same thing)
                            pi@MagicMirror2:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                            Reading package lists... Done
                            Building dependency tree... Done
                              libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                            Use 'sudo apt autoremove' to remove them.
                            The following packages will be REMOVED:
                              nodejs*
                            0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                            After this operation, 919 kB disk space will be freed.
                            (Reading database ... 107017 files and directories currently installed.)
                            Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                            Processing triggers for man-db (2.9.4-2) ...
                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                            ca-certificates is already the newest version (20210119).
                            curl is already the newest version (7.74.0-1.3+deb11u7).
                            gnupg is already the newest version (2.2.27-2+deb11u2).
                            Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                            Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                            Fetched 15.4 kB in 1s (16.3 kB/s)
                            Suggested packages:
                              npm
                              nodejs
                            0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 0 B/148 kB of archives.
                            After this operation, 919 kB of additional disk space will be used.
                            (Reading database ... 106955 files and directories currently installed.)
                            Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                            Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                            Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                            update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                              sdetweil @gonzonia
                              @gonzonia can u cat that file again
                              • G
                                gonzonia @sdetweil
                                deb [arch=arm64 Pin-Priority=600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                  sdetweil @gonzonia
                                  @gonzonia hmmmm… ok, don’t know… I will post that too…
                                  best to just move to new again I guess…
                                  can u try this
                                  sudo apt-get update
                                  sudo apt-get install nodejs -y
                                  • G
                                    gonzonia @sdetweil
                                    Thanks for trying. I appreciate all the support you provide the MM community.
                                    pi@MagicMirror2:~ $ sudo apt-get update
                                    Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    nodejs is already the newest version (12.22.12~dfsg-1~deb11u4).
                                    pi@MagicMirror2:~ $
                                      sdetweil @gonzonia
                                      @gonzonia can u also do
                                      ls /etc/apt/sources.list.d
                                      thats where the other sources are
                                      and cat each file it mentions
                                      nodesource.list  raspi.list
                                      is what I see on the 64bit os
                                      • G
                                        gonzonia @sdetweil
                                        pi@MagicMirror2:~ $ ls /etc/apt/sources.list.d
                                        pi@MagicMirror2:~ $ sudo cat /etc/apt/sources.list.d/raspi.list
                                        deb http://archive.raspberrypi.org/debian/ bullseye main
                                        # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                                        #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                                          sdetweil @gonzonia
                                          @gonzonia thanks… same as I see…
                                          • G
                                            gonzonia @sdetweil
                                            I’m just going to rebuild. I’ll let you know if I hit any snags. Thanks again.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
