    328 Posts 27 Posters 716.6k Views 24 Watching
      sdetweil @gonzonia
      @gonzonia said in new update/upgrade script, ready for testing:
      Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
      hm… the prior release says
      Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
      we’ll see…
      • G Offline
        gonzonia @sdetweil
        @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
          sdetweil @gonzonia
          @gonzonia also, make sure you back up…
          https://github.com/sdetweil/MagicMirror-backup-restore
            sdetweil @gonzonia
            @gonzonia so the prior version install of node20 went ok as expected.
            but I don’t see the ‘npm’ item in the install list
            Suggested packages:
              npm  <-------  I don't see this
            The following NEW packages will be installed:
              nodejs
            0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
            so lets do the uninstall again
            and then try
            sudo apt remove npm
            • G Offline
              gonzonia @sdetweil
              After an uninstall it says npm isn’t installed. I tried the install again and it’s still installing 12.22.12
              I did the backup. I’m just going to rebuild. It’s annoying but it should work. :crossed_fingers_light_skin_tone:
                sdetweil @gonzonia
                @gonzonia one more try… got some feedback from node user
                hang on while I do a quick test
                do this
                sudo cat  /etc/apt/sources.list.d/nodesource.list
                I see
                deb [arch=arm64 Pin-Priority:600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                • G Offline
                  gonzonia @sdetweil
                  pi@MagicMirror2:~ $ sudo cat  /etc/apt/sources.list.d/nodesource.list
                  deb [arch=arm64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                    sdetweil @gonzonia
                    @gonzonia ok, suggestion was to add the pin-priority
                    try the node20_install.sh again from my repo
                    • G Offline
                      gonzonia @sdetweil
                      Same thing. I feel like this line is the issue ----“Selecting previously unselected package nodejs.” How can I clear wherever it’s finding that?
                      (I also tried the uninstall from your repo and install, same thing)
                      pi@MagicMirror2:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                      Reading package lists... Done
                      Building dependency tree... Done
                        libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                      Use 'sudo apt autoremove' to remove them.
                      The following packages will be REMOVED:
                        nodejs*
                      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                      After this operation, 919 kB disk space will be freed.
                      (Reading database ... 107017 files and directories currently installed.)
                      Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      ca-certificates is already the newest version (20210119).
                      curl is already the newest version (7.74.0-1.3+deb11u7).
                      gnupg is already the newest version (2.2.27-2+deb11u2).
                      Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                      Fetched 15.4 kB in 1s (16.3 kB/s)
                      Suggested packages:
                        npm
                        nodejs
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 0 B/148 kB of archives.
                      After this operation, 919 kB of additional disk space will be used.
                      (Reading database ... 106955 files and directories currently installed.)
                      Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                      Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                      Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                      update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                        sdetweil @gonzonia
                        @gonzonia can u cat that file again
                        • G Offline
                          gonzonia @sdetweil
                          deb [arch=arm64 Pin-Priority=600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                            sdetweil @gonzonia
                            @gonzonia hmmmm… ok, don’t know… I will post that too…
                            best to just move to new again I guess…
                            can u try this
                            sudo apt-get update
                            sudo apt-get install nodejs -y
                            • G Offline
                              gonzonia @sdetweil
                              Thanks for trying. I appreciate all the support you provide the MM community.
                              pi@MagicMirror2:~ $ sudo apt-get update
                              Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
                              nodejs is already the newest version (12.22.12~dfsg-1~deb11u4).
                              pi@MagicMirror2:~ $
                                sdetweil @gonzonia
                                @gonzonia can u also do
                                ls /etc/apt/sources.list.d
                                thats where the other sources are
                                and cat each file it mentions
                                nodesource.list  raspi.list
                                is what I see on the 64bit os
                                • G Offline
                                  gonzonia @sdetweil
                                  pi@MagicMirror2:~ $ ls /etc/apt/sources.list.d
                                  pi@MagicMirror2:~ $ sudo cat /etc/apt/sources.list.d/raspi.list
                                  deb http://archive.raspberrypi.org/debian/ bullseye main
                                  # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                                  #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                                    sdetweil @gonzonia
                                    @gonzonia thanks… same as I see…
                                    • G Offline
                                      gonzonia @sdetweil
                                      I’m just going to rebuild. I’ll let you know if I hit any snags. Thanks again.
                                        Socrates
                                        Sorry to revive this old thread, but I used this script to update all my modules at once, and they worked perfectly after upgrading Node.js and npm.
                                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                        I have a question: Will this script automatically check for and apply module upgrades periodically? Or is it better to add it to a nightly crontab?
                                          sdetweil @Socrates
                                          @Socrates no… this script is only for the base.
                                            sdetweil @Socrates
                                            @Socrates note that without adding a parameter
                                            The script does nothing. It only tests the ability to update the base MagicMirror
                                            Update is two pass process
                                            Test. Make no changes
                                            Do. Apply the changes (with the parameter apply)
                                            Many users have modified MagicMirror base code not knowing about the config and css file design. These changes block the ability to update normally
                                            Over time they forget that they changed the files and what they actually changed. The force way to install is to wipe all changes, but now the result doesn’t work like it used to. Adding a lot of frustration.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
