    328 Posts 27 Posters 740.6k Views 24 Watching
    • G
      gonzonia @sdetweil
      @sdetweil I found the this thread and I tired running with “force” but I’m getting the same issue when it tries to update npm.
      pi@MagicMirror2:~/MagicMirror $ uname -a
      Linux MagicMirror2 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
      pi@MagicMirror2:~/MagicMirror $ lsb_release -a
      No LSB modules are available.
      Distributor ID:	Raspbian
      Description:	Raspbian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
        sdetweil @gonzonia
        @gonzonia lets try this
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
        this should remove node
        so node -v should fail
        then lets manually install node20
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
        then check node version
        node -v
        • G
          gonzonia @sdetweil
          @sdetweil said in new update/upgrade script, ready for testing:
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)”
          pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/uninstall_node.sh)"
          Reading package lists... Done
          Building dependency tree... Done
            libc-ares2 libjs-highlight.js
          Use 'sudo apt autoremove' to remove them.
          The following packages will be REMOVED:
            nodejs*
          0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
          After this operation, 183 MB disk space will be freed.
          Do you want to continue? [Y/n] Y
          (Reading database ... 112341 files and directories currently installed.)
          Removing nodejs (20.5.1-deb-1nodesource1) ...
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar/lib' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/bin' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp/bin' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man7' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man5' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/completion' not empty so not removed
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/bin' not empty so not removed
          Processing triggers for man-db (2.9.4-2) ...
          pi@MagicMirror2:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
          Package 'nodejs' is not installed, so not removed
          0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
          rm: cannot remove '/etc/apt/sources.list.d/nodesource.list': No such file or directory
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          ca-certificates is already the newest version (20210119).
          curl is already the newest version (7.74.0-1.3+deb11u7).
          gnupg is already the newest version (2.2.27-2+deb11u2).
          deb [arch=arm64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
          Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
          Fetched 15.4 kB in 1s (12.8 kB/s)
          The following additional packages will be installed:
            libnode72 nodejs-doc
          Suggested packages:
            npm
          The following NEW packages will be installed:
            libnode72 nodejs nodejs-doc
          0 upgraded, 3 newly installed, 0 to remove and 20 not upgraded.
          Need to get 0 B/9,956 kB of archives.
          After this operation, 43.3 MB of additional disk space will be used.
          Selecting previously unselected package libnode72:armhf.
          (Reading database ... 106718 files and directories currently installed.)
          Preparing to unpack .../libnode72_12.22.12~dfsg-1~deb11u4_armhf.deb ...
          Unpacking libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
          Selecting previously unselected package nodejs.
          Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
          Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
          Selecting previously unselected package nodejs-doc.
          Preparing to unpack .../nodejs-doc_12.22.12~dfsg-1~deb11u4_all.deb ...
          Unpacking nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
          Setting up libnode72:armhf (12.22.12~dfsg-1~deb11u4) ...
          Setting up nodejs-doc (12.22.12~dfsg-1~deb11u4) ...
          Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
          pi@MagicMirror2:~/MagicMirror $ node -v
          v12.22.12
          Why is it installing 12 .22.12???
            sdetweil @gonzonia
            @gonzonia said in new update/upgrade script, ready for testing:
            cause somebody is confused…
            so, lets try this
            do the remove again
            then do
            sudo rm -rf /usr/lib/node_modules/npm
            and test
            node -v
            npm -v
            both should fail
            command not found
            please confirm, if true then do the install command again
            otherwise don’t continue
            • G
              gonzonia @sdetweil
              Same result
                libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                nodejs*
              After this operation, 919 kB disk space will be freed.
              (Reading database ... 106969 files and directories currently installed.)
              Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
              pi@MagicMirror2:~/MagicMirror $ sudo rm -rf /usr/lib/node_modules/npm
              -bash: /usr/bin/node: No such file or directory
              pi@MagicMirror2:~/MagicMirror $ npm -v
              -bash: /usr/bin/npm: No such file or directory
              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Fetched 15.4 kB in 1s (14.2 kB/s)
              Suggested packages:
                npm
                nodejs
              0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
              Need to get 0 B/148 kB of archives.
              After this operation, 919 kB of additional disk space will be used.
              (Reading database ... 106907 files and directories currently installed.)
              update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
              v12.22.12
                sdetweil @gonzonia
                @gonzonia SO much fun…
                lets see if we can find that older version binary
                cd /
                find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                • G
                  gonzonia @sdetweil
                  I had a similar thought and ran just before you said that. I removed node and ran
                  sudo apt-get clean
                  Running the find after came back empty.
                  I tried installing again. Same result.
                  Now the find shows
                  pi@MagicMirror2:/ $ node -v
                  v12.22.12
                  pi@MagicMirror2:/ $ find . -type f 2>/dev/null | grep -i  nodejs_12.22.12
                  ./var/cache/apt/archives/nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb
                    sdetweil @gonzonia
                    @gonzonia ok, I am trying to flash that OS version… but I don’t see Apr 3 2023… I see feb 21 2023…
                      sdetweil @gonzonia
                      hm… the prior release says
                      Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
                      we’ll see…
                      • G
                        gonzonia @sdetweil
                        @sdetweil Thanks. When I ran into issues last update I ended up building it up from scratch again. There were some benefits to that and I have a pretty clean install now. I can do it again but would prefer to not have to.
                          sdetweil @gonzonia
                          @gonzonia also, make sure you back up…
                          https://github.com/sdetweil/MagicMirror-backup-restore
                            sdetweil @gonzonia
                            @gonzonia so the prior version install of node20 went ok as expected.
                            but I don’t see the ‘npm’ item in the install list
                            Suggested packages:
                              npm  <-------  I don't see this
                              nodejs
                            so lets do the uninstall again
                            and then try
                            sudo apt remove npm
                            • G
                              gonzonia @sdetweil
                              After an uninstall it says npm isn’t installed. I tried the install again and it’s still installing 12.22.12
                              I did the backup. I’m just going to rebuild. It’s annoying but it should work. :crossed_fingers_light_skin_tone:
                                sdetweil @gonzonia
                                @gonzonia one more try… got some feedback from node user
                                hang on while I do a quick test
                                do this
                                sudo cat  /etc/apt/sources.list.d/nodesource.list
                                I see
                                deb [arch=arm64 Pin-Priority:600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                • G
                                  gonzonia @sdetweil
                                  pi@MagicMirror2:~ $ sudo cat  /etc/apt/sources.list.d/nodesource.list
                                    sdetweil @gonzonia
                                    @gonzonia ok, suggestion was to add the pin-priority
                                    try the node20_install.sh again from my repo
                                    • G
                                      gonzonia @sdetweil
                                      Same thing. I feel like this line is the issue ----“Selecting previously unselected package nodejs.” How can I clear wherever it’s finding that?
                                      (I also tried the uninstall from your repo and install, same thing)
                                      pi@MagicMirror2:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                                        nodejs*
                                      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                      (Reading database ... 107017 files and directories currently installed.)
                                      Fetched 15.4 kB in 1s (16.3 kB/s)
                                      Suggested packages:
                                        npm
                                        nodejs
                                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                      (Reading database ... 106955 files and directories currently installed.)
                                        sdetweil @gonzonia
                                        @gonzonia can u cat that file again
                                        • G
                                          gonzonia @sdetweil
                                          deb [arch=arm64 Pin-Priority=600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                            sdetweil @gonzonia
                                            @gonzonia hmmmm… ok, don’t know… I will post that too…
                                            best to just move to new again I guess…
                                            can u try this
                                            sudo apt-get update
                                            sudo apt-get install nodejs -y
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
