    328 Posts 27 Posters 726.7k Views 24 Watching
      bdream
      Hi Sam! I run your update script an my Pi0
      Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
      pm2 restart MagicMirror
      looks good
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] [MagicMirror](0) ✓
      │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
      │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
      what is I’m doing wrong?
      Many thanks!!!
      cheers, bdream
        sdetweil @bdream
        @bdream something is wrong, 122 restarts 0 uptime.
        do
        pm2 stop 0
        pm2 logs --lines=100
          bdream
          here is
          pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
          PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
          PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
          PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
          PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
          PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
          0|MagicMir |
          0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
          0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
          0|MagicMir |
          0|MagicMir |
          /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
          0|MagicMir | npm ERR! errno ENOENT
          0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
          0|MagicMir | npm ERR! spawn ENOENT
          0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|MagicMir |
          0|MagicMir | npm ERR! A complete log of this run can be found in:
          0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
          0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
          0|MagicMir | npm ERR! code ELIFECYCLE
          0|MagicMir | npm ERR! syscall spawn
          0|MagicMir | npm ERR! file sh
          0|MagicMir |
          0|MagicMir |
          0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
          cheers, bdream
            sdetweil @bdream
            @bdream hm. looks like my upgrade script failed to restore the start script change
            edit package.json
            change the start line to
            "start": "./run-start.sh",
            then
            pm2 flush
            pm2 start 0
            I see the bug, but am on my phone right now and will have to fix it later
              bdream
              @sdetweil it dose not work
              if I change to
              "start": " ./run-start.sh",
              also as
              "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
              I get an web explorer showing an error
              ERR_CONNECTION_REFUSED
              localhos refused connection.
              cheers, bdream
                sdetweil @bdream
                @bdream notice the 1st has a space in front of the ./, I edited that space out
                  @bdream also. let’s try this
                  stop everything
                  then
                  npm run server
                  the server side should start.
                    bdream
                    @sdetweil said in new update/upgrade script, ready for testing:
                    That is also not helpful
                    stop everything
                    How to stop everything?
                    Is this enough?
                    pm2 stop 0
                    cheers, bdream
                      bdream
                      npm run server
                      I get this:
                      pi@RasPiZeroW:~ $ cd MagicMirror/
                      pi@RasPiZeroW:~/MagicMirror $ npm run server
                      > magicmirror@2.12.0 server /home/pi/MagicMirror
                      > node ./serveronly
                      internal/modules/cjs/loader.js:638
                          throw err;
                      Error: Cannot find module 'proxy-addr'
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                          at Module.require (internal/modules/cjs/loader.js:692:17)
                          at require (internal/modules/cjs/helpers.js:25:18)
                          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.12.0 server script.
                      npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
                      cheers, bdream
                        sdetweil @bdream
                        @bdream I have opened issue
                        https://github.com/MichMich/MagicMirror/issues/2069
                        I cannot debug more myself at this time. in hospital, sorry
                        chrisparkerC 1 Reply Last reply Reply Quote 0
                          bdream
                          @sdetweil Sam! You are in hospital :face_with_head-bandage:
                          So you have to focus on yourself!
                          Wish you all the best and fast recovery!
                          Hope you are back soon!
                          cheers, bdream
                            sdetweil @bdream
                            @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
                              bdream
                              @sdetweil sounds hard to you. far away from your computer.
                              near time you have to walk and walk all will go as before and better.
                              All the best!
                              cheers, bdream
                                sdetweil @bdream
                                @bdream if u rename the mm folder to mm. save and the reinstall does it work?
                                  i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
                                  let me know how it goes
                                  • chrisparkerC Offline
                                    chrisparker @sdetweil
                                    @sdetweil Get well soon!
                                    • E Offline
                                      ember1205
                                      A couple of quick questions…
                                      • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
                                      • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
                                        sdetweil @ember1205
                                        @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
                                        the update cycle is 90days, 1st of the month
                                        if u look at my upgrade-script I check the versions using curl, line 173
                                        • E Offline
                                          ember1205 @sdetweil
                                          Where’s a good place to discuss the scripts? I’m wondering how feasible and useful it might be to add to the upgrade-script.sh one.
                                            sdetweil @ember1205
                                            @ember1205 you could create an issue on the repo
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
