    328 Posts 27 Posters 741.0k Views 24 Watching
      bdream
      @sdetweil it dose not work
      if I change to
      "start": " ./run-start.sh",
      also as
      "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
      I get an web explorer showing an error
      ERR_CONNECTION_REFUSED
      localhos refused connection.
      cheers, bdream
        sdetweil @bdream
        @bdream notice the 1st has a space in front of the ./, I edited that space out
          @bdream also. let’s try this
          stop everything
          then
          npm run server
          the server side should start.
            bdream
            @sdetweil said in new update/upgrade script, ready for testing:
            That is also not helpful
            stop everything
            How to stop everything?
            Is this enough?
            pm2 stop 0
            cheers, bdream
              bdream
              npm run server
              I get this:
              pi@RasPiZeroW:~ $ cd MagicMirror/
              pi@RasPiZeroW:~/MagicMirror $ npm run server
              > magicmirror@2.12.0 server /home/pi/MagicMirror
              > node ./serveronly
              internal/modules/cjs/loader.js:638
                  throw err;
              Error: Cannot find module 'proxy-addr'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                  at Module.require (internal/modules/cjs/loader.js:692:17)
                  at require (internal/modules/cjs/helpers.js:25:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.12.0 server script.
              npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
              cheers, bdream
                sdetweil @bdream
                @bdream I have opened issue
                https://github.com/MichMich/MagicMirror/issues/2069
                I cannot debug more myself at this time. in hospital, sorry
                chrisparkerC 1 Reply Last reply
                  bdream
                  @sdetweil Sam! You are in hospital :face_with_head-bandage:
                  So you have to focus on yourself!
                  Wish you all the best and fast recovery!
                  Hope you are back soon!
                  cheers, bdream
                    sdetweil @bdream
                    @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
                      bdream
                      @sdetweil sounds hard to you. far away from your computer.
                      near time you have to walk and walk all will go as before and better.
                      All the best!
                      cheers, bdream
                        sdetweil @bdream
                        @bdream if u rename the mm folder to mm. save and the reinstall does it work?
                          i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
                          let me know how it goes
                          • chrisparkerC
                            chrisparker @sdetweil
                            @sdetweil Get well soon!
                            • E
                              ember1205
                              A couple of quick questions…
                              • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
                              • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
                                sdetweil @ember1205
                                @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
                                the update cycle is 90days, 1st of the month
                                if u look at my upgrade-script I check the versions using curl, line 173
                                E 1 Reply Last reply
                                • E
                                  ember1205 @sdetweil
                                  Where’s a good place to discuss the scripts? I’m wondering how feasible and useful it might be to add to the upgrade-script.sh one.
                                    sdetweil @ember1205
                                    @ember1205 you could create an issue on the repo
                                    • A
                                      ashishtank Module Developer
                                      @sdetweil : Thank you for the great installer script ! it worked well on Raspberry Pi Zero W. I had issue with electron and dependencies but it did the job :)
                                      • N Nneuland referenced this topic on
                                      • G
                                        gonzonia
                                        Running the upgrade script to install v2.25.0 and I get the following result. The last time I hit a roadblock I screwed things up enough that I did a fresh install. What are the proper steps to correct this?
                                         bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                        Reading package lists... Done
                                        Building dependency tree... Done
                                          libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                                        Use 'sudo apt autoremove' to remove them.
                                        The following packages will be REMOVED:
                                          nodejs*
                                        0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
                                        After this operation, 919 kB disk space will be freed.
                                        (Reading database ... 106969 files and directories currently installed.)
                                        Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                                        Processing triggers for man-db (2.9.4-2) ...
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                        ca-certificates is already the newest version (20210119).
                                        curl is already the newest version (7.74.0-1.3+deb11u7).
                                        gnupg is already the newest version (2.2.27-2+deb11u2).
                                        0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
                                        deb [arch=arm64  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                        Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                                        Fetched 15.4 kB in 1s (15.7 kB/s)
                                        Suggested packages:
                                          npm
                                        The following NEW packages will be installed:
                                          nodejs
                                        0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
                                        Need to get 0 B/148 kB of archives.
                                        After this operation, 919 kB of additional disk space will be used.
                                        Selecting previously unselected package nodejs.
                                        (Reading database ... 106907 files and directories currently installed.)
                                        Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                                        Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                                        Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                                        update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                                        doing test run = false
                                        Minimum Node version: v20.8.0
                                        Installed Node version: v12.22.12
                                        Node should be upgraded.
                                        A Node process is currently running. Can't upgrade.
                                        Please quit all Node processes and restart the update.
                                        running process(s) are
                                        pi 934 932 0 Sep14 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                                        G S 2 Replies Last reply
                                        • G
                                          gonzonia @gonzonia
                                          I rebooted, and for some reason, MM didn’t restart right away, so I ran the script . It got further but then has an issue upgrading npm
                                            sdetweil @gonzonia
                                            @gonzonia sheesh, SO much fun… nodejs says is works and use this process…
                                            we asked for node 20 and got something which turned into node 12…
                                            (but then it doesn’t)
                                            I JUST tested this on the latest raspian 64bit… (june this year)
                                            can you post output of these two commands
                                            uname -a
                                            lsb_release -a
                                            G 1 Reply Last reply
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
