    328 Posts 27 Posters 658.0k Views 24 Watching
      sdetweil @bdream
      @bdream I have opened issue
      https://github.com/MichMich/MagicMirror/issues/2069
      I cannot debug more myself at this time. in hospital, sorry
      chrisparkerC 1 Reply Last reply Reply Quote 0
        bdream
        @sdetweil Sam! You are in hospital :face_with_head-bandage:
        So you have to focus on yourself!
        Wish you all the best and fast recovery!
        Hope you are back soon!
        cheers, bdream
          sdetweil @bdream
          @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
            bdream
            @sdetweil sounds hard to you. far away from your computer.
            near time you have to walk and walk all will go as before and better.
            All the best!
            cheers, bdream
              sdetweil @bdream
              @bdream if u rename the mm folder to mm. save and the reinstall does it work?
                i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
                let me know how it goes
                • chrisparkerC Offline
                  chrisparker @sdetweil
                  @sdetweil Get well soon!
                  • E Offline
                    ember1205
                    A couple of quick questions…
                    • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
                    • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
                      sdetweil @ember1205
                      @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
                      the update cycle is 90days, 1st of the month
                      if u look at my upgrade-script I check the versions using curl, line 173
                      • E Offline
                        ember1205 @sdetweil
                        @sdetweil said in new update/upgrade script, ready for testing:
                        Where’s a good place to discuss the scripts? I’m wondering how feasible and useful it might be to add to the upgrade-script.sh one.
                        • 27
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 29 / 33
