    328 Posts 27 Posters 740.6k Views 24 Watching
    • BKeyportB
      @sdetweil Correct, but isn’t it supposed to run for modules, too?
        sdetweil @BKeyport
        @BKeyport not if it’s doing nothing
        • BKeyportB
          @sdetweil oh, gotcha.
          Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
          Thanks!
            sdetweil @BKeyport
            @BKeyport use force. It will do it.
              bdream
              Hi Sam! I run your update script an my Pi0
              Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
              pm2 restart MagicMirror
              looks good
              [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
              [PM2] [MagicMirror](0) ✓
              │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
              │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
              what is I’m doing wrong?
              Many thanks!!!
              cheers, bdream
                sdetweil @bdream
                @bdream something is wrong, 122 restarts 0 uptime.
                do
                pm2 stop 0
                pm2 logs --lines=100
                  bdream
                  here is
                  pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
                  PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                  PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                  PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
                  PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
                  PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
                  PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                  PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                  0|MagicMir |
                  0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
                  0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  0|MagicMir |
                  0|MagicMir |
                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                  0|MagicMir | npm ERR! errno ENOENT
                  0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  0|MagicMir | npm ERR! spawn ENOENT
                  0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  0|MagicMir |
                  0|MagicMir | npm ERR! A complete log of this run can be found in:
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
                  0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
                  0|MagicMir | npm ERR! code ELIFECYCLE
                  0|MagicMir | npm ERR! syscall spawn
                  0|MagicMir | npm ERR! file sh
                  0|MagicMir |
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
                  cheers, bdream
                    sdetweil @bdream
                    @bdream hm. looks like my upgrade script failed to restore the start script change
                    edit package.json
                    change the start line to
                    "start": "./run-start.sh",
                    then
                    pm2 flush
                    pm2 start 0
                    I see the bug, but am on my phone right now and will have to fix it later
                      bdream
                      @sdetweil it dose not work
                      if I change to
                      "start": " ./run-start.sh",
                      also as
                      "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
                      I get an web explorer showing an error
                      ERR_CONNECTION_REFUSED
                      localhos refused connection.
                      cheers, bdream
                        sdetweil @bdream
                        @bdream notice the 1st has a space in front of the ./, I edited that space out
                          @bdream also. let’s try this
                          stop everything
                          then
                          npm run server
                          the server side should start.
                            bdream
                            @sdetweil said in new update/upgrade script, ready for testing:
                            That is also not helpful
                            stop everything
                            How to stop everything?
                            Is this enough?
                            pm2 stop 0
                            cheers, bdream
                              bdream
                              npm run server
                              I get this:
                              pi@RasPiZeroW:~ $ cd MagicMirror/
                              pi@RasPiZeroW:~/MagicMirror $ npm run server
                              > magicmirror@2.12.0 server /home/pi/MagicMirror
                              > node ./serveronly
                              internal/modules/cjs/loader.js:638
                                  throw err;
                              Error: Cannot find module 'proxy-addr'
                                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                  at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                  at Module.require (internal/modules/cjs/loader.js:692:17)
                                  at require (internal/modules/cjs/helpers.js:25:18)
                                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                              npm ERR! errno 1
                              npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.12.0 server script.
                              npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
                              cheers, bdream
                                sdetweil @bdream
                                @bdream I have opened issue
                                https://github.com/MichMich/MagicMirror/issues/2069
                                I cannot debug more myself at this time. in hospital, sorry
                                chrisparkerC 1 Reply Last reply Reply Quote 0
                                  bdream
                                  @sdetweil Sam! You are in hospital :face_with_head-bandage:
                                  So you have to focus on yourself!
                                  Wish you all the best and fast recovery!
                                  Hope you are back soon!
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
                                      bdream
                                      @sdetweil sounds hard to you. far away from your computer.
                                      near time you have to walk and walk all will go as before and better.
                                      All the best!
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream if u rename the mm folder to mm. save and the reinstall does it work?
                                          i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
                                          let me know how it goes
                                          • chrisparkerC
                                            chrisparker @sdetweil
                                            @sdetweil Get well soon!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
