    328 Posts 27 Posters 726.9k Views 24 Watching
      Pi4 - 4Gb = Worked flawlessly. January 12, 2020 @ 2020 hours. NYC - USA
      • T Offline
        Tigershroffr
        kindly also mention on which part and module you have update the script
          sdetweil @Tigershroffr
          @Tigershroffr sorry. Not quite sure what u are asking
          • BKeyportB Offline
            BKeyport Module Developer
            Update script not working for MMM-CalendarExt2 update. Is it me or you?
            Test run using:
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            seems to walk through modules correctly. Live run
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            does not.
            Upgrade started - Tue Jan 28 14:25:31 PST 2020
            system is Linux pihole 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
            doing test run = true
            saving custom.css
            remote name = origin
            upgrading from version 2.10.1 to 2.10.1
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is up to date with 'origin/master'.
              (use "git add <file>..." to update what will be committed)
              (use "git checkout -- <file>..." to discard changes in working directory)
            	modified:   package-lock.json
            Untracked files:
              (use "git add <file>..." to include in what will be committed)
            	css/save_custom.css
            no changes added to commit (use "git add" and/or "git commit -a")
            there are 1 local files that are different than the master repo
               package-lock.json
            save/restore files selection = n
            restoring package-lock.json from repo
            skipping restore for package-lock.json, doing test run
            test merge result rc='' , if empty, no conflicts
            skipping merge, only test run
            processing for module MMM-CalendarExt2 please wait
            skipped processing for MMM-CalendarExt2, doing test run
            processing complete for module MMM-CalendarExt2
            processing for module MMM-DarkSkyForecast please wait
            skipped processing for MMM-DarkSkyForecast, doing test run
            processing complete for module MMM-DarkSkyForecast
            processing for module MMM-DHT-Sensor please wait
            skipped processing for MMM-DHT-Sensor, doing test run
            processing complete for module MMM-DHT-Sensor
            processing for module MMM-RTSPStream please wait
            skipped processing for MMM-RTSPStream, doing test run
            processing complete for module MMM-RTSPStream
            processing for module MMM-Remote-Control please wait
            skipped processing for MMM-Remote-Control, doing test run
            processing complete for module MMM-Remote-Control
            restoring custom.css
            removing git alias
            Upgrade ended - Tue Jan 28 14:25:40 PST 2020
            Upgrade started - Tue Jan 28 14:25:46 PST 2020
            user requested to apply changes
            doing test run = false
            saving custom.css
            local version 2.10.1 already same as master 2.10.1
            removing git alias
            Upgrade ended - Tue Jan 28 14:25:47 PST 2020
            screen on live run is:
            the log will be /home/pi/MagicMirror/installers/upgrade.log
            No LSB modules are available.
            saving custom.css
              sdetweil @BKeyport
              @BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
              Thx for the report
                @sdetweil >local version 2.10.1 already same as master 2.10.1
                u are upgrading from/to the same version, so no work is done…
                if u want to force it to apply changes (again) then use force as the parm
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                • BKeyportB Offline
                  @sdetweil Correct, but isn’t it supposed to run for modules, too?
                    sdetweil @BKeyport
                    @BKeyport not if it’s doing nothing
                    • BKeyportB Offline
                      @sdetweil oh, gotcha.
                      Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
                      Thanks!
                        sdetweil @BKeyport
                        @BKeyport use force. It will do it.
                          bdream
                          Hi Sam! I run your update script an my Pi0
                          Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
                          pm2 restart MagicMirror
                          looks good
                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                          [PM2] [MagicMirror](0) ✓
                          │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                          │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
                          what is I’m doing wrong?
                          Many thanks!!!
                          cheers, bdream
                            sdetweil @bdream
                            @bdream something is wrong, 122 restarts 0 uptime.
                            do
                            pm2 stop 0
                            pm2 logs --lines=100
                              bdream
                              here is
                              pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
                              PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                              PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                              PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
                              PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
                              PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
                              PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
                              /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                              0|MagicMir |
                              0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
                              0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|MagicMir |
                              0|MagicMir |
                              /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                              0|MagicMir | npm ERR! errno ENOENT
                              0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                              0|MagicMir | npm ERR! spawn ENOENT
                              0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
                              0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                              0|MagicMir |
                              0|MagicMir | npm ERR! A complete log of this run can be found in:
                              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
                              0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
                              0|MagicMir | npm ERR! code ELIFECYCLE
                              0|MagicMir | npm ERR! syscall spawn
                              0|MagicMir | npm ERR! file sh
                              0|MagicMir |
                              0|MagicMir |
                              0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
                              cheers, bdream
                                sdetweil @bdream
                                @bdream hm. looks like my upgrade script failed to restore the start script change
                                edit package.json
                                change the start line to
                                "start": "./run-start.sh",
                                then
                                pm2 flush
                                pm2 start 0
                                I see the bug, but am on my phone right now and will have to fix it later
                                  bdream
                                  @sdetweil it dose not work
                                  if I change to
                                  "start": " ./run-start.sh",
                                  also as
                                  "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
                                  I get an web explorer showing an error
                                  ERR_CONNECTION_REFUSED
                                  localhos refused connection.
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream notice the 1st has a space in front of the ./, I edited that space out
                                      @bdream also. let’s try this
                                      stop everything
                                      then
                                      npm run server
                                      the server side should start.
                                        bdream
                                        @sdetweil said in new update/upgrade script, ready for testing:
                                        That is also not helpful
                                        stop everything
                                        How to stop everything?
                                        Is this enough?
                                        pm2 stop 0
                                        cheers, bdream
                                          bdream
                                          npm run server
                                          I get this:
                                          pi@RasPiZeroW:~ $ cd MagicMirror/
                                          pi@RasPiZeroW:~/MagicMirror $ npm run server
                                          > magicmirror@2.12.0 server /home/pi/MagicMirror
                                          > node ./serveronly
                                          internal/modules/cjs/loader.js:638
                                              throw err;
                                          Error: Cannot find module 'proxy-addr'
                                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                              at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                              at Module.require (internal/modules/cjs/loader.js:692:17)
                                              at require (internal/modules/cjs/helpers.js:25:18)
                                              at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                                          npm ERR! errno 1
                                          npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the magicmirror@2.12.0 server script.
                                          npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream I have opened issue
                                            https://github.com/MichMich/MagicMirror/issues/2069
                                            I cannot debug more myself at this time. in hospital, sorry
                                            chrisparkerC 1 Reply Last reply Reply Quote 0
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
