    328 Posts 27 Posters 726.8k Views 24 Watching
      sdetweil @spitzlbergerj
      @spitzlbergerj yes, change ‘apply’ to ‘force’
      spitzlbergerjS 1 Reply Last reply Reply Quote 0
        sdetweil @evroom
        @evroom I decided to forget about alias altogether…
        • evroomE Offline
          evroom @sdetweil
          @sdetweil said in new update/upgrade script, ready for testing:
          Of course, your script, your call.
          Just keep it somewhere in the back of your head, should you stumble over it again in any way or form.
          As I minimum I learned something new, including using alias in a script at all.
          Thanks for the scripts and the help you provide to all users with fresh install and / or upgrade issues, including myself.
          MagicMirror version: 2.37.0
            sdetweil @evroom
            @evroom thanks for your help… I had learned about the shell options to expand aliases about 10 yrs ago, and forgot… my systems all run with it on.
            • spitzlbergerjS Offline
              spitzlbergerj Project Sponsor Module Developer @sdetweil
              now it worked, my MagicMirror is on the current version :smiling_face_with_open_mouth_smiling_eyes: :thumbs_up: .
              Many, many thanks for your patient help. It was a somewhat more difficult birth. But the end is good and so everything
              I have a lot of respect for you, who created such a complex script and patiently provides support. Thank you very much!
              One last question:
              During the update there was another message:
              npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
              Is there anything else I should do?
              Regards
              Josef
              http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                @spitzlbergerj said in new update/upgrade script, ready for testing:
                yes, sadly we tested for a few months and this didn’t happen… weird…
                on the warnings… really nothing u can do as a user… the code author should update
                but hasn’t…
                  @sdetweil thank you very much again!
                  Regards
                  Josef
                  • H Offline
                    hoogveld
                    After wrecking my MM installation after the second last update I used this script. It worked fine for me!!!
                    Thanks for all your work!
                      Pi4 - 4Gb = Worked flawlessly. January 12, 2020 @ 2020 hours. NYC - USA
                      • T Offline
                        Tigershroffr
                        kindly also mention on which part and module you have update the script
                          sdetweil @Tigershroffr
                          @Tigershroffr sorry. Not quite sure what u are asking
                          • BKeyportB Offline
                            BKeyport Module Developer
                            Update script not working for MMM-CalendarExt2 update. Is it me or you?
                            Test run using:
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                            seems to walk through modules correctly. Live run
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                            does not.
                            Upgrade started - Tue Jan 28 14:25:31 PST 2020
                            system is Linux pihole 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                            doing test run = true
                            saving custom.css
                            remote name = origin
                            upgrading from version 2.10.1 to 2.10.1
                            fetching latest revisions
                            git fetch rc=0
                            current branch = master
                            On branch master
                            Your branch is up to date with 'origin/master'.
                              (use "git add <file>..." to update what will be committed)
                              (use "git checkout -- <file>..." to discard changes in working directory)
                            	modified:   package-lock.json
                            Untracked files:
                              (use "git add <file>..." to include in what will be committed)
                            	css/save_custom.css
                            no changes added to commit (use "git add" and/or "git commit -a")
                            there are 1 local files that are different than the master repo
                               package-lock.json
                            save/restore files selection = n
                            restoring package-lock.json from repo
                            skipping restore for package-lock.json, doing test run
                            test merge result rc='' , if empty, no conflicts
                            skipping merge, only test run
                            processing for module MMM-CalendarExt2 please wait
                            skipped processing for MMM-CalendarExt2, doing test run
                            processing complete for module MMM-CalendarExt2
                            processing for module MMM-DarkSkyForecast please wait
                            skipped processing for MMM-DarkSkyForecast, doing test run
                            processing complete for module MMM-DarkSkyForecast
                            processing for module MMM-DHT-Sensor please wait
                            skipped processing for MMM-DHT-Sensor, doing test run
                            processing complete for module MMM-DHT-Sensor
                            processing for module MMM-RTSPStream please wait
                            skipped processing for MMM-RTSPStream, doing test run
                            processing complete for module MMM-RTSPStream
                            processing for module MMM-Remote-Control please wait
                            skipped processing for MMM-Remote-Control, doing test run
                            processing complete for module MMM-Remote-Control
                            restoring custom.css
                            removing git alias
                            Upgrade ended - Tue Jan 28 14:25:40 PST 2020
                            Upgrade started - Tue Jan 28 14:25:46 PST 2020
                            user requested to apply changes
                            doing test run = false
                            saving custom.css
                            local version 2.10.1 already same as master 2.10.1
                            removing git alias
                            Upgrade ended - Tue Jan 28 14:25:47 PST 2020
                            screen on live run is:
                            the log will be /home/pi/MagicMirror/installers/upgrade.log
                            No LSB modules are available.
                            saving custom.css
                              sdetweil @BKeyport
                              @BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
                              Thx for the report
                                @sdetweil >local version 2.10.1 already same as master 2.10.1
                                u are upgrading from/to the same version, so no work is done…
                                if u want to force it to apply changes (again) then use force as the parm
                                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                • BKeyportB Offline
                                  @sdetweil Correct, but isn’t it supposed to run for modules, too?
                                    sdetweil @BKeyport
                                    @BKeyport not if it’s doing nothing
                                    • BKeyportB Offline
                                      @sdetweil oh, gotcha.
                                      Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
                                      Thanks!
                                        sdetweil @BKeyport
                                        @BKeyport use force. It will do it.
                                          bdream
                                          Hi Sam! I run your update script an my Pi0
                                          Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
                                          pm2 restart MagicMirror
                                          looks good
                                          [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                                          [PM2] [MagicMirror](0) ✓
                                          │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                          │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
                                          what is I’m doing wrong?
                                          Many thanks!!!
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream something is wrong, 122 restarts 0 uptime.
                                            do
                                            pm2 stop 0
                                            pm2 logs --lines=100
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
