    328 Posts 27 Posters 726.8k Views 24 Watching
      sdetweil @Tigershroffr
      @Tigershroffr sorry. Not quite sure what u are asking
      • BKeyportB Online
        BKeyport Module Developer
        Update script not working for MMM-CalendarExt2 update. Is it me or you?
        Test run using:
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        seems to walk through modules correctly. Live run
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        does not.
        Upgrade started - Tue Jan 28 14:25:31 PST 2020
        system is Linux pihole 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
        doing test run = true
        saving custom.css
        remote name = origin
        upgrading from version 2.10.1 to 2.10.1
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is up to date with 'origin/master'.
          (use "git add <file>..." to update what will be committed)
          (use "git checkout -- <file>..." to discard changes in working directory)
        	modified:   package-lock.json
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
        	css/save_custom.css
        no changes added to commit (use "git add" and/or "git commit -a")
        there are 1 local files that are different than the master repo
           package-lock.json
        save/restore files selection = n
        restoring package-lock.json from repo
        skipping restore for package-lock.json, doing test run
        test merge result rc='' , if empty, no conflicts
        skipping merge, only test run
        processing for module MMM-CalendarExt2 please wait
        skipped processing for MMM-CalendarExt2, doing test run
        processing complete for module MMM-CalendarExt2
        processing for module MMM-DarkSkyForecast please wait
        skipped processing for MMM-DarkSkyForecast, doing test run
        processing complete for module MMM-DarkSkyForecast
        processing for module MMM-DHT-Sensor please wait
        skipped processing for MMM-DHT-Sensor, doing test run
        processing complete for module MMM-DHT-Sensor
        processing for module MMM-RTSPStream please wait
        skipped processing for MMM-RTSPStream, doing test run
        processing complete for module MMM-RTSPStream
        processing for module MMM-Remote-Control please wait
        skipped processing for MMM-Remote-Control, doing test run
        processing complete for module MMM-Remote-Control
        restoring custom.css
        removing git alias
        Upgrade ended - Tue Jan 28 14:25:40 PST 2020
        Upgrade started - Tue Jan 28 14:25:46 PST 2020
        user requested to apply changes
        doing test run = false
        saving custom.css
        local version 2.10.1 already same as master 2.10.1
        removing git alias
        Upgrade ended - Tue Jan 28 14:25:47 PST 2020
        screen on live run is:
        the log will be /home/pi/MagicMirror/installers/upgrade.log
        No LSB modules are available.
        saving custom.css
          sdetweil @BKeyport
          @BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
          Thx for the report
            @sdetweil >local version 2.10.1 already same as master 2.10.1
            u are upgrading from/to the same version, so no work is done…
            if u want to force it to apply changes (again) then use force as the parm
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            • BKeyportB Online
              @sdetweil Correct, but isn’t it supposed to run for modules, too?
                sdetweil @BKeyport
                @BKeyport not if it’s doing nothing
                • BKeyportB Online
                  @sdetweil oh, gotcha.
                  Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
                  Thanks!
                    sdetweil @BKeyport
                    @BKeyport use force. It will do it.
                      bdream
                      Hi Sam! I run your update script an my Pi0
                      Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
                      pm2 restart MagicMirror
                      looks good
                      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                      [PM2] [MagicMirror](0) ✓
                      │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                      │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
                      what is I’m doing wrong?
                      Many thanks!!!
                      cheers, bdream
                        sdetweil @bdream
                        @bdream something is wrong, 122 restarts 0 uptime.
                        do
                        pm2 stop 0
                        pm2 logs --lines=100
                          bdream
                          here is
                          pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
                          PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                          PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
                          PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
                          PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
                          PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                          PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
                          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                          0|MagicMir |
                          0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
                          0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                          0|MagicMir |
                          0|MagicMir |
                          /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                          0|MagicMir | npm ERR! errno ENOENT
                          0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                          0|MagicMir | npm ERR! spawn ENOENT
                          0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
                          0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          0|MagicMir |
                          0|MagicMir | npm ERR! A complete log of this run can be found in:
                          0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
                          0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
                          0|MagicMir | npm ERR! code ELIFECYCLE
                          0|MagicMir | npm ERR! syscall spawn
                          0|MagicMir | npm ERR! file sh
                          0|MagicMir |
                          0|MagicMir |
                          0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
                          cheers, bdream
                            sdetweil @bdream
                            @bdream hm. looks like my upgrade script failed to restore the start script change
                            edit package.json
                            change the start line to
                            "start": "./run-start.sh",
                            then
                            pm2 flush
                            pm2 start 0
                            I see the bug, but am on my phone right now and will have to fix it later
                              bdream
                              @sdetweil it dose not work
                              if I change to
                              "start": " ./run-start.sh",
                              also as
                              "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
                              I get an web explorer showing an error
                              ERR_CONNECTION_REFUSED
                              localhos refused connection.
                              cheers, bdream
                                sdetweil @bdream
                                @bdream notice the 1st has a space in front of the ./, I edited that space out
                                  @bdream also. let’s try this
                                  stop everything
                                  then
                                  npm run server
                                  the server side should start.
                                    bdream
                                    @sdetweil said in new update/upgrade script, ready for testing:
                                    That is also not helpful
                                    stop everything
                                    How to stop everything?
                                    Is this enough?
                                    pm2 stop 0
                                    cheers, bdream
                                      bdream
                                      npm run server
                                      I get this:
                                      pi@RasPiZeroW:~ $ cd MagicMirror/
                                      pi@RasPiZeroW:~/MagicMirror $ npm run server
                                      > magicmirror@2.12.0 server /home/pi/MagicMirror
                                      > node ./serveronly
                                      internal/modules/cjs/loader.js:638
                                          throw err;
                                      Error: Cannot find module 'proxy-addr'
                                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                          at Module.require (internal/modules/cjs/loader.js:692:17)
                                          at require (internal/modules/cjs/helpers.js:25:18)
                                          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                                      npm ERR! errno 1
                                      npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.12.0 server script.
                                      npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream I have opened issue
                                        https://github.com/MichMich/MagicMirror/issues/2069
                                        I cannot debug more myself at this time. in hospital, sorry
                                        chrisparkerC 1 Reply Last reply Reply Quote 0
                                          bdream
                                          @sdetweil Sam! You are in hospital :face_with_head-bandage:
                                          So you have to focus on yourself!
                                          Wish you all the best and fast recovery!
                                          Hope you are back soon!
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream knee replacement. lots of sitting around and exercising! just not near my computer system
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
