    328 Posts 27 Posters 726.7k Views 24 Watching
    • H Offline
      hoogveld
      After wrecking my MM installation after the second last update I used this script. It worked fine for me!!!
      Thanks for all your work!
        Pi4 - 4Gb = Worked flawlessly. January 12, 2020 @ 2020 hours. NYC - USA
        • T Offline
          Tigershroffr
          kindly also mention on which part and module you have update the script
            sdetweil @Tigershroffr
            @Tigershroffr sorry. Not quite sure what u are asking
            • BKeyportB Offline
              BKeyport Module Developer
              Update script not working for MMM-CalendarExt2 update. Is it me or you?
              Test run using:
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              seems to walk through modules correctly. Live run
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              does not.
              Upgrade started - Tue Jan 28 14:25:31 PST 2020
              system is Linux pihole 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              doing test run = true
              saving custom.css
              remote name = origin
              upgrading from version 2.10.1 to 2.10.1
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up to date with 'origin/master'.
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
              	modified:   package-lock.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	css/save_custom.css
              no changes added to commit (use "git add" and/or "git commit -a")
              there are 1 local files that are different than the master repo
                 package-lock.json
              save/restore files selection = n
              restoring package-lock.json from repo
              skipping restore for package-lock.json, doing test run
              test merge result rc='' , if empty, no conflicts
              skipping merge, only test run
              processing for module MMM-CalendarExt2 please wait
              skipped processing for MMM-CalendarExt2, doing test run
              processing complete for module MMM-CalendarExt2
              processing for module MMM-DarkSkyForecast please wait
              skipped processing for MMM-DarkSkyForecast, doing test run
              processing complete for module MMM-DarkSkyForecast
              processing for module MMM-DHT-Sensor please wait
              skipped processing for MMM-DHT-Sensor, doing test run
              processing complete for module MMM-DHT-Sensor
              processing for module MMM-RTSPStream please wait
              skipped processing for MMM-RTSPStream, doing test run
              processing complete for module MMM-RTSPStream
              processing for module MMM-Remote-Control please wait
              skipped processing for MMM-Remote-Control, doing test run
              processing complete for module MMM-Remote-Control
              restoring custom.css
              removing git alias
              Upgrade ended - Tue Jan 28 14:25:40 PST 2020
              Upgrade started - Tue Jan 28 14:25:46 PST 2020
              user requested to apply changes
              doing test run = false
              saving custom.css
              local version 2.10.1 already same as master 2.10.1
              removing git alias
              Upgrade ended - Tue Jan 28 14:25:47 PST 2020
              screen on live run is:
              the log will be /home/pi/MagicMirror/installers/upgrade.log
              No LSB modules are available.
              saving custom.css
                sdetweil @BKeyport
                @BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
                Thx for the report
                  @sdetweil >local version 2.10.1 already same as master 2.10.1
                  u are upgrading from/to the same version, so no work is done…
                  if u want to force it to apply changes (again) then use force as the parm
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  • BKeyportB Offline
                    @sdetweil Correct, but isn’t it supposed to run for modules, too?
                      sdetweil @BKeyport
                      @BKeyport not if it’s doing nothing
                      • BKeyportB Offline
                        @sdetweil oh, gotcha.
                        Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
                        Thanks!
                          sdetweil @BKeyport
                          @BKeyport use force. It will do it.
                            bdream
                            Hi Sam! I run your update script an my Pi0
                            Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
                            pm2 restart MagicMirror
                            looks good
                            [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                            [PM2] [MagicMirror](0) ✓
                            │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                            │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
                            what is I’m doing wrong?
                            Many thanks!!!
                            cheers, bdream
                              sdetweil @bdream
                              @bdream something is wrong, 122 restarts 0 uptime.
                              do
                              pm2 stop 0
                              pm2 logs --lines=100
                                bdream
                                here is
                                pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
                                PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                                PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
                                PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
                                PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
                                PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
                                /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                0|MagicMir |
                                0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
                                0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                0|MagicMir |
                                0|MagicMir |
                                /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                0|MagicMir | npm ERR! errno ENOENT
                                0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                0|MagicMir | npm ERR! spawn ENOENT
                                0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
                                0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                0|MagicMir |
                                0|MagicMir | npm ERR! A complete log of this run can be found in:
                                0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
                                0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
                                0|MagicMir | npm ERR! code ELIFECYCLE
                                0|MagicMir | npm ERR! syscall spawn
                                0|MagicMir | npm ERR! file sh
                                0|MagicMir |
                                0|MagicMir |
                                0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream hm. looks like my upgrade script failed to restore the start script change
                                  edit package.json
                                  change the start line to
                                  "start": "./run-start.sh",
                                  then
                                  pm2 flush
                                  pm2 start 0
                                  I see the bug, but am on my phone right now and will have to fix it later
                                    bdream
                                    @sdetweil it dose not work
                                    if I change to
                                    "start": " ./run-start.sh",
                                    also as
                                    "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
                                    I get an web explorer showing an error
                                    ERR_CONNECTION_REFUSED
                                    localhos refused connection.
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream notice the 1st has a space in front of the ./, I edited that space out
                                        @bdream also. let’s try this
                                        stop everything
                                        then
                                        npm run server
                                        the server side should start.
                                          bdream
                                          @sdetweil said in new update/upgrade script, ready for testing:
                                          That is also not helpful
                                          stop everything
                                          How to stop everything?
                                          Is this enough?
                                          pm2 stop 0
                                          cheers, bdream
                                            bdream
                                            npm run server
                                            I get this:
                                            pi@RasPiZeroW:~ $ cd MagicMirror/
                                            pi@RasPiZeroW:~/MagicMirror $ npm run server
                                            > magicmirror@2.12.0 server /home/pi/MagicMirror
                                            > node ./serveronly
                                            internal/modules/cjs/loader.js:638
                                                throw err;
                                            Error: Cannot find module 'proxy-addr'
                                                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                                at Module.require (internal/modules/cjs/loader.js:692:17)
                                                at require (internal/modules/cjs/helpers.js:25:18)
                                                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/utils.js:22:17)
                                            npm ERR! errno 1
                                            npm ERR! magicmirror@2.12.0 server: `node ./serveronly`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.12.0 server script.
                                            npm ERR!     /home/pi/.npm/_logs/2020-07-03T13_58_48_248Z-debug.log
                                            cheers, bdream
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
