    328 Posts 27 Posters 726.8k Views 24 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer @sdetweil
      @sdetweil thank you very much again!
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
      • H Offline
        hoogveld
        After wrecking my MM installation after the second last update I used this script. It worked fine for me!!!
        Thanks for all your work!
          Pi4 - 4Gb = Worked flawlessly. January 12, 2020 @ 2020 hours. NYC - USA
          • T Offline
            Tigershroffr
            kindly also mention on which part and module you have update the script
              sdetweil @Tigershroffr
              @Tigershroffr sorry. Not quite sure what u are asking
              • BKeyportB Online
                BKeyport Module Developer
                Update script not working for MMM-CalendarExt2 update. Is it me or you?
                Test run using:
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                seems to walk through modules correctly. Live run
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                does not.
                Upgrade started - Tue Jan 28 14:25:31 PST 2020
                system is Linux pihole 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                doing test run = true
                saving custom.css
                remote name = origin
                upgrading from version 2.10.1 to 2.10.1
                fetching latest revisions
                git fetch rc=0
                current branch = master
                On branch master
                Your branch is up to date with 'origin/master'.
                  (use "git add <file>..." to update what will be committed)
                  (use "git checkout -- <file>..." to discard changes in working directory)
                	modified:   package-lock.json
                Untracked files:
                  (use "git add <file>..." to include in what will be committed)
                	css/save_custom.css
                no changes added to commit (use "git add" and/or "git commit -a")
                there are 1 local files that are different than the master repo
                   package-lock.json
                save/restore files selection = n
                restoring package-lock.json from repo
                skipping restore for package-lock.json, doing test run
                test merge result rc='' , if empty, no conflicts
                skipping merge, only test run
                processing for module MMM-CalendarExt2 please wait
                skipped processing for MMM-CalendarExt2, doing test run
                processing complete for module MMM-CalendarExt2
                processing for module MMM-DarkSkyForecast please wait
                skipped processing for MMM-DarkSkyForecast, doing test run
                processing complete for module MMM-DarkSkyForecast
                processing for module MMM-DHT-Sensor please wait
                skipped processing for MMM-DHT-Sensor, doing test run
                processing complete for module MMM-DHT-Sensor
                processing for module MMM-RTSPStream please wait
                skipped processing for MMM-RTSPStream, doing test run
                processing complete for module MMM-RTSPStream
                processing for module MMM-Remote-Control please wait
                skipped processing for MMM-Remote-Control, doing test run
                processing complete for module MMM-Remote-Control
                restoring custom.css
                removing git alias
                Upgrade ended - Tue Jan 28 14:25:40 PST 2020
                Upgrade started - Tue Jan 28 14:25:46 PST 2020
                user requested to apply changes
                doing test run = false
                saving custom.css
                local version 2.10.1 already same as master 2.10.1
                removing git alias
                Upgrade ended - Tue Jan 28 14:25:47 PST 2020
                screen on live run is:
                the log will be /home/pi/MagicMirror/installers/upgrade.log
                No LSB modules are available.
                saving custom.css
                  sdetweil @BKeyport
                  @BKeyport gotta be me… I will look at in about 45 minutes, when I get home.
                  Thx for the report
                    @sdetweil >local version 2.10.1 already same as master 2.10.1
                    u are upgrading from/to the same version, so no work is done…
                    if u want to force it to apply changes (again) then use force as the parm
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                    • BKeyportB Online
                      @sdetweil Correct, but isn’t it supposed to run for modules, too?
                        sdetweil @BKeyport
                        @BKeyport not if it’s doing nothing
                        • BKeyportB Online
                          @sdetweil oh, gotcha.
                          Then I’ll manually update the module for now - would you be able to add that in at a later time? I’d love to be able to have a quick script to run through my modules and update 'em as they call for updates.
                          Thanks!
                            sdetweil @BKeyport
                            @BKeyport use force. It will do it.
                              bdream
                              Hi Sam! I run your update script an my Pi0
                              Seems it works fine :ok_hand: but my screen show up only the standard Raspian Desktop :crying_face:
                              pm2 restart MagicMirror
                              looks good
                              [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                              [PM2] [MagicMirror](0) ✓
                              │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                              │ 0   │ MagicMirror    │ default     │ 2.12.0  │ fork    │ 19770    │ 0s     │ 122… │ online    │ 0%       │ 2.5mb    │ pi       │ enabled  │
                              what is I’m doing wrong?
                              Many thanks!!!
                              cheers, bdream
                                sdetweil @bdream
                                @bdream something is wrong, 122 restarts 0 uptime.
                                do
                                pm2 stop 0
                                pm2 logs --lines=100
                                  bdream
                                  here is
                                  pi@RasPiZeroW:~/MagicMirror $ pm2 logs --lines=100
                                  PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                                  PM2        | 2020-07-03T13:25:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                  PM2        | 2020-07-03T13:25:01: PM2 log: App [MagicMirror:0] online
                                  PM2        | 2020-07-03T13:28:36: PM2 log: [Watch] Stop watching MagicMirror
                                  PM2        | 2020-07-03T13:28:36: PM2 log: Stopping app:MagicMirror id:0
                                  PM2        | 2020-07-03T13:28:37: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                                  PM2        | 2020-07-03T13:28:37: PM2 log: pid=29676 msg=process killed
                                  /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                                  0|MagicMir |
                                  0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
                                  0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                  0|MagicMir |
                                  0|MagicMir |
                                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                                  0|MagicMir | npm ERR! errno ENOENT
                                  0|MagicMir | npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                                  0|MagicMir | npm ERR! spawn ENOENT
                                  0|MagicMir | npm ERR! Failed at the magicmirror@2.12.0 start script.
                                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                  0|MagicMir |
                                  0|MagicMir | npm ERR! A complete log of this run can be found in:
                                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_27_39_492Z-debug.log
                                  0|MagicMir | sh: 1: ./node_modules/.bin/electron: not found
                                  0|MagicMir | npm ERR! code ELIFECYCLE
                                  0|MagicMir | npm ERR! syscall spawn
                                  0|MagicMir | npm ERR! file sh
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-07-03T11_28_26_351Z-debug.log
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream hm. looks like my upgrade script failed to restore the start script change
                                    edit package.json
                                    change the start line to
                                    "start": "./run-start.sh",
                                    then
                                    pm2 flush
                                    pm2 start 0
                                    I see the bug, but am on my phone right now and will have to fix it later
                                      bdream
                                      @sdetweil it dose not work
                                      if I change to
                                      "start": " ./run-start.sh",
                                      also as
                                      "start": "DISPLAY=\"${DISPLAY:=:0}\" ./run-start.sh",
                                      I get an web explorer showing an error
                                      ERR_CONNECTION_REFUSED
                                      localhos refused connection.
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream notice the 1st has a space in front of the ./, I edited that space out
                                          @bdream also. let’s try this
                                          stop everything
                                          then
                                          npm run server
                                          the server side should start.
                                            bdream
                                            @sdetweil said in new update/upgrade script, ready for testing:
                                            That is also not helpful
                                            stop everything
                                            How to stop everything?
                                            Is this enough?
                                            pm2 stop 0
                                            cheers, bdream
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
