    multiple modules in a region
    42 Posts 5 Posters 19.9k Views 6 Watching
    • BKeyportB Offline
      @sdetweil that being said, with a bit of CSS changes, you can get the calendar to grow quite a bit.
      I set mine to top_center, and use the following CSS to make it take up most of my center region and adjust it’s colors, cell sizes, etc…
      /* CalendarExt3 */
      .CX3 {
        --celllinecolor: #666;
        --cellbgcolor: rgba(0, 0, 0, 0.5);
        --cellheaderheight: 25px;
        --cellfooterheight: 2px;
        --defaultcolor: #FFF;
        --eventheight: calc(var(--fontsize) + 4px);
        --totalheight: calc(var(--eventheight) * var(--maxeventlines));
        --displayEndTime: none;
        --displayWeatherTemp: none;
        font-size: var(--fontsize);
        color: var(--defaultcolor);
        line-height: calc(var(--eventheight));
        min-width: 950px;
      With a little bit of work, and not putting anything in the right regions, you get the 2/3rds 1/3rd effect of Dakboard.
        MMRIZE @roth_nj
        @roth_nj
        If you have a sketch (even with a hand), I may help you.
          MMRIZE @roth_nj
          @roth_nj
          Is this similar to what you wanted? (DAKBoard style)
          .region.top.left {
            width: calc(25% - 60px);
            backdrop-filter: blur(10px) brightness(60%) grayscale(30%) drop-shadow(4px 4px 10px black);
            padding: 20px;
            border-radius: 20px;
            height: calc(100vh - 160px);
          .region.top.right {
            width: calc(75% - 20px);
          .region.center {
            display: none;
          .module.MMM-CalendarExt3 .module-header {
            font-weight: bold;
            font-size: 300%;
            color: white;
            line-height: 100%;
            border-bottom: none;
          I use only 3 regions. top_left top_right, and fullscreen_below.
            roth_nj @MMRIZE
            @MMRIZE
            this is the dakboard calendar that my wife wants. ive shown here several others (examples of both from dakboard and MM) and she likes this layout the best. i do agree its pretty clean looking. as stated before, it is essentially photos on the left 1/3rd and a calendar on the right 2/3rds in landscape view with some light modules on top of the pictures. im sure youve seen the pic floating around a lot.
            ive searched and read a lot on this and thats why i was stepping down the route of trying to get the modules into certain regions then going to try to mode with the css.
              roth_nj @MMRIZE
              @MMRIZE @sdetweil
              heres an idea: can a script be written that runs 2 instances of MM into 1 display at the same time? one being 1/3 of the screen and the other being the rest (or other 2/3rds)? then one instance of MM can run pictures fullscreen and the other can run the calendar full screen as well on its partition?
              also, sorry if theres a few different dicussions going on at the same time now. with having to wait for posts to get approved theres a bit of a lag and its probably getting messy keeping thought streams straight now
              M S 2 Replies Last reply Reply Quote 0
                MMRIZE @roth_nj
                @roth_nj
                There is no way to do so.
                However, I think mimicking DAKBoard style to MM with some CSS juggling.
                  sdetweil @roth_nj
                  @roth_nj said in multiple modules in a region:
                  I am the one that reviews and approves posts… until you get a reputation of 2 or above…
                  rep is increases if someone likes your post(s). generally because you contributed something.
                    roth_nj @MMRIZE
                    @MMRIZE
                    that looks good and gives me an idea of something to try…
                    are there any other modules that post pictures to a region instead of full screen?
                      sdetweil @roth_nj
                      you can try them…
                      i spent a lot of time on MMM-ImagesPhotos in fullscreen to get the aspect ratios correct as neither of the built in CSS settings (cover/contain) work properly (imho)
                      https://github.com/sdetweil/MMM-ImagesPhotos , but you can try it in other positions
                        MMRIZE @roth_nj
                        @roth_nj
                        similar?
                        mimic
                        • 1 / 5
