    multiple modules in a region
    42 Posts 5 Posters 26.2k Views 6 Watching
      roth_nj @MMRIZE
      @MMRIZE @sdetweil
      heres an idea: can a script be written that runs 2 instances of MM into 1 display at the same time? one being 1/3 of the screen and the other being the rest (or other 2/3rds)? then one instance of MM can run pictures fullscreen and the other can run the calendar full screen as well on its partition?
      also, sorry if theres a few different dicussions going on at the same time now. with having to wait for posts to get approved theres a bit of a lag and its probably getting messy keeping thought streams straight now
      M S 2 Replies Last reply
        MMRIZE @roth_nj
        @roth_nj
        There is no way to do so.
        However, I think mimicking DAKBoard style to MM with some CSS juggling.
          sdetweil @roth_nj
          @roth_nj said in multiple modules in a region:
          I am the one that reviews and approves posts… until you get a reputation of 2 or above…
          rep is increases if someone likes your post(s). generally because you contributed something.
            roth_nj @MMRIZE
            @MMRIZE
            that looks good and gives me an idea of something to try…
            are there any other modules that post pictures to a region instead of full screen?
              sdetweil @roth_nj
              you can try them…
              i spent a lot of time on MMM-ImagesPhotos in fullscreen to get the aspect ratios correct as neither of the built in CSS settings (cover/contain) work properly (imho)
              https://github.com/sdetweil/MMM-ImagesPhotos , but you can try it in other positions
                MMRIZE @roth_nj
                @roth_nj
                similar?
                mimic
                R 1 Reply Last reply
                  roth_nj @MMRIZE
                  @MMRIZE said in multiple modules in a region:
                  @roth_nj
                  similar?
                  mimic
                  that right there would be amazing
                  M 1 Reply Last reply
                    MMRIZE @roth_nj
                    @roth_nj
                    This would be just what you looked at in the previous screenshot.
                    Only for those modules on the screen, the CSS is severely overridden. So when you add additional modules, you should carefully handle them.
                    It is designed for resolution 1920 * 1080 horizon screen.
                    config
                    		module: "alert",
                    		module: "clock",
                    			displaySeconds: false,
                    			sendNotifications: false,
                    		//position: "top_left",
                    			broadcastEvents: true,
                    			broadcastPastEvents: true,
                    			maximumEntries: 99,
                    					symbol: "calendar-check",
                    					url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics",
                    					color: "red",
                    					url: "https://calendar.google.com/calendar/ical/ko.german.official%23holiday%40group.v.calendar.google.com/public/basic.ics",
                    					color: "red",
                    					symbol: "futbol",
                    					url: "webcal://ics.ecal.com/ecal-sub/65254bc972b4f3000d0051df/Tottenham%20Hotspur%20FC.ics",
                    					color: "#0066CC",
                    		module: "weather",
                    			type: "current",
                    			apiKey: "..."
                    		module: "MMM-CalendarExt3",
                    		position: "bottom_bar",
                    			locale: "en-US",
                    			mode: "month",
                    			maxEventLines: 3,
                    			headerWeekDayOptions: { weekday: 'narrow' },
                    			//firstDayOfWeek: 0,
                    			//minimalDaysOfNewYear: 1,
                    			useWeather: false,
                    		module: "MMM-WeatherBackground",
                    I used MMM-WeatherBackground for leftside background image, but you may use other modules.
                    See where the position I put the modules into and how they might be overridden in the CSS.
                    CSS (custom.css)
                    :root {
                      --color-text: #999;
                      --color-text-dimmed: #666;
                      --color-text-bright: #fff;
                      --color-background: black;
                      --font-primary: "Roboto Condensed";
                      --font-secondary: "Roboto";
                      --font-size: 20px;
                      --font-size-small: 0.75rem;
                      --gap-body-top: 20px;
                      --gap-body-right: 20px;
                      --gap-body-bottom: 20px;
                      --gap-body-left: 20px;
                      --gap-modules: 20px;
                    .fullscreen.below {
                      width: 33.3%;
                    .region.top.bar {
                      width: calc(33.3% - 60px);
                      padding: 20px;
                      height: calc(100vh - 40px);
                      position: absolute;
                      top: -20px;
                      left: 0;
                      text-align: right;
                      display: flex;
                      flex-direction: column;
                      justify-content: space-between;
                      background-image: linear-gradient(to right, rgb(0 0 0 / 0%), rgb(0 0 0 / 100%));
                    .region.top.left,
                    .region.top.right {
                      box-sizing: border-box;
                      text-align: right;
                      top: 0;
                      position: unset;
                    .region.bottom {
                      width: calc(66.7% - 20px);
                      padding: 20px;
                      height: calc(100vh - 80px);
                      position: absolute;
                      right: 0;
                      top: 0;
                    .region.bottom.left,
                    .region.bottom.right,
                    .region.center {
                      display: none;
                    .module.MMM-CalendarExt3 .module-header {
                      height: 0;
                      visibility: hidden;
                      line-height: 0;
                    .CX3 {
                      --cellheaderheight: 80px;
                    .CX3 .cell {
                      border: none;
                    .CX3 .cw {
                      display: none;
                    .CX3 .thisMonth {
                      background-color: unset;
                    .CX3 .cell:not(.thisMonth) .cellHeader .cellDate * {
                      filter: brightness(0.5);
                    .CX3 .weekGrid .weekday {
                      font-size: 250%;
                      line-height: 250%;
                    .CX3 .cellHeader .cellDate {
                      font-size: 250%;
                      text-align: center;
                      display: flex;
                      justify-content: center;
                      align-items: center;
                    .CX3 .cell.today {
                      border: none;
                    .CX3 .cell.today .cellHeader {
                    .CX3 .cell.today .cellHeader .cellDate {
                      border-radius: 50%;
                      max-width: 60px;
                      max-height: 60px;
                    .CX3 .cell.today .cellHeader .cellDate .month {
                      display: none;
                    .CX3 .week:nth-child(2) .cell:first-child .cellDate :not(.month) {
                      display: none;
                    .CX3 .date_1 .cellDate .dateParts:not(.month) {
                      display: none;
                    .module.clock .digital {
                      display: flex;
                      flex-direction: column-reverse;
                    R S 2 Replies Last reply
                      roth_nj @MMRIZE
                      @MMRIZE
                      that is awesome. looks like its actually in portrait but you rotated all the text to be read the other way? thats one way to skin that cat. i like it.
                      so, i know im not the first one to ask for a configuration like this. i know because i spent quite i bit of time searching and reading through all i could (here, github, reddit, etc)… it might be worth while putting together a polished post saying for a dakboard clone?
                      for reference. i went though and set up the dakboard but me being me, refused to pay for the upgrade. i needed it to handle 6 ical’s and wanted to be able to change the colors. simple things really, but they lock both those abilities behind the upgrade.
                      again, thank you very much. ill play around with it again tonight after work. im sure ill end up having some questions sooner or later
                        sdetweil @MMRIZE
                        @roth_nj
                        just be careful , as he whacked the css pretty hard here to make this work, and other modules may no longer fit properly…
                        MM is after all, just a web page…
                        R BKeyportB 2 Replies Last reply
                          roth_nj @sdetweil
                          @sdetweil said in multiple modules in a region:
                          @roth_nj
                          understood. as of now i only have the mmm_wallpaper and mmm_calenderext3 added in. i have half of the default modules turned off and only the clock+2 weathers still on atm. even if i do add something, it will be something like the default modules. something light and simple over the top of the photos
                          • BKeyportB
                            @sdetweil that’s half the fun of MM - whacking the CSS until you get what you want. :)
                              roth_nj @roth_nj
                              @MMRIZE
                              I was able to pop that code in easy enough and its all working well. this is all still running on my Mac to my monitor via electron so ill wait until I get it into my actual pi and wall display before going crazy with the finishing touches. (spacing, colors, boarders, edges, etc). hoping ill be able to get that part up and running this weekend.
                              one thing I was playing around with now trying to tweak but not having any luck is the fade of the calendar pictures to the right side of them. I tried the fadeedges config option for the calendar in the main config file but it was breaking it. would it be a module/config thing? or a css thing?
                              here’s what it looks like at the moment
                                MMRIZE @roth_nj
                                @roth_nj
                                That is not faded. It only assigns a pale blue colour to Saturday on cellHeader in CSS.
                                You can find .weekday_6 things in MMM-CalendarExt3.css then override it in your custom.css.
                                .CX3 .weekday_6 {
                                  color: #339;
                                And long-full-day name looks somewhat ugly, So you’d better consider headerWeekDayOptions: "short", or “narrow”.
                                R 2 Replies Last reply
                                  roth_nj @MMRIZE
                                  @MMRIZE
                                  a little misunderstanding here. i am talking about this zone at the wallpaper background to the calendar.
                                  i already changed the sunday red and saturday blue to both be white at this point
                                    roth_nj @MMRIZE
                                    @MMRIZE
                                      MMRIZE @roth_nj
                                      @roth_nj
                                      See “.region.top.bar”. I put a gradient layer there.
                                        roth_nj @MMRIZE
                                        @MMRIZE
                                        bingo… awesome thanks again. I was looking for anything with fade. gradient makes sense — I’m not a programmer in any sense. after changing that, I spread the wallpaper out to 40% but left the calendar overlapping a little bit still at 66%
                                        its getting real close now. but like I said I’m not going to mess with too much more until I get it up on my pi+monitor
                                        thanks again for the help
                                        BKeyportB 1 Reply Last reply
                                        • BKeyportB
                                          BKeyport Module Developer @roth_nj
                                          @roth_nj Been playing around, and here’s what I came up with.
                                          alt text
                                            roth_nj
                                            @MMRIZE it got my pi programmed and the mirror up and running on the screen. i have started doing some minor graphical tweaks like font/color/size etc and changed the 33% wallpaper size to 40%… all that stuff is pretty clear to me on what/where to edit and theres a ton of into on the forum/github
                                            i have a couple follow up questions for you now: i want to adjust the position of the calendar top and clock. you can see in this picture that they are off set from the “top” of the screen. i want to get them to the edge. thanks again
