    multiple modules in a region
    42 Posts 5 Posters 26.2k Views 6 Watching
      MMRIZE @roth_nj
      @roth_nj
      This would be just what you looked at in the previous screenshot.
      Only for those modules on the screen, the CSS is severely overridden. So when you add additional modules, you should carefully handle them.
      It is designed for resolution 1920 * 1080 horizon screen.
      config
      		module: "alert",
      		module: "clock",
      			displaySeconds: false,
      			sendNotifications: false,
      		//position: "top_left",
      			broadcastEvents: true,
      			broadcastPastEvents: true,
      			maximumEntries: 99,
      					symbol: "calendar-check",
      					url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics",
      					color: "red",
      					url: "https://calendar.google.com/calendar/ical/ko.german.official%23holiday%40group.v.calendar.google.com/public/basic.ics",
      					color: "red",
      					symbol: "futbol",
      					url: "webcal://ics.ecal.com/ecal-sub/65254bc972b4f3000d0051df/Tottenham%20Hotspur%20FC.ics",
      					color: "#0066CC",
      		module: "weather",
      			type: "current",
      			apiKey: "..."
      		module: "MMM-CalendarExt3",
      		position: "bottom_bar",
      			locale: "en-US",
      			mode: "month",
      			maxEventLines: 3,
      			headerWeekDayOptions: { weekday: 'narrow' },
      			//firstDayOfWeek: 0,
      			//minimalDaysOfNewYear: 1,
      			useWeather: false,
      		module: "MMM-WeatherBackground",
      I used MMM-WeatherBackground for leftside background image, but you may use other modules.
      See where the position I put the modules into and how they might be overridden in the CSS.
      CSS (custom.css)
      :root {
        --color-text: #999;
        --color-text-dimmed: #666;
        --color-text-bright: #fff;
        --color-background: black;
        --font-primary: "Roboto Condensed";
        --font-secondary: "Roboto";
        --font-size: 20px;
        --font-size-small: 0.75rem;
        --gap-body-top: 20px;
        --gap-body-right: 20px;
        --gap-body-bottom: 20px;
        --gap-body-left: 20px;
        --gap-modules: 20px;
      .fullscreen.below {
        width: 33.3%;
      .region.top.bar {
        width: calc(33.3% - 60px);
        padding: 20px;
        height: calc(100vh - 40px);
        position: absolute;
        top: -20px;
        left: 0;
        text-align: right;
        display: flex;
        flex-direction: column;
        justify-content: space-between;
        background-image: linear-gradient(to right, rgb(0 0 0 / 0%), rgb(0 0 0 / 100%));
      .region.top.left,
      .region.top.right {
        box-sizing: border-box;
        text-align: right;
        top: 0;
        position: unset;
      .region.bottom {
        width: calc(66.7% - 20px);
        padding: 20px;
        height: calc(100vh - 80px);
        position: absolute;
        right: 0;
        top: 0;
      .region.bottom.left,
      .region.bottom.right,
      .region.center {
        display: none;
      .module.MMM-CalendarExt3 .module-header {
        height: 0;
        visibility: hidden;
        line-height: 0;
      .CX3 {
        --cellheaderheight: 80px;
      .CX3 .cell {
        border: none;
      .CX3 .cw {
        display: none;
      .CX3 .thisMonth {
        background-color: unset;
      .CX3 .cell:not(.thisMonth) .cellHeader .cellDate * {
        filter: brightness(0.5);
      .CX3 .weekGrid .weekday {
        font-size: 250%;
        line-height: 250%;
      .CX3 .cellHeader .cellDate {
        font-size: 250%;
        text-align: center;
        display: flex;
        justify-content: center;
        align-items: center;
      .CX3 .cell.today {
        border: none;
      .CX3 .cell.today .cellHeader {
      .CX3 .cell.today .cellHeader .cellDate {
        border-radius: 50%;
        max-width: 60px;
        max-height: 60px;
      .CX3 .cell.today .cellHeader .cellDate .month {
        display: none;
      .CX3 .week:nth-child(2) .cell:first-child .cellDate :not(.month) {
        display: none;
      .CX3 .date_1 .cellDate .dateParts:not(.month) {
        display: none;
      .module.clock .digital {
        display: flex;
        flex-direction: column-reverse;
      R S 2 Replies Last reply
        roth_nj @MMRIZE
        @MMRIZE
        that is awesome. looks like its actually in portrait but you rotated all the text to be read the other way? thats one way to skin that cat. i like it.
        so, i know im not the first one to ask for a configuration like this. i know because i spent quite i bit of time searching and reading through all i could (here, github, reddit, etc)… it might be worth while putting together a polished post saying for a dakboard clone?
        for reference. i went though and set up the dakboard but me being me, refused to pay for the upgrade. i needed it to handle 6 ical’s and wanted to be able to change the colors. simple things really, but they lock both those abilities behind the upgrade.
        again, thank you very much. ill play around with it again tonight after work. im sure ill end up having some questions sooner or later
        R 1 Reply Last reply
          sdetweil @MMRIZE
          @roth_nj
          @MMRIZE said in multiple modules in a region:
          just be careful , as he whacked the css pretty hard here to make this work, and other modules may no longer fit properly…
          MM is after all, just a web page…
          R BKeyportB 2 Replies Last reply
            roth_nj @sdetweil
            @sdetweil said in multiple modules in a region:
            @roth_nj
            understood. as of now i only have the mmm_wallpaper and mmm_calenderext3 added in. i have half of the default modules turned off and only the clock+2 weathers still on atm. even if i do add something, it will be something like the default modules. something light and simple over the top of the photos
            • BKeyportB
              @sdetweil that’s half the fun of MM - whacking the CSS until you get what you want. :)
                roth_nj @roth_nj
                @MMRIZE
                I was able to pop that code in easy enough and its all working well. this is all still running on my Mac to my monitor via electron so ill wait until I get it into my actual pi and wall display before going crazy with the finishing touches. (spacing, colors, boarders, edges, etc). hoping ill be able to get that part up and running this weekend.
                one thing I was playing around with now trying to tweak but not having any luck is the fade of the calendar pictures to the right side of them. I tried the fadeedges config option for the calendar in the main config file but it was breaking it. would it be a module/config thing? or a css thing?
                here’s what it looks like at the moment
                M 1 Reply Last reply
                  MMRIZE @roth_nj
                  @roth_nj
                  That is not faded. It only assigns a pale blue colour to Saturday on cellHeader in CSS.
                  You can find .weekday_6 things in MMM-CalendarExt3.css then override it in your custom.css.
                  .CX3 .weekday_6 {
                    color: #339;
                  And long-full-day name looks somewhat ugly, So you’d better consider headerWeekDayOptions: "short", or “narrow”.
                  R 2 Replies Last reply
                    roth_nj @MMRIZE
                    @MMRIZE
                    a little misunderstanding here. i am talking about this zone at the wallpaper background to the calendar.
                    i already changed the sunday red and saturday blue to both be white at this point
                      roth_nj @MMRIZE
                      @MMRIZE
                        MMRIZE @roth_nj
                        @roth_nj
                        See “.region.top.bar”. I put a gradient layer there.
                          roth_nj @MMRIZE
                          @MMRIZE
                          bingo… awesome thanks again. I was looking for anything with fade. gradient makes sense — I’m not a programmer in any sense. after changing that, I spread the wallpaper out to 40% but left the calendar overlapping a little bit still at 66%
                          its getting real close now. but like I said I’m not going to mess with too much more until I get it up on my pi+monitor
                          thanks again for the help
                          BKeyportB 1 Reply Last reply
                          • BKeyportB
                            BKeyport Module Developer @roth_nj
                            @roth_nj Been playing around, and here’s what I came up with.
                            alt text
                              roth_nj
                              @MMRIZE it got my pi programmed and the mirror up and running on the screen. i have started doing some minor graphical tweaks like font/color/size etc and changed the 33% wallpaper size to 40%… all that stuff is pretty clear to me on what/where to edit and theres a ton of into on the forum/github
                              i have a couple follow up questions for you now: i want to adjust the position of the calendar top and clock. you can see in this picture that they are off set from the “top” of the screen. i want to get them to the edge. thanks again
                                roth_nj
                                  roth_nj
                                  i was able to fix the clock alignment. digging into the custom.css, i found that the top right and top left were formatted the same. i split them out and modified the top left to alight and fix the position:
                                  .region.top.left {
                                    text-align: right;
                                    top: 20px;
                                    right: 20px;
                                    position: absolute;//unset
                                  .region.top.right {
                                    text-align: right;
                                    bottom: 0;
                                    position: unset;
                                    sdetweil @roth_nj
                                    @roth_nj please try to use the code block wrapper for css and js
                                    paste stuff into post, select pasted
                                    hit the </> button
                                      roth_nj
                                      this is the latest. im pretty happy with the formatting now. i have no idea if it did it “right” but i got it to look how i wanted. only big thing left i think is to get it to be a 4-5 week rolling calendar vs just the whole month. then some minor stuff like color/font/etc.
                                      this is what i ended up changing in the custom css you shared. split apart the top right and top left to be different. made the top left position absolute and moved it to where it looked good. used the same px as the padding for other regions. added in the bottom bar (wasn’t in there - calendar is in the bottom bar). again made that absolute and moved it until it looked good. im going to guess if i tried adding the header in, it would be off the screen.
                                      .region.bottom.bar {
                                        padding: 20px;
                                        position: absolute;
                                        top: -100px;
                                      .region.top.left {
                                        text-align: right;
                                        top: 20px;
                                        right: 20px;
                                      .region.top.right {
                                        text-align: right;
                                        bottom: 0;
                                        position: unset;
                                        roth_nj
                                        i need a little bit of css help.
                                        how do i write a small section of code for the custom css change all various texts in a module to a certain color? for instance, for the clock and weather, i want all the text to be white. not gray/dimmed. i can find in the main css, and custom css where its been set but i only want to do it for those modules becuase it will mess up the calendar.
                                        ive been trying to use dev mode and everything. i understand the basic concepts on what im trying to do, i just dont know how to code it.
                                        ive been following this but still stuck
                                        https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                                        heres a couple things i;ve tried. both inside a section of code and new. this was just me testing around. ive tried a bunch of other stuff but at the point of needing help
                                          display: flex;
                                          color-text: #fff;
                                          color-text: #FFF;
                                          roth_nj
                                          ok im actually getting some where but i have another question. i got the code figured out to change part of it. why does the whole module not work?
                                          this changed the color of the date text to white
                                          .module.clock .date{
                                            color: #FFF;
                                          but when i do this, nothing happens. this all in the custom.css by the way
                                          .module.clock .module{
                                            color: #FFF;
                                            sdetweil @roth_nj
                                            @roth_nj because most of the html elements do not inherit their parents styles
                                            so you changed the element with the module class, but the child module_content does use or pass the style on. you can see it’s missing in the developers window
                                            you can pass multiple parts of the selector clause using the , (comma) between them
                                            .clock  .date, .time {
                                                 color:blue
                                            • 2 / 3
