    multiple modules in a region
    42 Posts 5 Posters 25.9k Views 6 Watching
      MMRIZE @roth_nj
      @roth_nj
      That is not faded. It only assigns a pale blue colour to Saturday on cellHeader in CSS.
      You can find .weekday_6 things in MMM-CalendarExt3.css then override it in your custom.css.
      .CX3 .weekday_6 {
        color: #339;
      And long-full-day name looks somewhat ugly, So you’d better consider headerWeekDayOptions: "short", or “narrow”.
        roth_nj @MMRIZE
        @MMRIZE
        a little misunderstanding here. i am talking about this zone at the wallpaper background to the calendar.
        i already changed the sunday red and saturday blue to both be white at this point
          roth_nj @MMRIZE
          @MMRIZE
            MMRIZE @roth_nj
            @roth_nj
            See “.region.top.bar”. I put a gradient layer there.
              roth_nj @MMRIZE
              @MMRIZE
              bingo… awesome thanks again. I was looking for anything with fade. gradient makes sense — I’m not a programmer in any sense. after changing that, I spread the wallpaper out to 40% but left the calendar overlapping a little bit still at 66%
              its getting real close now. but like I said I’m not going to mess with too much more until I get it up on my pi+monitor
              thanks again for the help
              • BKeyportB
                BKeyport Module Developer @roth_nj
                @roth_nj Been playing around, and here’s what I came up with.
                alt text
                  roth_nj
                  @MMRIZE it got my pi programmed and the mirror up and running on the screen. i have started doing some minor graphical tweaks like font/color/size etc and changed the 33% wallpaper size to 40%… all that stuff is pretty clear to me on what/where to edit and theres a ton of into on the forum/github
                  i have a couple follow up questions for you now: i want to adjust the position of the calendar top and clock. you can see in this picture that they are off set from the “top” of the screen. i want to get them to the edge. thanks again
                    roth_nj
                      roth_nj
                      i was able to fix the clock alignment. digging into the custom.css, i found that the top right and top left were formatted the same. i split them out and modified the top left to alight and fix the position:
                      .region.top.left {
                        box-sizing: border-box;
                        text-align: right;
                        top: 20px;
                        right: 20px;
                        position: absolute;//unset
                      .region.top.right {
                        text-align: right;
                        bottom: 0;
                        position: unset;
                        sdetweil @roth_nj
                        @roth_nj please try to use the code block wrapper for css and js
                        paste stuff into post, select pasted
                        hit the </> button
                          roth_nj
                          this is the latest. im pretty happy with the formatting now. i have no idea if it did it “right” but i got it to look how i wanted. only big thing left i think is to get it to be a 4-5 week rolling calendar vs just the whole month. then some minor stuff like color/font/etc.
                          this is what i ended up changing in the custom css you shared. split apart the top right and top left to be different. made the top left position absolute and moved it to where it looked good. used the same px as the padding for other regions. added in the bottom bar (wasn’t in there - calendar is in the bottom bar). again made that absolute and moved it until it looked good. im going to guess if i tried adding the header in, it would be off the screen.
                          .region.bottom.bar {
                            padding: 20px;
                            position: absolute;
                            top: -100px;
                          .region.top.left {
                            text-align: right;
                            top: 20px;
                            right: 20px;
                          .region.top.right {
                            text-align: right;
                            bottom: 0;
                            position: unset;
                            roth_nj
                            i need a little bit of css help.
                            how do i write a small section of code for the custom css change all various texts in a module to a certain color? for instance, for the clock and weather, i want all the text to be white. not gray/dimmed. i can find in the main css, and custom css where its been set but i only want to do it for those modules becuase it will mess up the calendar.
                            ive been trying to use dev mode and everything. i understand the basic concepts on what im trying to do, i just dont know how to code it.
                            ive been following this but still stuck
                            https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                            heres a couple things i;ve tried. both inside a section of code and new. this was just me testing around. ive tried a bunch of other stuff but at the point of needing help
                            .module.clock .digital {
                              display: flex;
                              flex-direction: column-reverse;
                              color-text: #fff;
                              color-text: #FFF;
                              roth_nj
                              ok im actually getting some where but i have another question. i got the code figured out to change part of it. why does the whole module not work?
                              this changed the color of the date text to white
                              .module.clock .date{
                                color: #FFF;
                              but when i do this, nothing happens. this all in the custom.css by the way
                              .module.clock .module{
                                color: #FFF;
                                sdetweil @roth_nj
                                @roth_nj because most of the html elements do not inherit their parents styles
                                so you changed the element with the module class, but the child module_content does use or pass the style on. you can see it’s missing in the developers window
                                you can pass multiple parts of the selector clause using the , (comma) between them
                                .clock  .date, .time {
                                     color:blue
                                  roth_nj
                                  thank you!
                                  i changed this:
                                    color: #FFF;
                                  .module.clock .sun{
                                    color: #FFF;
                                  .module.clock .moon{
                                    color: #FFF;
                                  .module.MMM-MoonPhase .module-header{
                                    color: #FFF;
                                  #moonphase-phase, #moonphase-age, #moonphase-phase-age {
                                  	color: #FFF;
                                  to this, but in a few modules, so its quite bit neater now:
                                  .module.clock .date,.sun,.moon,.module-header,#moonphase-phase, #moonphase-age, #moonphase-phase-age{
                                    color: #FFF;
                                  is there a way to change ALL the text color in a module to a certain color? i did this the hard way and found each displayed text figured out how to code it. just want to know for future added modules or i decide to change these are going to add in more code
                                    sdetweil @roth_nj
                                    @roth_nj there are no enforceable standards or any training for novice developers like on magic mirror. So everybody does it different.
                                    that means the short answer is, no there’s no simple way
                                    some document their class uses, but most do not. so you have to go through the developers console or read their code to figure out what they do so that you can override it
                                    many times a module will provide a css file with a list of all the classes they use, and default values
                                    • BKeyportB
                                      @sdetweil and there’s those like me who hack through things, and have to re-remember how they did stuff when they come back to it. It’s the wild, wild, west out there.
                                        sdetweil @BKeyport
                                        @BKeyport yes, true, but the net answer for him, is , No there is no simple way to do all the text, all the time…
                                          roth_nj
                                          @MMRIZE
                                          i do have a question for you since im using the code you helped set up in this thread.
                                          im thinking of adding in a week view and day view or task list/agenda as well. i would like to have that group change in and out with the 5 week calendar view.
                                          what is your suggestion on the best module to do that? ive read about pages and carousel. tips for implementation given the custom css work already done here?
                                          thanks again
                                          • BKeyportB
                                            @roth_nj Agenda view is best served by MMM-CalendarExt3Agenda. Great module…
                                            • 2 / 3
