    REQUEST : SEMS PORTAL for Magic Mirror
    16 Posts 4 Posters 7.8k Views 4 Watching
    • JerryPJ Offline
      JerryP
      Yes pleas.
      • F Offline
        Fifteen15Studios
        Looks like this GitHub repo is for connecting the SEMS Portal and Home Assistant. Have you looked into the Home Assistant modules? I have one, that I forked from someone else, that displays the value of sensors from Home Assistant:
        https://github.com/Fifteen15Studios/MMM-homeassistant-sensors
        And there is another one that can display other information from Home Assistant:
        https://github.com/wonderslug/MMM-HomeAssistantDisplay
        If you have the two systems linked already (the GoodWe solar and Home Assistant) this may be the way to go.
        • N Offline
          nkc @Fifteen15Studios
          @Fifteen15Studios : Need a magic Mirror solution - not anything else - the solution will get the values from sems portal api’s - I have a powershell script which works - it needs to be converted to a Magic Mirror Module - if anyone is interested in reverse engineering this script to a magic mirror module - please let me know.
          Thank you and regards.
          JerryPJ 1 Reply Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @nkc
            @nkc
            • JerryPJ Offline
              JerryP @JerryP
              And now there is data on the mirror. full in test fase
              JerryPJ 1 Reply Last reply Reply Quote 1
              • JerryPJ Offline
                JerryP @JerryP
                More to show…
                • JerryPJ Offline
                  JerryP @JerryP
                  Vandaag het zonnetje een klein beetje op de panelen.
                  Today I was a littelbit sunny. and the module is in test fase.
                  • JerryPJ Offline
                    JerryP @JerryP
                    A small step for men…
                    N J 3 Replies Last reply Reply Quote 0
                    • N Offline
                      nkc @JerryP
                      @JerryP : Hi Jerry - Are you willing to share this code - Where can I find your code ?
                      Thank you.
                      JerryPJ N 2 Replies Last reply Reply Quote 0
                      • JerryPJ Offline
                        JerryP @nkc
                        @nkc said in REQUEST : SEMS PORTAL for Magic Mirror:
                        Thank you.
                        MMM-SemPortal
                        • N Offline
                          nkc @JerryP
                          @JerryP -Hi Jerry - Would you have a copy of the above version of programs - If you do could I have a copy - I like the above version - it save a lot of space for my arrangents on the mirror - - Please let me know where to pick the above version from - Thank You - Neel.
                          • JerryPJ Offline
                            JerryP @nkc
                            @nkc
                            check out this module
                            https://github.com/HugoTheStreamer/MMM-GoodWe
                            sdetweil edited to make link visible
                            • N nkc has marked this topic as solved on
                            • N Offline
                              nkc @nkc
                              Hi Jerry - Would you have this version of the program ;
                                Jose1701 @JerryP
                                @JerryP said in REQUEST : SEMS PORTAL for Magic Mirror:
                                This is very nice. I like it a lot.
                                I use a very simple module to show the data. https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                                Unfortunately I use a hoymiles inverter.
                                Any ideas to get it as nice as this module?
                                Jose
                                • JerryPJ Offline
                                  JerryP @Jose1701
                                  @Jose1701
                                  No… i ready have no idea
