    REQUEST : SEMS PORTAL for Magic Mirror
    16 Posts 4 Posters 8.0k Views 4 Watching
    • N
      nkc @Fifteen15Studios
      @Fifteen15Studios : Need a magic Mirror solution - not anything else - the solution will get the values from sems portal api’s - I have a powershell script which works - it needs to be converted to a Magic Mirror Module - if anyone is interested in reverse engineering this script to a magic mirror module - please let me know.
      Thank you and regards.
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @nkc
        @nkc
        • JerryPJ
          JerryP @JerryP
          And now there is data on the mirror. full in test fase
          • JerryPJ
            JerryP @JerryP
            More to show…
            • JerryPJ
              JerryP @JerryP
              Vandaag het zonnetje een klein beetje op de panelen.
              Today I was a littelbit sunny. and the module is in test fase.
              • JerryPJ
                JerryP @JerryP
                A small step for men…
                N J 3 Replies Last reply
                • N
                  nkc @JerryP
                  @JerryP : Hi Jerry - Are you willing to share this code - Where can I find your code ?
                  Thank you.
                  JerryPJ N 2 Replies Last reply
                  • JerryPJ
                    JerryP @nkc
                    @nkc said in REQUEST : SEMS PORTAL for Magic Mirror:
                    Thank you.
                    MMM-SemPortal
                    • N
                      nkc @JerryP
                      @JerryP -Hi Jerry - Would you have a copy of the above version of programs - If you do could I have a copy - I like the above version - it save a lot of space for my arrangents on the mirror - - Please let me know where to pick the above version from - Thank You - Neel.
                      • JerryPJ
                        JerryP @nkc
                        @nkc
                        check out this module
                        https://github.com/HugoTheStreamer/MMM-GoodWe
                        sdetweil edited to make link visible
                        • N nkc has marked this topic as solved on
                        • N
                          nkc @nkc
                          Hi Jerry - Would you have this version of the program ;
                            Jose1701 @JerryP
                            @JerryP said in REQUEST : SEMS PORTAL for Magic Mirror:
                            This is very nice. I like it a lot.
                            I use a very simple module to show the data. https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                            Unfortunately I use a hoymiles inverter.
                            Any ideas to get it as nice as this module?
                            Jose
                            • JerryPJ
                              JerryP @Jose1701
                              @Jose1701
                              No… i ready have no idea
