    Magic Touch Display
    15 Posts 5 Posters 7.2k Views 6 Watching
      Pjarki @Egnos
      @Egnos the python script is now uploaded here: https://github.com/TheSwedishMaker/FridaytheAIVOICE
      • E Offline
        Egnos @Pjarki
        @Pjarki Thanks, I’ll try to do some tests. I will let you know!
          Chazzer @Pjarki
          @Pjarki Looks very nice! Thank u for sharing
            Manino @Pjarki
            @Pjarki Funny modules! I have them now, and have been thinking about to not use the MMM-ModuleController. I like the blurry background for the calculator. But there is one issue with the MMM-DrawingBoard for me, It is a bit laggy.
            Do you know if it’s because of the non existing ModuleController in my config?
            First of all then, I don’t know where to put these, can you tell me where to put them?
            this.sendNotification(‘HIDE_MODULES’, { exceptionList: [“MMM-DrawingBoard”] });
            this.sendNotification(‘SHOW_MODULES’);
              sdetweil @Manino
              @Manino those sendNotification go in other modules
                Manino @sdetweil
                @sdetweil What other modules?
                  sdetweil @Manino
                  @Manino whatever other module want to control show and hide of modules.
                  sendNotification is a broadcast to all other modules. if they understand the notification then they can act on it
                  MMM-ModuleController obviously watches for this notification from some other module and then acts to show or hide modules.
                    Manino @sdetweil
                    @sdetweil Yes, but should I copy paste it into config or what?
                    I’m on a very low level of the Magic Mirror, have been here for only a month and I can’t understand were to put the line or lines. I have tried at least 50 different places, in files, cofig, and also the css. I can’t do it right.
                      sdetweil @Manino
                      @Manino no. that would go inside another.module where u want to control modules being shown or hidden
                      consider a module that has an on/off button, a toggle, default on.
                      when you press it, all the other modules should be hidden. when you press it again the modules should be shown
                      now, YOU could write and maintain all the code that does the show and hide, OR you could send that notification to some other module that provides that function.
                      so, in this button action section of this new module you could paste this code to signal hide and show.
                      it doesn’t go anywhere else
                        Manino @sdetweil
                        @sdetweil And what is another.module?
                        I have the MMM-ModuleController, MMM-Calculator, MMM-DrawingBoard. Do you mean someone of those or is it something else? I do understand what is supposed to happen, but can’t figure out HOW to do it with those lines.
