    Update to v2.25.0
    11 Posts 3 Posters 3.0k Views 3 Watching
    • MZ-BERM Offline
      MZ-BER
      Hey there,
      Just finished reading up on all the issues popping up after the MagicMirror² v2.25.0 update, and to be honest, it’s got me a bit spooked about updating. Right now, all my modules are running smoothly and I don’t want to mess that up. But I get it, I can’t dodge the update forever, especially with some of the dependencies retiring.
      I’m thinking about using @sdetweil update script to update the MagicMirror, but I’m not sure how that’s going to affect my modules. If you’ve got any tips or suggestions on how to handle this, I’d really appreciate it.
      Here is the list with my running modules:
      • MMM-Wallpaper
      • MMM-Multimonth
      • MMM-OpenWeatherForecast
      • MMM-MyCalendar
      • MMM-NINA
      • MMM-PublicTransportHafas
      • MMM-Fuel
      • MMM-GoogleSheets
      • MMM-PIR-Sensor-Lite
      • MMM-NowPlayingOnSpotify
      • MMM-Todoist
      • MMM-Jast
      • MMM-NewsAPI
      S JalibuJ 2 Replies Last reply Reply Quote 0
        sdetweil @MZ-BER
        @MZ-BER I have updated my upgrade-script to recognize more removed libraries.
        make sure to run thru the test run to see if any modules are affected. no changes are made in the test run cycle
        MZ-BERM 2 Replies Last reply Reply Quote 0
        • JalibuJ Offline
          Jalibu Module Developer @MZ-BER
          @MZ-BER MMM-NINA and MMM-Jast will work with v2.25.0 :smiling_face_with_sunglasses:
          MZ-BERM 1 Reply Last reply Reply Quote 1
          • MZ-BERM Offline
            MZ-BER @Jalibu
            @Jalibu Well, I didn’t expect anything different from you. :D
            • MZ-BERM Offline
              MZ-BER @sdetweil
              @sdetweil Thanks you! This is my upgrade.log.
              pgrade started - Tue Oct 24 10:52:06 CEST 2023
              system is Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
              n (node version manager tool) not installed, doing test run, install skipped
              Minimum Node version: v20.8.0
              Installed Node version: v16.20.2
              Node should be upgraded.
              Node.js upgrade defered, doing test run
              Minimum npm version: V10.1.0
              Installed npm version: V8.19.4
              npm should be upgraded.
              npm upgrade defered, doing test run  ...
              saving custom.css
              remote name = origin
              upgrading from version 2.24.0 to 2.25.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
                (use "git pull" to update your local branch)
                (use "git add <file>..." to update what will be committed)
                (use "git restore <file>..." to discard changes in working directory)
              	modified:   css/main.css
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	core
              	css/save_custom.css
              	installers/mm_temp.sh
              	installers/pm2_MagicMirror.json
              	installers/pm2_MagicMirror_new.json
              	run-start.sh
              no changes added to commit (use "git add" and/or "git commit -a")
              there are 1 local files that are different than the master repo
                 css/main.css
              save/restore files selection = y
              erasing lock files
              Saved working directory and index state WIP on master: e87f50e Release 2.24.0 (#3141)
              test merge result rc='' , if empty, no conflicts
              skipping merge, only test run
              	  package.json not found for module MMM-MyCalendar
              		 bypass adding package.json for module MMM-MyCalendar, doing test run
              	  package.json not found for module MMM-GoogleSheets
              		 bypass adding package.json for module MMM-GoogleSheets, doing test run
              downloading dumpactivemodules script
              processing for module MMM-Wallpaper please wait
              skipped processing for MMM-Wallpaper, doing test run
              processing complete for module MMM-Wallpaper
              processing for module MMM-CountDown please wait
              skipped processing for MMM-CountDown, doing test run
              processing complete for module MMM-CountDown
              processing for module MMM-OpenWeatherForecast please wait
              skipped processing for MMM-OpenWeatherForecast, doing test run
              processing complete for module MMM-OpenWeatherForecast
              processing for module MMM-NINA please wait
              skipped processing for MMM-NINA, doing test run
              processing complete for module MMM-NINA
              processing for module MMM-PublicTransportHafas please wait
              skipped processing for MMM-PublicTransportHafas, doing test run
              processing complete for module MMM-PublicTransportHafas
              processing for module MMM-Fuel please wait
              skipped processing for MMM-Fuel, doing test run
              processing complete for module MMM-Fuel
              processing for module MMM-MyVolvo please wait
              skipped processing for MMM-MyVolvo, doing test run
              processing complete for module MMM-MyVolvo
              processing for module MMM-PIR-Sensor-Lite please wait
              skipped processing for MMM-PIR-Sensor-Lite, doing test run
              processing complete for module MMM-PIR-Sensor-Lite
              processing for module MMM-NowPlayingOnSpotify please wait
              skipped processing for MMM-NowPlayingOnSpotify, doing test run
              processing complete for module MMM-NowPlayingOnSpotify
              processing for module MMM-Todoist please wait
              skipped processing for MMM-Todoist, doing test run
              processing complete for module MMM-Todoist
              processing for module MMM-Jast please wait
              skipped processing for MMM-Jast, doing test run
              processing complete for module MMM-Jast
              processing for module MMM-NewsAPI please wait
              skipped processing for MMM-NewsAPI, doing test run
              processing complete for module MMM-NewsAPI
              restoring custom.css
              removing git alias
              test run, restoring files stashed
              Removing vendor/package-lock.json
              Removing package-lock.json
              Removing fonts/package-lock.json
              On branch master
                (use "git add/rm <file>..." to update what will be committed)
              	deleted:    fonts/package-lock.json
              	deleted:    package-lock.json
              	deleted:    vendor/package-lock.json
              Untracked files:
              	core
              	run-start.sh
              Dropped refs/stash@{0} (c2cb1efe09ca1e3538f822bd9f6caccf74e510ec)
              Upgrade ended - Tue Oct 24 10:52:38 CEST 2023
              As expected Node and NPM needs to be upgraded and Im aware of the CSS file. But Im a bit confused about the results regarding the modules. Are they fine after the upgrade or not? The log is not clear for me.
              Thank you in advance!
              • MZ-BERM Offline
                MZ-BER @sdetweil
                Hi @sdetweil, does the log tell me I have to only check MMM-MyCalendar & MMM-GoogleSheets, and all of the other modules are okay?
                  sdetweil @MZ-BER
                  @MZ-BER sorry for not replying sooner.
                  I need to improve the messages.
                  those two modules are impacted by the removal of libraries. and would fail , stopping MagicMirror.
                  the upgrade script will fix them.
                  MZ-BERM 1 Reply Last reply Reply Quote 0
                  • MZ-BERM Offline
                    MZ-BER @sdetweil
                    @sdetweil No worries at all. Thanks for responding. I was able to upgrade with your script. Only MMM-NewsAPI and MMM-MyCalendar needed some attention.
                    For MMM-NewsAPI I had to install fetch-node and for MMM-MyCalendar I applied the workaround.
                    S 3 Replies Last reply Reply Quote 0
                      sdetweil @MZ-BER
                      @MZ-BER but, you KNEW about it before you started the ACTUAL upgrade, and so you were prepared.
                      that’s the whole point of the two pass approach.
                      awesome feedback. thanks.
                        sdetweil @MZ-BER
                        @MZ-BER for MMM-NewsApi, the upgrade should have fixed that for you. (it’s node-fetch)
                        but, in addition, he has a module upgrade that fixes it natively without the extra npm install…
                          sdetweil @MZ-BER
                          @MZ-BER what do you think of these new messages
                          	 require for node-fetch in module MMM-NewsAPI not found in package.json
                          		  bypass installing node-fetch for module MMM-NewsAPI , doing test run
                          updating dependencies for active modules with package.json files
                          	processing for module birthdaylist please wait
                          	skipped processing for birthdaylist, doing test run
                          	processing complete for module birthdaylist
