    Update to v2.25.0
    11 Posts 3 Posters 3.1k Views 3 Watching
      sdetweil @MZ-BER
      @MZ-BER I have updated my upgrade-script to recognize more removed libraries.
      make sure to run thru the test run to see if any modules are affected. no changes are made in the test run cycle
      MZ-BERM 2 Replies Last reply
      • JalibuJ
        Jalibu Module Developer @MZ-BER
        @MZ-BER MMM-NINA and MMM-Jast will work with v2.25.0 :smiling_face_with_sunglasses:
        MZ-BERM 1 Reply Last reply
        • MZ-BERM
          MZ-BER @Jalibu
          @Jalibu Well, I didn’t expect anything different from you. :D
          • MZ-BERM
            MZ-BER @sdetweil
            @sdetweil Thanks you! This is my upgrade.log.
            pgrade started - Tue Oct 24 10:52:06 CEST 2023
            system is Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
            n (node version manager tool) not installed, doing test run, install skipped
            Minimum Node version: v20.8.0
            Installed Node version: v16.20.2
            Node should be upgraded.
            Node.js upgrade defered, doing test run
            Minimum npm version: V10.1.0
            Installed npm version: V8.19.4
            npm should be upgraded.
            npm upgrade defered, doing test run  ...
            saving custom.css
            remote name = origin
            upgrading from version 2.24.0 to 2.25.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is behind 'origin/master' by 1 commit, and can be fast-forwarded.
              (use "git pull" to update your local branch)
              (use "git add <file>..." to update what will be committed)
              (use "git restore <file>..." to discard changes in working directory)
            	modified:   css/main.css
            Untracked files:
              (use "git add <file>..." to include in what will be committed)
            	core
            	css/save_custom.css
            	installers/mm_temp.sh
            	installers/pm2_MagicMirror.json
            	installers/pm2_MagicMirror_new.json
            	run-start.sh
            no changes added to commit (use "git add" and/or "git commit -a")
            there are 1 local files that are different than the master repo
               css/main.css
            save/restore files selection = y
            erasing lock files
            Saved working directory and index state WIP on master: e87f50e Release 2.24.0 (#3141)
            test merge result rc='' , if empty, no conflicts
            skipping merge, only test run
            	  package.json not found for module MMM-MyCalendar
            		 bypass adding package.json for module MMM-MyCalendar, doing test run
            	  package.json not found for module MMM-GoogleSheets
            		 bypass adding package.json for module MMM-GoogleSheets, doing test run
            downloading dumpactivemodules script
            processing for module MMM-Wallpaper please wait
            skipped processing for MMM-Wallpaper, doing test run
            processing complete for module MMM-Wallpaper
            processing for module MMM-CountDown please wait
            skipped processing for MMM-CountDown, doing test run
            processing complete for module MMM-CountDown
            processing for module MMM-OpenWeatherForecast please wait
            skipped processing for MMM-OpenWeatherForecast, doing test run
            processing complete for module MMM-OpenWeatherForecast
            processing for module MMM-NINA please wait
            skipped processing for MMM-NINA, doing test run
            processing complete for module MMM-NINA
            processing for module MMM-PublicTransportHafas please wait
            skipped processing for MMM-PublicTransportHafas, doing test run
            processing complete for module MMM-PublicTransportHafas
            processing for module MMM-Fuel please wait
            skipped processing for MMM-Fuel, doing test run
            processing complete for module MMM-Fuel
            processing for module MMM-MyVolvo please wait
            skipped processing for MMM-MyVolvo, doing test run
            processing complete for module MMM-MyVolvo
            processing for module MMM-PIR-Sensor-Lite please wait
            skipped processing for MMM-PIR-Sensor-Lite, doing test run
            processing complete for module MMM-PIR-Sensor-Lite
            processing for module MMM-NowPlayingOnSpotify please wait
            skipped processing for MMM-NowPlayingOnSpotify, doing test run
            processing complete for module MMM-NowPlayingOnSpotify
            processing for module MMM-Todoist please wait
            skipped processing for MMM-Todoist, doing test run
            processing complete for module MMM-Todoist
            processing for module MMM-Jast please wait
            skipped processing for MMM-Jast, doing test run
            processing complete for module MMM-Jast
            processing for module MMM-NewsAPI please wait
            skipped processing for MMM-NewsAPI, doing test run
            processing complete for module MMM-NewsAPI
            restoring custom.css
            removing git alias
            test run, restoring files stashed
            Removing vendor/package-lock.json
            Removing package-lock.json
            Removing fonts/package-lock.json
            On branch master
              (use "git add/rm <file>..." to update what will be committed)
            	deleted:    fonts/package-lock.json
            	deleted:    package-lock.json
            	deleted:    vendor/package-lock.json
            Untracked files:
            	core
            	run-start.sh
            Dropped refs/stash@{0} (c2cb1efe09ca1e3538f822bd9f6caccf74e510ec)
            Upgrade ended - Tue Oct 24 10:52:38 CEST 2023
            As expected Node and NPM needs to be upgraded and Im aware of the CSS file. But Im a bit confused about the results regarding the modules. Are they fine after the upgrade or not? The log is not clear for me.
            Thank you in advance!
            • MZ-BERM
              MZ-BER @sdetweil
              Hi @sdetweil, does the log tell me I have to only check MMM-MyCalendar & MMM-GoogleSheets, and all of the other modules are okay?
                sdetweil @MZ-BER
                @MZ-BER sorry for not replying sooner.
                I need to improve the messages.
                those two modules are impacted by the removal of libraries. and would fail , stopping MagicMirror.
                the upgrade script will fix them.
                • MZ-BERM
                  MZ-BER @sdetweil
                  @sdetweil No worries at all. Thanks for responding. I was able to upgrade with your script. Only MMM-NewsAPI and MMM-MyCalendar needed some attention.
                  For MMM-NewsAPI I had to install fetch-node and for MMM-MyCalendar I applied the workaround.
                  S 3 Replies Last reply
                    sdetweil @MZ-BER
                    @MZ-BER but, you KNEW about it before you started the ACTUAL upgrade, and so you were prepared.
                    that’s the whole point of the two pass approach.
                    awesome feedback. thanks.
                      sdetweil @MZ-BER
                      @MZ-BER for MMM-NewsApi, the upgrade should have fixed that for you. (it’s node-fetch)
                      but, in addition, he has a module upgrade that fixes it natively without the extra npm install…
                        sdetweil @MZ-BER
                        @MZ-BER what do you think of these new messages
                        	 require for node-fetch in module MMM-NewsAPI not found in package.json
                        		  bypass installing node-fetch for module MMM-NewsAPI , doing test run
                        updating dependencies for active modules with package.json files
                        	processing for module birthdaylist please wait
                        	skipped processing for birthdaylist, doing test run
                        	processing complete for module birthdaylist
