    Failed Update
    45 Posts 3 Posters 12.5k Views 3 Watching
      sdetweil @DarkV
      @DarkV ok, thx… let me see the
      ~/MagicMirror/installers/upgrade.log
      when u finish
        DarkV @sdetweil
        Here is the log and a failed update again
        pgrade started - Sun Oct  2 10:41:43 BST 2022
        system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
        Minimum Node version: v16.9.1
        Installed Node version: v16.17.1
        No Node.js upgrade necessary.
        Minimum npm version: V7.11.2
        Installed npm version: V8.15.0
        No npm upgrade necessary.
        saving custom.css
        remote name = origin
        upgrading from version 2.20.0 to 2.21.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is behind 'origin/master' by 4694 commits, and can be fast-forwarded.
          (use "git pull" to update your local branch)
          (use "git add <file>..." to update what will be committed)
          (use "git restore <file>..." to discard changes in working directory)
        	modified:   installers/mm.sh
        	modified:   package-lock.json
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
        	core
        	css/save_custom.css
        	installers/mm_temp.sh
        	installers/pm2_MagicMirror.json
        	installers/pm2_MagicMirror_new.json
        	run-start.sh
        no changes added to commit (use "git add" and/or "git commit -a")
        there are 2 local files that are different than the master repo
           installers/mm.sh
           package-lock.json
        save/restore files selection = y
        erasing lock files
        Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop
        test merge result rc='' , if empty, no conflicts
        skipping merge, only test run
        downloading dumpactivemodules script
        processing for module MMM-Tools please wait
        skipped processing for MMM-Tools, doing test run
        processing complete for module MMM-Tools
        restoring custom.css
        removing git alias
        test run, restoring files stashed
        Removing vendor/package-lock.json
        Removing package-lock.json
        Removing fonts/package-lock.json
        On branch master
          (use "git add/rm <file>..." to update what will be committed)
        	deleted:    fonts/package-lock.json
        	deleted:    package-lock.json
        	deleted:    vendor/package-lock.json
        Untracked files:
        	core
        	run-start.sh
        Dropped refs/stash@{0} (0640a953f8283b8d55b598386c17d310f8a75680)
        Upgrade ended - Sun Oct  2 10:41:58 BST 2022
        Upgrade started - Sun Oct  2 10:42:15 BST 2022
        user requested to apply changes
        doing test run = false
        saving custom.css
        git fetch rc=0
        On branch master
        Untracked files:
        	core
        	css/save_custom.css
        	run-start.sh
        there are 1 local files that are different than the master repo
           installers/mm.sh
        erasing lock files
        executing merge, apply specified
        merge result rc= 0
         Updating 30d5bfe5..9e029304 Fast-forward  .github/ISSUE_TEMPLATE.md
            4 +-  .github/workflows/automated-tests.yaml
            4 +-  .github/workflows/codecov-test-suites.yaml
            2 +-  CHANGELOG.md
          100 +-  LICENSE.md
            2 +-  css/main.css
           18 +-  fonts/package-lock.json
           28 +-  fonts/package.json
            4 +-  js/node_helper.js
           17 +-  modules/default/calendar/README.md
            0  modules/default/calendar/calendar.js
           21 +-  modules/default/calendar/calendarutils.js
           37 +-  modules/default/calendar/node_helper.js
            8 +  modules/default/currentweather/currentweather.js
           33 -  modules/default/defaultmodules.js
            2 +-  modules/default/newsfeed/newsfeedfetcher.js
           13 +  modules/default/weather/README.md
            2 +-  modules/default/weather/current.njk
            0  modules/default/weather/providers/README.md
            0  modules/default/weather/providers/darksky.js
            0  .../default/weather/providers/openweathermap.js
            0  modules/default/weather/providers/smhi.js
           61 +-  modules/default/weather/providers/ukmetoffice.js
            0  modules/default/weather/providers/weatherbit.js
           26 +-  modules/default/weather/providers/weathergov.js
            0  modules/default/weather/weatherobject.js
            0  modules/default/weatherforecast/weatherforecast.js
           33 -  package-lock.json
         3885 +++++++++++---------  package.json
           38 +-  tests/configs/data/calendar_test_recurring.ics
            2 +-  tests/e2e/env_spec.js
           17 +-  tests/e2e/global-setup.js
           57 +-  tests/e2e/modules/alert_spec.js
            9 +-  tests/e2e/modules/calendar_spec.js
          111 +-  tests/e2e/modules/clock_es_spec.js
           47 +-  tests/e2e/modules/clock_spec.js
           77 +-  tests/e2e/modules/compliments_spec.js
           60 +-  tests/e2e/modules/helloworld_spec.js
           18 +-  tests/e2e/modules/newsfeed_spec.js
           48 +-  tests/e2e/modules/weather_spec.js
          225 +-  tests/e2e/modules_display_spec.js
           10 +-  tests/e2e/modules_position_spec.js
            9 +-  tests/e2e/translations_spec.js
            6 +-  tests/e2e/without_modules.js
           12 +-  .../__snapshots__/updatenotification_spec.js.snap
            6 +-  translations/en.json
            1 -  vendor/package-lock.json
           42 +-  vendor/package.json
            6 +-  vendor/vendor.js
            0  49 files changed, 2858 insertions(+), 2243 deletions(-)
        mode change 100755 => 100644 modules/default/calendar/README.md
        mode change 100755 => 100644 modules/default/calendar/calendar.js  delete mode 100644 modules/default/currentweather/currentweather.js
        mode change 100755 => 100644 modules/default/weather/README.md
        mode change 100755 => 100644 modules/default/weather/current.njk
        mode change 100755 => 100644 modules/default/weather/providers/README.md
        mode change 100755 => 100644 modules/default/weather/providers/darksky.js
        mode change 100755 => 100644 modules/default/weather/providers/openweathermap.js
        mode change 100755 => 100644 modules/default/weather/providers/ukmetoffice.js
        mode change 100755 => 100644 modules/default/weather/providers/weathergov.js
        mode change 100755 => 100644 modules/default/weather/weatherobject.js  delete mode 100644 modules/default/weatherforecast/weatherforecast.js
        mode change 100755 => 100644 vendor/package.json
        mode change 100755 => 100644 vendor/vendor.js
        processor architecture is armv7l
        npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options
        npm WARN invalid config Must be one or more of: dev, optional, peer
        > magicmirror@2.21.0 postinstall
        > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        > magicmirror@2.21.0 install-vendor
        > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        changed 3 packages in 9s
        > magicmirror@2.21.0 install-fonts
        > echo "Installing fonts ...
        > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        changed 2 packages in 4s
        > magicmirror@2.21.0 prepare
        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
        husky - Git hooks installed
        added 455 packages, removed 3 packages, changed 13 packages, and audited 754 packages in 3m
        91 packages are looking for funding
          run `npm fund` for details
        3 moderate severity vulnerabilities
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
        npm install completed - Sun Oct  2 10:45:27 BST 2022 on base
        fixing sandbox permissions
        added 3 packages, and audited 4 packages in 3s
        1 package is looking for funding
        found 0 vulnerabilities
        removing git alias
        we stashed a set of files that appear changed from the latest repo versions. you should review them
        Upgrade ended - Sun Oct  2 10:45:33 BST 2022
        Upgrade started - Tue Oct 17 12:57:21 BST 2023
        system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
        Minimum Node version: v20.8.0
        Installed Node version: v16.20.2
        Node should be upgraded.
        A Node process is currently running. Can't upgrade.
        Please quit all Node processes and restart the update.
        junior 18317 18316 0 Oct07 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 17 12:58:30 BST 2023
        junior 8378 8377 5 12:58 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 17 13:04:45 BST 2023
        junior 8378 8377 0 12:58 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Sun Oct 22 09:24:16 BST 2023
        junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 24 11:04:00 BST 2023
        n (node version manager tool) not installed, doing test run, install skipped
        Upgrade started - Tue Oct 24 11:04:44 BST 2023
        added 1 package, and audited 2 packages in 2s
        npm notice
        npm notice New major version of npm available! 8.19.4 -> 10.2.1
        npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.2.1>
        npm notice Run `npm install -g npm@10.2.1` to update!
        npm notice
          installing : node-v20.8.0
               mkdir : /usr/local/n/versions/node/20.8.0
               fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-arm64.tar.xz
             copying : node/20.8.0
           installed :  (with npm 10.1.0)
        Note: the node command changed location and the old location may be remembered in your current shell.
                 old : /usr/bin/node
                 new : /usr/local/bin/node
        If "node --version" shows the old version then start a new shell, or reset the location hash with:
        hash -r  (for bash, zsh, ash, dash, and ksh)
        rehash   (for csh and tcsh)
        forcing low Node version
        Installed Node version: V1.0.0
        running process(s) are
        junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electro                                           n.js
        junior@MAGIC-MIRROR:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/s                                           detweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        npm WARN cli npm v10.1.0 does not support Node.js v16.20.2. This version of npm                                            supports the following node versions: `^18.17.0 || >=20.5.0`. You can find the l                                           atest version at https://nodejs.org/.
        /usr/bin/n: line 746: /usr/local/bin/node: No such file or directory
        update log will be in /home/junior/MagicMirror/installers/upgrade.log
        apply: line 207: /usr/local/bin/node: No such file or directory
          sdetweil @DarkV
          @DarkV you have to stop your running mm first
          pm2 stop all
            DarkV @sdetweil
            @sdetweil said in Failed Update:
            pm2 stop all
            I can now update because that worked—many thanks for your assistance.
              sdetweil @DarkV
              @DarkV were u able to update successfully?
                DarkV @sdetweil
                @sdetweil it goes through the update process successfully, but on the mirror, it still reports that it is 3 updates behind upon reboot
                  sdetweil @DarkV
                  @DarkV well then it didn’t do the upgrade
                  this is a two step process( two links on the page)
                  test, alert any issues, files might be overwritten, etc
                  make no changes
                  apply, DO THE UPGRADE
                  except, if its the same version is already installed.
                  DON’T DO IT AGAIN…
                  but if you change the apply parm to force
                  then it will
                  show me the ~/MagicMirror/installers/upgrade.log
                    DarkV @sdetweil
                    Upgrade started - Sun Oct 2 10:41:43 BST 2022
                    Check current Node installation …
                    Check current NPM installation …
                    saving custom.css
                    git fetch rc=0
                    On branch master
                    Your branch is behind ‘origin/master’ by 4694 commits, and can be fast-forwarded.
                    (use “git pull” to update your local branch)
                    (use “git add …” to update what will be committed)
                    (use “git restore …” to discard changes in working directory)
                    Untracked files:
                    (use “git add …” to include in what will be committed)
                    core
                    css/save_custom.css
                    run-start.sh
                    no changes added to commit (use “git add” and/or “git commit -a”)
                    installers/mm.sh
                    package-lock.json
                    erasing lock files
                    test merge result rc=‘’ , if empty, no conflicts
                    removing git alias
                    On branch master
                    (use “git add/rm …” to update what will be committed)
                    Untracked files:
                    core
                    run-start.sh
                    saving custom.css
                    git fetch rc=0
                    On branch master
                    Untracked files:
                    core
                    css/save_custom.css
                    run-start.sh
                    installers/mm.sh
                    erasing lock files
                    merge result rc= 0
                    Updating 30d5bfe5…9e029304 Fast-forward .github/ISSUE_TEMPLATE.md
                    4 ± .github/workflows/automated-tests.yaml
                    4 ± .github/workflows/codecov-test-suites.yaml
                    2 ± CHANGELOG.md
                    100 ± LICENSE.md
                    2 ± css/main.css
                    18 ± fonts/package-lock.json
                    28 ± fonts/package.json
                    4 ± js/node_helper.js
                    17 ± modules/default/calendar/README.md
                    21 ± modules/default/calendar/calendarutils.js
                    37 ± modules/default/calendar/node_helper.js
                    2 ± modules/default/newsfeed/newsfeedfetcher.js
                    2 ± modules/default/weather/current.njk
                    0 …/default/weather/providers/openweathermap.js
                    61 ± modules/default/weather/providers/ukmetoffice.js
                    26 ± modules/default/weather/providers/weathergov.js
                    3885 ++++++++++±-------- package.json
                    38 ± tests/configs/data/calendar_test_recurring.ics
                    2 ± tests/e2e/env_spec.js
                    17 ± tests/e2e/global-setup.js
                    57 ± tests/e2e/modules/alert_spec.js
                    9 ± tests/e2e/modules/calendar_spec.js
                    111 ± tests/e2e/modules/clock_es_spec.js
                    47 ± tests/e2e/modules/clock_spec.js
                    77 ± tests/e2e/modules/compliments_spec.js
                    60 ± tests/e2e/modules/helloworld_spec.js
                    18 ± tests/e2e/modules/newsfeed_spec.js
                    48 ± tests/e2e/modules/weather_spec.js
                    225 ± tests/e2e/modules_display_spec.js
                    10 ± tests/e2e/modules_position_spec.js
                    9 ± tests/e2e/translations_spec.js
                    6 ± tests/e2e/without_modules.js
                    12 ± …/snapshots/updatenotification_spec.js.snap
                    6 ± translations/en.json
                    42 ± vendor/package.json
                    6 ± vendor/vendor.js
                    npm WARN invalid config omit=“dev --no-audit --no-fund --no-update-notifier” set in command line options
                    echo "Installing vendor files …
                    echo "Installing fonts …
                    Installing fonts …
                    run npm fund for details
                    Run npm audit for details.
                    removing git alias
                    A Node process is currently running. Can’t upgrade.
                    npm notice
                    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.1
                    npm notice Run npm install -g npm@10.2.1 to update!
                    npm notice
                    old : /usr/bin/node
                    If “node --version” shows the old version then start a new shell, or reset the location hash with:
                    Upgrade started - Tue Oct 24 13:23:22 BST 2023
                    node not installed, trying via apt-get
                    Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (16.20.2-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    npm not installed, trying via apt-get
                    Installing Node.js …
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease
                    Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x bullseye InRelease [4,586 B] Get:4 https://deb.nodesource.com/node_20.x bullseye/main armhf Packages [783 B] Fetched 5,369 B in 1s (4,513 B/s) Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                    Node.js installation Done! version=
                    pm2 installed, checking version 5.2.0 vs 5.3.0
                    pm2 same major version, so updating
                    added 4 packages, removed 30 packages, and changed 153 packages in 18s
                    13 packages are looking for funding
                    Be sure to have the latest version by doing npm install pm2@latest -g before doing this procedure.
                    In-memory PM2 is out-of-date, do:
                    $ pm2 update
                    In memory PM2 version: 5.2.0
                    Local PM2 version: 5.3.0
                                  https://pm2.io/
                     Harden your Node.js Production Environment
                      - Real-time Monitoring Web Interface
                      - Pro Active Alerting System
                      - Production Profiling for Memory and CPU
                      - PM2 Runtime High Availability Fallback
                             Start using it by typing:
                                    $ pm2 plus
                    [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
                    [PM2] MagicMirror ✓
                    [PM2] [v] All Applications Stopped
                    [PM2] [v] PM2 Daemon Stopped
                    [PM2] Spawning PM2 daemon with pm2_home=/home/junior/.pm2
                    [PM2] Restoring processes located in /home/junior/.pm2/dump.pm2
                    [PM2] Process /home/junior/MagicMirror/installers/mm.sh restored
                    PM2 updated
                    Upgrade started - Tue Oct 24 13:56:39 BST 2023
                    node not installed, doing test run, install skipped
                    junior 1519 1518 0 13:37 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                    Upgrade started - Tue Oct 24 13:57:20 BST 2023
                    Node.js upgrade defered, doing test run
                    Minimum npm version: V10.1.0
                    Installed npm version: V10.1.0
                    saving custom.css
                    upgrading from version 2.22.0 to 2.25.0
                    git fetch rc=0
                    On branch master
                    Your branch is behind ‘origin/master’ by 3 commits, and can be fast-forwarded.
                    Untracked files:
                    core
                    css/save_custom.css
                    installers/stashed_files
                    run-start.sh
                    installers/mm.sh
                    erasing lock files
                    Saved working directory and index state WIP on master: f14e9561 Create Thai Language file (#3028)
                    no modules found needing npm refresh
                    removing git alias
                    On branch master
                    Untracked files:
                    core
                    run-start.sh
                    Dropped refs/stash@{0} (c813d55595387ff98151af075aa3d1f202d8f8c3)
                    Upgrade ended - Tue Oct 24 13:57:34 BST 2023
                    Upgrade started - Tue Oct 24 13:57:52 BST 2023
                    Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (20.5.1-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease
                    Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                    pm2 installed, checking version 5.3.0 vs 5.3.0
                    changed 157 packages in 15s
                    [PM2] MagicMirror ✓
                    PM2 updated
                      DarkV @sdetweil
                      saving custom.css
                      git fetch rc=0
                      On branch master
                      Untracked files:
                      core
                      css/save_custom.css
                      run-start.sh
                      installers/mm.sh
                      package-lock.json
                      erasing lock files
                      removing git alias
                      On branch master
                      Untracked files:
                      core
                      run-start.sh
                      saving custom.css
                      git fetch rc=0
                      On branch master
                      Untracked files:
                      core
                      css/save_custom.css
                      run-start.sh
                      installers/mm.sh
                      erasing lock files
                      merge result rc= 0
                      2 ± CHANGELOG.md
                      100 ± LICENSE.md
                      2 ± css/main.css
                      Installing fonts …
                      removing git alias
                      npm notice
                      npm notice
                      old : /usr/bin/node
                      $ pm2 update
                                    https://pm2.io/
                                      $ pm2 plus
                      [PM2] MagicMirror ✓
                      PM2 updated
                      saving custom.css
                      git fetch rc=0
                      On branch master
                      Untracked files:
                      core
                      css/save_custom.css
                      run-start.sh
                      installers/mm.sh
                      erasing lock files
                      removing git alias
                      On branch master
                      Untracked files:
                      core
                      run-start.sh
                      [PM2] MagicMirror ✓
                      PM2 updated
                        sdetweil @DarkV
                        @DarkV said in Failed Update:
                        that is not in my repo currently
                        did you git clone the MagicMirror_scripts repo and are executing from the clone??
                        don’t do that… execute by copy/paste the lines on the github page
                        • 1 / 5
