Failed Update
I tried to Update my wife’s mirror and got this error ( I tried to stop MM with no success as It is still running)
Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Oct 17 13:12:23 2023
junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
bash: line 117: [: !=: unary operator expecteddoing test run = true, NO updates will be applied!
update log will be in /home/junior/MagicMirror/installers/upgrade.log
Check current Node installation …
Minimum Node version: v20.8.0
Installed Node version: v16.20.2
Node should be upgraded.
A Node process is currently running. Can’t upgrade.
Please quit all Node processes and restart the update.
running process(s) are
junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
junior@MAGIC-MIRROR:~ $.js
junior@MAGIC-MIRROR:~ $ ^C
junior@MAGIC-MIRROR:~ $ pm2 stop mm -
@sdetweil I did this
sudo apt-get remove nodejs npm -y
hash -r
which node
which nif which n response with empty then do
sudo apt-get install n
once n responds then
sudo n 20.8.0 --arch armv7l
hash -r
node -vThen both scripts and it went through!
@DarkV bug in the script please run again
note it’s a two step process
- test, make no changes
- actually do changes
@DarkV said in Failed Update:
I have fixed this in the upgrade-script.sh
(and another similar) -
@sdetweil Wil try again, I tried it a week ago and it failed to start after the update with a failed to update .json. I had to restore from a previous image. I will try again.
I will report back -
Here is the log and a failed update again
pgrade started - Sun Oct 2 10:41:43 BST 2022 system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye doing test run = true, NO updates will be applied! [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv16.9.1[0m [0mInstalled Node version: [1mv16.17.1[0m [92mNo Node.js upgrade necessary.[0m [96mCheck current NPM installation ...[0m [0mNPM currently installed. Checking version number. [0mMinimum npm version: [1mV7.11.2[0m [0mInstalled npm version: [1mV8.15.0[0m [92mNo npm upgrade necessary.[0m saving custom.css remote name = origin upgrading from version 2.20.0 to 2.21.0 fetching latest revisions git fetch rc=0 current branch = master On branch master Your branch is behind 'origin/master' by 4694 commits, and can be fast-forwarded. (use "git pull" to update your local branch) Changes not staged for commit: (use "git add <file>..." to update what will be committed) (use "git restore <file>..." to discard changes in working directory) modified: installers/mm.sh modified: package-lock.json Untracked files: (use "git add <file>..." to include in what will be committed) 0 core css/save_custom.css installers/mm_temp.sh installers/pm2_MagicMirror.json installers/pm2_MagicMirror_new.json run-start.sh no changes added to commit (use "git add" and/or "git commit -a") there are 2 local files that are different than the master repo installers/mm.sh package-lock.json save/restore files selection = y erasing lock files Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop test merge result rc='' , if empty, no conflicts skipping merge, only test run Checking for modules with removed libraries downloading dumpactivemodules script processing dependency changes for active modules with package.json files processing for module MMM-Tools please wait ---------------------------------- skipped processing for MMM-Tools, doing test run processing complete for module MMM-Tools restoring custom.css removing git alias test run, restoring files stashed Removing vendor/package-lock.json Removing package-lock.json Removing fonts/package-lock.json On branch master Your branch is behind 'origin/master' by 4694 commits, and can be fast-forwarded. (use "git pull" to update your local branch) Changes not staged for commit: (use "git add/rm <file>..." to update what will be committed) (use "git restore <file>..." to discard changes in working directory) deleted: fonts/package-lock.json modified: installers/mm.sh deleted: package-lock.json deleted: vendor/package-lock.json Untracked files: (use "git add <file>..." to include in what will be committed) 0 core installers/mm_temp.sh installers/pm2_MagicMirror.json installers/pm2_MagicMirror_new.json run-start.sh no changes added to commit (use "git add" and/or "git commit -a") Dropped refs/stash@{0} (0640a953f8283b8d55b598386c17d310f8a75680) Upgrade ended - Sun Oct 2 10:41:58 BST 2022 Upgrade started - Sun Oct 2 10:42:15 BST 2022 system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye user requested to apply changes doing test run = false [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv16.9.1[0m [0mInstalled Node version: [1mv16.17.1[0m [92mNo Node.js upgrade necessary.[0m [96mCheck current NPM installation ...[0m [0mNPM currently installed. Checking version number. [0mMinimum npm version: [1mV7.11.2[0m [0mInstalled npm version: [1mV8.15.0[0m [92mNo npm upgrade necessary.[0m saving custom.css remote name = origin upgrading from version 2.20.0 to 2.21.0 fetching latest revisions git fetch rc=0 current branch = master On branch master Your branch is behind 'origin/master' by 4694 commits, and can be fast-forwarded. (use "git pull" to update your local branch) Changes not staged for commit: (use "git add/rm <file>..." to update what will be committed) (use "git restore <file>..." to discard changes in working directory) deleted: fonts/package-lock.json modified: installers/mm.sh deleted: package-lock.json deleted: vendor/package-lock.json Untracked files: (use "git add <file>..." to include in what will be committed) 0 core css/save_custom.css installers/mm_temp.sh installers/pm2_MagicMirror.json installers/pm2_MagicMirror_new.json run-start.sh no changes added to commit (use "git add" and/or "git commit -a") there are 1 local files that are different than the master repo installers/mm.sh save/restore files selection = y erasing lock files Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop test merge result rc='' , if empty, no conflicts executing merge, apply specified merge result rc= 0 Updating 30d5bfe5..9e029304 Fast-forward .github/ISSUE_TEMPLATE.md 4 +- .github/workflows/automated-tests.yaml 4 +- .github/workflows/codecov-test-suites.yaml 2 +- CHANGELOG.md 100 +- LICENSE.md 2 +- css/main.css 18 +- fonts/package-lock.json 28 +- fonts/package.json 4 +- js/node_helper.js 17 +- modules/default/calendar/README.md 0 modules/default/calendar/calendar.js 21 +- modules/default/calendar/calendarutils.js 37 +- modules/default/calendar/node_helper.js 8 + modules/default/currentweather/currentweather.js 33 - modules/default/defaultmodules.js 2 +- modules/default/newsfeed/newsfeedfetcher.js 13 + modules/default/weather/README.md 2 +- modules/default/weather/current.njk 0 modules/default/weather/providers/README.md 0 modules/default/weather/providers/darksky.js 0 .../default/weather/providers/openweathermap.js 0 modules/default/weather/providers/smhi.js 61 +- modules/default/weather/providers/ukmetoffice.js 0 modules/default/weather/providers/weatherbit.js 26 +- modules/default/weather/providers/weathergov.js 0 modules/default/weather/weatherobject.js 0 modules/default/weatherforecast/weatherforecast.js 33 - package-lock.json 3885 +++++++++++--------- package.json 38 +- tests/configs/data/calendar_test_recurring.ics 2 +- tests/e2e/env_spec.js 17 +- tests/e2e/global-setup.js 57 +- tests/e2e/modules/alert_spec.js 9 +- tests/e2e/modules/calendar_spec.js 111 +- tests/e2e/modules/clock_es_spec.js 47 +- tests/e2e/modules/clock_spec.js 77 +- tests/e2e/modules/compliments_spec.js 60 +- tests/e2e/modules/helloworld_spec.js 18 +- tests/e2e/modules/newsfeed_spec.js 48 +- tests/e2e/modules/weather_spec.js 225 +- tests/e2e/modules_display_spec.js 10 +- tests/e2e/modules_position_spec.js 9 +- tests/e2e/translations_spec.js 6 +- tests/e2e/without_modules.js 12 +- .../__snapshots__/updatenotification_spec.js.snap 6 +- translations/en.json 1 - vendor/package-lock.json 42 +- vendor/package.json 6 +- vendor/vendor.js 0 49 files changed, 2858 insertions(+), 2243 deletions(-) mode change 100755 => 100644 modules/default/calendar/README.md mode change 100755 => 100644 modules/default/calendar/calendar.js delete mode 100644 modules/default/currentweather/currentweather.js mode change 100755 => 100644 modules/default/weather/README.md mode change 100755 => 100644 modules/default/weather/current.njk mode change 100755 => 100644 modules/default/weather/providers/README.md mode change 100755 => 100644 modules/default/weather/providers/darksky.js mode change 100755 => 100644 modules/default/weather/providers/openweathermap.js mode change 100755 => 100644 modules/default/weather/providers/ukmetoffice.js mode change 100755 => 100644 modules/default/weather/providers/weathergov.js mode change 100755 => 100644 modules/default/weather/weatherobject.js delete mode 100644 modules/default/weatherforecast/weatherforecast.js mode change 100755 => 100644 vendor/package.json mode change 100755 => 100644 vendor/vendor.js processor architecture is armv7l updating MagicMirror runtime, please wait npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options npm WARN invalid config Must be one or more of: dev, optional, peer > magicmirror@2.21.0 postinstall > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully! > " > magicmirror@2.21.0 install-vendor > echo "Installing vendor files ... > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing vendor files ... changed 3 packages in 9s > magicmirror@2.21.0 install-fonts > echo "Installing fonts ... > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier Installing fonts ... changed 2 packages in 4s MagicMirror² installation finished successfully! > magicmirror@2.21.0 prepare > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed. husky - Git hooks installed added 455 packages, removed 3 packages, changed 13 packages, and audited 754 packages in 3m 91 packages are looking for funding run `npm fund` for details 3 moderate severity vulnerabilities To address all issues (including breaking changes), run: npm audit fix --force Run `npm audit` for details. npm install completed - Sun Oct 2 10:45:27 BST 2022 on base fixing sandbox permissions Checking for modules with removed libraries downloading dumpactivemodules script processing dependency changes for active modules with package.json files processing for module MMM-Tools please wait ---------------------------------- npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options npm WARN invalid config Must be one or more of: dev, optional, peer added 3 packages, and audited 4 packages in 3s 1 package is looking for funding run `npm fund` for details found 0 vulnerabilities processing complete for module MMM-Tools restoring custom.css removing git alias we stashed a set of files that appear changed from the latest repo versions. you should review them Upgrade ended - Sun Oct 2 10:45:33 BST 2022 Upgrade started - Tue Oct 17 12:57:21 BST 2023 system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye doing test run = true, NO updates will be applied! [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv20.8.0[0m [0mInstalled Node version: [1mv16.20.2[0m [96mNode should be upgraded.[0m [91mA Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. junior 18317 18316 0 Oct07 0 00:00:00 node ./node_modules/.bin/electron js/electron.js Upgrade started - Tue Oct 17 12:58:30 BST 2023 system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye doing test run = true, NO updates will be applied! [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv20.8.0[0m [0mInstalled Node version: [1mv16.20.2[0m [96mNode should be upgraded.[0m [91mA Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. junior 8378 8377 5 12:58 0 00:00:00 node ./node_modules/.bin/electron js/electron.js Upgrade started - Tue Oct 17 13:04:45 BST 2023 system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye doing test run = true, NO updates will be applied! [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv20.8.0[0m [0mInstalled Node version: [1mv16.20.2[0m [96mNode should be upgraded.[0m [91mA Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. junior 8378 8377 0 12:58 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js Upgrade started - Sun Oct 22 09:24:16 BST 2023 system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye doing test run = true, NO updates will be applied! [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv20.8.0[0m [0mInstalled Node version: [1mv16.20.2[0m [96mNode should be upgraded.[0m [91mA Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js Upgrade started - Tue Oct 24 11:04:00 BST 2023 system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye n (node version manager tool) not installed, doing test run, install skipped doing test run = true, NO updates will be applied! [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. [0mMinimum Node version: [1mv20.8.0[0m [0mInstalled Node version: [1mv16.20.2[0m [96mNode should be upgraded.[0m [91mA Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js Upgrade started - Tue Oct 24 11:04:44 BST 2023 system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux user requested to apply changes the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye added 1 package, and audited 2 packages in 2s found 0 vulnerabilities npm notice npm notice New major version of npm available! 8.19.4 -> 10.2.1 npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.2.1> npm notice Run `npm install -g npm@10.2.1` to update! npm notice installing : node-v20.8.0 mkdir : /usr/local/n/versions/node/20.8.0 fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-arm64.tar.xz copying : node/20.8.0 installed : (with npm 10.1.0) Note: the node command changed location and the old location may be remembered in your current shell. old : /usr/bin/node new : /usr/local/bin/node If "node --version" shows the old version then start a new shell, or reset the location hash with: hash -r (for bash, zsh, ash, dash, and ksh) rehash (for csh and tcsh) doing test run = false [96mCheck current Node installation ...[0m [0mNode currently installed. Checking version number. forcing low Node version [0mMinimum Node version: [1mv20.8.0[0m [0mInstalled Node version: [1mV1.0.0[0m [96mNode should be upgraded.[0m [91mA Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js Node currently installed. Checking version number. Minimum Node version: v20.8.0 Installed Node version: v16.20.2 Node should be upgraded. A Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. running process(s) are junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electro n.js junior@MAGIC-MIRROR:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/s detweil/MagicMirror_scripts/master/upgrade-script.sh)" apply npm WARN cli npm v10.1.0 does not support Node.js v16.20.2. This version of npm supports the following node versions: `^18.17.0 || >=20.5.0`. You can find the l atest version at https://nodejs.org/. /usr/bin/n: line 746: /usr/local/bin/node: No such file or directory doing test run = false update log will be in /home/junior/MagicMirror/installers/upgrade.log Check current Node installation ... Node currently installed. Checking version number. apply: line 207: /usr/local/bin/node: No such file or directory Minimum Node version: v20.8.0 Installed Node version: V1.0.0 Node should be upgraded. A Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. running process(s) are junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electro n.js junior@MAGIC-MIRROR:~ $ -
@DarkV you have to stop your running mm first
pm2 stop all
@sdetweil said in Failed Update:
pm2 stop all
I can now update because that worked—many thanks for your assistance.
@DarkV were u able to update successfully?
@sdetweil it goes through the update process successfully, but on the mirror, it still reports that it is 3 updates behind upon reboot
