    Failed Update
    45 Posts 3 Posters 18.4k Views 3 Watching
      sdetweil @DarkV
      @DarkV oh such joy
      sudo n ls
      sudo n prune
      sudo n uninstall
      hash -r
      which node
        DarkV @sdetweil
        @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
        login as: junior
        junior@192.168.2.52’s password:
        Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Tue Oct 31 12:51:37 2023
        junior@MAGIC-MIRROR:~ $ hash -r
        junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
        Reading package lists… Done
        Building dependency tree… Done
        Reading state information… Done
        Package ‘npm’ is not installed, so not removed
        libfuse2 raspinfo
        Use ‘sudo apt autoremove’ to remove them.
        The following packages will be REMOVED:
        nodejs
        0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
        After this operation, 183 MB disk space will be freed.
        (Reading database … 108415 files and directories currently installed.)
        Removing nodejs (20.5.1-deb-1nodesource1) …
        dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
        Processing triggers for man-db (2.9.4-2) …
        junior@MAGIC-MIRROR:~ $ node -v
        -bash: /usr/local/bin/node: No such file or directory
        junior@MAGIC-MIRROR:~ $ which node
        /usr/local/bin/node
        junior@MAGIC-MIRROR:~ $ ^C
        junior@MAGIC-MIRROR:~ $ sudo n ls
        node/20.8.0
        junior@MAGIC-MIRROR:~ $ sudo n prune
        /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
        node/20.8.0
        junior@MAGIC-MIRROR:~ $ sudo n uninstall
        Do you wish to delete node and npm from /usr/local? y
        Uninstalling node and npm
        /usr/local/bin/node
        /usr/local/bin/npm
        /usr/local/bin/npx
        /usr/local/bin/corepack
        /usr/local/include/node
        /usr/local/lib/node_modules/npm
        /usr/local/lib/node_modules/corepack
        /usr/local/share/doc/node
        /usr/local/share/man/man1/node.1
        which node
          sdetweil @DarkV
          @DarkV ok,
          two more commands for info before running
          lsb_release -a
          file /bin/bash
          NOW try to run my upgrade script… note that it will NOT install node in test mode…
          so you have to use the second link that adds the apply parm
            DarkV @sdetweil
            @sdetweil said in Failed Update:
            file /bin/bash
            unior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
            curl: (18) transfer closed with 23780100 bytes remaining to read
            xz: (stdin): Unexpected end of input
            tar: Unexpected EOF in archive
            tar: Error is not recoverable: exiting now
            Error: failed to download archive for 20.8.0
            doing test run = false
            update log will be in /home/junior/MagicMirror/installers/upgrade.log
            Check current Node installation …
            Minimum Node version: v20.8.0
            Installed Node version: v20.5.1
            Node should be upgraded.
            Installing Node.js …
            nodejs is already the newest version (20.5.1-deb-1nodesource1).
            libfuse2 raspinfo
            node version is
            Node.js installation Done! version=v20.5.1
            npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
              sdetweil @DarkV
              @DarkV man this is a pain
              one more try
              hash -r
              which node
              which n
              if which n response with empty then do
              sudo apt-get install n
              once n responds then
              sudo n 20.8.0	--arch armv7l
              hash -r
              node -v
              should say V20.8.0
              i notice that I didn’t copy this little part from the install script…
              please let me know
              S D 2 Replies Last reply Reply Quote 0
                @DarkV never mind that won’t work… need node and npm to install n… grr…
                ok, only way out is to redo the sd card
                backup your MM
                see https://github.com/sdetweil/MagicMirror-backup-restore
                copy the backup folder MM_backup off the sd card (it can save to github too)
                reflash the sd card with latest os
                boot, no updates,
                run install script to install MM
                verify it runs
                restore your config using my restore script (can restore directly from github too)
                test
                sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.
                  DarkV @sdetweil
                  @sdetweil All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.
                  You have brought me happiness and protected me from madness. That’s a significant victory.Screenshot 2023-10-31 135119.png
                    @DarkV before you jump off the bridge! try this
                    hash -r
                    make sure gone
                    which node
                    then
                    sudo apt-get install nodejs:armv7l
                    node -v
                      DarkV @sdetweil
                      @sdetweil I don’t know what happened, but the reply is above. Many thanks
                        sdetweil @DarkV
                        @DarkV cool… i didn’t expect that it, i’m glad!!
                          DarkV @sdetweil
                          @sdetweil I did this
                          hash -r
                          which node
                          which n
                          hash -r
                          node -v
                          Then both scripts and it went through!
                            sdetweil @DarkV
                            @DarkV said in Failed Update:
                            –arch armv7l
                            awesome… it was that sneaky little --arch parm…
                            fixing upgrade script now . sorry for your troubles
                              DarkV @sdetweil
                              @sdetweil No worries, thanks you for your time
                                sdetweil @DarkV
                                @DarkV any chance you still have the os image file you are running
                                the info says (from the upgrade.log)
                                6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                only one I can find online says
                                6.1.21-v7+
                                trying to test fix for the problem you encountered.
                                if you still have the image file can you give me its name…
                                also, what pi is this, 3 or 4?
                                thanks
                                | edit: was able to make one
                                | install bullseye armhf
                                | edit /boot/config.txt
                                add
                                arm_64bit=1
                                then u will boot 64bit kernel, (seen with uname -a, aarch64)
                                Linux raspberrypi4 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                                and have 32 bit runtime (seen with file /bin/bash
                                /bin/bash: ELF 32-bit LSB executable
                                lavolp3L D 2 Replies Last reply Reply Quote 0
                                • lavolp3L Offline
                                  Sam, I did an update yesterday and found Node 20.8 not working on my raspbian bullseye install.
                                  I had an issue mentioned by someone else here before referring a missing GLIBCXX_3.4.26 file.
                                  I needed to purge and install node 18.x. Then it worked.
                                  Possible that this happens for more users with Raspbian
                                  Bullseye.
                                  I see your upgrade script requests Node 20.8.
                                  Not sure if that may be an issue for other people as well?
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                    sdetweil @lavolp3
                                    @lavolp3 can u send me the ~/MagicMirror/installers/upgrade.log
                                    so I can see what happened…
                                    same userid at gmail
                                      sdetweil @lavolp3
                                      @lavolp3 I check for buster and downgrade to node 18… not bullseye…
                                      interested to see the log…
                                      • lavolp3L Offline
                                        @sdetweil Sorry I have BUSTER installed. My mistake.
                                        Here the lastlog
                                        Upgrade started - Wed Nov  1 10:25:06 CET 2023
                                        system is Linux magicmirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                        n (node version manager tool) not installed, doing test run, install skipped
                                        Minimum Node version: v18.18.0
                                        Installed Node version: v16.20.2
                                        Upgrade started - Wed Nov  1 10:45:19 CET 2023
                                        user requested to force apply changes
                                        node not installed, trying via apt-get
                                        Reading package lists... Building dependency tree... Reading state information... nodejs is already the newest version (20.9.0-1nodesource1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        npm not installed, trying via apt-get
                                        npm NOT installed now, install now
                                        Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: npm : Depends: nodejs (>= 6.11~) Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed Depends: node-aproba (>= 1.2~) but it is not going to be installed Depends: node-archy (>= 1.0~) but it is not going to be installed Depends: node-cacache (>= 10.0.4~) but it is not going to be installed Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed Depends: node-call-limit (>= 1.1~) but it is not going to be installed Depends: node-chownr (>= 1.0.1~) but it is not going to be installed Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed Depends: node-detect-indent (>= 5.0~) but it is not going to be installed Depends: node-detect-newline (>= 2.1~) but it is not going to be installed Depends: node-editor (>= 1.0~) but it is not going to be installed Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed Depends: node-glob (>= 7.1.2~) but it is not going to be installed Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed Depends: node-iferr (>= 0.1.5~) but it is not going to be installed Depends: node-inflight (>= 1.0.6~) but it is not going to be installed Depends: node-inherits (>= 2.0.3~) but it is not going to be installed Depends: node-ini (>= 1.3.5~) but it is not going to be installed Depends: node-npm-package-arg but it is not going to be installed Depends: node-promzard but it is not going to be installed Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed Depends: node-lazy-property (>= 1.0~) but it is not going to be installed Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed Depends: node-mississippi (>= 3.0~) but it is not going to be installed Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed Depends: node-nopt but it is not going to be installed Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed Depends: node-gyp (>= 3.6.2~) but it is not going to be installed Depends: node-resolve-from (>= 4.0~) but it is not going to be installed Depends: node-encoding but it is not going to be installed Depends: node-errno but it is not going to be installed Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed Depends: node-once (>= 1.4~) but it is not going to be installed Depends: node-opener (>= 1.4.3~) but it is not going to be installed Depends: node-osenv (>= 0.1.5~) but it is not going to be installed Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed Depends: node-ansi but it is not going to be installed Depends: node-qw (>= 1.0.1~) but it is not going to be installed Depends: node-read (>= 1.0.7~) but it is not going to be installed Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed Depends: node-request (>= 2.83~) but it is not going to be installed Depends: node-retry (>= 0.10.1~) but it is not going to be installed Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed Depends: node-semver (>= 5.5~) but it is not going to be installed Depends: node-sha (>= 2.0.1~) but it is not going to be installed Depends: node-slide (>= 1.1.6~) but it is not going to be installed Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed Depends: node-from2 but it is not going to be installed Depends: node-stream-iterate but it is not going to be installed Depends: node-ssri (>= 5.2.4~) but it is not going to be installed Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed Depends: node-tar (>= 4.4~) but it is not going to be installed Depends: node-text-table (>= 0.2~) but it is not going to be installed Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed Depends: node-unique-filename (>= 1.1~) but it is not going to be installed Depends: node-unpipe (>= 1.0~) but it is not going to be installed Depends: node-boxen (>= 1.2.1~) but it is not going to be installed Depends: node-import-lazy but it is not going to be installed Depends: node-is-npm (>= 1.0~) but it is not going to be installed Depends: node-latest-version (>= 3.0~) but it is not going to be installed Depends: node-semver-diff (>= 2.0~) but it is not going to be installed Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed Depends: node-which (>= 1.3~) but it is not going to be installed Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
                                        forcing low Node version
                                        Installed Node version: V1.0.0
                                        That was the last failed upgrade. Node V1.0.0 lol. Node 20 was installed.
                                        After that I manually purged Node, installed Node 18 and did the npm run install-mm
                                          sdetweil @lavolp3
                                          @lavolp3 ok, can you do
                                          sudo apt update --fix-missing
                                          sudo apt install -f
                                          watch out for node changing…
                                          • lavolp3L Offline
                                            @sdetweil Sam, sorry for the confusion, everything is working. A said I had installed node 18 and then it all worked. I didn’t need help, just wanted to point out that node 20 seems to not be working with some systems. But as I see you got that covered in your script.
                                            • 2 / 3
