    Failed Update
    45 Posts 3 Posters 18.4k Views 3 Watching
      @DarkV before you jump off the bridge! try this
      sudo apt-get remove nodejs npm -y
      hash -r
      make sure gone
      which node
      then
      sudo apt-get install nodejs:armv7l
      node -v
        DarkV @sdetweil
        @sdetweil I don’t know what happened, but the reply is above. Many thanks
          sdetweil @DarkV
          @DarkV cool… i didn’t expect that it, i’m glad!!
            DarkV @sdetweil
            @sdetweil I did this
            hash -r
            which node
            which n
            if which n response with empty then do
            once n responds then
            sudo n 20.8.0 --arch armv7l
            hash -r
            node -v
            Then both scripts and it went through!
              sdetweil @DarkV
              @DarkV said in Failed Update:
              –arch armv7l
              awesome… it was that sneaky little --arch parm…
              fixing upgrade script now . sorry for your troubles
                DarkV @sdetweil
                @sdetweil No worries, thanks you for your time
                  sdetweil @DarkV
                  @DarkV any chance you still have the os image file you are running
                  the info says (from the upgrade.log)
                  6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                  only one I can find online says
                  6.1.21-v7+
                  trying to test fix for the problem you encountered.
                  if you still have the image file can you give me its name…
                  also, what pi is this, 3 or 4?
                  thanks
                  | edit: was able to make one
                  | install bullseye armhf
                  | edit /boot/config.txt
                  add
                  arm_64bit=1
                  then u will boot 64bit kernel, (seen with uname -a, aarch64)
                  Linux raspberrypi4 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                  and have 32 bit runtime (seen with file /bin/bash
                  /bin/bash: ELF 32-bit LSB executable
                  lavolp3L D 2 Replies Last reply Reply Quote 0
                  • lavolp3L Offline
                    Sam, I did an update yesterday and found Node 20.8 not working on my raspbian bullseye install.
                    I had an issue mentioned by someone else here before referring a missing GLIBCXX_3.4.26 file.
                    I needed to purge and install node 18.x. Then it worked.
                    Possible that this happens for more users with Raspbian
                    Bullseye.
                    I see your upgrade script requests Node 20.8.
                    Not sure if that may be an issue for other people as well?
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                      sdetweil @lavolp3
                      @lavolp3 can u send me the ~/MagicMirror/installers/upgrade.log
                      so I can see what happened…
                      same userid at gmail
                        sdetweil @lavolp3
                        @lavolp3 I check for buster and downgrade to node 18… not bullseye…
                        interested to see the log…
                        • lavolp3L Offline
                          @sdetweil Sorry I have BUSTER installed. My mistake.
                          Here the lastlog
                          Upgrade started - Wed Nov  1 10:25:06 CET 2023
                          system is Linux magicmirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                          n (node version manager tool) not installed, doing test run, install skipped
                          Minimum Node version: v18.18.0
                          Installed Node version: v16.20.2
                          Node should be upgraded.
                          Upgrade started - Wed Nov  1 10:45:19 CET 2023
                          user requested to force apply changes
                          node not installed, trying via apt-get
                          Reading package lists... Building dependency tree... Reading state information... nodejs is already the newest version (20.9.0-1nodesource1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          npm not installed, trying via apt-get
                          npm NOT installed now, install now
                          Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: npm : Depends: nodejs (>= 6.11~) Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed Depends: node-aproba (>= 1.2~) but it is not going to be installed Depends: node-archy (>= 1.0~) but it is not going to be installed Depends: node-cacache (>= 10.0.4~) but it is not going to be installed Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed Depends: node-call-limit (>= 1.1~) but it is not going to be installed Depends: node-chownr (>= 1.0.1~) but it is not going to be installed Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed Depends: node-detect-indent (>= 5.0~) but it is not going to be installed Depends: node-detect-newline (>= 2.1~) but it is not going to be installed Depends: node-editor (>= 1.0~) but it is not going to be installed Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed Depends: node-glob (>= 7.1.2~) but it is not going to be installed Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed Depends: node-iferr (>= 0.1.5~) but it is not going to be installed Depends: node-inflight (>= 1.0.6~) but it is not going to be installed Depends: node-inherits (>= 2.0.3~) but it is not going to be installed Depends: node-ini (>= 1.3.5~) but it is not going to be installed Depends: node-npm-package-arg but it is not going to be installed Depends: node-promzard but it is not going to be installed Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed Depends: node-lazy-property (>= 1.0~) but it is not going to be installed Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed Depends: node-mississippi (>= 3.0~) but it is not going to be installed Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed Depends: node-nopt but it is not going to be installed Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed Depends: node-gyp (>= 3.6.2~) but it is not going to be installed Depends: node-resolve-from (>= 4.0~) but it is not going to be installed Depends: node-encoding but it is not going to be installed Depends: node-errno but it is not going to be installed Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed Depends: node-once (>= 1.4~) but it is not going to be installed Depends: node-opener (>= 1.4.3~) but it is not going to be installed Depends: node-osenv (>= 0.1.5~) but it is not going to be installed Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed Depends: node-ansi but it is not going to be installed Depends: node-qw (>= 1.0.1~) but it is not going to be installed Depends: node-read (>= 1.0.7~) but it is not going to be installed Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed Depends: node-request (>= 2.83~) but it is not going to be installed Depends: node-retry (>= 0.10.1~) but it is not going to be installed Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed Depends: node-semver (>= 5.5~) but it is not going to be installed Depends: node-sha (>= 2.0.1~) but it is not going to be installed Depends: node-slide (>= 1.1.6~) but it is not going to be installed Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed Depends: node-from2 but it is not going to be installed Depends: node-stream-iterate but it is not going to be installed Depends: node-ssri (>= 5.2.4~) but it is not going to be installed Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed Depends: node-tar (>= 4.4~) but it is not going to be installed Depends: node-text-table (>= 0.2~) but it is not going to be installed Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed Depends: node-unique-filename (>= 1.1~) but it is not going to be installed Depends: node-unpipe (>= 1.0~) but it is not going to be installed Depends: node-boxen (>= 1.2.1~) but it is not going to be installed Depends: node-import-lazy but it is not going to be installed Depends: node-is-npm (>= 1.0~) but it is not going to be installed Depends: node-latest-version (>= 3.0~) but it is not going to be installed Depends: node-semver-diff (>= 2.0~) but it is not going to be installed Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed Depends: node-which (>= 1.3~) but it is not going to be installed Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
                          doing test run = false
                          forcing low Node version
                          Installed Node version: V1.0.0
                          That was the last failed upgrade. Node V1.0.0 lol. Node 20 was installed.
                          After that I manually purged Node, installed Node 18 and did the npm run install-mm
                            sdetweil @lavolp3
                            @lavolp3 ok, can you do
                            sudo apt update --fix-missing
                            sudo apt install -f
                            watch out for node changing…
                            • lavolp3L Offline
                              @sdetweil Sam, sorry for the confusion, everything is working. A said I had installed node 18 and then it all worked. I didn’t need help, just wanted to point out that node 20 seems to not be working with some systems. But as I see you got that covered in your script.
                                DarkV @sdetweil
                                @sdetweil The Image was my previous install I made in February when I migrated from SD to M2 SSD. So an older version of what I am using now.
                                I am using PI4.
                                  sdetweil @DarkV
                                  @DarkV thanks
                                    DarkV @sdetweil
                                    @sdetweil My image is 112GB (although only 8.4 GB is used) as I used Win32 disc imager software. If you still want me to upload let me know although I don’t know a site that will allow a file that large.
                                    S D 2 Replies Last reply Reply Quote 0
                                      sdetweil @DarkV
                                      @DarkV Thanks. I found a way to create the hybrid system so I could test your original.problem…
                                        DarkV @DarkV
                                        @DarkV Sorry to bug you again, but there is an update, since you said that my setup in a Hybrid setup, what script do I use? The wifey will kill me if I mess it up and for some reason I cannot backup my M2 Sata drive with Windows 11 as it is not detected, meaning I have one shot to get it right
                                          sdetweil @DarkV
                                          @DarkV I think I have fixed the upgrade script.
                                          of course backup your mm system,
                                          use my backup restore scripts.
                                          https://github.com/sdetweil/MagicMirror-backup-restore
                                          if you have space, copy the entire mm folder to another to save it.
                                          don’t upgrade if there is nothing you need
                                            DarkV @sdetweil
                                            @sdetweil Many thanks. Will backup the system before I try.
                                            • 2 / 3
