    Failed Update
    45 Posts 3 Posters 18.4k Views 3 Watching
      DarkV @sdetweil
      Upgrade started - Sun Oct 2 10:41:43 BST 2022
      system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
      Check current Node installation …
      Minimum Node version: v16.9.1
      Installed Node version: v16.17.1
      No Node.js upgrade necessary.
      Check current NPM installation …
      Minimum npm version: V7.11.2
      Installed npm version: V8.15.0
      No npm upgrade necessary.
      saving custom.css
      remote name = origin
      upgrading from version 2.20.0 to 2.21.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is behind ‘origin/master’ by 4694 commits, and can be fast-forwarded.
      (use “git pull” to update your local branch)
      (use “git add …” to update what will be committed)
      (use “git restore …” to discard changes in working directory)
      modified: installers/mm.sh
      modified: package-lock.json
      Untracked files:
      (use “git add …” to include in what will be committed)
      core
      css/save_custom.css
      installers/mm_temp.sh
      installers/pm2_MagicMirror.json
      installers/pm2_MagicMirror_new.json
      run-start.sh
      no changes added to commit (use “git add” and/or “git commit -a”)
      there are 2 local files that are different than the master repo
      installers/mm.sh
      package-lock.json
      save/restore files selection = y
      erasing lock files
      Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop
      test merge result rc=‘’ , if empty, no conflicts
      skipping merge, only test run
      downloading dumpactivemodules script
      processing for module MMM-Tools please wait
      skipped processing for MMM-Tools, doing test run
      processing complete for module MMM-Tools
      restoring custom.css
      removing git alias
      test run, restoring files stashed
      Removing vendor/package-lock.json
      Removing package-lock.json
      Removing fonts/package-lock.json
      On branch master
      (use “git add/rm …” to update what will be committed)
      deleted: fonts/package-lock.json
      deleted: package-lock.json
      deleted: vendor/package-lock.json
      Untracked files:
      core
      run-start.sh
      Dropped refs/stash@{0} (0640a953f8283b8d55b598386c17d310f8a75680)
      Upgrade ended - Sun Oct 2 10:41:58 BST 2022
      Upgrade started - Sun Oct 2 10:42:15 BST 2022
      user requested to apply changes
      doing test run = false
      saving custom.css
      git fetch rc=0
      On branch master
      Untracked files:
      core
      css/save_custom.css
      run-start.sh
      there are 1 local files that are different than the master repo
      installers/mm.sh
      erasing lock files
      executing merge, apply specified
      merge result rc= 0
      Updating 30d5bfe5…9e029304 Fast-forward .github/ISSUE_TEMPLATE.md
      4 ± .github/workflows/automated-tests.yaml
      4 ± .github/workflows/codecov-test-suites.yaml
      2 ± CHANGELOG.md
      100 ± LICENSE.md
      2 ± css/main.css
      18 ± fonts/package-lock.json
      28 ± fonts/package.json
      4 ± js/node_helper.js
      17 ± modules/default/calendar/README.md
      0 modules/default/calendar/calendar.js
      21 ± modules/default/calendar/calendarutils.js
      37 ± modules/default/calendar/node_helper.js
      8 + modules/default/currentweather/currentweather.js
      33 - modules/default/defaultmodules.js
      2 ± modules/default/newsfeed/newsfeedfetcher.js
      13 + modules/default/weather/README.md
      2 ± modules/default/weather/current.njk
      0 modules/default/weather/providers/README.md
      0 modules/default/weather/providers/darksky.js
      0 …/default/weather/providers/openweathermap.js
      0 modules/default/weather/providers/smhi.js
      61 ± modules/default/weather/providers/ukmetoffice.js
      0 modules/default/weather/providers/weatherbit.js
      26 ± modules/default/weather/providers/weathergov.js
      0 modules/default/weather/weatherobject.js
      0 modules/default/weatherforecast/weatherforecast.js
      33 - package-lock.json
      3885 ++++++++++±-------- package.json
      38 ± tests/configs/data/calendar_test_recurring.ics
      2 ± tests/e2e/env_spec.js
      17 ± tests/e2e/global-setup.js
      57 ± tests/e2e/modules/alert_spec.js
      9 ± tests/e2e/modules/calendar_spec.js
      111 ± tests/e2e/modules/clock_es_spec.js
      47 ± tests/e2e/modules/clock_spec.js
      77 ± tests/e2e/modules/compliments_spec.js
      60 ± tests/e2e/modules/helloworld_spec.js
      18 ± tests/e2e/modules/newsfeed_spec.js
      48 ± tests/e2e/modules/weather_spec.js
      225 ± tests/e2e/modules_display_spec.js
      10 ± tests/e2e/modules_position_spec.js
      9 ± tests/e2e/translations_spec.js
      6 ± tests/e2e/without_modules.js
      12 ± …/snapshots/updatenotification_spec.js.snap
      6 ± translations/en.json
      1 - vendor/package-lock.json
      42 ± vendor/package.json
      6 ± vendor/vendor.js
      0 49 files changed, 2858 insertions(+), 2243 deletions(-)
      mode change 100755 => 100644 modules/default/calendar/README.md
      mode change 100755 => 100644 modules/default/calendar/calendar.js delete mode 100644 modules/default/currentweather/currentweather.js
      mode change 100755 => 100644 modules/default/weather/README.md
      mode change 100755 => 100644 modules/default/weather/current.njk
      mode change 100755 => 100644 modules/default/weather/providers/README.md
      mode change 100755 => 100644 modules/default/weather/providers/darksky.js
      mode change 100755 => 100644 modules/default/weather/providers/openweathermap.js
      mode change 100755 => 100644 modules/default/weather/providers/ukmetoffice.js
      mode change 100755 => 100644 modules/default/weather/providers/weathergov.js
      mode change 100755 => 100644 modules/default/weather/weatherobject.js delete mode 100644 modules/default/weatherforecast/weatherforecast.js
      mode change 100755 => 100644 vendor/package.json
      mode change 100755 => 100644 vendor/vendor.js
      processor architecture is armv7l
      npm WARN invalid config omit=“dev --no-audit --no-fund --no-update-notifier” set in command line options
      npm WARN invalid config Must be one or more of: dev, optional, peer
      magicmirror@2.21.0 postinstall
      npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      magicmirror@2.21.0 install-vendor
      echo "Installing vendor files …
      " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      changed 3 packages in 9s
      magicmirror@2.21.0 install-fonts
      echo "Installing fonts …
      " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      Installing fonts …
      changed 2 packages in 4s
      magicmirror@2.21.0 prepare
      [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      husky - Git hooks installed
      added 455 packages, removed 3 packages, changed 13 packages, and audited 754 packages in 3m
      91 packages are looking for funding
      run npm fund for details
      3 moderate severity vulnerabilities
      To address all issues (including breaking changes), run:
      npm audit fix --force
      Run npm audit for details.
      npm install completed - Sun Oct 2 10:45:27 BST 2022 on base
      fixing sandbox permissions
      added 3 packages, and audited 4 packages in 3s
      1 package is looking for funding
      found 0 vulnerabilities
      removing git alias
      we stashed a set of files that appear changed from the latest repo versions. you should review them
      Upgrade ended - Sun Oct 2 10:45:33 BST 2022
      Upgrade started - Tue Oct 17 12:57:21 BST 2023
      system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
      Minimum Node version: v20.8.0
      Installed Node version: v16.20.2
      Node should be upgraded.
      A Node process is currently running. Can’t upgrade.
      Please quit all Node processes and restart the update.
      junior 18317 18316 0 Oct07 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
      Upgrade started - Tue Oct 17 12:58:30 BST 2023
      junior 8378 8377 5 12:58 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
      Upgrade started - Tue Oct 17 13:04:45 BST 2023
      junior 8378 8377 0 12:58 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
      Upgrade started - Sun Oct 22 09:24:16 BST 2023
      junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
      Upgrade started - Tue Oct 24 11:04:00 BST 2023
      n (node version manager tool) not installed, doing test run, install skipped
      Upgrade started - Tue Oct 24 11:04:44 BST 2023
      added 1 package, and audited 2 packages in 2s
      npm notice
      npm notice New major version of npm available! 8.19.4 -> 10.2.1
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.1
      npm notice Run npm install -g npm@10.2.1 to update!
      npm notice
      installing : node-v20.8.0
      mkdir : /usr/local/n/versions/node/20.8.0
      fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-arm64.tar.xz
      copying : node/20.8.0
      installed : (with npm 10.1.0)
      Note: the node command changed location and the old location may be remembered in your current shell.
      old : /usr/bin/node
      new : /usr/local/bin/node
      If “node --version” shows the old version then start a new shell, or reset the location hash with:
      hash -r (for bash, zsh, ash, dash, and ksh)
      rehash (for csh and tcsh)
      forcing low Node version
      Installed Node version: V1.0.0
      Upgrade started - Tue Oct 24 13:23:22 BST 2023
      node not installed, trying via apt-get
      Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (16.20.2-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      npm not installed, trying via apt-get
      Installing Node.js …
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease
      Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x bullseye InRelease [4,586 B] Get:4 https://deb.nodesource.com/node_20.x bullseye/main armhf Packages [783 B] Fetched 5,369 B in 1s (4,513 B/s) Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
      Node.js installation Done! version=
      pm2 installed, checking version 5.2.0 vs 5.3.0
      pm2 same major version, so updating
      added 4 packages, removed 30 packages, and changed 153 packages in 18s
      13 packages are looking for funding
      Be sure to have the latest version by doing npm install pm2@latest -g before doing this procedure.
      In-memory PM2 is out-of-date, do:
      $ pm2 update
      In memory PM2 version: 5.2.0
      Local PM2 version: 5.3.0
                    https://pm2.io/
       Harden your Node.js Production Environment
        - Real-time Monitoring Web Interface
        - Pro Active Alerting System
        - Production Profiling for Memory and CPU
        - PM2 Runtime High Availability Fallback
               Start using it by typing:
                      $ pm2 plus
      [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
      [PM2] MagicMirror ✓
      [PM2] [v] All Applications Stopped
      [PM2] [v] PM2 Daemon Stopped
      [PM2] Spawning PM2 daemon with pm2_home=/home/junior/.pm2
      [PM2] Restoring processes located in /home/junior/.pm2/dump.pm2
      [PM2] Process /home/junior/MagicMirror/installers/mm.sh restored
      PM2 updated
      Upgrade started - Tue Oct 24 13:56:39 BST 2023
      node not installed, doing test run, install skipped
      junior 1519 1518 0 13:37 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
      Upgrade started - Tue Oct 24 13:57:20 BST 2023
      Node.js upgrade defered, doing test run
      Minimum npm version: V10.1.0
      Installed npm version: V10.1.0
      saving custom.css
      upgrading from version 2.22.0 to 2.25.0
      git fetch rc=0
      On branch master
      Your branch is behind ‘origin/master’ by 3 commits, and can be fast-forwarded.
      Untracked files:
      core
      css/save_custom.css
      installers/stashed_files
      run-start.sh
      installers/mm.sh
      erasing lock files
      Saved working directory and index state WIP on master: f14e9561 Create Thai Language file (#3028)
      no modules found needing npm refresh
      removing git alias
      On branch master
      Untracked files:
      core
      run-start.sh
      Dropped refs/stash@{0} (c813d55595387ff98151af075aa3d1f202d8f8c3)
      Upgrade ended - Tue Oct 24 13:57:34 BST 2023
      Upgrade started - Tue Oct 24 13:57:52 BST 2023
      Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (20.5.1-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease
      Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
      pm2 installed, checking version 5.3.0 vs 5.3.0
      changed 157 packages in 15s
      [PM2] MagicMirror ✓
      PM2 updated
        DarkV @sdetweil
        saving custom.css
        git fetch rc=0
        On branch master
        Untracked files:
        core
        css/save_custom.css
        run-start.sh
        installers/mm.sh
        package-lock.json
        erasing lock files
        removing git alias
        On branch master
        Untracked files:
        core
        run-start.sh
        saving custom.css
        git fetch rc=0
        On branch master
        Untracked files:
        core
        css/save_custom.css
        run-start.sh
        installers/mm.sh
        erasing lock files
        merge result rc= 0
        2 ± CHANGELOG.md
        100 ± LICENSE.md
        2 ± css/main.css
        Installing fonts …
        removing git alias
        npm notice
        npm notice
        old : /usr/bin/node
        $ pm2 update
                      https://pm2.io/
                        $ pm2 plus
        [PM2] MagicMirror ✓
        PM2 updated
        saving custom.css
        git fetch rc=0
        On branch master
        Untracked files:
        core
        css/save_custom.css
        run-start.sh
        installers/mm.sh
        erasing lock files
        removing git alias
        On branch master
        Untracked files:
        core
        run-start.sh
        [PM2] MagicMirror ✓
        PM2 updated
          sdetweil @DarkV
          @DarkV said in Failed Update:
          that is not in my repo currently
          did you git clone the MagicMirror_scripts repo and are executing from the clone??
          don’t do that… execute by copy/paste the lines on the github page
            sdetweil @DarkV
            @DarkV has node 20.5.1
            that is the bad version
            sudo apt-get remove nodejs npm -y
            rename the log file out of the way. we don’t need info from Oct 2 now
            new log will be created
              DarkV @sdetweil
              @sdetweil Processing triggers for man-db (2.9.4-2) …
              junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              update log will be in /home/junior/MagicMirror/installers/upgrade.log
              bash: line 209: /usr/local/bin/node: No such file or directory
              /usr/bin/env: ‘node’: No such file or directory
              junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
              apply: line 176: /usr/local/bin/node: No such file or directory
              apply: line 209: /usr/local/bin/node: No such file or directory
              MagicMirror running under control of PM2, stopping
                sdetweil @DarkV
                @DarkV show me the ~/MagicMirror/installers/upgrade.log
                looks like this is a hybrid os… 64 bit kernel and 32 bit runtime… and the wrong architecture node was installed
                so, again do this,
                hash -r
                hash -r
                node -v
                should get not found
                then do
                which node
                show the results, nothing means not found
                if there is a result do
                node -v
                  DarkV @sdetweil
                  @sdetweil Reading package lists… Done
                  Building dependency tree… Done
                  Reading state information… Done
                  Package ‘npm’ is not installed, so not removed
                  libfuse2 raspinfo
                  The following packages will be REMOVED:
                  nodejs
                  0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                  After this operation, 183 MB disk space will be freed.
                  (Reading database … 108415 files and directories currently installed.)
                  Removing nodejs (20.5.1-deb-1nodesource1) …
                  dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
                  junior@MAGIC-MIRROR:~ $ hash -r
                  junior@MAGIC-MIRROR:~ $ node -v
                  -bash: /usr/local/bin/node: No such file or directory
                  junior@MAGIC-MIRROR:~ $ which node
                  /usr/local/bin/node
                    sdetweil @DarkV
                    @DarkV oh such joy
                    sudo n ls
                    sudo n prune
                    sudo n uninstall
                    hash -r
                    which node
                      DarkV @sdetweil
                      @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
                      login as: junior
                      junior@192.168.2.52’s password:
                      The programs included with the Debian GNU/Linux system are free software;
                      the exact distribution terms for each program are described in the
                      individual files in /usr/share/doc/*/copyright.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      permitted by applicable law.
                      Last login: Tue Oct 31 12:51:37 2023
                      junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
                      libfuse2 raspinfo
                      nodejs
                      /usr/local/bin/node
                      junior@MAGIC-MIRROR:~ $ ^C
                      junior@MAGIC-MIRROR:~ $ sudo n ls
                      node/20.8.0
                      junior@MAGIC-MIRROR:~ $ sudo n prune
                      /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
                      node/20.8.0
                      junior@MAGIC-MIRROR:~ $ sudo n uninstall
                      Do you wish to delete node and npm from /usr/local? y
                      Uninstalling node and npm
                      /usr/local/bin/node
                      /usr/local/bin/npm
                      /usr/local/bin/npx
                      /usr/local/bin/corepack
                      /usr/local/include/node
                      /usr/local/lib/node_modules/npm
                      /usr/local/lib/node_modules/corepack
                      /usr/local/share/doc/node
                      /usr/local/share/man/man1/node.1
                      which node
                        sdetweil @DarkV
                        @DarkV ok,
                        two more commands for info before running
                        lsb_release -a
                        file /bin/bash
                        NOW try to run my upgrade script… note that it will NOT install node in test mode…
                        so you have to use the second link that adds the apply parm
                          DarkV @sdetweil
                          @sdetweil said in Failed Update:
                          file /bin/bash
                          curl: (18) transfer closed with 23780100 bytes remaining to read
                          xz: (stdin): Unexpected end of input
                          tar: Unexpected EOF in archive
                          tar: Error is not recoverable: exiting now
                          Error: failed to download archive for 20.8.0
                          Installed Node version: v20.5.1
                          libfuse2 raspinfo
                          node version is
                          Node.js installation Done! version=v20.5.1
                          npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                            sdetweil @DarkV
                            @DarkV man this is a pain
                            one more try
                            hash -r
                            which node
                            which n
                            if which n response with empty then do
                            sudo apt-get install n
                            once n responds then
                            sudo n 20.8.0	--arch armv7l
                            hash -r
                            node -v
                            should say V20.8.0
                            i notice that I didn’t copy this little part from the install script…
                            please let me know
                            S D 2 Replies Last reply Reply Quote 0
                              @DarkV never mind that won’t work… need node and npm to install n… grr…
                              ok, only way out is to redo the sd card
                              backup your MM
                              see https://github.com/sdetweil/MagicMirror-backup-restore
                              copy the backup folder MM_backup off the sd card (it can save to github too)
                              reflash the sd card with latest os
                              boot, no updates,
                              run install script to install MM
                              verify it runs
                              restore your config using my restore script (can restore directly from github too)
                              test
                              sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.
                                DarkV @sdetweil
                                @sdetweil All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.
                                You have brought me happiness and protected me from madness. That’s a significant victory.Screenshot 2023-10-31 135119.png
                                  @DarkV before you jump off the bridge! try this
                                  hash -r
                                  make sure gone
                                  which node
                                  then
                                  sudo apt-get install nodejs:armv7l
                                  node -v
                                    DarkV @sdetweil
                                    @sdetweil I don’t know what happened, but the reply is above. Many thanks
                                      sdetweil @DarkV
                                      @DarkV cool… i didn’t expect that it, i’m glad!!
                                        DarkV @sdetweil
                                        @sdetweil I did this
                                        hash -r
                                        which node
                                        which n
                                        hash -r
                                        node -v
                                        Then both scripts and it went through!
                                          sdetweil @DarkV
                                          –arch armv7l
                                          awesome… it was that sneaky little --arch parm…
                                          fixing upgrade script now . sorry for your troubles
                                            DarkV @sdetweil
                                            @sdetweil No worries, thanks you for your time
                                            • 2 / 3
