    Failed Update
    45 Posts 3 Posters 18.2k Views 3 Watching
      sdetweil @DarkV
      @DarkV well then it didn’t do the upgrade
      this is a two step process( two links on the page)
      test, alert any issues, files might be overwritten, etc
      make no changes
      apply, DO THE UPGRADE
      except, if its the same version is already installed.
      DON’T DO IT AGAIN…
      but if you change the apply parm to force
      then it will
      show me the ~/MagicMirror/installers/upgrade.log
        DarkV @sdetweil
        Upgrade started - Sun Oct 2 10:41:43 BST 2022
        system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
        Check current Node installation …
        Minimum Node version: v16.9.1
        Installed Node version: v16.17.1
        No Node.js upgrade necessary.
        Check current NPM installation …
        Minimum npm version: V7.11.2
        Installed npm version: V8.15.0
        No npm upgrade necessary.
        saving custom.css
        remote name = origin
        upgrading from version 2.20.0 to 2.21.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is behind ‘origin/master’ by 4694 commits, and can be fast-forwarded.
        (use “git pull” to update your local branch)
        (use “git add …” to update what will be committed)
        (use “git restore …” to discard changes in working directory)
        modified: installers/mm.sh
        modified: package-lock.json
        Untracked files:
        (use “git add …” to include in what will be committed)
        core
        css/save_custom.css
        installers/mm_temp.sh
        installers/pm2_MagicMirror.json
        installers/pm2_MagicMirror_new.json
        run-start.sh
        no changes added to commit (use “git add” and/or “git commit -a”)
        there are 2 local files that are different than the master repo
        installers/mm.sh
        package-lock.json
        save/restore files selection = y
        erasing lock files
        Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop
        test merge result rc=‘’ , if empty, no conflicts
        skipping merge, only test run
        downloading dumpactivemodules script
        processing for module MMM-Tools please wait
        skipped processing for MMM-Tools, doing test run
        processing complete for module MMM-Tools
        restoring custom.css
        removing git alias
        test run, restoring files stashed
        Removing vendor/package-lock.json
        Removing package-lock.json
        Removing fonts/package-lock.json
        On branch master
        (use “git add/rm …” to update what will be committed)
        deleted: fonts/package-lock.json
        deleted: package-lock.json
        deleted: vendor/package-lock.json
        Untracked files:
        core
        run-start.sh
        Dropped refs/stash@{0} (0640a953f8283b8d55b598386c17d310f8a75680)
        Upgrade ended - Sun Oct 2 10:41:58 BST 2022
        Upgrade started - Sun Oct 2 10:42:15 BST 2022
        user requested to apply changes
        doing test run = false
        saving custom.css
        git fetch rc=0
        On branch master
        Untracked files:
        core
        css/save_custom.css
        run-start.sh
        there are 1 local files that are different than the master repo
        installers/mm.sh
        erasing lock files
        executing merge, apply specified
        merge result rc= 0
        Updating 30d5bfe5…9e029304 Fast-forward .github/ISSUE_TEMPLATE.md
        4 ± .github/workflows/automated-tests.yaml
        4 ± .github/workflows/codecov-test-suites.yaml
        2 ± CHANGELOG.md
        100 ± LICENSE.md
        2 ± css/main.css
        18 ± fonts/package-lock.json
        28 ± fonts/package.json
        4 ± js/node_helper.js
        17 ± modules/default/calendar/README.md
        0 modules/default/calendar/calendar.js
        21 ± modules/default/calendar/calendarutils.js
        37 ± modules/default/calendar/node_helper.js
        8 + modules/default/currentweather/currentweather.js
        33 - modules/default/defaultmodules.js
        2 ± modules/default/newsfeed/newsfeedfetcher.js
        13 + modules/default/weather/README.md
        2 ± modules/default/weather/current.njk
        0 modules/default/weather/providers/README.md
        0 modules/default/weather/providers/darksky.js
        0 …/default/weather/providers/openweathermap.js
        0 modules/default/weather/providers/smhi.js
        61 ± modules/default/weather/providers/ukmetoffice.js
        0 modules/default/weather/providers/weatherbit.js
        26 ± modules/default/weather/providers/weathergov.js
        0 modules/default/weather/weatherobject.js
        0 modules/default/weatherforecast/weatherforecast.js
        33 - package-lock.json
        3885 ++++++++++±-------- package.json
        38 ± tests/configs/data/calendar_test_recurring.ics
        2 ± tests/e2e/env_spec.js
        17 ± tests/e2e/global-setup.js
        57 ± tests/e2e/modules/alert_spec.js
        9 ± tests/e2e/modules/calendar_spec.js
        111 ± tests/e2e/modules/clock_es_spec.js
        47 ± tests/e2e/modules/clock_spec.js
        77 ± tests/e2e/modules/compliments_spec.js
        60 ± tests/e2e/modules/helloworld_spec.js
        18 ± tests/e2e/modules/newsfeed_spec.js
        48 ± tests/e2e/modules/weather_spec.js
        225 ± tests/e2e/modules_display_spec.js
        10 ± tests/e2e/modules_position_spec.js
        9 ± tests/e2e/translations_spec.js
        6 ± tests/e2e/without_modules.js
        12 ± …/snapshots/updatenotification_spec.js.snap
        6 ± translations/en.json
        1 - vendor/package-lock.json
        42 ± vendor/package.json
        6 ± vendor/vendor.js
        0 49 files changed, 2858 insertions(+), 2243 deletions(-)
        mode change 100755 => 100644 modules/default/calendar/README.md
        mode change 100755 => 100644 modules/default/calendar/calendar.js delete mode 100644 modules/default/currentweather/currentweather.js
        mode change 100755 => 100644 modules/default/weather/README.md
        mode change 100755 => 100644 modules/default/weather/current.njk
        mode change 100755 => 100644 modules/default/weather/providers/README.md
        mode change 100755 => 100644 modules/default/weather/providers/darksky.js
        mode change 100755 => 100644 modules/default/weather/providers/openweathermap.js
        mode change 100755 => 100644 modules/default/weather/providers/ukmetoffice.js
        mode change 100755 => 100644 modules/default/weather/providers/weathergov.js
        mode change 100755 => 100644 modules/default/weather/weatherobject.js delete mode 100644 modules/default/weatherforecast/weatherforecast.js
        mode change 100755 => 100644 vendor/package.json
        mode change 100755 => 100644 vendor/vendor.js
        processor architecture is armv7l
        npm WARN invalid config omit=“dev --no-audit --no-fund --no-update-notifier” set in command line options
        npm WARN invalid config Must be one or more of: dev, optional, peer
        magicmirror@2.21.0 postinstall
        npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        magicmirror@2.21.0 install-vendor
        echo "Installing vendor files …
        " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        changed 3 packages in 9s
        magicmirror@2.21.0 install-fonts
        echo "Installing fonts …
        " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        Installing fonts …
        changed 2 packages in 4s
        magicmirror@2.21.0 prepare
        [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
        husky - Git hooks installed
        added 455 packages, removed 3 packages, changed 13 packages, and audited 754 packages in 3m
        91 packages are looking for funding
        run npm fund for details
        3 moderate severity vulnerabilities
        To address all issues (including breaking changes), run:
        npm audit fix --force
        Run npm audit for details.
        npm install completed - Sun Oct 2 10:45:27 BST 2022 on base
        fixing sandbox permissions
        added 3 packages, and audited 4 packages in 3s
        1 package is looking for funding
        found 0 vulnerabilities
        removing git alias
        we stashed a set of files that appear changed from the latest repo versions. you should review them
        Upgrade ended - Sun Oct 2 10:45:33 BST 2022
        Upgrade started - Tue Oct 17 12:57:21 BST 2023
        system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
        Minimum Node version: v20.8.0
        Installed Node version: v16.20.2
        Node should be upgraded.
        A Node process is currently running. Can’t upgrade.
        Please quit all Node processes and restart the update.
        junior 18317 18316 0 Oct07 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 17 12:58:30 BST 2023
        junior 8378 8377 5 12:58 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 17 13:04:45 BST 2023
        junior 8378 8377 0 12:58 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Sun Oct 22 09:24:16 BST 2023
        junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 24 11:04:00 BST 2023
        n (node version manager tool) not installed, doing test run, install skipped
        Upgrade started - Tue Oct 24 11:04:44 BST 2023
        added 1 package, and audited 2 packages in 2s
        npm notice
        npm notice New major version of npm available! 8.19.4 -> 10.2.1
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.1
        npm notice Run npm install -g npm@10.2.1 to update!
        npm notice
        installing : node-v20.8.0
        mkdir : /usr/local/n/versions/node/20.8.0
        fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-arm64.tar.xz
        copying : node/20.8.0
        installed : (with npm 10.1.0)
        Note: the node command changed location and the old location may be remembered in your current shell.
        old : /usr/bin/node
        new : /usr/local/bin/node
        If “node --version” shows the old version then start a new shell, or reset the location hash with:
        hash -r (for bash, zsh, ash, dash, and ksh)
        rehash (for csh and tcsh)
        forcing low Node version
        Installed Node version: V1.0.0
        Upgrade started - Tue Oct 24 13:23:22 BST 2023
        node not installed, trying via apt-get
        Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (16.20.2-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        npm not installed, trying via apt-get
        Installing Node.js …
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease
        Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x bullseye InRelease [4,586 B] Get:4 https://deb.nodesource.com/node_20.x bullseye/main armhf Packages [783 B] Fetched 5,369 B in 1s (4,513 B/s) Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
        Node.js installation Done! version=
        pm2 installed, checking version 5.2.0 vs 5.3.0
        pm2 same major version, so updating
        added 4 packages, removed 30 packages, and changed 153 packages in 18s
        13 packages are looking for funding
        Be sure to have the latest version by doing npm install pm2@latest -g before doing this procedure.
        In-memory PM2 is out-of-date, do:
        $ pm2 update
        In memory PM2 version: 5.2.0
        Local PM2 version: 5.3.0
                      https://pm2.io/
         Harden your Node.js Production Environment
          - Real-time Monitoring Web Interface
          - Pro Active Alerting System
          - Production Profiling for Memory and CPU
          - PM2 Runtime High Availability Fallback
                 Start using it by typing:
                        $ pm2 plus
        [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
        [PM2] MagicMirror ✓
        [PM2] [v] All Applications Stopped
        [PM2] [v] PM2 Daemon Stopped
        [PM2] Spawning PM2 daemon with pm2_home=/home/junior/.pm2
        [PM2] Restoring processes located in /home/junior/.pm2/dump.pm2
        [PM2] Process /home/junior/MagicMirror/installers/mm.sh restored
        PM2 updated
        Upgrade started - Tue Oct 24 13:56:39 BST 2023
        node not installed, doing test run, install skipped
        junior 1519 1518 0 13:37 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        Upgrade started - Tue Oct 24 13:57:20 BST 2023
        Node.js upgrade defered, doing test run
        Minimum npm version: V10.1.0
        Installed npm version: V10.1.0
        saving custom.css
        upgrading from version 2.22.0 to 2.25.0
        git fetch rc=0
        On branch master
        Your branch is behind ‘origin/master’ by 3 commits, and can be fast-forwarded.
        Untracked files:
        core
        css/save_custom.css
        installers/stashed_files
        run-start.sh
        installers/mm.sh
        erasing lock files
        Saved working directory and index state WIP on master: f14e9561 Create Thai Language file (#3028)
        no modules found needing npm refresh
        removing git alias
        On branch master
        Untracked files:
        core
        run-start.sh
        Dropped refs/stash@{0} (c813d55595387ff98151af075aa3d1f202d8f8c3)
        Upgrade ended - Tue Oct 24 13:57:34 BST 2023
        Upgrade started - Tue Oct 24 13:57:52 BST 2023
        Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (20.5.1-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease
        Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
        pm2 installed, checking version 5.3.0 vs 5.3.0
        changed 157 packages in 15s
        [PM2] MagicMirror ✓
        PM2 updated
          DarkV @sdetweil
          saving custom.css
          git fetch rc=0
          On branch master
          Untracked files:
          core
          css/save_custom.css
          run-start.sh
          installers/mm.sh
          package-lock.json
          erasing lock files
          removing git alias
          On branch master
          Untracked files:
          core
          run-start.sh
          saving custom.css
          git fetch rc=0
          On branch master
          Untracked files:
          core
          css/save_custom.css
          run-start.sh
          installers/mm.sh
          erasing lock files
          merge result rc= 0
          2 ± CHANGELOG.md
          100 ± LICENSE.md
          2 ± css/main.css
          Installing fonts …
          removing git alias
          npm notice
          npm notice
          old : /usr/bin/node
          $ pm2 update
                        https://pm2.io/
                          $ pm2 plus
          [PM2] MagicMirror ✓
          PM2 updated
          saving custom.css
          git fetch rc=0
          On branch master
          Untracked files:
          core
          css/save_custom.css
          run-start.sh
          installers/mm.sh
          erasing lock files
          removing git alias
          On branch master
          Untracked files:
          core
          run-start.sh
          [PM2] MagicMirror ✓
          PM2 updated
            sdetweil @DarkV
            @DarkV said in Failed Update:
            that is not in my repo currently
            did you git clone the MagicMirror_scripts repo and are executing from the clone??
            don’t do that… execute by copy/paste the lines on the github page
              sdetweil @DarkV
              @DarkV has node 20.5.1
              that is the bad version
              sudo apt-get remove nodejs npm -y
              rename the log file out of the way. we don’t need info from Oct 2 now
              new log will be created
                DarkV @sdetweil
                @sdetweil Processing triggers for man-db (2.9.4-2) …
                junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                update log will be in /home/junior/MagicMirror/installers/upgrade.log
                bash: line 209: /usr/local/bin/node: No such file or directory
                /usr/bin/env: ‘node’: No such file or directory
                junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                apply: line 176: /usr/local/bin/node: No such file or directory
                apply: line 209: /usr/local/bin/node: No such file or directory
                MagicMirror running under control of PM2, stopping
                  sdetweil @DarkV
                  @DarkV show me the ~/MagicMirror/installers/upgrade.log
                  looks like this is a hybrid os… 64 bit kernel and 32 bit runtime… and the wrong architecture node was installed
                  so, again do this,
                  hash -r
                  hash -r
                  node -v
                  should get not found
                  then do
                  which node
                  show the results, nothing means not found
                  if there is a result do
                  node -v
                    DarkV @sdetweil
                    @sdetweil Reading package lists… Done
                    Building dependency tree… Done
                    Reading state information… Done
                    Package ‘npm’ is not installed, so not removed
                    libfuse2 raspinfo
                    The following packages will be REMOVED:
                    nodejs
                    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                    After this operation, 183 MB disk space will be freed.
                    (Reading database … 108415 files and directories currently installed.)
                    Removing nodejs (20.5.1-deb-1nodesource1) …
                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
                    junior@MAGIC-MIRROR:~ $ hash -r
                    junior@MAGIC-MIRROR:~ $ node -v
                    -bash: /usr/local/bin/node: No such file or directory
                    junior@MAGIC-MIRROR:~ $ which node
                    /usr/local/bin/node
                      sdetweil @DarkV
                      @DarkV oh such joy
                      sudo n ls
                      sudo n prune
                      sudo n uninstall
                      hash -r
                      which node
                        DarkV @sdetweil
                        @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
                        login as: junior
                        junior@192.168.2.52’s password:
                        The programs included with the Debian GNU/Linux system are free software;
                        the exact distribution terms for each program are described in the
                        individual files in /usr/share/doc/*/copyright.
                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                        permitted by applicable law.
                        Last login: Tue Oct 31 12:51:37 2023
                        junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
                        libfuse2 raspinfo
                        nodejs
                        /usr/local/bin/node
                        junior@MAGIC-MIRROR:~ $ ^C
                        junior@MAGIC-MIRROR:~ $ sudo n ls
                        node/20.8.0
                        junior@MAGIC-MIRROR:~ $ sudo n prune
                        /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
                        node/20.8.0
                        junior@MAGIC-MIRROR:~ $ sudo n uninstall
                        Do you wish to delete node and npm from /usr/local? y
                        Uninstalling node and npm
                        /usr/local/bin/node
                        /usr/local/bin/npm
                        /usr/local/bin/npx
                        /usr/local/bin/corepack
                        /usr/local/include/node
                        /usr/local/lib/node_modules/npm
                        /usr/local/lib/node_modules/corepack
                        /usr/local/share/doc/node
                        /usr/local/share/man/man1/node.1
                        which node
                          sdetweil @DarkV
                          @DarkV ok,
                          two more commands for info before running
                          lsb_release -a
                          file /bin/bash
                          NOW try to run my upgrade script… note that it will NOT install node in test mode…
                          so you have to use the second link that adds the apply parm
                            DarkV @sdetweil
                            @sdetweil said in Failed Update:
                            file /bin/bash
                            curl: (18) transfer closed with 23780100 bytes remaining to read
                            xz: (stdin): Unexpected end of input
                            tar: Unexpected EOF in archive
                            tar: Error is not recoverable: exiting now
                            Error: failed to download archive for 20.8.0
                            Installed Node version: v20.5.1
                            libfuse2 raspinfo
                            node version is
                            Node.js installation Done! version=v20.5.1
                            npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                              sdetweil @DarkV
                              @DarkV man this is a pain
                              one more try
                              hash -r
                              which node
                              which n
                              if which n response with empty then do
                              sudo apt-get install n
                              once n responds then
                              sudo n 20.8.0	--arch armv7l
                              hash -r
                              node -v
                              should say V20.8.0
                              i notice that I didn’t copy this little part from the install script…
                              please let me know
                              S D 2 Replies Last reply Reply Quote 0
                                @DarkV never mind that won’t work… need node and npm to install n… grr…
                                ok, only way out is to redo the sd card
                                backup your MM
                                see https://github.com/sdetweil/MagicMirror-backup-restore
                                copy the backup folder MM_backup off the sd card (it can save to github too)
                                reflash the sd card with latest os
                                boot, no updates,
                                run install script to install MM
                                verify it runs
                                restore your config using my restore script (can restore directly from github too)
                                test
                                sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.
                                  DarkV @sdetweil
                                  @sdetweil All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.
                                  You have brought me happiness and protected me from madness. That’s a significant victory.Screenshot 2023-10-31 135119.png
                                    @DarkV before you jump off the bridge! try this
                                    hash -r
                                    make sure gone
                                    which node
                                    then
                                    sudo apt-get install nodejs:armv7l
                                    node -v
                                      DarkV @sdetweil
                                      @sdetweil I don’t know what happened, but the reply is above. Many thanks
                                        sdetweil @DarkV
                                        @DarkV cool… i didn’t expect that it, i’m glad!!
                                          DarkV @sdetweil
                                          @sdetweil I did this
                                          hash -r
                                          which node
                                          which n
                                          hash -r
                                          node -v
                                          Then both scripts and it went through!
                                            sdetweil @DarkV
                                            –arch armv7l
                                            awesome… it was that sneaky little --arch parm…
                                            fixing upgrade script now . sorry for your troubles
