    Failed Update
    45 Posts 3 Posters 19.1k Views 3 Watching
      sdetweil @DarkV
      @DarkV said in Failed Update:
      bash: line 117: [: !=: unary operator expected
      I have fixed this in the upgrade-script.sh
      (and another similar)
        DarkV @sdetweil
        @sdetweil Wil try again, I tried it a week ago and it failed to start after the update with a failed to update .json. I had to restore from a previous image. I will try again.
        I will report back
          sdetweil @DarkV
          @DarkV ok, thx… let me see the
          ~/MagicMirror/installers/upgrade.log
          when u finish
            DarkV @sdetweil
            Here is the log and a failed update again
            pgrade started - Sun Oct  2 10:41:43 BST 2022
            system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
            Minimum Node version: v16.9.1
            Installed Node version: v16.17.1
            No Node.js upgrade necessary.
            Minimum npm version: V7.11.2
            Installed npm version: V8.15.0
            No npm upgrade necessary.
            saving custom.css
            remote name = origin
            upgrading from version 2.20.0 to 2.21.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is behind 'origin/master' by 4694 commits, and can be fast-forwarded.
              (use "git pull" to update your local branch)
              (use "git add <file>..." to update what will be committed)
              (use "git restore <file>..." to discard changes in working directory)
            	modified:   installers/mm.sh
            	modified:   package-lock.json
            Untracked files:
              (use "git add <file>..." to include in what will be committed)
            	core
            	css/save_custom.css
            	installers/mm_temp.sh
            	installers/pm2_MagicMirror.json
            	installers/pm2_MagicMirror_new.json
            	run-start.sh
            no changes added to commit (use "git add" and/or "git commit -a")
            there are 2 local files that are different than the master repo
               installers/mm.sh
               package-lock.json
            save/restore files selection = y
            erasing lock files
            Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop
            test merge result rc='' , if empty, no conflicts
            skipping merge, only test run
            downloading dumpactivemodules script
            processing for module MMM-Tools please wait
            skipped processing for MMM-Tools, doing test run
            processing complete for module MMM-Tools
            restoring custom.css
            removing git alias
            test run, restoring files stashed
            Removing vendor/package-lock.json
            Removing package-lock.json
            Removing fonts/package-lock.json
            On branch master
              (use "git add/rm <file>..." to update what will be committed)
            	deleted:    fonts/package-lock.json
            	deleted:    package-lock.json
            	deleted:    vendor/package-lock.json
            Untracked files:
            	core
            	run-start.sh
            Dropped refs/stash@{0} (0640a953f8283b8d55b598386c17d310f8a75680)
            Upgrade ended - Sun Oct  2 10:41:58 BST 2022
            Upgrade started - Sun Oct  2 10:42:15 BST 2022
            user requested to apply changes
            doing test run = false
            saving custom.css
            git fetch rc=0
            On branch master
            Untracked files:
            	core
            	css/save_custom.css
            	run-start.sh
            there are 1 local files that are different than the master repo
               installers/mm.sh
            erasing lock files
            executing merge, apply specified
            merge result rc= 0
             Updating 30d5bfe5..9e029304 Fast-forward  .github/ISSUE_TEMPLATE.md
                4 +-  .github/workflows/automated-tests.yaml
                4 +-  .github/workflows/codecov-test-suites.yaml
                2 +-  CHANGELOG.md
              100 +-  LICENSE.md
                2 +-  css/main.css
               18 +-  fonts/package-lock.json
               28 +-  fonts/package.json
                4 +-  js/node_helper.js
               17 +-  modules/default/calendar/README.md
                0  modules/default/calendar/calendar.js
               21 +-  modules/default/calendar/calendarutils.js
               37 +-  modules/default/calendar/node_helper.js
                8 +  modules/default/currentweather/currentweather.js
               33 -  modules/default/defaultmodules.js
                2 +-  modules/default/newsfeed/newsfeedfetcher.js
               13 +  modules/default/weather/README.md
                2 +-  modules/default/weather/current.njk
                0  modules/default/weather/providers/README.md
                0  modules/default/weather/providers/darksky.js
                0  .../default/weather/providers/openweathermap.js
                0  modules/default/weather/providers/smhi.js
               61 +-  modules/default/weather/providers/ukmetoffice.js
                0  modules/default/weather/providers/weatherbit.js
               26 +-  modules/default/weather/providers/weathergov.js
                0  modules/default/weather/weatherobject.js
                0  modules/default/weatherforecast/weatherforecast.js
               33 -  package-lock.json
             3885 +++++++++++---------  package.json
               38 +-  tests/configs/data/calendar_test_recurring.ics
                2 +-  tests/e2e/env_spec.js
               17 +-  tests/e2e/global-setup.js
               57 +-  tests/e2e/modules/alert_spec.js
                9 +-  tests/e2e/modules/calendar_spec.js
              111 +-  tests/e2e/modules/clock_es_spec.js
               47 +-  tests/e2e/modules/clock_spec.js
               77 +-  tests/e2e/modules/compliments_spec.js
               60 +-  tests/e2e/modules/helloworld_spec.js
               18 +-  tests/e2e/modules/newsfeed_spec.js
               48 +-  tests/e2e/modules/weather_spec.js
              225 +-  tests/e2e/modules_display_spec.js
               10 +-  tests/e2e/modules_position_spec.js
                9 +-  tests/e2e/translations_spec.js
                6 +-  tests/e2e/without_modules.js
               12 +-  .../__snapshots__/updatenotification_spec.js.snap
                6 +-  translations/en.json
                1 -  vendor/package-lock.json
               42 +-  vendor/package.json
                6 +-  vendor/vendor.js
                0  49 files changed, 2858 insertions(+), 2243 deletions(-)
            mode change 100755 => 100644 modules/default/calendar/README.md
            mode change 100755 => 100644 modules/default/calendar/calendar.js  delete mode 100644 modules/default/currentweather/currentweather.js
            mode change 100755 => 100644 modules/default/weather/README.md
            mode change 100755 => 100644 modules/default/weather/current.njk
            mode change 100755 => 100644 modules/default/weather/providers/README.md
            mode change 100755 => 100644 modules/default/weather/providers/darksky.js
            mode change 100755 => 100644 modules/default/weather/providers/openweathermap.js
            mode change 100755 => 100644 modules/default/weather/providers/ukmetoffice.js
            mode change 100755 => 100644 modules/default/weather/providers/weathergov.js
            mode change 100755 => 100644 modules/default/weather/weatherobject.js  delete mode 100644 modules/default/weatherforecast/weatherforecast.js
            mode change 100755 => 100644 vendor/package.json
            mode change 100755 => 100644 vendor/vendor.js
            processor architecture is armv7l
            npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options
            npm WARN invalid config Must be one or more of: dev, optional, peer
            > magicmirror@2.21.0 postinstall
            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            > magicmirror@2.21.0 install-vendor
            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            changed 3 packages in 9s
            > magicmirror@2.21.0 install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            changed 2 packages in 4s
            > magicmirror@2.21.0 prepare
            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
            husky - Git hooks installed
            added 455 packages, removed 3 packages, changed 13 packages, and audited 754 packages in 3m
            91 packages are looking for funding
              run `npm fund` for details
            3 moderate severity vulnerabilities
            To address all issues (including breaking changes), run:
              npm audit fix --force
            Run `npm audit` for details.
            npm install completed - Sun Oct  2 10:45:27 BST 2022 on base
            fixing sandbox permissions
            added 3 packages, and audited 4 packages in 3s
            1 package is looking for funding
            found 0 vulnerabilities
            removing git alias
            we stashed a set of files that appear changed from the latest repo versions. you should review them
            Upgrade ended - Sun Oct  2 10:45:33 BST 2022
            Upgrade started - Tue Oct 17 12:57:21 BST 2023
            system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
            Minimum Node version: v20.8.0
            Installed Node version: v16.20.2
            Node should be upgraded.
            A Node process is currently running. Can't upgrade.
            Please quit all Node processes and restart the update.
            junior 18317 18316 0 Oct07 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
            Upgrade started - Tue Oct 17 12:58:30 BST 2023
            junior 8378 8377 5 12:58 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
            Upgrade started - Tue Oct 17 13:04:45 BST 2023
            junior 8378 8377 0 12:58 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
            Upgrade started - Sun Oct 22 09:24:16 BST 2023
            junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
            Upgrade started - Tue Oct 24 11:04:00 BST 2023
            n (node version manager tool) not installed, doing test run, install skipped
            Upgrade started - Tue Oct 24 11:04:44 BST 2023
            added 1 package, and audited 2 packages in 2s
            npm notice
            npm notice New major version of npm available! 8.19.4 -> 10.2.1
            npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.2.1>
            npm notice Run `npm install -g npm@10.2.1` to update!
            npm notice
              installing : node-v20.8.0
                   mkdir : /usr/local/n/versions/node/20.8.0
                   fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-arm64.tar.xz
                 copying : node/20.8.0
               installed :  (with npm 10.1.0)
            Note: the node command changed location and the old location may be remembered in your current shell.
                     old : /usr/bin/node
                     new : /usr/local/bin/node
            If "node --version" shows the old version then start a new shell, or reset the location hash with:
            hash -r  (for bash, zsh, ash, dash, and ksh)
            rehash   (for csh and tcsh)
            forcing low Node version
            Installed Node version: V1.0.0
            running process(s) are
            junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electro                                           n.js
            junior@MAGIC-MIRROR:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/s                                           detweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            npm WARN cli npm v10.1.0 does not support Node.js v16.20.2. This version of npm                                            supports the following node versions: `^18.17.0 || >=20.5.0`. You can find the l                                           atest version at https://nodejs.org/.
            /usr/bin/n: line 746: /usr/local/bin/node: No such file or directory
            update log will be in /home/junior/MagicMirror/installers/upgrade.log
            apply: line 207: /usr/local/bin/node: No such file or directory
              sdetweil @DarkV
              @DarkV you have to stop your running mm first
              pm2 stop all
                DarkV @sdetweil
                @sdetweil said in Failed Update:
                pm2 stop all
                I can now update because that worked—many thanks for your assistance.
                  sdetweil @DarkV
                  @DarkV were u able to update successfully?
                    DarkV @sdetweil
                    @sdetweil it goes through the update process successfully, but on the mirror, it still reports that it is 3 updates behind upon reboot
                      sdetweil @DarkV
                      @DarkV well then it didn’t do the upgrade
                      this is a two step process( two links on the page)
                      test, alert any issues, files might be overwritten, etc
                      make no changes
                      apply, DO THE UPGRADE
                      except, if its the same version is already installed.
                      DON’T DO IT AGAIN…
                      but if you change the apply parm to force
                      then it will
                      show me the ~/MagicMirror/installers/upgrade.log
                        DarkV @sdetweil
                        Upgrade started - Sun Oct 2 10:41:43 BST 2022
                        Check current Node installation …
                        Check current NPM installation …
                        saving custom.css
                        git fetch rc=0
                        On branch master
                        Your branch is behind ‘origin/master’ by 4694 commits, and can be fast-forwarded.
                        (use “git pull” to update your local branch)
                        (use “git add …” to update what will be committed)
                        (use “git restore …” to discard changes in working directory)
                        Untracked files:
                        (use “git add …” to include in what will be committed)
                        core
                        css/save_custom.css
                        run-start.sh
                        no changes added to commit (use “git add” and/or “git commit -a”)
                        installers/mm.sh
                        package-lock.json
                        erasing lock files
                        test merge result rc=‘’ , if empty, no conflicts
                        removing git alias
                        On branch master
                        (use “git add/rm …” to update what will be committed)
                        Untracked files:
                        core
                        run-start.sh
                        saving custom.css
                        git fetch rc=0
                        On branch master
                        Untracked files:
                        core
                        css/save_custom.css
                        run-start.sh
                        installers/mm.sh
                        erasing lock files
                        merge result rc= 0
                        Updating 30d5bfe5…9e029304 Fast-forward .github/ISSUE_TEMPLATE.md
                        4 ± .github/workflows/automated-tests.yaml
                        4 ± .github/workflows/codecov-test-suites.yaml
                        2 ± CHANGELOG.md
                        100 ± LICENSE.md
                        2 ± css/main.css
                        18 ± fonts/package-lock.json
                        28 ± fonts/package.json
                        4 ± js/node_helper.js
                        17 ± modules/default/calendar/README.md
                        21 ± modules/default/calendar/calendarutils.js
                        37 ± modules/default/calendar/node_helper.js
                        2 ± modules/default/newsfeed/newsfeedfetcher.js
                        2 ± modules/default/weather/current.njk
                        0 …/default/weather/providers/openweathermap.js
                        61 ± modules/default/weather/providers/ukmetoffice.js
                        26 ± modules/default/weather/providers/weathergov.js
                        3885 ++++++++++±-------- package.json
                        38 ± tests/configs/data/calendar_test_recurring.ics
                        2 ± tests/e2e/env_spec.js
                        17 ± tests/e2e/global-setup.js
                        57 ± tests/e2e/modules/alert_spec.js
                        9 ± tests/e2e/modules/calendar_spec.js
                        111 ± tests/e2e/modules/clock_es_spec.js
                        47 ± tests/e2e/modules/clock_spec.js
                        77 ± tests/e2e/modules/compliments_spec.js
                        60 ± tests/e2e/modules/helloworld_spec.js
                        18 ± tests/e2e/modules/newsfeed_spec.js
                        48 ± tests/e2e/modules/weather_spec.js
                        225 ± tests/e2e/modules_display_spec.js
                        10 ± tests/e2e/modules_position_spec.js
                        9 ± tests/e2e/translations_spec.js
                        6 ± tests/e2e/without_modules.js
                        12 ± …/snapshots/updatenotification_spec.js.snap
                        6 ± translations/en.json
                        42 ± vendor/package.json
                        6 ± vendor/vendor.js
                        npm WARN invalid config omit=“dev --no-audit --no-fund --no-update-notifier” set in command line options
                        echo "Installing vendor files …
                        echo "Installing fonts …
                        Installing fonts …
                        run npm fund for details
                        Run npm audit for details.
                        removing git alias
                        A Node process is currently running. Can’t upgrade.
                        npm notice
                        npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.1
                        npm notice Run npm install -g npm@10.2.1 to update!
                        npm notice
                        old : /usr/bin/node
                        If “node --version” shows the old version then start a new shell, or reset the location hash with:
                        Upgrade started - Tue Oct 24 13:23:22 BST 2023
                        node not installed, trying via apt-get
                        Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (16.20.2-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        npm not installed, trying via apt-get
                        Installing Node.js …
                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease
                        Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x bullseye InRelease [4,586 B] Get:4 https://deb.nodesource.com/node_20.x bullseye/main armhf Packages [783 B] Fetched 5,369 B in 1s (4,513 B/s) Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                        Node.js installation Done! version=
                        pm2 installed, checking version 5.2.0 vs 5.3.0
                        pm2 same major version, so updating
                        added 4 packages, removed 30 packages, and changed 153 packages in 18s
                        13 packages are looking for funding
                        Be sure to have the latest version by doing npm install pm2@latest -g before doing this procedure.
                        In-memory PM2 is out-of-date, do:
                        $ pm2 update
                        In memory PM2 version: 5.2.0
                        Local PM2 version: 5.3.0
                                      https://pm2.io/
                         Harden your Node.js Production Environment
                          - Real-time Monitoring Web Interface
                          - Pro Active Alerting System
                          - Production Profiling for Memory and CPU
                          - PM2 Runtime High Availability Fallback
                                 Start using it by typing:
                                        $ pm2 plus
                        [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
                        [PM2] MagicMirror ✓
                        [PM2] [v] All Applications Stopped
                        [PM2] [v] PM2 Daemon Stopped
                        [PM2] Spawning PM2 daemon with pm2_home=/home/junior/.pm2
                        [PM2] Restoring processes located in /home/junior/.pm2/dump.pm2
                        [PM2] Process /home/junior/MagicMirror/installers/mm.sh restored
                        PM2 updated
                        Upgrade started - Tue Oct 24 13:56:39 BST 2023
                        node not installed, doing test run, install skipped
                        junior 1519 1518 0 13:37 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                        Upgrade started - Tue Oct 24 13:57:20 BST 2023
                        Node.js upgrade defered, doing test run
                        Minimum npm version: V10.1.0
                        Installed npm version: V10.1.0
                        saving custom.css
                        upgrading from version 2.22.0 to 2.25.0
                        git fetch rc=0
                        On branch master
                        Your branch is behind ‘origin/master’ by 3 commits, and can be fast-forwarded.
                        Untracked files:
                        core
                        css/save_custom.css
                        installers/stashed_files
                        run-start.sh
                        installers/mm.sh
                        erasing lock files
                        Saved working directory and index state WIP on master: f14e9561 Create Thai Language file (#3028)
                        no modules found needing npm refresh
                        removing git alias
                        On branch master
                        Untracked files:
                        core
                        run-start.sh
                        Dropped refs/stash@{0} (c813d55595387ff98151af075aa3d1f202d8f8c3)
                        Upgrade ended - Tue Oct 24 13:57:34 BST 2023
                        Upgrade started - Tue Oct 24 13:57:52 BST 2023
                        Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (20.5.1-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease
                        Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                        pm2 installed, checking version 5.3.0 vs 5.3.0
                        changed 157 packages in 15s
                        [PM2] MagicMirror ✓
                        PM2 updated
                          DarkV @sdetweil
                          saving custom.css
                          git fetch rc=0
                          On branch master
                          Untracked files:
                          core
                          css/save_custom.css
                          run-start.sh
                          installers/mm.sh
                          package-lock.json
                          erasing lock files
                          removing git alias
                          On branch master
                          Untracked files:
                          core
                          run-start.sh
                          saving custom.css
                          git fetch rc=0
                          On branch master
                          Untracked files:
                          core
                          css/save_custom.css
                          run-start.sh
                          installers/mm.sh
                          erasing lock files
                          merge result rc= 0
                          2 ± CHANGELOG.md
                          100 ± LICENSE.md
                          2 ± css/main.css
                          Installing fonts …
                          removing git alias
                          npm notice
                          npm notice
                          old : /usr/bin/node
                          $ pm2 update
                                        https://pm2.io/
                                          $ pm2 plus
                          [PM2] MagicMirror ✓
                          PM2 updated
                          saving custom.css
                          git fetch rc=0
                          On branch master
                          Untracked files:
                          core
                          css/save_custom.css
                          run-start.sh
                          installers/mm.sh
                          erasing lock files
                          removing git alias
                          On branch master
                          Untracked files:
                          core
                          run-start.sh
                          [PM2] MagicMirror ✓
                          PM2 updated
                            sdetweil @DarkV
                            that is not in my repo currently
                            did you git clone the MagicMirror_scripts repo and are executing from the clone??
                            don’t do that… execute by copy/paste the lines on the github page
                              sdetweil @DarkV
                              @DarkV has node 20.5.1
                              that is the bad version
                              sudo apt-get remove nodejs npm -y
                              rename the log file out of the way. we don’t need info from Oct 2 now
                              new log will be created
                                DarkV @sdetweil
                                @sdetweil Processing triggers for man-db (2.9.4-2) …
                                junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                bash: line 209: /usr/local/bin/node: No such file or directory
                                /usr/bin/env: ‘node’: No such file or directory
                                junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                                apply: line 176: /usr/local/bin/node: No such file or directory
                                apply: line 209: /usr/local/bin/node: No such file or directory
                                MagicMirror running under control of PM2, stopping
                                  sdetweil @DarkV
                                  @DarkV show me the ~/MagicMirror/installers/upgrade.log
                                  looks like this is a hybrid os… 64 bit kernel and 32 bit runtime… and the wrong architecture node was installed
                                  so, again do this,
                                  hash -r
                                  hash -r
                                  node -v
                                  should get not found
                                  then do
                                  which node
                                  show the results, nothing means not found
                                  if there is a result do
                                  node -v
                                    DarkV @sdetweil
                                    @sdetweil Reading package lists… Done
                                    Building dependency tree… Done
                                    Reading state information… Done
                                    Package ‘npm’ is not installed, so not removed
                                    libfuse2 raspinfo
                                    The following packages will be REMOVED:
                                    nodejs
                                    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                                    After this operation, 183 MB disk space will be freed.
                                    (Reading database … 108415 files and directories currently installed.)
                                    Removing nodejs (20.5.1-deb-1nodesource1) …
                                    dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
                                    junior@MAGIC-MIRROR:~ $ hash -r
                                    junior@MAGIC-MIRROR:~ $ node -v
                                    -bash: /usr/local/bin/node: No such file or directory
                                    junior@MAGIC-MIRROR:~ $ which node
                                    /usr/local/bin/node
                                      sdetweil @DarkV
                                      @DarkV oh such joy
                                      sudo n ls
                                      sudo n prune
                                      sudo n uninstall
                                      hash -r
                                      which node
                                        DarkV @sdetweil
                                        @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
                                        login as: junior
                                        junior@192.168.2.52’s password:
                                        The programs included with the Debian GNU/Linux system are free software;
                                        the exact distribution terms for each program are described in the
                                        individual files in /usr/share/doc/*/copyright.
                                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                        permitted by applicable law.
                                        Last login: Tue Oct 31 12:51:37 2023
                                        junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
                                        libfuse2 raspinfo
                                        nodejs
                                        /usr/local/bin/node
                                        junior@MAGIC-MIRROR:~ $ ^C
                                        junior@MAGIC-MIRROR:~ $ sudo n ls
                                        node/20.8.0
                                        junior@MAGIC-MIRROR:~ $ sudo n prune
                                        /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
                                        node/20.8.0
                                        junior@MAGIC-MIRROR:~ $ sudo n uninstall
                                        Do you wish to delete node and npm from /usr/local? y
                                        Uninstalling node and npm
                                        /usr/local/bin/node
                                        /usr/local/bin/npm
                                        /usr/local/bin/npx
                                        /usr/local/bin/corepack
                                        /usr/local/include/node
                                        /usr/local/lib/node_modules/npm
                                        /usr/local/lib/node_modules/corepack
                                        /usr/local/share/doc/node
                                        /usr/local/share/man/man1/node.1
                                        which node
                                          sdetweil @DarkV
                                          @DarkV ok,
                                          two more commands for info before running
                                          lsb_release -a
                                          file /bin/bash
                                          NOW try to run my upgrade script… note that it will NOT install node in test mode…
                                          so you have to use the second link that adds the apply parm
                                            DarkV @sdetweil
                                            file /bin/bash
                                            curl: (18) transfer closed with 23780100 bytes remaining to read
                                            xz: (stdin): Unexpected end of input
                                            tar: Unexpected EOF in archive
                                            tar: Error is not recoverable: exiting now
                                            Error: failed to download archive for 20.8.0
                                            Installed Node version: v20.5.1
                                            libfuse2 raspinfo
                                            node version is
                                            Node.js installation Done! version=v20.5.1
                                            npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
