    Failed Update
    45 Posts 3 Posters 17.1k Views 3 Watching
      sdetweil @DarkV
      @DarkV you have to stop your running mm first
      pm2 stop all
        DarkV @sdetweil
        @sdetweil said in Failed Update:
        pm2 stop all
        I can now update because that worked—many thanks for your assistance.
          sdetweil @DarkV
          @DarkV were u able to update successfully?
            DarkV @sdetweil
            @sdetweil it goes through the update process successfully, but on the mirror, it still reports that it is 3 updates behind upon reboot
              sdetweil @DarkV
              @DarkV well then it didn’t do the upgrade
              this is a two step process( two links on the page)
              test, alert any issues, files might be overwritten, etc
              make no changes
              apply, DO THE UPGRADE
              except, if its the same version is already installed.
              DON’T DO IT AGAIN…
              but if you change the apply parm to force
              then it will
              show me the ~/MagicMirror/installers/upgrade.log
                DarkV @sdetweil
                Upgrade started - Sun Oct 2 10:41:43 BST 2022
                system is Linux MAGIC-MIRROR 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022 armv7l GNU/Linux
                the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                Check current Node installation …
                Minimum Node version: v16.9.1
                Installed Node version: v16.17.1
                No Node.js upgrade necessary.
                Check current NPM installation …
                Minimum npm version: V7.11.2
                Installed npm version: V8.15.0
                No npm upgrade necessary.
                saving custom.css
                remote name = origin
                upgrading from version 2.20.0 to 2.21.0
                fetching latest revisions
                git fetch rc=0
                current branch = master
                On branch master
                Your branch is behind ‘origin/master’ by 4694 commits, and can be fast-forwarded.
                (use “git pull” to update your local branch)
                (use “git add …” to update what will be committed)
                (use “git restore …” to discard changes in working directory)
                modified: installers/mm.sh
                modified: package-lock.json
                Untracked files:
                (use “git add …” to include in what will be committed)
                core
                css/save_custom.css
                installers/mm_temp.sh
                installers/pm2_MagicMirror.json
                installers/pm2_MagicMirror_new.json
                run-start.sh
                no changes added to commit (use “git add” and/or “git commit -a”)
                there are 2 local files that are different than the master repo
                installers/mm.sh
                package-lock.json
                save/restore files selection = y
                erasing lock files
                Saved working directory and index state WIP on master: 30d5bfe5 Merge pull request #2873 from MichMich/develop
                test merge result rc=‘’ , if empty, no conflicts
                skipping merge, only test run
                downloading dumpactivemodules script
                processing for module MMM-Tools please wait
                skipped processing for MMM-Tools, doing test run
                processing complete for module MMM-Tools
                restoring custom.css
                removing git alias
                test run, restoring files stashed
                Removing vendor/package-lock.json
                Removing package-lock.json
                Removing fonts/package-lock.json
                On branch master
                (use “git add/rm …” to update what will be committed)
                deleted: fonts/package-lock.json
                deleted: package-lock.json
                deleted: vendor/package-lock.json
                Untracked files:
                core
                run-start.sh
                Dropped refs/stash@{0} (0640a953f8283b8d55b598386c17d310f8a75680)
                Upgrade ended - Sun Oct 2 10:41:58 BST 2022
                Upgrade started - Sun Oct 2 10:42:15 BST 2022
                user requested to apply changes
                doing test run = false
                saving custom.css
                git fetch rc=0
                On branch master
                Untracked files:
                core
                css/save_custom.css
                run-start.sh
                there are 1 local files that are different than the master repo
                installers/mm.sh
                erasing lock files
                executing merge, apply specified
                merge result rc= 0
                Updating 30d5bfe5…9e029304 Fast-forward .github/ISSUE_TEMPLATE.md
                4 ± .github/workflows/automated-tests.yaml
                4 ± .github/workflows/codecov-test-suites.yaml
                2 ± CHANGELOG.md
                100 ± LICENSE.md
                2 ± css/main.css
                18 ± fonts/package-lock.json
                28 ± fonts/package.json
                4 ± js/node_helper.js
                17 ± modules/default/calendar/README.md
                0 modules/default/calendar/calendar.js
                21 ± modules/default/calendar/calendarutils.js
                37 ± modules/default/calendar/node_helper.js
                8 + modules/default/currentweather/currentweather.js
                33 - modules/default/defaultmodules.js
                2 ± modules/default/newsfeed/newsfeedfetcher.js
                13 + modules/default/weather/README.md
                2 ± modules/default/weather/current.njk
                0 modules/default/weather/providers/README.md
                0 modules/default/weather/providers/darksky.js
                0 …/default/weather/providers/openweathermap.js
                0 modules/default/weather/providers/smhi.js
                61 ± modules/default/weather/providers/ukmetoffice.js
                0 modules/default/weather/providers/weatherbit.js
                26 ± modules/default/weather/providers/weathergov.js
                0 modules/default/weather/weatherobject.js
                0 modules/default/weatherforecast/weatherforecast.js
                33 - package-lock.json
                3885 ++++++++++±-------- package.json
                38 ± tests/configs/data/calendar_test_recurring.ics
                2 ± tests/e2e/env_spec.js
                17 ± tests/e2e/global-setup.js
                57 ± tests/e2e/modules/alert_spec.js
                9 ± tests/e2e/modules/calendar_spec.js
                111 ± tests/e2e/modules/clock_es_spec.js
                47 ± tests/e2e/modules/clock_spec.js
                77 ± tests/e2e/modules/compliments_spec.js
                60 ± tests/e2e/modules/helloworld_spec.js
                18 ± tests/e2e/modules/newsfeed_spec.js
                48 ± tests/e2e/modules/weather_spec.js
                225 ± tests/e2e/modules_display_spec.js
                10 ± tests/e2e/modules_position_spec.js
                9 ± tests/e2e/translations_spec.js
                6 ± tests/e2e/without_modules.js
                12 ± …/snapshots/updatenotification_spec.js.snap
                6 ± translations/en.json
                1 - vendor/package-lock.json
                42 ± vendor/package.json
                6 ± vendor/vendor.js
                0 49 files changed, 2858 insertions(+), 2243 deletions(-)
                mode change 100755 => 100644 modules/default/calendar/README.md
                mode change 100755 => 100644 modules/default/calendar/calendar.js delete mode 100644 modules/default/currentweather/currentweather.js
                mode change 100755 => 100644 modules/default/weather/README.md
                mode change 100755 => 100644 modules/default/weather/current.njk
                mode change 100755 => 100644 modules/default/weather/providers/README.md
                mode change 100755 => 100644 modules/default/weather/providers/darksky.js
                mode change 100755 => 100644 modules/default/weather/providers/openweathermap.js
                mode change 100755 => 100644 modules/default/weather/providers/ukmetoffice.js
                mode change 100755 => 100644 modules/default/weather/providers/weathergov.js
                mode change 100755 => 100644 modules/default/weather/weatherobject.js delete mode 100644 modules/default/weatherforecast/weatherforecast.js
                mode change 100755 => 100644 vendor/package.json
                mode change 100755 => 100644 vendor/vendor.js
                processor architecture is armv7l
                npm WARN invalid config omit=“dev --no-audit --no-fund --no-update-notifier” set in command line options
                npm WARN invalid config Must be one or more of: dev, optional, peer
                magicmirror@2.21.0 postinstall
                npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                magicmirror@2.21.0 install-vendor
                echo "Installing vendor files …
                " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                changed 3 packages in 9s
                magicmirror@2.21.0 install-fonts
                echo "Installing fonts …
                " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                Installing fonts …
                changed 2 packages in 4s
                magicmirror@2.21.0 prepare
                [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                husky - Git hooks installed
                added 455 packages, removed 3 packages, changed 13 packages, and audited 754 packages in 3m
                91 packages are looking for funding
                run npm fund for details
                3 moderate severity vulnerabilities
                To address all issues (including breaking changes), run:
                npm audit fix --force
                Run npm audit for details.
                npm install completed - Sun Oct 2 10:45:27 BST 2022 on base
                fixing sandbox permissions
                added 3 packages, and audited 4 packages in 3s
                1 package is looking for funding
                found 0 vulnerabilities
                removing git alias
                we stashed a set of files that appear changed from the latest repo versions. you should review them
                Upgrade ended - Sun Oct 2 10:45:33 BST 2022
                Upgrade started - Tue Oct 17 12:57:21 BST 2023
                system is Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                Minimum Node version: v20.8.0
                Installed Node version: v16.20.2
                Node should be upgraded.
                A Node process is currently running. Can’t upgrade.
                Please quit all Node processes and restart the update.
                junior 18317 18316 0 Oct07 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
                Upgrade started - Tue Oct 17 12:58:30 BST 2023
                junior 8378 8377 5 12:58 0 00:00:00 node ./node_modules/.bin/electron js/electron.js
                Upgrade started - Tue Oct 17 13:04:45 BST 2023
                junior 8378 8377 0 12:58 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                Upgrade started - Sun Oct 22 09:24:16 BST 2023
                junior 3451 3450 0 Oct17 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                Upgrade started - Tue Oct 24 11:04:00 BST 2023
                n (node version manager tool) not installed, doing test run, install skipped
                Upgrade started - Tue Oct 24 11:04:44 BST 2023
                added 1 package, and audited 2 packages in 2s
                npm notice
                npm notice New major version of npm available! 8.19.4 -> 10.2.1
                npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.1
                npm notice Run npm install -g npm@10.2.1 to update!
                npm notice
                installing : node-v20.8.0
                mkdir : /usr/local/n/versions/node/20.8.0
                fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-arm64.tar.xz
                copying : node/20.8.0
                installed : (with npm 10.1.0)
                Note: the node command changed location and the old location may be remembered in your current shell.
                old : /usr/bin/node
                new : /usr/local/bin/node
                If “node --version” shows the old version then start a new shell, or reset the location hash with:
                hash -r (for bash, zsh, ash, dash, and ksh)
                rehash (for csh and tcsh)
                forcing low Node version
                Installed Node version: V1.0.0
                Upgrade started - Tue Oct 24 13:23:22 BST 2023
                node not installed, trying via apt-get
                Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (16.20.2-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                npm not installed, trying via apt-get
                Installing Node.js …
                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease
                Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_10.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Get:3 https://deb.nodesource.com/node_20.x bullseye InRelease [4,586 B] Get:4 https://deb.nodesource.com/node_20.x bullseye/main armhf Packages [783 B] Fetched 5,369 B in 1s (4,513 B/s) Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                Node.js installation Done! version=
                pm2 installed, checking version 5.2.0 vs 5.3.0
                pm2 same major version, so updating
                added 4 packages, removed 30 packages, and changed 153 packages in 18s
                13 packages are looking for funding
                Be sure to have the latest version by doing npm install pm2@latest -g before doing this procedure.
                In-memory PM2 is out-of-date, do:
                $ pm2 update
                In memory PM2 version: 5.2.0
                Local PM2 version: 5.3.0
                              https://pm2.io/
                 Harden your Node.js Production Environment
                  - Real-time Monitoring Web Interface
                  - Pro Active Alerting System
                  - Production Profiling for Memory and CPU
                  - PM2 Runtime High Availability Fallback
                         Start using it by typing:
                                $ pm2 plus
                [PM2] Applying action deleteProcessId on app [all](ids: [ 0 ])
                [PM2] MagicMirror ✓
                [PM2] [v] All Applications Stopped
                [PM2] [v] PM2 Daemon Stopped
                [PM2] Spawning PM2 daemon with pm2_home=/home/junior/.pm2
                [PM2] Restoring processes located in /home/junior/.pm2/dump.pm2
                [PM2] Process /home/junior/MagicMirror/installers/mm.sh restored
                PM2 updated
                Upgrade started - Tue Oct 24 13:56:39 BST 2023
                node not installed, doing test run, install skipped
                junior 1519 1518 0 13:37 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                Upgrade started - Tue Oct 24 13:57:20 BST 2023
                Node.js upgrade defered, doing test run
                Minimum npm version: V10.1.0
                Installed npm version: V10.1.0
                saving custom.css
                upgrading from version 2.22.0 to 2.25.0
                git fetch rc=0
                On branch master
                Your branch is behind ‘origin/master’ by 3 commits, and can be fast-forwarded.
                Untracked files:
                core
                css/save_custom.css
                installers/stashed_files
                run-start.sh
                installers/mm.sh
                erasing lock files
                Saved working directory and index state WIP on master: f14e9561 Create Thai Language file (#3028)
                no modules found needing npm refresh
                removing git alias
                On branch master
                Untracked files:
                core
                run-start.sh
                Dropped refs/stash@{0} (c813d55595387ff98151af075aa3d1f202d8f8c3)
                Upgrade ended - Tue Oct 24 13:57:34 BST 2023
                Upgrade started - Tue Oct 24 13:57:52 BST 2023
                Reading package lists… Building dependency tree… Reading state information… nodejs is already the newest version (20.5.1-deb-1nodesource1). The following packages were automatically installed and are no longer required: libfuse2 raspinfo Use ‘sudo apt autoremove’ to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease
                Node release info = ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ SCRIPT DEPRECATION WARNING This script, located at https://deb.nodesource.com/setup_X, used to install Node.js is deprecated now and will eventually be made inactive. Please visit the NodeSource distributions Github and follow the instructions to migrate your repo. https://github.com/nodesource/distributions The NodeSource Node.js Linux distributions GitHub repository contains information about which versions of Node.js and which Linux distributions are supported and how to install it. https://github.com/nodesource/distributions SCRIPT DEPRECATION WARNING ================================================================================ ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ================================================================================ TO AVOID THIS WAIT MIGRATE THE SCRIPT Continuing in 60 seconds (press Ctrl-C to abort) … ## Installing the NodeSource Node.js 20.x repo… ## Populating apt-get cache… + apt-get update Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Confirming “bullseye” is supported… + curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_20.x/dists/bullseye/Release’ ## Adding the NodeSource signing key to your keyring… + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 20.x repo… + echo ‘deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ > /etc/apt/sources.list.d/nodesource.list + echo ‘deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x bullseye main’ >> /etc/apt/sources.list.d/nodesource.list ## Running apt-get update for you… + apt-get update Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_20.x bullseye InRelease Reading package lists… ## Run sudo apt-get install -y nodejs to install Node.js 20.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo “deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main” | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                pm2 installed, checking version 5.3.0 vs 5.3.0
                changed 157 packages in 15s
                [PM2] MagicMirror ✓
                PM2 updated
                  DarkV @sdetweil
                  saving custom.css
                  git fetch rc=0
                  On branch master
                  Untracked files:
                  core
                  css/save_custom.css
                  run-start.sh
                  installers/mm.sh
                  package-lock.json
                  erasing lock files
                  removing git alias
                  On branch master
                  Untracked files:
                  core
                  run-start.sh
                  saving custom.css
                  git fetch rc=0
                  On branch master
                  Untracked files:
                  core
                  css/save_custom.css
                  run-start.sh
                  installers/mm.sh
                  erasing lock files
                  merge result rc= 0
                  2 ± CHANGELOG.md
                  100 ± LICENSE.md
                  2 ± css/main.css
                  Installing fonts …
                  removing git alias
                  npm notice
                  npm notice
                  old : /usr/bin/node
                  $ pm2 update
                                https://pm2.io/
                                  $ pm2 plus
                  [PM2] MagicMirror ✓
                  PM2 updated
                  saving custom.css
                  git fetch rc=0
                  On branch master
                  Untracked files:
                  core
                  css/save_custom.css
                  run-start.sh
                  installers/mm.sh
                  erasing lock files
                  removing git alias
                  On branch master
                  Untracked files:
                  core
                  run-start.sh
                  [PM2] MagicMirror ✓
                  PM2 updated
                    sdetweil @DarkV
                    @DarkV said in Failed Update:
                    that is not in my repo currently
                    did you git clone the MagicMirror_scripts repo and are executing from the clone??
                    don’t do that… execute by copy/paste the lines on the github page
                      sdetweil @DarkV
                      @DarkV has node 20.5.1
                      that is the bad version
                      sudo apt-get remove nodejs npm -y
                      rename the log file out of the way. we don’t need info from Oct 2 now
                      new log will be created
                        DarkV @sdetweil
                        @sdetweil Processing triggers for man-db (2.9.4-2) …
                        junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                        update log will be in /home/junior/MagicMirror/installers/upgrade.log
                        bash: line 209: /usr/local/bin/node: No such file or directory
                        /usr/bin/env: ‘node’: No such file or directory
                        junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                        apply: line 176: /usr/local/bin/node: No such file or directory
                        apply: line 209: /usr/local/bin/node: No such file or directory
                        MagicMirror running under control of PM2, stopping
                          sdetweil @DarkV
                          @DarkV show me the ~/MagicMirror/installers/upgrade.log
                          looks like this is a hybrid os… 64 bit kernel and 32 bit runtime… and the wrong architecture node was installed
                          so, again do this,
                          hash -r
                          hash -r
                          node -v
                          should get not found
                          then do
                          which node
                          show the results, nothing means not found
                          if there is a result do
                          node -v
                            DarkV @sdetweil
                            @sdetweil Reading package lists… Done
                            Building dependency tree… Done
                            Reading state information… Done
                            Package ‘npm’ is not installed, so not removed
                            libfuse2 raspinfo
                            The following packages will be REMOVED:
                            nodejs
                            0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                            After this operation, 183 MB disk space will be freed.
                            (Reading database … 108415 files and directories currently installed.)
                            Removing nodejs (20.5.1-deb-1nodesource1) …
                            dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
                            junior@MAGIC-MIRROR:~ $ hash -r
                            junior@MAGIC-MIRROR:~ $ node -v
                            -bash: /usr/local/bin/node: No such file or directory
                            junior@MAGIC-MIRROR:~ $ which node
                            /usr/local/bin/node
                              sdetweil @DarkV
                              @DarkV oh such joy
                              sudo n ls
                              sudo n prune
                              sudo n uninstall
                              hash -r
                              which node
                                DarkV @sdetweil
                                @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
                                login as: junior
                                junior@192.168.2.52’s password:
                                The programs included with the Debian GNU/Linux system are free software;
                                the exact distribution terms for each program are described in the
                                individual files in /usr/share/doc/*/copyright.
                                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                permitted by applicable law.
                                Last login: Tue Oct 31 12:51:37 2023
                                junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
                                libfuse2 raspinfo
                                nodejs
                                /usr/local/bin/node
                                junior@MAGIC-MIRROR:~ $ ^C
                                junior@MAGIC-MIRROR:~ $ sudo n ls
                                node/20.8.0
                                junior@MAGIC-MIRROR:~ $ sudo n prune
                                /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
                                node/20.8.0
                                junior@MAGIC-MIRROR:~ $ sudo n uninstall
                                Do you wish to delete node and npm from /usr/local? y
                                Uninstalling node and npm
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                /usr/local/bin/npx
                                /usr/local/bin/corepack
                                /usr/local/include/node
                                /usr/local/lib/node_modules/npm
                                /usr/local/lib/node_modules/corepack
                                /usr/local/share/doc/node
                                /usr/local/share/man/man1/node.1
                                which node
                                  sdetweil @DarkV
                                  @DarkV ok,
                                  two more commands for info before running
                                  lsb_release -a
                                  file /bin/bash
                                  NOW try to run my upgrade script… note that it will NOT install node in test mode…
                                  so you have to use the second link that adds the apply parm
                                    DarkV @sdetweil
                                    file /bin/bash
                                    curl: (18) transfer closed with 23780100 bytes remaining to read
                                    xz: (stdin): Unexpected end of input
                                    tar: Unexpected EOF in archive
                                    tar: Error is not recoverable: exiting now
                                    Error: failed to download archive for 20.8.0
                                    Installed Node version: v20.5.1
                                    libfuse2 raspinfo
                                    node version is
                                    Node.js installation Done! version=v20.5.1
                                    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                                      sdetweil @DarkV
                                      @DarkV man this is a pain
                                      one more try
                                      hash -r
                                      which node
                                      which n
                                      if which n response with empty then do
                                      sudo apt-get install n
                                      once n responds then
                                      sudo n 20.8.0	--arch armv7l
                                      hash -r
                                      node -v
                                      should say V20.8.0
                                      i notice that I didn’t copy this little part from the install script…
                                      please let me know
                                      S D 2 Replies Last reply Reply Quote 0
                                        @DarkV never mind that won’t work… need node and npm to install n… grr…
                                        ok, only way out is to redo the sd card
                                        backup your MM
                                        see https://github.com/sdetweil/MagicMirror-backup-restore
                                        copy the backup folder MM_backup off the sd card (it can save to github too)
                                        reflash the sd card with latest os
                                        boot, no updates,
                                        run install script to install MM
                                        verify it runs
                                        restore your config using my restore script (can restore directly from github too)
                                        test
                                        sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.
                                          DarkV @sdetweil
                                          @sdetweil All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.
                                          You have brought me happiness and protected me from madness. That’s a significant victory.Screenshot 2023-10-31 135119.png
                                            @DarkV before you jump off the bridge! try this
                                            hash -r
                                            make sure gone
                                            which node
                                            then
                                            sudo apt-get install nodejs:armv7l
                                            node -v
