    Failed Update
    45 Posts 3 Posters 19.1k Views 3 Watching
      DarkV @sdetweil
      @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
      login as: junior
      junior@192.168.2.52’s password:
      Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Tue Oct 31 12:51:37 2023
      junior@MAGIC-MIRROR:~ $ hash -r
      junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
      Reading package lists… Done
      Building dependency tree… Done
      Reading state information… Done
      Package ‘npm’ is not installed, so not removed
      libfuse2 raspinfo
      Use ‘sudo apt autoremove’ to remove them.
      The following packages will be REMOVED:
      nodejs
      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      After this operation, 183 MB disk space will be freed.
      (Reading database … 108415 files and directories currently installed.)
      Removing nodejs (20.5.1-deb-1nodesource1) …
      dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
      Processing triggers for man-db (2.9.4-2) …
      junior@MAGIC-MIRROR:~ $ node -v
      -bash: /usr/local/bin/node: No such file or directory
      junior@MAGIC-MIRROR:~ $ which node
      /usr/local/bin/node
      junior@MAGIC-MIRROR:~ $ ^C
      junior@MAGIC-MIRROR:~ $ sudo n ls
      node/20.8.0
      junior@MAGIC-MIRROR:~ $ sudo n prune
      /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
      node/20.8.0
      junior@MAGIC-MIRROR:~ $ sudo n uninstall
      Do you wish to delete node and npm from /usr/local? y
      Uninstalling node and npm
      /usr/local/bin/node
      /usr/local/bin/npm
      /usr/local/bin/npx
      /usr/local/bin/corepack
      /usr/local/include/node
      /usr/local/lib/node_modules/npm
      /usr/local/lib/node_modules/corepack
      /usr/local/share/doc/node
      /usr/local/share/man/man1/node.1
      which node
        sdetweil @DarkV
        @DarkV ok,
        two more commands for info before running
        lsb_release -a
        file /bin/bash
        NOW try to run my upgrade script… note that it will NOT install node in test mode…
        so you have to use the second link that adds the apply parm
          DarkV @sdetweil
          @sdetweil said in Failed Update:
          file /bin/bash
          unior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          curl: (18) transfer closed with 23780100 bytes remaining to read
          xz: (stdin): Unexpected end of input
          tar: Unexpected EOF in archive
          tar: Error is not recoverable: exiting now
          Error: failed to download archive for 20.8.0
          doing test run = false
          update log will be in /home/junior/MagicMirror/installers/upgrade.log
          Check current Node installation …
          Minimum Node version: v20.8.0
          Installed Node version: v20.5.1
          Node should be upgraded.
          Installing Node.js …
          nodejs is already the newest version (20.5.1-deb-1nodesource1).
          libfuse2 raspinfo
          node version is
          Node.js installation Done! version=v20.5.1
          npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
            sdetweil @DarkV
            @DarkV man this is a pain
            one more try
            hash -r
            which node
            which n
            if which n response with empty then do
            sudo apt-get install n
            once n responds then
            sudo n 20.8.0	--arch armv7l
            hash -r
            node -v
            should say V20.8.0
            i notice that I didn’t copy this little part from the install script…
            please let me know
            S D 2 Replies Last reply Reply Quote 0
              @DarkV never mind that won’t work… need node and npm to install n… grr…
              ok, only way out is to redo the sd card
              backup your MM
              see https://github.com/sdetweil/MagicMirror-backup-restore
              copy the backup folder MM_backup off the sd card (it can save to github too)
              reflash the sd card with latest os
              boot, no updates,
              run install script to install MM
              verify it runs
              restore your config using my restore script (can restore directly from github too)
              test
              sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.
                DarkV @sdetweil
                @sdetweil All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.
                You have brought me happiness and protected me from madness. That’s a significant victory.Screenshot 2023-10-31 135119.png
                  @DarkV before you jump off the bridge! try this
                  hash -r
                  make sure gone
                  which node
                  then
                  sudo apt-get install nodejs:armv7l
                  node -v
                    DarkV @sdetweil
                    @sdetweil I don’t know what happened, but the reply is above. Many thanks
                      sdetweil @DarkV
                      @DarkV cool… i didn’t expect that it, i’m glad!!
                        DarkV @sdetweil
                        @sdetweil I did this
                        hash -r
                        which node
                        which n
                        hash -r
                        node -v
                        Then both scripts and it went through!
                          sdetweil @DarkV
                          @DarkV said in Failed Update:
                          –arch armv7l
                          awesome… it was that sneaky little --arch parm…
                          fixing upgrade script now . sorry for your troubles
                            DarkV @sdetweil
                            @sdetweil No worries, thanks you for your time
                              sdetweil @DarkV
                              @DarkV any chance you still have the os image file you are running
                              the info says (from the upgrade.log)
                              6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                              only one I can find online says
                              6.1.21-v7+
                              trying to test fix for the problem you encountered.
                              if you still have the image file can you give me its name…
                              also, what pi is this, 3 or 4?
                              thanks
                              | edit: was able to make one
                              | install bullseye armhf
                              | edit /boot/config.txt
                              add
                              arm_64bit=1
                              then u will boot 64bit kernel, (seen with uname -a, aarch64)
                              Linux raspberrypi4 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                              and have 32 bit runtime (seen with file /bin/bash
                              /bin/bash: ELF 32-bit LSB executable
                              lavolp3L D 2 Replies Last reply Reply Quote 0
                              • lavolp3L
                                Sam, I did an update yesterday and found Node 20.8 not working on my raspbian bullseye install.
                                I had an issue mentioned by someone else here before referring a missing GLIBCXX_3.4.26 file.
                                I needed to purge and install node 18.x. Then it worked.
                                Possible that this happens for more users with Raspbian
                                Bullseye.
                                I see your upgrade script requests Node 20.8.
                                Not sure if that may be an issue for other people as well?
                                How to troubleshoot modules
                                MMM-soccer v2, MMM-AVStock
                                  sdetweil @lavolp3
                                  @lavolp3 can u send me the ~/MagicMirror/installers/upgrade.log
                                  so I can see what happened…
                                  same userid at gmail
                                    sdetweil @lavolp3
                                    @lavolp3 I check for buster and downgrade to node 18… not bullseye…
                                    interested to see the log…
                                    • lavolp3L
                                      @sdetweil Sorry I have BUSTER installed. My mistake.
                                      Here the lastlog
                                      Upgrade started - Wed Nov  1 10:25:06 CET 2023
                                      system is Linux magicmirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
                                      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                      n (node version manager tool) not installed, doing test run, install skipped
                                      Minimum Node version: v18.18.0
                                      Installed Node version: v16.20.2
                                      Upgrade started - Wed Nov  1 10:45:19 CET 2023
                                      user requested to force apply changes
                                      node not installed, trying via apt-get
                                      Reading package lists... Building dependency tree... Reading state information... nodejs is already the newest version (20.9.0-1nodesource1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      npm not installed, trying via apt-get
                                      npm NOT installed now, install now
                                      Reading package lists... Building dependency tree... Reading state information... Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: npm : Depends: nodejs (>= 6.11~) Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed Depends: node-aproba (>= 1.2~) but it is not going to be installed Depends: node-archy (>= 1.0~) but it is not going to be installed Depends: node-cacache (>= 10.0.4~) but it is not going to be installed Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed Depends: node-call-limit (>= 1.1~) but it is not going to be installed Depends: node-chownr (>= 1.0.1~) but it is not going to be installed Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed Depends: node-detect-indent (>= 5.0~) but it is not going to be installed Depends: node-detect-newline (>= 2.1~) but it is not going to be installed Depends: node-editor (>= 1.0~) but it is not going to be installed Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed Depends: node-glob (>= 7.1.2~) but it is not going to be installed Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed Depends: node-iferr (>= 0.1.5~) but it is not going to be installed Depends: node-inflight (>= 1.0.6~) but it is not going to be installed Depends: node-inherits (>= 2.0.3~) but it is not going to be installed Depends: node-ini (>= 1.3.5~) but it is not going to be installed Depends: node-npm-package-arg but it is not going to be installed Depends: node-promzard but it is not going to be installed Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed Depends: node-lazy-property (>= 1.0~) but it is not going to be installed Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed Depends: node-mississippi (>= 3.0~) but it is not going to be installed Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed Depends: node-nopt but it is not going to be installed Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed Depends: node-gyp (>= 3.6.2~) but it is not going to be installed Depends: node-resolve-from (>= 4.0~) but it is not going to be installed Depends: node-encoding but it is not going to be installed Depends: node-errno but it is not going to be installed Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed Depends: node-once (>= 1.4~) but it is not going to be installed Depends: node-opener (>= 1.4.3~) but it is not going to be installed Depends: node-osenv (>= 0.1.5~) but it is not going to be installed Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed Depends: node-ansi but it is not going to be installed Depends: node-qw (>= 1.0.1~) but it is not going to be installed Depends: node-read (>= 1.0.7~) but it is not going to be installed Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed Depends: node-request (>= 2.83~) but it is not going to be installed Depends: node-retry (>= 0.10.1~) but it is not going to be installed Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed Depends: node-semver (>= 5.5~) but it is not going to be installed Depends: node-sha (>= 2.0.1~) but it is not going to be installed Depends: node-slide (>= 1.1.6~) but it is not going to be installed Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed Depends: node-from2 but it is not going to be installed Depends: node-stream-iterate but it is not going to be installed Depends: node-ssri (>= 5.2.4~) but it is not going to be installed Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed Depends: node-tar (>= 4.4~) but it is not going to be installed Depends: node-text-table (>= 0.2~) but it is not going to be installed Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed Depends: node-unique-filename (>= 1.1~) but it is not going to be installed Depends: node-unpipe (>= 1.0~) but it is not going to be installed Depends: node-boxen (>= 1.2.1~) but it is not going to be installed Depends: node-import-lazy but it is not going to be installed Depends: node-is-npm (>= 1.0~) but it is not going to be installed Depends: node-latest-version (>= 3.0~) but it is not going to be installed Depends: node-semver-diff (>= 2.0~) but it is not going to be installed Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed Depends: node-which (>= 1.3~) but it is not going to be installed Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
                                      forcing low Node version
                                      Installed Node version: V1.0.0
                                      That was the last failed upgrade. Node V1.0.0 lol. Node 20 was installed.
                                      After that I manually purged Node, installed Node 18 and did the npm run install-mm
                                        sdetweil @lavolp3
                                        @lavolp3 ok, can you do
                                        sudo apt update --fix-missing
                                        sudo apt install -f
                                        watch out for node changing…
                                        • lavolp3L
                                          @sdetweil Sam, sorry for the confusion, everything is working. A said I had installed node 18 and then it all worked. I didn’t need help, just wanted to point out that node 20 seems to not be working with some systems. But as I see you got that covered in your script.
                                            DarkV @sdetweil
                                            @sdetweil The Image was my previous install I made in February when I migrated from SD to M2 SSD. So an older version of what I am using now.
                                            I am using PI4.
                                            • 2 / 3
