    Failed Update
    45 Posts 3 Posters 19.3k Views 3 Watching
      sdetweil @DarkV
      @DarkV said in Failed Update:
      /gpgkey/nodesource.gpg.key | gpg --dearmor
      that is not in my repo currently
      did you git clone the MagicMirror_scripts repo and are executing from the clone??
      don’t do that… execute by copy/paste the lines on the github page
        sdetweil @DarkV
        @DarkV has node 20.5.1
        that is the bad version
        sudo apt-get remove nodejs npm -y
        rename the log file out of the way. we don’t need info from Oct 2 now
        new log will be created
        D 1 Reply Last reply
          DarkV @sdetweil
          @sdetweil Processing triggers for man-db (2.9.4-2) …
          junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          update log will be in /home/junior/MagicMirror/installers/upgrade.log
          Check current Node installation …
          bash: line 209: /usr/local/bin/node: No such file or directory
          Minimum Node version: v20.8.0
          Installed Node version: V1.0.0
          Node should be upgraded.
          /usr/bin/env: ‘node’: No such file or directory
          junior@MAGIC-MIRROR:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          apply: line 176: /usr/local/bin/node: No such file or directory
          doing test run = false
          apply: line 209: /usr/local/bin/node: No such file or directory
          MagicMirror running under control of PM2, stopping
            sdetweil @DarkV
            @DarkV show me the ~/MagicMirror/installers/upgrade.log
            looks like this is a hybrid os… 64 bit kernel and 32 bit runtime… and the wrong architecture node was installed
            so, again do this,
            hash -r
            hash -r
            node -v
            should get not found
            then do
            which node
            show the results, nothing means not found
            if there is a result do
            node -v
              DarkV @sdetweil
              @sdetweil Reading package lists… Done
              Building dependency tree… Done
              Reading state information… Done
              Package ‘npm’ is not installed, so not removed
              libfuse2 raspinfo
              Use ‘sudo apt autoremove’ to remove them.
              The following packages will be REMOVED:
              nodejs
              0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
              After this operation, 183 MB disk space will be freed.
              (Reading database … 108415 files and directories currently installed.)
              Removing nodejs (20.5.1-deb-1nodesource1) …
              dpkg: warning: while removing nodejs, directory ‘/usr/lib/node_modules’ not empty so not removed
              junior@MAGIC-MIRROR:~ $ hash -r
              junior@MAGIC-MIRROR:~ $ node -v
              -bash: /usr/local/bin/node: No such file or directory
              junior@MAGIC-MIRROR:~ $ which node
              /usr/local/bin/node
                sdetweil @DarkV
                @DarkV oh such joy
                sudo n ls
                sudo n prune
                sudo n uninstall
                hash -r
                which node
                  DarkV @sdetweil
                  @sdetweil I am glad you know what all this means as I have no clue, many thanks for taking the time to help me, the wifey will kill me if this f***s up:beaming_face_with_smiling_eyes: .
                  login as: junior
                  junior@192.168.2.52’s password:
                  Linux MAGIC-MIRROR 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
                  The programs included with the Debian GNU/Linux system are free software;
                  the exact distribution terms for each program are described in the
                  individual files in /usr/share/doc/*/copyright.
                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  permitted by applicable law.
                  Last login: Tue Oct 31 12:51:37 2023
                  junior@MAGIC-MIRROR:~ $ sudo apt-get remove nodejs npm -y
                  libfuse2 raspinfo
                  nodejs
                  /usr/local/bin/node
                  junior@MAGIC-MIRROR:~ $ ^C
                  junior@MAGIC-MIRROR:~ $ sudo n ls
                  node/20.8.0
                  junior@MAGIC-MIRROR:~ $ sudo n prune
                  /usr/bin/n: line 474: /usr/local/bin/node: No such file or directory
                  node/20.8.0
                  junior@MAGIC-MIRROR:~ $ sudo n uninstall
                  Do you wish to delete node and npm from /usr/local? y
                  Uninstalling node and npm
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  /usr/local/bin/npx
                  /usr/local/bin/corepack
                  /usr/local/include/node
                  /usr/local/lib/node_modules/npm
                  /usr/local/lib/node_modules/corepack
                  /usr/local/share/doc/node
                  /usr/local/share/man/man1/node.1
                  which node
                    sdetweil @DarkV
                    @DarkV ok,
                    two more commands for info before running
                    lsb_release -a
                    file /bin/bash
                    NOW try to run my upgrade script… note that it will NOT install node in test mode…
                    so you have to use the second link that adds the apply parm
                      DarkV @sdetweil
                      @sdetweil said in Failed Update:
                      file /bin/bash
                      curl: (18) transfer closed with 23780100 bytes remaining to read
                      xz: (stdin): Unexpected end of input
                      tar: Unexpected EOF in archive
                      tar: Error is not recoverable: exiting now
                      Error: failed to download archive for 20.8.0
                      Installed Node version: v20.5.1
                      Installing Node.js …
                      nodejs is already the newest version (20.5.1-deb-1nodesource1).
                      libfuse2 raspinfo
                      node version is
                      Node.js installation Done! version=v20.5.1
                      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                        sdetweil @DarkV
                        @DarkV man this is a pain
                        one more try
                        hash -r
                        which node
                        which n
                        if which n response with empty then do
                        sudo apt-get install n
                        once n responds then
                        sudo n 20.8.0	--arch armv7l
                        hash -r
                        node -v
                        should say V20.8.0
                        i notice that I didn’t copy this little part from the install script…
                        please let me know
                        S D 2 Replies Last reply
                          @DarkV never mind that won’t work… need node and npm to install n… grr…
                          ok, only way out is to redo the sd card
                          backup your MM
                          see https://github.com/sdetweil/MagicMirror-backup-restore
                          copy the backup folder MM_backup off the sd card (it can save to github too)
                          reflash the sd card with latest os
                          boot, no updates,
                          run install script to install MM
                          verify it runs
                          restore your config using my restore script (can restore directly from github too)
                          test
                          sorry, the nodejs guys made a mess of this as they changed the node install process too… and it doesn’t work.
                            DarkV @sdetweil
                            @sdetweil All is OK. I am so grateful for all of your assistance. In my opinion, what you performed was alchemy or witchcraft. I’ve been attempting to identify the problem and have made multiple unsuccessful attempts. An old picture I had from a few months ago was my saviour. My wife was becoming tired of my futile attempts at updating.
                            You have brought me happiness and protected me from madness. That’s a significant victory.Screenshot 2023-10-31 135119.png
                              @DarkV before you jump off the bridge! try this
                              hash -r
                              make sure gone
                              which node
                              then
                              sudo apt-get install nodejs:armv7l
                              node -v
                                DarkV @sdetweil
                                @sdetweil I don’t know what happened, but the reply is above. Many thanks
                                  sdetweil @DarkV
                                  @DarkV cool… i didn’t expect that it, i’m glad!!
                                    DarkV @sdetweil
                                    @sdetweil I did this
                                    hash -r
                                    which node
                                    which n
                                    hash -r
                                    node -v
                                    Then both scripts and it went through!
                                      sdetweil @DarkV
                                      –arch armv7l
                                      awesome… it was that sneaky little --arch parm…
                                      fixing upgrade script now . sorry for your troubles
                                        DarkV @sdetweil
                                        @sdetweil No worries, thanks you for your time
                                          sdetweil @DarkV
                                          @DarkV any chance you still have the os image file you are running
                                          the info says (from the upgrade.log)
                                          6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye
                                          only one I can find online says
                                          6.1.21-v7+
                                          trying to test fix for the problem you encountered.
                                          if you still have the image file can you give me its name…
                                          also, what pi is this, 3 or 4?
                                          thanks
                                          | edit: was able to make one
                                          | install bullseye armhf
                                          | edit /boot/config.txt
                                          add
                                          arm_64bit=1
                                          then u will boot 64bit kernel, (seen with uname -a, aarch64)
                                          Linux raspberrypi4 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64 GNU/Linux
                                          and have 32 bit runtime (seen with file /bin/bash
                                          /bin/bash: ELF 32-bit LSB executable
                                          lavolp3L D 2 Replies Last reply
                                          • lavolp3L
                                            Sam, I did an update yesterday and found Node 20.8 not working on my raspbian bullseye install.
                                            I had an issue mentioned by someone else here before referring a missing GLIBCXX_3.4.26 file.
                                            I needed to purge and install node 18.x. Then it worked.
                                            Possible that this happens for more users with Raspbian
                                            Bullseye.
                                            I see your upgrade script requests Node 20.8.
                                            Not sure if that may be an issue for other people as well?
                                            How to troubleshoot modules
                                            MMM-soccer v2, MMM-AVStock
                                            S 2 Replies Last reply
                                            • 2 / 3
