    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 9.9k Views 4 Watching
      sdetweil @RIKKO14
      @RIKKO14
      yes that module is missing a library
      if you run my upgrade script with force, it should fix it
        RIKKO14
        I do :
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        Minimum Node version: v20.8.0
        Installed Node version: v20.8.0
        No Node.js upgrade necessary.
        Minimum npm version: V10.1.0
        Installed npm version: V10.1.0
        No npm upgrade necessary.
        saving custom.css
        upgrading from version 2.25.0 to 2.25.0
        fetching latest revisions
        updating dependencies for active modules with package.json files
        	processing for module EXT-UpdateNotification please wait
        	skipped processing for EXT-UpdateNotification, doing test run
        	processing complete for module EXT-UpdateNotification
        	processing for module MMM-GoogleAssistant please wait
        	skipped processing for MMM-GoogleAssistant, doing test run
        	processing complete for module MMM-GoogleAssistant
        	processing for module EXT-Alert please wait
        	skipped processing for EXT-Alert, doing test run
        	processing complete for module EXT-Alert
        	processing for module EXT-Bring please wait
        	skipped processing for EXT-Bring, doing test run
        	processing complete for module EXT-Bring
        	processing for module EXT-Browser please wait
        	skipped processing for EXT-Browser, doing test run
        	processing complete for module EXT-Browser
        	processing for module EXT-Detector please wait
        	skipped processing for EXT-Detector, doing test run
        	processing complete for module EXT-Detector
        	processing for module EXT-Librespot please wait
        	skipped processing for EXT-Librespot, doing test run
        	processing complete for module EXT-Librespot
        	processing for module EXT-Photos please wait
        	skipped processing for EXT-Photos, doing test run
        	processing complete for module EXT-Photos
        	processing for module EXT-RadioPlayer please wait
        	skipped processing for EXT-RadioPlayer, doing test run
        	processing complete for module EXT-RadioPlayer
        	processing for module EXT-ScreenManager please wait
        	skipped processing for EXT-ScreenManager, doing test run
        	processing complete for module EXT-ScreenManager
        	processing for module EXT-Spotify please wait
        	skipped processing for EXT-Spotify, doing test run
        	processing complete for module EXT-Spotify
        	processing for module Gateway please wait
        	skipped processing for Gateway, doing test run
        	processing complete for module Gateway
        	processing for module MMM-DHT-Sensor please wait
        	skipped processing for MMM-DHT-Sensor, doing test run
        	processing complete for module MMM-DHT-Sensor
        	processing for module MMM-RainForecast-FR please wait
        	skipped processing for MMM-RainForecast-FR, doing test run
        	processing complete for module MMM-RainForecast-FR
        	processing for module MMM-TomTomTraffic please wait
        	skipped processing for MMM-TomTomTraffic, doing test run
        	processing complete for module MMM-TomTomTraffic
        	processing for module MMM-MovieListings please wait
        	skipped processing for MMM-MovieListings, doing test run
        	processing complete for module MMM-MovieListings
        	processing for module MMM-MarineWeather please wait
        	skipped processing for MMM-MarineWeather, doing test run
        	processing complete for module MMM-MarineWeather
        restoring custom.css
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        doing test run = false
        force: ligne 450 : [: -le : opérateur unaire attendu
        saving custom.css
        > magicmirror@2.25.0 postinstall
        > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        > magicmirror@2.25.0 install-vendor
        > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        up to date in 3s
        > magicmirror@2.25.0 install-fonts
        > echo "Installing fonts ...
        > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        up to date in 4s
        > magicmirror@2.25.0 prepare
        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
        no husky installed.
        added 334 packages in 2m
        97 packages are looking for funding
          run `npm fund` for details
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        > EXT-UpdateNotification@2.1.0 preinstall
        > installer/preinstall.sh
        Welcome to EXT-UpdateNotification v2.1.0
        No root checking...
        Checking EXT-UpdateNotification: pi/pi
        Checking MagicMirror: pi/pi
        Checking OS...
        OS Detected: linux-gnueabihf (raspbian 11 aarch64)
        Installing all npm libraries...
        > EXT-UpdateNotification@2.1.0 postinstall
        > installer/postinstall.sh
        Minify Main code
        Found: 8 files to minify
        Process File: ../EXT-UpdateNotification.js
        Process File: ../components/gitCheck.js
        Process File: ../components/loadLibraries.js
        Process File: ../components/npmCheck.js
        Process File: ../components/parseData.js
        Process File: ../components/update.js
        Process File: ../node_helper.js
        Process File: ../components/check.js
        Done
        Support is now moved in a dedicated Server: https://forum.bugsounet.fr
        @bugsounet
        EXT-UpdateNotification is now installed !
        added 248 packages, and audited 249 packages in 50s
        39 packages are looking for funding
        found 0 vulnerabilities
        > MMM-GoogleAssistant@5.4.0 preinstall
        Welcome to MMM-GoogleAssistant v5.4.0
        No root checking...
        Checking MMM-GoogleAssistant: pi/pi
        Checking OS...
        > MMM-GoogleAssistant@5.4.0 postinstall
        > installer/postinstall.sh -m -b
        Minify Main code...
        Found: 27 files to minify
        Process File: ../MMM-GoogleAssistant.js
        Process File: ../components/shellExec.js
        Process File: ../components/searchOnGoogle.js
        Process File: ../components/screenParser.js
        Process File: ../components/recipes.js
        Process File: ../components/proto-loader.js
        Process File: ../components/platform.js
        Process File: ../components/lpcm16.js
        Process File: ../components/googleSearch.js
        Process File: ../components/googleAssistant.js
        Process File: ../components/embedded-assistant.js
        Process File: ../components/conversation.js
        Process File: ../components/configMerge.js
        Process File: ../components/auth.js
        Process File: ../components/assistantSearch.js
        Process File: ../components/assistantResponse.js
        Process File: ../components/assistantConverse.js
        Process File: ../components/activateProcess.js
        Process File: ../components/activateAssistant.js
        Process File: ../components/Hooks.js
        Process File: ../components/Gateway.js
        Process File: ../components/GAConfig.js
        Process File: ../components/BufferToMP3.js
        Process File: ../components/Assistant.js
        Done
        @bugsounet
        MMM-GoogleAssistant is now installed !
        added 158 packages in 32s
        52 packages are looking for funding
        > EXT-Alert@1.2.3 preinstall
        Welcome to EXT-Alert v1.2.3
        No root checking...
        Checking EXT-Alert: pi/pi
        Checking OS...
        > EXT-Alert@1.2.3 postinstall
        Minify Main code...
        Found: 5 files to minify
        Process File: ../EXT-Alert.js
        Process File: ../components/AlertInit.js
        Process File: ../components/AlertDisplay.js
        Process File: ../components/AlertCommander.js
        Done
        @bugsounet
        EXT-Alert is now installed !
        added 42 packages in 12s
        13 packages are looking for funding
        > EXT-Bring@1.2.2 preinstall
        Welcome to EXT-Bring v1.2.2
        No root checking...
        Checking EXT-Bring: pi/pi
        Checking OS...
        > EXT-Bring@1.2.2 postinstall
        Minify Main code...
        Process File: ../EXT-Bring.js
        Process File: ../components/bring-lib.js
        Done
        @bugsounet
        EXT-Bring is now installed !
        added 50 packages in 14s
        16 packages are looking for funding
        > EXT-Browser@1.2.3 preinstall
        Welcome to EXT-Browser v1.2.3
        No root checking...
        Checking EXT-Browser: pi/pi
        Checking OS...
        > EXT-Browser@1.2.3 postinstall
        Minify Main code...
        Found: 3 files to minify
        Process File: ../EXT-Browser.js
        Process File: ../components/BrowserDisplay.js
        Done
        @bugsounet
        EXT-Browser is now installed !
        added 42 packages in 7s
        npm ERR! code 255
        npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
        npm ERR! command failed
        npm ERR! command sh -c installer/postinstall.sh -r -m -b
        npm ERR! Prepare snowboy library...
        npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
        npm ERR! Failed!
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
        > EXT-Librespot@1.2.5 preinstall
        Welcome to EXT-Librespot v1.2.5
        No root checking...
        Checking EXT-Librespot: pi/pi
        Checking OS...
        > EXT-Librespot@1.2.5 postinstall
        Minify Main code...
        Found: 2 files to minify
        Process File: ../EXT-Librespot.js
        Done
        @bugsounet
        EXT-Librespot is now installed !
        added 195 packages in 26s
        25 packages are looking for funding
        > EXT-Photos@1.1.3 preinstall
        Welcome to EXT-Photos v1.1.3
        No root checking...
        Checking EXT-Photos: pi/pi
        Checking OS...
        > EXT-Photos@1.1.3 postinstall
        Minify Main code...
        Process File: ../EXT-Photos.js
        Done
        @bugsounet
        EXT-Photos is now installed !
        added 42 packages in 8s
        > EXT-RadioPlayer@1.1.6 preinstall
        > installer/preinstall.sh -d 'vlc'
        Welcome to EXT-RadioPlayer v1.1.6
        No root checking...
        Checking EXT-RadioPlayer: pi/pi
        Checking OS...
        Checking all dependencies...
        All Dependencies needed are installed !
        > EXT-RadioPlayer@1.1.6 postinstall
        Minify Main code...
        Process File: ../EXT-RadioPlayer.js
        Done
        @bugsounet
        EXT-RadioPlayer is now installed !
        added 50 packages in 11s
        14 packages are looking for funding
        > EXT-ScreenManager@1.1.0 preinstall
        Welcome to EXT-ScreenManager v1.1.0
        No root checking...
        Checking EXT-ScreenManager: pi/pi
        Checking OS...
        > EXT-ScreenManager@1.1.0 postinstall
        Minify Main code
        Process File: ../EXT-ScreenManager.js
        Done
        @bugsounet
        EXT-ScreenManager is now installed !
        added 64 packages, and audited 65 packages in 12s
        > EXT-Spotify@2.3.3 preinstall
        Welcome to EXT-Spotify v2.3.3
        No root checking...
        Checking EXT-Spotify: pi/pi
        Checking OS...
        > EXT-Spotify@2.3.3 postinstall
        Minify Main code...
        Found: 6 files to minify
        Process File: ../EXT-Spotify.js
        Process File: ../components/spotifyLib.js
        Process File: ../components/spotifyClass.js
        Process File: ../components/JSPanel.js
        Process File: ../components/CanvasLyrics.js
        Done
        @bugsounet
        EXT-Spotify is now installed !
        added 143 packages in 23s
        48 packages are looking for funding
        npm ERR! code 255
        npm ERR! path /home/pi/MagicMirror/modules/Gateway
        npm ERR! Minify Main code...
        npm ERR! node:internal/modules/cjs/loader:1051
        npm ERR!   throw err;
        npm ERR!   ^
        npm ERR!
        npm ERR! Error: Cannot find module 'esbuild'
        npm ERR! Require stack:
        npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
        npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
        npm ERR!     at require (node:internal/modules/helpers:130:18)
        npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
        npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
        npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
        npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
        npm ERR!   code: 'MODULE_NOT_FOUND',
        npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
        npm ERR! }
        npm ERR!
        npm ERR! Node.js v20.8.0
        npm ERR! Minify Failed!
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
        rebuilt dependencies successfully
        added 9 packages, and audited 10 packages in 3s
        1 package is looking for funding
        up to date, audited 1 package in 2s
        added 47 packages, and audited 48 packages in 8s
        2 moderate severity vulnerabilities
        Some issues need review, and may require choosing
        a different dependency.
        Run `npm audit` for details.
        added 4 packages, and audited 5 packages in 2s
          sdetweil @RIKKO14
          @RIKKO14 you need the word
          force
          added on the end of the upgrade command
            RIKKO14
            pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            bash: $'\E[200~bash' : commande introuvable
            saving custom.css
            up to date in 7s
            up to date in 47s
            no husky installed.
            added 334 packages in 3m
            No root checking...
            Checking OS...
            Minify Main code
            Done
            @bugsounet
            added 248 packages, and audited 249 packages in 26s
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            added 158 packages in 16s
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            added 42 packages in 5s
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            added 50 packages in 13s
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            npm ERR! code 255
            npm ERR! Failed!
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            added 195 packages in 18s
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            added 50 packages in 9s
            No root checking...
            Checking OS...
            Minify Main code
            Done
            @bugsounet
            added 64 packages, and audited 65 packages in 13s
            No root checking...
            Checking OS...
            Minify Main code...
            Done
            @bugsounet
            added 143 packages in 14s
            npm ERR! code 255
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR! }
            npm ERR!
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
            added 9 packages, and audited 10 packages in 2s
            up to date, audited 1 package in 949ms
            added 47 packages, and audited 48 packages in 7s
            pi@raspberrypi:~/MagicMirror $ pm2 stop 0
            [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
            [PM2] [MagicMirror](0) ✓
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
            pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
            npm start
            > magicmirror@2.25.0 start
            [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
            [05.11.2023 15:59.49.477] [LOG]   Loading config ...
            [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
            [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
            [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
            [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
            [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
            [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
            [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
            [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
            [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
            [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
            [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
            [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
            [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
            [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
            [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
            [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
            [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
            [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
            [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
            Require stack:
            - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
                at node:internal/modules/cjs/loader:1084:15
                at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at node:internal/modules/cjs/loader:929:27
                at Function._load (node:electron/js2c/asar_bundle:2:13327)
                at Module.require (node:internal/modules/cjs/loader:1150:19)
                at require (node:internal/modules/cjs/helpers:110:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
                at Module._compile (node:internal/modules/cjs/loader:1271:14)
                at Object..js (node:internal/modules/cjs/loader:1326:10)
                at Module.load (node:internal/modules/cjs/loader:1126:32)
                at node:internal/modules/cjs/loader:967:12
                at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
            (Use `electron --trace-warnings ...` to show where the warning was created)
            [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
            [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
            MESA-LOADER: failed to retrieve device information
            MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
            failed to load driver: kms_swrast
            MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
            failed to load swrast driver
              @RIKKO14 now another module… DHT-Sensor missing a library
              go to the module folder and
              see this topic
                RIKKO14
                I do
                cd ~/MagicMirror/modules/MMM-DHT-Sensor
                npm install
                then
                npm start
                then
                cd ~/MagicMirror/modules/MMM-GoogleAssistant
                npm run update
                npm run refresh
                then
                pm2 restart 0
                then
                sudo reboot now
                and finally everything works well
                thank you for your help
                  sdetweil @RIKKO14
                  @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                  bugsounetB 1 Reply Last reply Reply Quote 0
                  • bugsounetB
                    bugsounet Banned @sdetweil
                    @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
                      sdetweil @bugsounet
                      @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
                      I check for rebuild not refresh… will fix upgrade
                      • bugsounetB
                        @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
                          sdetweil @bugsounet
                          @bugsounet @RIKKO14
                          can either of you run this on your French systems
                          LC_ALL=C  free -m
                          should output in english
                            RIKKO14
                            @sdetweil Hello,
                            it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
                              sdetweil @RIKKO14
                              @RIKKO14 just one command run in terminal
                              returns amount of memory being used
                              my scripts use this an depend on the English text,
                              trying to make sure it comes out in English is all.
                              has no affect on system
                                MMRIZE @RIKKO14
                                @RIKKO14
                                If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.
                                  RIKKO14
                                  here it is :
                                    sdetweil @RIKKO14
                                    @RIKKO14 thank you! perfect
