    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 9.6k Views 4 Watching
      RIKKO14
      If I anderstand my MM is up to date and node is up to date too.
      So Why my MM didn’t launch ?..
        sdetweil @RIKKO14
        @RIKKO14 one command at a time
        show results of each one at a time
          sdetweil @RIKKO14
          @RIKKO14
          yes that module is missing a library
          if you run my upgrade script with force, it should fix it
            RIKKO14
            I do :
            pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            Minimum Node version: v20.8.0
            Installed Node version: v20.8.0
            No Node.js upgrade necessary.
            Minimum npm version: V10.1.0
            Installed npm version: V10.1.0
            No npm upgrade necessary.
            saving custom.css
            upgrading from version 2.25.0 to 2.25.0
            fetching latest revisions
            updating dependencies for active modules with package.json files
            	processing for module EXT-UpdateNotification please wait
            	skipped processing for EXT-UpdateNotification, doing test run
            	processing complete for module EXT-UpdateNotification
            	processing for module MMM-GoogleAssistant please wait
            	skipped processing for MMM-GoogleAssistant, doing test run
            	processing complete for module MMM-GoogleAssistant
            	processing for module EXT-Alert please wait
            	skipped processing for EXT-Alert, doing test run
            	processing complete for module EXT-Alert
            	processing for module EXT-Bring please wait
            	skipped processing for EXT-Bring, doing test run
            	processing complete for module EXT-Bring
            	processing for module EXT-Browser please wait
            	skipped processing for EXT-Browser, doing test run
            	processing complete for module EXT-Browser
            	processing for module EXT-Detector please wait
            	skipped processing for EXT-Detector, doing test run
            	processing complete for module EXT-Detector
            	processing for module EXT-Librespot please wait
            	skipped processing for EXT-Librespot, doing test run
            	processing complete for module EXT-Librespot
            	processing for module EXT-Photos please wait
            	skipped processing for EXT-Photos, doing test run
            	processing complete for module EXT-Photos
            	processing for module EXT-RadioPlayer please wait
            	skipped processing for EXT-RadioPlayer, doing test run
            	processing complete for module EXT-RadioPlayer
            	processing for module EXT-ScreenManager please wait
            	skipped processing for EXT-ScreenManager, doing test run
            	processing complete for module EXT-ScreenManager
            	processing for module EXT-Spotify please wait
            	skipped processing for EXT-Spotify, doing test run
            	processing complete for module EXT-Spotify
            	processing for module Gateway please wait
            	skipped processing for Gateway, doing test run
            	processing complete for module Gateway
            	processing for module MMM-DHT-Sensor please wait
            	skipped processing for MMM-DHT-Sensor, doing test run
            	processing complete for module MMM-DHT-Sensor
            	processing for module MMM-RainForecast-FR please wait
            	skipped processing for MMM-RainForecast-FR, doing test run
            	processing complete for module MMM-RainForecast-FR
            	processing for module MMM-TomTomTraffic please wait
            	skipped processing for MMM-TomTomTraffic, doing test run
            	processing complete for module MMM-TomTomTraffic
            	processing for module MMM-MovieListings please wait
            	skipped processing for MMM-MovieListings, doing test run
            	processing complete for module MMM-MovieListings
            	processing for module MMM-MarineWeather please wait
            	skipped processing for MMM-MarineWeather, doing test run
            	processing complete for module MMM-MarineWeather
            restoring custom.css
            pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            doing test run = false
            force: ligne 450 : [: -le : opérateur unaire attendu
            saving custom.css
            > magicmirror@2.25.0 postinstall
            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            > magicmirror@2.25.0 install-vendor
            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 3s
            > magicmirror@2.25.0 install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 4s
            > magicmirror@2.25.0 prepare
            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
            no husky installed.
            added 334 packages in 2m
            97 packages are looking for funding
              run `npm fund` for details
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            > EXT-UpdateNotification@2.1.0 preinstall
            > installer/preinstall.sh
            Welcome to EXT-UpdateNotification v2.1.0
            No root checking...
            Checking EXT-UpdateNotification: pi/pi
            Checking MagicMirror: pi/pi
            Checking OS...
            OS Detected: linux-gnueabihf (raspbian 11 aarch64)
            Installing all npm libraries...
            > EXT-UpdateNotification@2.1.0 postinstall
            > installer/postinstall.sh
            Minify Main code
            Found: 8 files to minify
            Process File: ../EXT-UpdateNotification.js
            Process File: ../components/gitCheck.js
            Process File: ../components/loadLibraries.js
            Process File: ../components/npmCheck.js
            Process File: ../components/parseData.js
            Process File: ../components/update.js
            Process File: ../node_helper.js
            Process File: ../components/check.js
            Done
            Support is now moved in a dedicated Server: https://forum.bugsounet.fr
            @bugsounet
            EXT-UpdateNotification is now installed !
            added 248 packages, and audited 249 packages in 50s
            39 packages are looking for funding
            found 0 vulnerabilities
            > MMM-GoogleAssistant@5.4.0 preinstall
            Welcome to MMM-GoogleAssistant v5.4.0
            No root checking...
            Checking MMM-GoogleAssistant: pi/pi
            Checking OS...
            > MMM-GoogleAssistant@5.4.0 postinstall
            > installer/postinstall.sh -m -b
            Minify Main code...
            Found: 27 files to minify
            Process File: ../MMM-GoogleAssistant.js
            Process File: ../components/shellExec.js
            Process File: ../components/searchOnGoogle.js
            Process File: ../components/screenParser.js
            Process File: ../components/recipes.js
            Process File: ../components/proto-loader.js
            Process File: ../components/platform.js
            Process File: ../components/lpcm16.js
            Process File: ../components/googleSearch.js
            Process File: ../components/googleAssistant.js
            Process File: ../components/embedded-assistant.js
            Process File: ../components/conversation.js
            Process File: ../components/configMerge.js
            Process File: ../components/auth.js
            Process File: ../components/assistantSearch.js
            Process File: ../components/assistantResponse.js
            Process File: ../components/assistantConverse.js
            Process File: ../components/activateProcess.js
            Process File: ../components/activateAssistant.js
            Process File: ../components/Hooks.js
            Process File: ../components/Gateway.js
            Process File: ../components/GAConfig.js
            Process File: ../components/BufferToMP3.js
            Process File: ../components/Assistant.js
            Done
            @bugsounet
            MMM-GoogleAssistant is now installed !
            added 158 packages in 32s
            52 packages are looking for funding
            > EXT-Alert@1.2.3 preinstall
            Welcome to EXT-Alert v1.2.3
            No root checking...
            Checking EXT-Alert: pi/pi
            Checking OS...
            > EXT-Alert@1.2.3 postinstall
            Minify Main code...
            Found: 5 files to minify
            Process File: ../EXT-Alert.js
            Process File: ../components/AlertInit.js
            Process File: ../components/AlertDisplay.js
            Process File: ../components/AlertCommander.js
            Done
            @bugsounet
            EXT-Alert is now installed !
            added 42 packages in 12s
            13 packages are looking for funding
            > EXT-Bring@1.2.2 preinstall
            Welcome to EXT-Bring v1.2.2
            No root checking...
            Checking EXT-Bring: pi/pi
            Checking OS...
            > EXT-Bring@1.2.2 postinstall
            Minify Main code...
            Process File: ../EXT-Bring.js
            Process File: ../components/bring-lib.js
            Done
            @bugsounet
            EXT-Bring is now installed !
            added 50 packages in 14s
            16 packages are looking for funding
            > EXT-Browser@1.2.3 preinstall
            Welcome to EXT-Browser v1.2.3
            No root checking...
            Checking EXT-Browser: pi/pi
            Checking OS...
            > EXT-Browser@1.2.3 postinstall
            Minify Main code...
            Found: 3 files to minify
            Process File: ../EXT-Browser.js
            Process File: ../components/BrowserDisplay.js
            Done
            @bugsounet
            EXT-Browser is now installed !
            added 42 packages in 7s
            npm ERR! code 255
            npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
            npm ERR! command failed
            npm ERR! command sh -c installer/postinstall.sh -r -m -b
            npm ERR! Prepare snowboy library...
            npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
            npm ERR! Failed!
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
            > EXT-Librespot@1.2.5 preinstall
            Welcome to EXT-Librespot v1.2.5
            No root checking...
            Checking EXT-Librespot: pi/pi
            Checking OS...
            > EXT-Librespot@1.2.5 postinstall
            Minify Main code...
            Found: 2 files to minify
            Process File: ../EXT-Librespot.js
            Done
            @bugsounet
            EXT-Librespot is now installed !
            added 195 packages in 26s
            25 packages are looking for funding
            > EXT-Photos@1.1.3 preinstall
            Welcome to EXT-Photos v1.1.3
            No root checking...
            Checking EXT-Photos: pi/pi
            Checking OS...
            > EXT-Photos@1.1.3 postinstall
            Minify Main code...
            Process File: ../EXT-Photos.js
            Done
            @bugsounet
            EXT-Photos is now installed !
            added 42 packages in 8s
            > EXT-RadioPlayer@1.1.6 preinstall
            > installer/preinstall.sh -d 'vlc'
            Welcome to EXT-RadioPlayer v1.1.6
            No root checking...
            Checking EXT-RadioPlayer: pi/pi
            Checking OS...
            Checking all dependencies...
            All Dependencies needed are installed !
            > EXT-RadioPlayer@1.1.6 postinstall
            Minify Main code...
            Process File: ../EXT-RadioPlayer.js
            Done
            @bugsounet
            EXT-RadioPlayer is now installed !
            added 50 packages in 11s
            14 packages are looking for funding
            > EXT-ScreenManager@1.1.0 preinstall
            Welcome to EXT-ScreenManager v1.1.0
            No root checking...
            Checking EXT-ScreenManager: pi/pi
            Checking OS...
            > EXT-ScreenManager@1.1.0 postinstall
            Minify Main code
            Process File: ../EXT-ScreenManager.js
            Done
            @bugsounet
            EXT-ScreenManager is now installed !
            added 64 packages, and audited 65 packages in 12s
            > EXT-Spotify@2.3.3 preinstall
            Welcome to EXT-Spotify v2.3.3
            No root checking...
            Checking EXT-Spotify: pi/pi
            Checking OS...
            > EXT-Spotify@2.3.3 postinstall
            Minify Main code...
            Found: 6 files to minify
            Process File: ../EXT-Spotify.js
            Process File: ../components/spotifyLib.js
            Process File: ../components/spotifyClass.js
            Process File: ../components/JSPanel.js
            Process File: ../components/CanvasLyrics.js
            Done
            @bugsounet
            EXT-Spotify is now installed !
            added 143 packages in 23s
            48 packages are looking for funding
            npm ERR! code 255
            npm ERR! path /home/pi/MagicMirror/modules/Gateway
            npm ERR! Minify Main code...
            npm ERR! node:internal/modules/cjs/loader:1051
            npm ERR!   throw err;
            npm ERR!   ^
            npm ERR!
            npm ERR! Error: Cannot find module 'esbuild'
            npm ERR! Require stack:
            npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
            npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
            npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
            npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
            npm ERR!     at require (node:internal/modules/helpers:130:18)
            npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
            npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
            npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
            npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
            npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
            npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
            npm ERR!   code: 'MODULE_NOT_FOUND',
            npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
            npm ERR! }
            npm ERR!
            npm ERR! Node.js v20.8.0
            npm ERR! Minify Failed!
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
            rebuilt dependencies successfully
            added 9 packages, and audited 10 packages in 3s
            1 package is looking for funding
            up to date, audited 1 package in 2s
            added 47 packages, and audited 48 packages in 8s
            2 moderate severity vulnerabilities
            Some issues need review, and may require choosing
            a different dependency.
            Run `npm audit` for details.
            added 4 packages, and audited 5 packages in 2s
              sdetweil @RIKKO14
              @RIKKO14 you need the word
              force
              added on the end of the upgrade command
                RIKKO14
                pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                bash: $'\E[200~bash' : commande introuvable
                saving custom.css
                up to date in 7s
                up to date in 47s
                no husky installed.
                added 334 packages in 3m
                No root checking...
                Checking OS...
                Minify Main code
                Done
                @bugsounet
                added 248 packages, and audited 249 packages in 26s
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                added 158 packages in 16s
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                added 42 packages in 5s
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                added 50 packages in 13s
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                npm ERR! code 255
                npm ERR! Failed!
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                added 195 packages in 18s
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                added 50 packages in 9s
                No root checking...
                Checking OS...
                Minify Main code
                Done
                @bugsounet
                added 64 packages, and audited 65 packages in 13s
                No root checking...
                Checking OS...
                Minify Main code...
                Done
                @bugsounet
                added 143 packages in 14s
                npm ERR! code 255
                npm ERR!   throw err;
                npm ERR!   ^
                npm ERR!
                npm ERR! }
                npm ERR!
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
                added 9 packages, and audited 10 packages in 2s
                up to date, audited 1 package in 949ms
                added 47 packages, and audited 48 packages in 7s
                pi@raspberrypi:~/MagicMirror $ pm2 stop 0
                [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                [PM2] [MagicMirror](0) ✓
                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                npm start
                > magicmirror@2.25.0 start
                [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
                [05.11.2023 15:59.49.477] [LOG]   Loading config ...
                [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
                [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
                [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
                [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
                [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
                [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
                [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
                [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
                [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
                [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
                [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
                [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
                [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
                [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
                [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
                [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
                [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
                [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
                [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
                Require stack:
                - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
                    at node:internal/modules/cjs/loader:1084:15
                    at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                    at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                    at node:internal/modules/cjs/loader:929:27
                    at Function._load (node:electron/js2c/asar_bundle:2:13327)
                    at Module.require (node:internal/modules/cjs/loader:1150:19)
                    at require (node:internal/modules/cjs/helpers:110:18)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
                    at Module._compile (node:internal/modules/cjs/loader:1271:14)
                    at Object..js (node:internal/modules/cjs/loader:1326:10)
                    at Module.load (node:internal/modules/cjs/loader:1126:32)
                    at node:internal/modules/cjs/loader:967:12
                    at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
                (Use `electron --trace-warnings ...` to show where the warning was created)
                [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                MESA-LOADER: failed to retrieve device information
                MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                failed to load driver: kms_swrast
                MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                failed to load swrast driver
                  @RIKKO14 now another module… DHT-Sensor missing a library
                  go to the module folder and
                  see this topic
                    RIKKO14
                    I do
                    cd ~/MagicMirror/modules/MMM-DHT-Sensor
                    npm install
                    then
                    npm start
                    then
                    cd ~/MagicMirror/modules/MMM-GoogleAssistant
                    npm run update
                    npm run refresh
                    then
                    pm2 restart 0
                    then
                    sudo reboot now
                    and finally everything works well
                    thank you for your help
                      sdetweil @RIKKO14
                      @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                      bugsounetB 1 Reply Last reply Reply Quote 0
                      • bugsounetB Offline
                        bugsounet Banned @sdetweil
                        @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
                          sdetweil @bugsounet
                          @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
                          I check for rebuild not refresh… will fix upgrade
                            @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
                              sdetweil @bugsounet
                              @bugsounet @RIKKO14
                              can either of you run this on your French systems
                              LC_ALL=C  free -m
                              should output in english
                                RIKKO14
                                @sdetweil Hello,
                                it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
                                  sdetweil @RIKKO14
                                  @RIKKO14 just one command run in terminal
                                  returns amount of memory being used
                                  my scripts use this an depend on the English text,
                                  trying to make sure it comes out in English is all.
                                  has no affect on system
                                    MMRIZE @RIKKO14
                                    @RIKKO14
                                    If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.
                                      RIKKO14
                                      here it is :
                                        sdetweil @RIKKO14
                                        @RIKKO14 thank you! perfect
