    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 10.2k Views 4 Watching
      sdetweil @RIKKO14
      @RIKKO14 after all this time, you still don’t run my scripts?
      and you still don’t remember that to do thing with MM you MUST be in the MagicMirror folder
      npm anything has to have MagicMirror as the current folder
      then continue on
      yes, this release requires node 18 or 20 as the code depends on the new internal ‘fetch’ function, instead of using external libs…
      was part of the announcement…
      my upgrade script does all the work… as usual
      again see
        RIKKO14
        I do this :
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        install log being saved to /home/pi/install.log
        Updating packages ...
        W: Erreur de GPG : https://deb.nodesource.com/node_18.x nodistro InRelease : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 2F59B5F99B1BE0B4
        E: Le dépôt https://deb.nodesource.com/node_18.x nodistro InRelease n'est pas signé.
        Update failed, retrying installation ...
        Installing helper tools ...
        installing correct version of node and npm, please wait
        It seems like MagicMirror is already installed.
        To prevent overwriting, the installer will be aborted.
        Please rename the ~/MagicMirror folder and try again.
        pi@raspberrypi:~/MagicMirror $ upgrade-script.sh
        bash: upgrade-script.sh : commande introuvable
        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        Minimum Node version: v20.8.0
        Installed Node version: v20.8.0
        No Node.js upgrade necessary.
        Minimum npm version: V10.1.0
        Installed npm version: V10.1.0
        No npm upgrade necessary.
        saving custom.css
        upgrading from version 2.25.0 to 2.25.0
        fetching latest revisions
        updating dependencies for active modules with package.json files
        	processing for module EXT-UpdateNotification please wait
        	skipped processing for EXT-UpdateNotification, doing test run
        	processing complete for module EXT-UpdateNotification
        	processing for module MMM-GoogleAssistant please wait
        	skipped processing for MMM-GoogleAssistant, doing test run
        	processing complete for module MMM-GoogleAssistant
        	processing for module EXT-Alert please wait
        	skipped processing for EXT-Alert, doing test run
        	processing complete for module EXT-Alert
        	processing for module EXT-Bring please wait
        	skipped processing for EXT-Bring, doing test run
        	processing complete for module EXT-Bring
        	processing for module EXT-Browser please wait
        	skipped processing for EXT-Browser, doing test run
        	processing complete for module EXT-Browser
        	processing for module EXT-Detector please wait
        	skipped processing for EXT-Detector, doing test run
        	processing complete for module EXT-Detector
        	processing for module EXT-Librespot please wait
        	skipped processing for EXT-Librespot, doing test run
        	processing complete for module EXT-Librespot
        	processing for module EXT-Photos please wait
        	skipped processing for EXT-Photos, doing test run
        	processing complete for module EXT-Photos
        	processing for module EXT-RadioPlayer please wait
        	skipped processing for EXT-RadioPlayer, doing test run
        	processing complete for module EXT-RadioPlayer
        	processing for module EXT-ScreenManager please wait
        	skipped processing for EXT-ScreenManager, doing test run
        	processing complete for module EXT-ScreenManager
        	processing for module EXT-Spotify please wait
        	skipped processing for EXT-Spotify, doing test run
        	processing complete for module EXT-Spotify
        	processing for module Gateway please wait
        	skipped processing for Gateway, doing test run
        	processing complete for module Gateway
        	processing for module MMM-DHT-Sensor please wait
        	skipped processing for MMM-DHT-Sensor, doing test run
        	processing complete for module MMM-DHT-Sensor
        	processing for module MMM-RainForecast-FR please wait
        	skipped processing for MMM-RainForecast-FR, doing test run
        	processing complete for module MMM-RainForecast-FR
        	processing for module MMM-TomTomTraffic please wait
        	skipped processing for MMM-TomTomTraffic, doing test run
        	processing complete for module MMM-TomTomTraffic
        	processing for module MMM-MovieListings please wait
        	skipped processing for MMM-MovieListings, doing test run
        	processing complete for module MMM-MovieListings
        	processing for module MMM-MarineWeather please wait
        	skipped processing for MMM-MarineWeather, doing test run
        	processing complete for module MMM-MarineWeather
        restoring custom.css
        but the problem stil the same… MagicMirror desn’t launch. Then after i reboot of my pi I do "bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)” but the problem stil the same. MagicMirror doesn’t launch. my screen is :
        there is something I’m doing wrong but I don’t know what and don’t understand…
          sdetweil @RIKKO14
          @RIKKO14 yes…
          1. install, it fails, already installed…
          1. upgrade, it is doing only test run, so no changes are made…
          1. to ACTUALLY do the upgrade there is a parameter added to the end of the link ‘apply’ (no quotes)
          If you WANT to actually apply the changes, copy/paste this line into the terminal window on your device:
          BUT, because your code level is already 2.25, upgrade will not work, unless you FORCE it…
          by changing the parm from ‘apply’ to ‘force’ (again no quotes)
          you should NOT clone this repo to your system, you click the link to copy it and then paste and execute directly from github
          and MM won’t start cause u have the new code and old libs, and probably the wrong nodejs version when ‘installed’…
          SO, try upgrade again with the ‘force’ parm
            RIKKO14
            pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"force
                                    \______/
            pi@raspberrypi:~ $
              sdetweil @RIKKO14
              @RIKKO14 DO NOT RUN INSTALL…
              run UPGRADE with force
              I will look for how to fix the gpg key problem
              execute these commands, (copy paste)
              curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
              NODE_MAJOR=18
              echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
              then do
              sudo apt-get update
              R 1 Reply Last reply
                RIKKO14 @sdetweil
                  RIKKO14 @RIKKO14
                  My node version is 20.8.0 but i don’t know to launch my MM…
                  MM didn’t start…
                    sdetweil @RIKKO14
                    @RIKKO14
                    do
                    pm2 stop all
                    npm run install-mm
                    npm start
                    please confirm results
                      RIKKO14
                      The result :
                      pi@raspberrypi:~/MagicMirror $ pm2 stop all
                      npm run install-mm
                      npm start
                      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                      [PM2] [MagicMirror](0) ✓
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                      > magicmirror@2.25.0 install-mm
                      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                      npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                      > magicmirror@2.25.0 postinstall
                      > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                      > magicmirror@2.25.0 install-vendor
                      > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                      up to date in 1s
                      > magicmirror@2.25.0 install-fonts
                      > echo "Installing fonts ...
                      > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                      up to date in 1s
                      > magicmirror@2.25.0 prepare
                      > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                      no husky installed.
                      up to date in 14s
                      > magicmirror@2.25.0 start
                      [05.11.2023 14:46.59.755] [LOG]   Starting MagicMirror: v2.25.0
                      [05.11.2023 14:46.59.761] [LOG]   Loading config ...
                      [05.11.2023 14:46.59.767] [DEBUG] config template file not exists, no envsubst
                      [05.11.2023 14:46.59.775] [LOG]   Loading module helpers ...
                      [05.11.2023 14:46.59.778] [LOG]   No helper found for module: alert.
                      [05.11.2023 14:46.59.800] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:46.59.801] [LOG]   Module helper loaded: EXT-UpdateNotification
                      [05.11.2023 14:46.59.803] [LOG]   No helper found for module: clock.
                      [05.11.2023 14:47.00.090] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.091] [LOG]   Module helper loaded: calendar
                      [05.11.2023 14:47.00.098] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.099] [LOG]   Module helper loaded: MMM-GoogleAssistant
                      [05.11.2023 14:47.00.103] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.103] [LOG]   Module helper loaded: EXT-Alert
                      [05.11.2023 14:47.00.115] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.116] [LOG]   Module helper loaded: EXT-Bring
                      [05.11.2023 14:47.00.127] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.127] [LOG]   Module helper loaded: EXT-Browser
                      [05.11.2023 14:47.00.142] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.142] [LOG]   Module helper loaded: EXT-Detector
                      [05.11.2023 14:47.00.595] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.596] [LOG]   Module helper loaded: EXT-Librespot
                      [05.11.2023 14:47.00.599] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.599] [LOG]   Module helper loaded: EXT-Photos
                      [05.11.2023 14:47.00.603] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.603] [LOG]   Module helper loaded: EXT-RadioPlayer
                      [05.11.2023 14:47.00.638] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.638] [LOG]   Module helper loaded: EXT-ScreenManager
                      [05.11.2023 14:47.00.967] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.968] [LOG]   Module helper loaded: EXT-Spotify
                      [05.11.2023 14:47.00.975] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.975] [LOG]   Module helper loaded: Gateway
                      [05.11.2023 14:47.00.998] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.00.999] [LOG]   Module helper loaded: MMM-DHT-Sensor
                      [05.11.2023 14:47.00.999] [LOG]   No helper found for module: MMM-WeatherOrNot.
                      [05.11.2023 14:47.01.093] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.01.094] [LOG]   Module helper loaded: MMM-RainForecast-FR
                      [05.11.2023 14:47.01.094] [LOG]   No helper found for module: MMM-TomTomTraffic.
                      [05.11.2023 14:47.01.594] [LOG]   Initializing new module helper ...
                      [05.11.2023 14:47.01.595] [LOG]   Module helper loaded: MMM-MovieListings
                      [05.11.2023 14:47.01.600] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
                      Require stack:
                      - /home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js
                          at node:internal/modules/cjs/loader:1084:15
                          at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                          at node:internal/modules/cjs/loader:929:27
                          at Function._load (node:electron/js2c/asar_bundle:2:13327)
                      at Module.require (node:internal/modules/cjs/loader:1150:19)
                          at require (node:internal/modules/cjs/helpers:110:18)
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js:14:15)
                          at Module._compile (node:internal/modules/cjs/loader:1271:14)
                          at Object..js (node:internal/modules/cjs/loader:1326:10)
                          at Module.load (node:internal/modules/cjs/loader:1126:32)
                          at node:internal/modules/cjs/loader:967:12
                          at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
                      (Use `electron --trace-warnings ...` to show where the warning was created)
                      [05.11.2023 14:47.01.601] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      [12072:1105/144701.952277:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                      MESA-LOADER: failed to retrieve device information
                      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                      failed to load driver: kms_swrast
                      MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                      failed to load swrast driver
                      And MM didn’t launch…
                      S 2 Replies Last reply
                        RIKKO14
                        If I anderstand my MM is up to date and node is up to date too.
                        So Why my MM didn’t launch ?..
                          sdetweil @RIKKO14
                          @RIKKO14 one command at a time
                          show results of each one at a time
                            sdetweil @RIKKO14
                            @RIKKO14
                            yes that module is missing a library
                            if you run my upgrade script with force, it should fix it
                              RIKKO14
                              I do :
                              saving custom.css
                              pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                              doing test run = false
                              force: ligne 450 : [: -le : opérateur unaire attendu
                              saving custom.css
                              up to date in 3s
                              up to date in 4s
                              no husky installed.
                              added 334 packages in 2m
                              97 packages are looking for funding
                                run `npm fund` for details
                              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              > EXT-UpdateNotification@2.1.0 preinstall
                              > installer/preinstall.sh
                              Welcome to EXT-UpdateNotification v2.1.0
                              No root checking...
                              Checking EXT-UpdateNotification: pi/pi
                              Checking MagicMirror: pi/pi
                              Checking OS...
                              OS Detected: linux-gnueabihf (raspbian 11 aarch64)
                              Installing all npm libraries...
                              > EXT-UpdateNotification@2.1.0 postinstall
                              > installer/postinstall.sh
                              Minify Main code
                              Found: 8 files to minify
                              Process File: ../EXT-UpdateNotification.js
                              Process File: ../components/gitCheck.js
                              Process File: ../components/loadLibraries.js
                              Process File: ../components/npmCheck.js
                              Process File: ../components/parseData.js
                              Process File: ../components/update.js
                              Process File: ../node_helper.js
                              Process File: ../components/check.js
                              Done
                              Support is now moved in a dedicated Server: https://forum.bugsounet.fr
                              @bugsounet
                              EXT-UpdateNotification is now installed !
                              added 248 packages, and audited 249 packages in 50s
                              39 packages are looking for funding
                              found 0 vulnerabilities
                              > MMM-GoogleAssistant@5.4.0 preinstall
                              Welcome to MMM-GoogleAssistant v5.4.0
                              No root checking...
                              Checking MMM-GoogleAssistant: pi/pi
                              Checking OS...
                              > MMM-GoogleAssistant@5.4.0 postinstall
                              > installer/postinstall.sh -m -b
                              Minify Main code...
                              Found: 27 files to minify
                              Process File: ../MMM-GoogleAssistant.js
                              Process File: ../components/shellExec.js
                              Process File: ../components/searchOnGoogle.js
                              Process File: ../components/screenParser.js
                              Process File: ../components/recipes.js
                              Process File: ../components/proto-loader.js
                              Process File: ../components/platform.js
                              Process File: ../components/lpcm16.js
                              Process File: ../components/googleSearch.js
                              Process File: ../components/googleAssistant.js
                              Process File: ../components/embedded-assistant.js
                              Process File: ../components/conversation.js
                              Process File: ../components/configMerge.js
                              Process File: ../components/auth.js
                              Process File: ../components/assistantSearch.js
                              Process File: ../components/assistantResponse.js
                              Process File: ../components/assistantConverse.js
                              Process File: ../components/activateProcess.js
                              Process File: ../components/activateAssistant.js
                              Process File: ../components/Hooks.js
                              Process File: ../components/Gateway.js
                              Process File: ../components/GAConfig.js
                              Process File: ../components/BufferToMP3.js
                              Process File: ../components/Assistant.js
                              Done
                              @bugsounet
                              MMM-GoogleAssistant is now installed !
                              added 158 packages in 32s
                              52 packages are looking for funding
                              > EXT-Alert@1.2.3 preinstall
                              Welcome to EXT-Alert v1.2.3
                              No root checking...
                              Checking EXT-Alert: pi/pi
                              Checking OS...
                              > EXT-Alert@1.2.3 postinstall
                              Minify Main code...
                              Found: 5 files to minify
                              Process File: ../EXT-Alert.js
                              Process File: ../components/AlertInit.js
                              Process File: ../components/AlertDisplay.js
                              Process File: ../components/AlertCommander.js
                              Done
                              @bugsounet
                              EXT-Alert is now installed !
                              added 42 packages in 12s
                              13 packages are looking for funding
                              > EXT-Bring@1.2.2 preinstall
                              Welcome to EXT-Bring v1.2.2
                              No root checking...
                              Checking EXT-Bring: pi/pi
                              Checking OS...
                              > EXT-Bring@1.2.2 postinstall
                              Minify Main code...
                              Process File: ../EXT-Bring.js
                              Process File: ../components/bring-lib.js
                              Done
                              @bugsounet
                              EXT-Bring is now installed !
                              added 50 packages in 14s
                              16 packages are looking for funding
                              > EXT-Browser@1.2.3 preinstall
                              Welcome to EXT-Browser v1.2.3
                              No root checking...
                              Checking EXT-Browser: pi/pi
                              Checking OS...
                              > EXT-Browser@1.2.3 postinstall
                              Minify Main code...
                              Found: 3 files to minify
                              Process File: ../EXT-Browser.js
                              Process File: ../components/BrowserDisplay.js
                              Done
                              @bugsounet
                              EXT-Browser is now installed !
                              added 42 packages in 7s
                              npm ERR! code 255
                              npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
                              npm ERR! command failed
                              npm ERR! command sh -c installer/postinstall.sh -r -m -b
                              npm ERR! Prepare snowboy library...
                              npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
                              npm ERR! Failed!
                              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
                              > EXT-Librespot@1.2.5 preinstall
                              Welcome to EXT-Librespot v1.2.5
                              No root checking...
                              Checking EXT-Librespot: pi/pi
                              Checking OS...
                              > EXT-Librespot@1.2.5 postinstall
                              Minify Main code...
                              Found: 2 files to minify
                              Process File: ../EXT-Librespot.js
                              Done
                              @bugsounet
                              EXT-Librespot is now installed !
                              added 195 packages in 26s
                              25 packages are looking for funding
                              > EXT-Photos@1.1.3 preinstall
                              Welcome to EXT-Photos v1.1.3
                              No root checking...
                              Checking EXT-Photos: pi/pi
                              Checking OS...
                              > EXT-Photos@1.1.3 postinstall
                              Minify Main code...
                              Process File: ../EXT-Photos.js
                              Done
                              @bugsounet
                              EXT-Photos is now installed !
                              added 42 packages in 8s
                              > EXT-RadioPlayer@1.1.6 preinstall
                              > installer/preinstall.sh -d 'vlc'
                              Welcome to EXT-RadioPlayer v1.1.6
                              No root checking...
                              Checking EXT-RadioPlayer: pi/pi
                              Checking OS...
                              Checking all dependencies...
                              All Dependencies needed are installed !
                              > EXT-RadioPlayer@1.1.6 postinstall
                              Minify Main code...
                              Process File: ../EXT-RadioPlayer.js
                              Done
                              @bugsounet
                              EXT-RadioPlayer is now installed !
                              added 50 packages in 11s
                              14 packages are looking for funding
                              > EXT-ScreenManager@1.1.0 preinstall
                              Welcome to EXT-ScreenManager v1.1.0
                              No root checking...
                              Checking EXT-ScreenManager: pi/pi
                              Checking OS...
                              > EXT-ScreenManager@1.1.0 postinstall
                              Minify Main code
                              Process File: ../EXT-ScreenManager.js
                              Done
                              @bugsounet
                              EXT-ScreenManager is now installed !
                              added 64 packages, and audited 65 packages in 12s
                              > EXT-Spotify@2.3.3 preinstall
                              Welcome to EXT-Spotify v2.3.3
                              No root checking...
                              Checking EXT-Spotify: pi/pi
                              Checking OS...
                              > EXT-Spotify@2.3.3 postinstall
                              Minify Main code...
                              Found: 6 files to minify
                              Process File: ../EXT-Spotify.js
                              Process File: ../components/spotifyLib.js
                              Process File: ../components/spotifyClass.js
                              Process File: ../components/JSPanel.js
                              Process File: ../components/CanvasLyrics.js
                              Done
                              @bugsounet
                              EXT-Spotify is now installed !
                              added 143 packages in 23s
                              48 packages are looking for funding
                              npm ERR! code 255
                              npm ERR! path /home/pi/MagicMirror/modules/Gateway
                              npm ERR! Minify Main code...
                              npm ERR! node:internal/modules/cjs/loader:1051
                              npm ERR!   throw err;
                              npm ERR!   ^
                              npm ERR!
                              npm ERR! Error: Cannot find module 'esbuild'
                              npm ERR! Require stack:
                              npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
                              npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                              npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
                              npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
                              npm ERR!     at require (node:internal/modules/helpers:130:18)
                              npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
                              npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
                              npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                              npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
                              npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
                              npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
                              npm ERR!   code: 'MODULE_NOT_FOUND',
                              npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
                              npm ERR! }
                              npm ERR!
                              npm ERR! Node.js v20.8.0
                              npm ERR! Minify Failed!
                              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
                              rebuilt dependencies successfully
                              added 9 packages, and audited 10 packages in 3s
                              1 package is looking for funding
                              up to date, audited 1 package in 2s
                              added 47 packages, and audited 48 packages in 8s
                              2 moderate severity vulnerabilities
                              Some issues need review, and may require choosing
                              a different dependency.
                              Run `npm audit` for details.
                              added 4 packages, and audited 5 packages in 2s
                                sdetweil @RIKKO14
                                @RIKKO14 you need the word
                                force
                                added on the end of the upgrade command
                                  RIKKO14
                                  pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                  bash: $'\E[200~bash' : commande introuvable
                                  saving custom.css
                                  up to date in 7s
                                  up to date in 47s
                                  no husky installed.
                                  added 334 packages in 3m
                                  No root checking...
                                  Checking OS...
                                  Minify Main code
                                  Done
                                  @bugsounet
                                  added 248 packages, and audited 249 packages in 26s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  added 158 packages in 16s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  added 42 packages in 5s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  added 50 packages in 13s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  npm ERR! code 255
                                  npm ERR! Failed!
                                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  added 195 packages in 18s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  added 50 packages in 9s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code
                                  Done
                                  @bugsounet
                                  added 64 packages, and audited 65 packages in 13s
                                  No root checking...
                                  Checking OS...
                                  Minify Main code...
                                  Done
                                  @bugsounet
                                  added 143 packages in 14s
                                  npm ERR! code 255
                                  npm ERR!   throw err;
                                  npm ERR!   ^
                                  npm ERR!
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
                                  added 9 packages, and audited 10 packages in 2s
                                  up to date, audited 1 package in 949ms
                                  added 47 packages, and audited 48 packages in 7s
                                  pi@raspberrypi:~/MagicMirror $ pm2 stop 0
                                  [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                                  pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                                  npm start
                                  [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
                                  [05.11.2023 15:59.49.477] [LOG]   Loading config ...
                                  [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
                                  [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
                                  [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
                                  [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
                                  [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
                                  [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
                                  [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
                                  [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
                                  [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
                                  [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
                                  [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
                                  [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
                                  [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
                                  [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
                                  [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
                                  [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
                                  [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
                                  [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
                                  [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
                                  Require stack:
                                  - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
                                  [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                  [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                                    @RIKKO14 now another module… DHT-Sensor missing a library
                                    go to the module folder and
                                    see this topic
                                      RIKKO14
                                      I do
                                      cd ~/MagicMirror/modules/MMM-DHT-Sensor
                                      npm install
                                      then
                                      npm start
                                      then
                                      cd ~/MagicMirror/modules/MMM-GoogleAssistant
                                      npm run update
                                      npm run refresh
                                      then
                                      pm2 restart 0
                                      then
                                      sudo reboot now
                                      and finally everything works well
                                      thank you for your help
                                        sdetweil @RIKKO14
                                        @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                                        bugsounetB 1 Reply Last reply
                                        • bugsounetB
                                          bugsounet Banned @sdetweil
                                          @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
                                            sdetweil @bugsounet
                                            @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
                                            I check for rebuild not refresh… will fix upgrade
