    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 8.9k Views 4 Watching
      RIKKO14
      I can’t update my MM, it’s a node problem but I can’t solve it.
      here’s what I did with no results…
      What do you recommend ?
      Thank you for your help
        @RIKKO14 now another module… DHT-Sensor missing a library
        go to the module folder and
        see this topic
          sdetweil @RIKKO14
          @RIKKO14 after all this time, you still don’t run my scripts?
          and you still don’t remember that to do thing with MM you MUST be in the MagicMirror folder
          npm anything has to have MagicMirror as the current folder
          then continue on
          yes, this release requires node 18 or 20 as the code depends on the new internal ‘fetch’ function, instead of using external libs…
          was part of the announcement…
          my upgrade script does all the work… as usual
          again see
            RIKKO14
            I do this :
            pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                    \______/
            install log being saved to /home/pi/install.log
            Updating packages ...
            W: Erreur de GPG : https://deb.nodesource.com/node_18.x nodistro InRelease : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 2F59B5F99B1BE0B4
            E: Le dépôt https://deb.nodesource.com/node_18.x nodistro InRelease n'est pas signé.
            Update failed, retrying installation ...
            Installing helper tools ...
            installing correct version of node and npm, please wait
            It seems like MagicMirror is already installed.
            To prevent overwriting, the installer will be aborted.
            Please rename the ~/MagicMirror folder and try again.
            pi@raspberrypi:~/MagicMirror $ upgrade-script.sh
            bash: upgrade-script.sh : commande introuvable
            pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            Minimum Node version: v20.8.0
            Installed Node version: v20.8.0
            No Node.js upgrade necessary.
            Minimum npm version: V10.1.0
            Installed npm version: V10.1.0
            No npm upgrade necessary.
            saving custom.css
            upgrading from version 2.25.0 to 2.25.0
            fetching latest revisions
            updating dependencies for active modules with package.json files
            	processing for module EXT-UpdateNotification please wait
            	skipped processing for EXT-UpdateNotification, doing test run
            	processing complete for module EXT-UpdateNotification
            	processing for module MMM-GoogleAssistant please wait
            	skipped processing for MMM-GoogleAssistant, doing test run
            	processing complete for module MMM-GoogleAssistant
            	processing for module EXT-Alert please wait
            	skipped processing for EXT-Alert, doing test run
            	processing complete for module EXT-Alert
            	processing for module EXT-Bring please wait
            	skipped processing for EXT-Bring, doing test run
            	processing complete for module EXT-Bring
            	processing for module EXT-Browser please wait
            	skipped processing for EXT-Browser, doing test run
            	processing complete for module EXT-Browser
            	processing for module EXT-Detector please wait
            	skipped processing for EXT-Detector, doing test run
            	processing complete for module EXT-Detector
            	processing for module EXT-Librespot please wait
            	skipped processing for EXT-Librespot, doing test run
            	processing complete for module EXT-Librespot
            	processing for module EXT-Photos please wait
            	skipped processing for EXT-Photos, doing test run
            	processing complete for module EXT-Photos
            	processing for module EXT-RadioPlayer please wait
            	skipped processing for EXT-RadioPlayer, doing test run
            	processing complete for module EXT-RadioPlayer
            	processing for module EXT-ScreenManager please wait
            	skipped processing for EXT-ScreenManager, doing test run
            	processing complete for module EXT-ScreenManager
            	processing for module EXT-Spotify please wait
            	skipped processing for EXT-Spotify, doing test run
            	processing complete for module EXT-Spotify
            	processing for module Gateway please wait
            	skipped processing for Gateway, doing test run
            	processing complete for module Gateway
            	processing for module MMM-DHT-Sensor please wait
            	skipped processing for MMM-DHT-Sensor, doing test run
            	processing complete for module MMM-DHT-Sensor
            	processing for module MMM-RainForecast-FR please wait
            	skipped processing for MMM-RainForecast-FR, doing test run
            	processing complete for module MMM-RainForecast-FR
            	processing for module MMM-TomTomTraffic please wait
            	skipped processing for MMM-TomTomTraffic, doing test run
            	processing complete for module MMM-TomTomTraffic
            	processing for module MMM-MovieListings please wait
            	skipped processing for MMM-MovieListings, doing test run
            	processing complete for module MMM-MovieListings
            	processing for module MMM-MarineWeather please wait
            	skipped processing for MMM-MarineWeather, doing test run
            	processing complete for module MMM-MarineWeather
            restoring custom.css
            but the problem stil the same… MagicMirror desn’t launch. Then after i reboot of my pi I do "bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)” but the problem stil the same. MagicMirror doesn’t launch. my screen is :
            there is something I’m doing wrong but I don’t know what and don’t understand…
              sdetweil @RIKKO14
              @RIKKO14 yes…
              1. install, it fails, already installed…
              1. upgrade, it is doing only test run, so no changes are made…
              1. to ACTUALLY do the upgrade there is a parameter added to the end of the link ‘apply’ (no quotes)
              If you WANT to actually apply the changes, copy/paste this line into the terminal window on your device:
              BUT, because your code level is already 2.25, upgrade will not work, unless you FORCE it…
              by changing the parm from ‘apply’ to ‘force’ (again no quotes)
              you should NOT clone this repo to your system, you click the link to copy it and then paste and execute directly from github
              and MM won’t start cause u have the new code and old libs, and probably the wrong nodejs version when ‘installed’…
              SO, try upgrade again with the ‘force’ parm
                RIKKO14
                pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"force
                                        \______/
                pi@raspberrypi:~ $
                  sdetweil @RIKKO14
                  @RIKKO14 DO NOT RUN INSTALL…
                  run UPGRADE with force
                  I will look for how to fix the gpg key problem
                  execute these commands, (copy paste)
                  curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                  NODE_MAJOR=18
                  echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
                  then do
                  sudo apt-get update
                    RIKKO14 @sdetweil
                      RIKKO14 @RIKKO14
                      My node version is 20.8.0 but i don’t know to launch my MM…
                      MM didn’t start…
                        sdetweil @RIKKO14
                        @RIKKO14
                        do
                        pm2 stop all
                        npm run install-mm
                        npm start
                        please confirm results
                          RIKKO14
                          The result :
                          pi@raspberrypi:~/MagicMirror $ pm2 stop all
                          npm run install-mm
                          npm start
                          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                          [PM2] [MagicMirror](0) ✓
                          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                          > magicmirror@2.25.0 install-mm
                          > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                          npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                          > magicmirror@2.25.0 postinstall
                          > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                          > magicmirror@2.25.0 install-vendor
                          > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                          up to date in 1s
                          > magicmirror@2.25.0 install-fonts
                          > echo "Installing fonts ...
                          > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                          up to date in 1s
                          > magicmirror@2.25.0 prepare
                          > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                          no husky installed.
                          up to date in 14s
                          > magicmirror@2.25.0 start
                          [05.11.2023 14:46.59.755] [LOG]   Starting MagicMirror: v2.25.0
                          [05.11.2023 14:46.59.761] [LOG]   Loading config ...
                          [05.11.2023 14:46.59.767] [DEBUG] config template file not exists, no envsubst
                          [05.11.2023 14:46.59.775] [LOG]   Loading module helpers ...
                          [05.11.2023 14:46.59.778] [LOG]   No helper found for module: alert.
                          [05.11.2023 14:46.59.800] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:46.59.801] [LOG]   Module helper loaded: EXT-UpdateNotification
                          [05.11.2023 14:46.59.803] [LOG]   No helper found for module: clock.
                          [05.11.2023 14:47.00.090] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.091] [LOG]   Module helper loaded: calendar
                          [05.11.2023 14:47.00.098] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.099] [LOG]   Module helper loaded: MMM-GoogleAssistant
                          [05.11.2023 14:47.00.103] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.103] [LOG]   Module helper loaded: EXT-Alert
                          [05.11.2023 14:47.00.115] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.116] [LOG]   Module helper loaded: EXT-Bring
                          [05.11.2023 14:47.00.127] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.127] [LOG]   Module helper loaded: EXT-Browser
                          [05.11.2023 14:47.00.142] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.142] [LOG]   Module helper loaded: EXT-Detector
                          [05.11.2023 14:47.00.595] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.596] [LOG]   Module helper loaded: EXT-Librespot
                          [05.11.2023 14:47.00.599] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.599] [LOG]   Module helper loaded: EXT-Photos
                          [05.11.2023 14:47.00.603] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.603] [LOG]   Module helper loaded: EXT-RadioPlayer
                          [05.11.2023 14:47.00.638] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.638] [LOG]   Module helper loaded: EXT-ScreenManager
                          [05.11.2023 14:47.00.967] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.968] [LOG]   Module helper loaded: EXT-Spotify
                          [05.11.2023 14:47.00.975] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.975] [LOG]   Module helper loaded: Gateway
                          [05.11.2023 14:47.00.998] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.00.999] [LOG]   Module helper loaded: MMM-DHT-Sensor
                          [05.11.2023 14:47.00.999] [LOG]   No helper found for module: MMM-WeatherOrNot.
                          [05.11.2023 14:47.01.093] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.01.094] [LOG]   Module helper loaded: MMM-RainForecast-FR
                          [05.11.2023 14:47.01.094] [LOG]   No helper found for module: MMM-TomTomTraffic.
                          [05.11.2023 14:47.01.594] [LOG]   Initializing new module helper ...
                          [05.11.2023 14:47.01.595] [LOG]   Module helper loaded: MMM-MovieListings
                          [05.11.2023 14:47.01.600] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
                          Require stack:
                          - /home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js
                              at node:internal/modules/cjs/loader:1084:15
                              at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at node:internal/modules/cjs/loader:929:27
                              at Function._load (node:electron/js2c/asar_bundle:2:13327)
                          at Module.require (node:internal/modules/cjs/loader:1150:19)
                              at require (node:internal/modules/cjs/helpers:110:18)
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js:14:15)
                              at Module._compile (node:internal/modules/cjs/loader:1271:14)
                              at Object..js (node:internal/modules/cjs/loader:1326:10)
                              at Module.load (node:internal/modules/cjs/loader:1126:32)
                              at node:internal/modules/cjs/loader:967:12
                              at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
                          (Use `electron --trace-warnings ...` to show where the warning was created)
                          [05.11.2023 14:47.01.601] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                          [12072:1105/144701.952277:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                          MESA-LOADER: failed to retrieve device information
                          MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                          failed to load driver: kms_swrast
                          MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                          failed to load swrast driver
                          And MM didn’t launch…
                            RIKKO14
                            If I anderstand my MM is up to date and node is up to date too.
                            So Why my MM didn’t launch ?..
                              sdetweil @RIKKO14
                              @RIKKO14 one command at a time
                              show results of each one at a time
                                sdetweil @RIKKO14
                                @RIKKO14
                                yes that module is missing a library
                                if you run my upgrade script with force, it should fix it
                                  RIKKO14
                                  I do :
                                  saving custom.css
                                  pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                  doing test run = false
                                  force: ligne 450 : [: -le : opérateur unaire attendu
                                  saving custom.css
                                  up to date in 3s
                                  up to date in 4s
                                  no husky installed.
                                  added 334 packages in 2m
                                  97 packages are looking for funding
                                    run `npm fund` for details
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  > EXT-UpdateNotification@2.1.0 preinstall
                                  > installer/preinstall.sh
                                  Welcome to EXT-UpdateNotification v2.1.0
                                  No root checking...
                                  Checking EXT-UpdateNotification: pi/pi
                                  Checking MagicMirror: pi/pi
                                  Checking OS...
                                  OS Detected: linux-gnueabihf (raspbian 11 aarch64)
                                  Installing all npm libraries...
                                  > EXT-UpdateNotification@2.1.0 postinstall
                                  > installer/postinstall.sh
                                  Minify Main code
                                  Found: 8 files to minify
                                  Process File: ../EXT-UpdateNotification.js
                                  Process File: ../components/gitCheck.js
                                  Process File: ../components/loadLibraries.js
                                  Process File: ../components/npmCheck.js
                                  Process File: ../components/parseData.js
                                  Process File: ../components/update.js
                                  Process File: ../node_helper.js
                                  Process File: ../components/check.js
                                  Done
                                  Support is now moved in a dedicated Server: https://forum.bugsounet.fr
                                  @bugsounet
                                  EXT-UpdateNotification is now installed !
                                  added 248 packages, and audited 249 packages in 50s
                                  39 packages are looking for funding
                                  found 0 vulnerabilities
                                  > MMM-GoogleAssistant@5.4.0 preinstall
                                  Welcome to MMM-GoogleAssistant v5.4.0
                                  No root checking...
                                  Checking MMM-GoogleAssistant: pi/pi
                                  Checking OS...
                                  > MMM-GoogleAssistant@5.4.0 postinstall
                                  > installer/postinstall.sh -m -b
                                  Minify Main code...
                                  Found: 27 files to minify
                                  Process File: ../MMM-GoogleAssistant.js
                                  Process File: ../components/shellExec.js
                                  Process File: ../components/searchOnGoogle.js
                                  Process File: ../components/screenParser.js
                                  Process File: ../components/recipes.js
                                  Process File: ../components/proto-loader.js
                                  Process File: ../components/platform.js
                                  Process File: ../components/lpcm16.js
                                  Process File: ../components/googleSearch.js
                                  Process File: ../components/googleAssistant.js
                                  Process File: ../components/embedded-assistant.js
                                  Process File: ../components/conversation.js
                                  Process File: ../components/configMerge.js
                                  Process File: ../components/auth.js
                                  Process File: ../components/assistantSearch.js
                                  Process File: ../components/assistantResponse.js
                                  Process File: ../components/assistantConverse.js
                                  Process File: ../components/activateProcess.js
                                  Process File: ../components/activateAssistant.js
                                  Process File: ../components/Hooks.js
                                  Process File: ../components/Gateway.js
                                  Process File: ../components/GAConfig.js
                                  Process File: ../components/BufferToMP3.js
                                  Process File: ../components/Assistant.js
                                  Done
                                  @bugsounet
                                  MMM-GoogleAssistant is now installed !
                                  added 158 packages in 32s
                                  52 packages are looking for funding
                                  > EXT-Alert@1.2.3 preinstall
                                  Welcome to EXT-Alert v1.2.3
                                  No root checking...
                                  Checking EXT-Alert: pi/pi
                                  Checking OS...
                                  > EXT-Alert@1.2.3 postinstall
                                  Minify Main code...
                                  Found: 5 files to minify
                                  Process File: ../EXT-Alert.js
                                  Process File: ../components/AlertInit.js
                                  Process File: ../components/AlertDisplay.js
                                  Process File: ../components/AlertCommander.js
                                  Done
                                  @bugsounet
                                  EXT-Alert is now installed !
                                  added 42 packages in 12s
                                  13 packages are looking for funding
                                  > EXT-Bring@1.2.2 preinstall
                                  Welcome to EXT-Bring v1.2.2
                                  No root checking...
                                  Checking EXT-Bring: pi/pi
                                  Checking OS...
                                  > EXT-Bring@1.2.2 postinstall
                                  Minify Main code...
                                  Process File: ../EXT-Bring.js
                                  Process File: ../components/bring-lib.js
                                  Done
                                  @bugsounet
                                  EXT-Bring is now installed !
                                  added 50 packages in 14s
                                  16 packages are looking for funding
                                  > EXT-Browser@1.2.3 preinstall
                                  Welcome to EXT-Browser v1.2.3
                                  No root checking...
                                  Checking EXT-Browser: pi/pi
                                  Checking OS...
                                  > EXT-Browser@1.2.3 postinstall
                                  Minify Main code...
                                  Found: 3 files to minify
                                  Process File: ../EXT-Browser.js
                                  Process File: ../components/BrowserDisplay.js
                                  Done
                                  @bugsounet
                                  EXT-Browser is now installed !
                                  added 42 packages in 7s
                                  npm ERR! code 255
                                  npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
                                  npm ERR! command failed
                                  npm ERR! command sh -c installer/postinstall.sh -r -m -b
                                  npm ERR! Prepare snowboy library...
                                  npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
                                  npm ERR! Failed!
                                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
                                  > EXT-Librespot@1.2.5 preinstall
                                  Welcome to EXT-Librespot v1.2.5
                                  No root checking...
                                  Checking EXT-Librespot: pi/pi
                                  Checking OS...
                                  > EXT-Librespot@1.2.5 postinstall
                                  Minify Main code...
                                  Found: 2 files to minify
                                  Process File: ../EXT-Librespot.js
                                  Done
                                  @bugsounet
                                  EXT-Librespot is now installed !
                                  added 195 packages in 26s
                                  25 packages are looking for funding
                                  > EXT-Photos@1.1.3 preinstall
                                  Welcome to EXT-Photos v1.1.3
                                  No root checking...
                                  Checking EXT-Photos: pi/pi
                                  Checking OS...
                                  > EXT-Photos@1.1.3 postinstall
                                  Minify Main code...
                                  Process File: ../EXT-Photos.js
                                  Done
                                  @bugsounet
                                  EXT-Photos is now installed !
                                  added 42 packages in 8s
                                  > EXT-RadioPlayer@1.1.6 preinstall
                                  > installer/preinstall.sh -d 'vlc'
                                  Welcome to EXT-RadioPlayer v1.1.6
                                  No root checking...
                                  Checking EXT-RadioPlayer: pi/pi
                                  Checking OS...
                                  Checking all dependencies...
                                  All Dependencies needed are installed !
                                  > EXT-RadioPlayer@1.1.6 postinstall
                                  Minify Main code...
                                  Process File: ../EXT-RadioPlayer.js
                                  Done
                                  @bugsounet
                                  EXT-RadioPlayer is now installed !
                                  added 50 packages in 11s
                                  14 packages are looking for funding
                                  > EXT-ScreenManager@1.1.0 preinstall
                                  Welcome to EXT-ScreenManager v1.1.0
                                  No root checking...
                                  Checking EXT-ScreenManager: pi/pi
                                  Checking OS...
                                  > EXT-ScreenManager@1.1.0 postinstall
                                  Minify Main code
                                  Process File: ../EXT-ScreenManager.js
                                  Done
                                  @bugsounet
                                  EXT-ScreenManager is now installed !
                                  added 64 packages, and audited 65 packages in 12s
                                  > EXT-Spotify@2.3.3 preinstall
                                  Welcome to EXT-Spotify v2.3.3
                                  No root checking...
                                  Checking EXT-Spotify: pi/pi
                                  Checking OS...
                                  > EXT-Spotify@2.3.3 postinstall
                                  Minify Main code...
                                  Found: 6 files to minify
                                  Process File: ../EXT-Spotify.js
                                  Process File: ../components/spotifyLib.js
                                  Process File: ../components/spotifyClass.js
                                  Process File: ../components/JSPanel.js
                                  Process File: ../components/CanvasLyrics.js
                                  Done
                                  @bugsounet
                                  EXT-Spotify is now installed !
                                  added 143 packages in 23s
                                  48 packages are looking for funding
                                  npm ERR! code 255
                                  npm ERR! path /home/pi/MagicMirror/modules/Gateway
                                  npm ERR! Minify Main code...
                                  npm ERR! node:internal/modules/cjs/loader:1051
                                  npm ERR!   throw err;
                                  npm ERR!   ^
                                  npm ERR!
                                  npm ERR! Error: Cannot find module 'esbuild'
                                  npm ERR! Require stack:
                                  npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
                                  npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                                  npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
                                  npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
                                  npm ERR!     at require (node:internal/modules/helpers:130:18)
                                  npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
                                  npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
                                  npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                                  npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
                                  npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
                                  npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
                                  npm ERR!   code: 'MODULE_NOT_FOUND',
                                  npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR! Node.js v20.8.0
                                  npm ERR! Minify Failed!
                                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
                                  rebuilt dependencies successfully
                                  added 9 packages, and audited 10 packages in 3s
                                  1 package is looking for funding
                                  up to date, audited 1 package in 2s
                                  added 47 packages, and audited 48 packages in 8s
                                  2 moderate severity vulnerabilities
                                  Some issues need review, and may require choosing
                                  a different dependency.
                                  Run `npm audit` for details.
                                  added 4 packages, and audited 5 packages in 2s
                                    sdetweil @RIKKO14
                                    @RIKKO14 you need the word
                                    force
                                    added on the end of the upgrade command
                                      RIKKO14
                                      pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                      bash: $'\E[200~bash' : commande introuvable
                                      saving custom.css
                                      up to date in 7s
                                      up to date in 47s
                                      no husky installed.
                                      added 334 packages in 3m
                                      No root checking...
                                      Checking OS...
                                      Minify Main code
                                      Done
                                      @bugsounet
                                      added 248 packages, and audited 249 packages in 26s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      added 158 packages in 16s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      added 42 packages in 5s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      added 50 packages in 13s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      npm ERR! code 255
                                      npm ERR! Failed!
                                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      added 195 packages in 18s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      added 50 packages in 9s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code
                                      Done
                                      @bugsounet
                                      added 64 packages, and audited 65 packages in 13s
                                      No root checking...
                                      Checking OS...
                                      Minify Main code...
                                      Done
                                      @bugsounet
                                      added 143 packages in 14s
                                      npm ERR! code 255
                                      npm ERR!   throw err;
                                      npm ERR!   ^
                                      npm ERR!
                                      npm ERR! }
                                      npm ERR!
                                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
                                      added 9 packages, and audited 10 packages in 2s
                                      up to date, audited 1 package in 949ms
                                      added 47 packages, and audited 48 packages in 7s
                                      pi@raspberrypi:~/MagicMirror $ pm2 stop 0
                                      [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                                      pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                                      npm start
                                      [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
                                      [05.11.2023 15:59.49.477] [LOG]   Loading config ...
                                      [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
                                      [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
                                      [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
                                      [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
                                      [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
                                      [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
                                      [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
                                      [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
                                      [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
                                      [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
                                      [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
                                      [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
                                      [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
                                      [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
                                      [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
                                      [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
                                      [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
                                      [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
                                      [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
                                      Require stack:
                                      - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
                                      [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                      [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                                        see this topic
                                          RIKKO14
                                          I do
                                          cd ~/MagicMirror/modules/MMM-DHT-Sensor
                                          npm install
                                          then
                                          npm start
                                          then
                                          cd ~/MagicMirror/modules/MMM-GoogleAssistant
                                          npm run update
                                          npm run refresh
                                          then
                                          pm2 restart 0
                                          then
                                          sudo reboot now
                                          and finally everything works well
                                          thank you for your help
                                            sdetweil @RIKKO14
                                            @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                                            bugsounetB 1 Reply Last reply Reply Quote 0
                                            • bugsounetB Offline
                                              bugsounet Banned @sdetweil
                                              @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
