    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 10.2k Views 4 Watching
      RIKKO14
      pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"force
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                              \______/
      install log being saved to /home/pi/install.log
      Updating packages ...
      W: Erreur de GPG : https://deb.nodesource.com/node_18.x nodistro InRelease : Les signatures suivantes n'ont pas pu être vérifiées car la clé publique n'est pas disponible : NO_PUBKEY 2F59B5F99B1BE0B4
      E: Le dépôt https://deb.nodesource.com/node_18.x nodistro InRelease n'est pas signé.
      Update failed, retrying installation ...
      Installing helper tools ...
      It seems like MagicMirror is already installed.
      To prevent overwriting, the installer will be aborted.
      Please rename the ~/MagicMirror folder and try again.
      pi@raspberrypi:~ $
        sdetweil @RIKKO14
        @RIKKO14 DO NOT RUN INSTALL…
        run UPGRADE with force
        I will look for how to fix the gpg key problem
        execute these commands, (copy paste)
        curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
        NODE_MAJOR=18
        echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
        then do
        sudo apt-get update
        R 1 Reply Last reply
          RIKKO14 @sdetweil
            RIKKO14 @RIKKO14
            My node version is 20.8.0 but i don’t know to launch my MM…
            MM didn’t start…
              sdetweil @RIKKO14
              @RIKKO14
              do
              pm2 stop all
              npm run install-mm
              npm start
              please confirm results
                RIKKO14
                The result :
                pi@raspberrypi:~/MagicMirror $ pm2 stop all
                npm run install-mm
                npm start
                [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                [PM2] [MagicMirror](0) ✓
                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                > magicmirror@2.25.0 install-mm
                > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                > magicmirror@2.25.0 postinstall
                > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                > magicmirror@2.25.0 install-vendor
                > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                up to date in 1s
                > magicmirror@2.25.0 install-fonts
                > echo "Installing fonts ...
                > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                up to date in 1s
                > magicmirror@2.25.0 prepare
                > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                no husky installed.
                up to date in 14s
                > magicmirror@2.25.0 start
                [05.11.2023 14:46.59.755] [LOG]   Starting MagicMirror: v2.25.0
                [05.11.2023 14:46.59.761] [LOG]   Loading config ...
                [05.11.2023 14:46.59.767] [DEBUG] config template file not exists, no envsubst
                [05.11.2023 14:46.59.775] [LOG]   Loading module helpers ...
                [05.11.2023 14:46.59.778] [LOG]   No helper found for module: alert.
                [05.11.2023 14:46.59.800] [LOG]   Initializing new module helper ...
                [05.11.2023 14:46.59.801] [LOG]   Module helper loaded: EXT-UpdateNotification
                [05.11.2023 14:46.59.803] [LOG]   No helper found for module: clock.
                [05.11.2023 14:47.00.090] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.091] [LOG]   Module helper loaded: calendar
                [05.11.2023 14:47.00.098] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.099] [LOG]   Module helper loaded: MMM-GoogleAssistant
                [05.11.2023 14:47.00.103] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.103] [LOG]   Module helper loaded: EXT-Alert
                [05.11.2023 14:47.00.115] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.116] [LOG]   Module helper loaded: EXT-Bring
                [05.11.2023 14:47.00.127] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.127] [LOG]   Module helper loaded: EXT-Browser
                [05.11.2023 14:47.00.142] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.142] [LOG]   Module helper loaded: EXT-Detector
                [05.11.2023 14:47.00.595] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.596] [LOG]   Module helper loaded: EXT-Librespot
                [05.11.2023 14:47.00.599] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.599] [LOG]   Module helper loaded: EXT-Photos
                [05.11.2023 14:47.00.603] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.603] [LOG]   Module helper loaded: EXT-RadioPlayer
                [05.11.2023 14:47.00.638] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.638] [LOG]   Module helper loaded: EXT-ScreenManager
                [05.11.2023 14:47.00.967] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.968] [LOG]   Module helper loaded: EXT-Spotify
                [05.11.2023 14:47.00.975] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.975] [LOG]   Module helper loaded: Gateway
                [05.11.2023 14:47.00.998] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.00.999] [LOG]   Module helper loaded: MMM-DHT-Sensor
                [05.11.2023 14:47.00.999] [LOG]   No helper found for module: MMM-WeatherOrNot.
                [05.11.2023 14:47.01.093] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.01.094] [LOG]   Module helper loaded: MMM-RainForecast-FR
                [05.11.2023 14:47.01.094] [LOG]   No helper found for module: MMM-TomTomTraffic.
                [05.11.2023 14:47.01.594] [LOG]   Initializing new module helper ...
                [05.11.2023 14:47.01.595] [LOG]   Module helper loaded: MMM-MovieListings
                [05.11.2023 14:47.01.600] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
                Require stack:
                - /home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js
                    at node:internal/modules/cjs/loader:1084:15
                    at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                    at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                    at node:internal/modules/cjs/loader:929:27
                    at Function._load (node:electron/js2c/asar_bundle:2:13327)
                at Module.require (node:internal/modules/cjs/loader:1150:19)
                    at require (node:internal/modules/cjs/helpers:110:18)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js:14:15)
                    at Module._compile (node:internal/modules/cjs/loader:1271:14)
                    at Object..js (node:internal/modules/cjs/loader:1326:10)
                    at Module.load (node:internal/modules/cjs/loader:1126:32)
                    at node:internal/modules/cjs/loader:967:12
                    at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
                (Use `electron --trace-warnings ...` to show where the warning was created)
                [05.11.2023 14:47.01.601] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                [12072:1105/144701.952277:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                MESA-LOADER: failed to retrieve device information
                MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                failed to load driver: kms_swrast
                MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                failed to load swrast driver
                And MM didn’t launch…
                S 2 Replies Last reply
                  RIKKO14
                  If I anderstand my MM is up to date and node is up to date too.
                  So Why my MM didn’t launch ?..
                    sdetweil @RIKKO14
                    @RIKKO14 one command at a time
                    show results of each one at a time
                      sdetweil @RIKKO14
                      @RIKKO14
                      yes that module is missing a library
                      if you run my upgrade script with force, it should fix it
                        RIKKO14
                        I do :
                        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                        Minimum Node version: v20.8.0
                        Installed Node version: v20.8.0
                        No Node.js upgrade necessary.
                        Minimum npm version: V10.1.0
                        Installed npm version: V10.1.0
                        No npm upgrade necessary.
                        saving custom.css
                        upgrading from version 2.25.0 to 2.25.0
                        fetching latest revisions
                        updating dependencies for active modules with package.json files
                        	processing for module EXT-UpdateNotification please wait
                        	skipped processing for EXT-UpdateNotification, doing test run
                        	processing complete for module EXT-UpdateNotification
                        	processing for module MMM-GoogleAssistant please wait
                        	skipped processing for MMM-GoogleAssistant, doing test run
                        	processing complete for module MMM-GoogleAssistant
                        	processing for module EXT-Alert please wait
                        	skipped processing for EXT-Alert, doing test run
                        	processing complete for module EXT-Alert
                        	processing for module EXT-Bring please wait
                        	skipped processing for EXT-Bring, doing test run
                        	processing complete for module EXT-Bring
                        	processing for module EXT-Browser please wait
                        	skipped processing for EXT-Browser, doing test run
                        	processing complete for module EXT-Browser
                        	processing for module EXT-Detector please wait
                        	skipped processing for EXT-Detector, doing test run
                        	processing complete for module EXT-Detector
                        	processing for module EXT-Librespot please wait
                        	skipped processing for EXT-Librespot, doing test run
                        	processing complete for module EXT-Librespot
                        	processing for module EXT-Photos please wait
                        	skipped processing for EXT-Photos, doing test run
                        	processing complete for module EXT-Photos
                        	processing for module EXT-RadioPlayer please wait
                        	skipped processing for EXT-RadioPlayer, doing test run
                        	processing complete for module EXT-RadioPlayer
                        	processing for module EXT-ScreenManager please wait
                        	skipped processing for EXT-ScreenManager, doing test run
                        	processing complete for module EXT-ScreenManager
                        	processing for module EXT-Spotify please wait
                        	skipped processing for EXT-Spotify, doing test run
                        	processing complete for module EXT-Spotify
                        	processing for module Gateway please wait
                        	skipped processing for Gateway, doing test run
                        	processing complete for module Gateway
                        	processing for module MMM-DHT-Sensor please wait
                        	skipped processing for MMM-DHT-Sensor, doing test run
                        	processing complete for module MMM-DHT-Sensor
                        	processing for module MMM-RainForecast-FR please wait
                        	skipped processing for MMM-RainForecast-FR, doing test run
                        	processing complete for module MMM-RainForecast-FR
                        	processing for module MMM-TomTomTraffic please wait
                        	skipped processing for MMM-TomTomTraffic, doing test run
                        	processing complete for module MMM-TomTomTraffic
                        	processing for module MMM-MovieListings please wait
                        	skipped processing for MMM-MovieListings, doing test run
                        	processing complete for module MMM-MovieListings
                        	processing for module MMM-MarineWeather please wait
                        	skipped processing for MMM-MarineWeather, doing test run
                        	processing complete for module MMM-MarineWeather
                        restoring custom.css
                        pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                        doing test run = false
                        force: ligne 450 : [: -le : opérateur unaire attendu
                        saving custom.css
                        up to date in 3s
                        up to date in 4s
                        no husky installed.
                        added 334 packages in 2m
                        97 packages are looking for funding
                          run `npm fund` for details
                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        > EXT-UpdateNotification@2.1.0 preinstall
                        > installer/preinstall.sh
                        Welcome to EXT-UpdateNotification v2.1.0
                        No root checking...
                        Checking EXT-UpdateNotification: pi/pi
                        Checking MagicMirror: pi/pi
                        Checking OS...
                        OS Detected: linux-gnueabihf (raspbian 11 aarch64)
                        Installing all npm libraries...
                        > EXT-UpdateNotification@2.1.0 postinstall
                        > installer/postinstall.sh
                        Minify Main code
                        Found: 8 files to minify
                        Process File: ../EXT-UpdateNotification.js
                        Process File: ../components/gitCheck.js
                        Process File: ../components/loadLibraries.js
                        Process File: ../components/npmCheck.js
                        Process File: ../components/parseData.js
                        Process File: ../components/update.js
                        Process File: ../node_helper.js
                        Process File: ../components/check.js
                        Done
                        Support is now moved in a dedicated Server: https://forum.bugsounet.fr
                        @bugsounet
                        EXT-UpdateNotification is now installed !
                        added 248 packages, and audited 249 packages in 50s
                        39 packages are looking for funding
                        found 0 vulnerabilities
                        > MMM-GoogleAssistant@5.4.0 preinstall
                        Welcome to MMM-GoogleAssistant v5.4.0
                        No root checking...
                        Checking MMM-GoogleAssistant: pi/pi
                        Checking OS...
                        > MMM-GoogleAssistant@5.4.0 postinstall
                        > installer/postinstall.sh -m -b
                        Minify Main code...
                        Found: 27 files to minify
                        Process File: ../MMM-GoogleAssistant.js
                        Process File: ../components/shellExec.js
                        Process File: ../components/searchOnGoogle.js
                        Process File: ../components/screenParser.js
                        Process File: ../components/recipes.js
                        Process File: ../components/proto-loader.js
                        Process File: ../components/platform.js
                        Process File: ../components/lpcm16.js
                        Process File: ../components/googleSearch.js
                        Process File: ../components/googleAssistant.js
                        Process File: ../components/embedded-assistant.js
                        Process File: ../components/conversation.js
                        Process File: ../components/configMerge.js
                        Process File: ../components/auth.js
                        Process File: ../components/assistantSearch.js
                        Process File: ../components/assistantResponse.js
                        Process File: ../components/assistantConverse.js
                        Process File: ../components/activateProcess.js
                        Process File: ../components/activateAssistant.js
                        Process File: ../components/Hooks.js
                        Process File: ../components/Gateway.js
                        Process File: ../components/GAConfig.js
                        Process File: ../components/BufferToMP3.js
                        Process File: ../components/Assistant.js
                        Done
                        @bugsounet
                        MMM-GoogleAssistant is now installed !
                        added 158 packages in 32s
                        52 packages are looking for funding
                        > EXT-Alert@1.2.3 preinstall
                        Welcome to EXT-Alert v1.2.3
                        No root checking...
                        Checking EXT-Alert: pi/pi
                        Checking OS...
                        > EXT-Alert@1.2.3 postinstall
                        Minify Main code...
                        Found: 5 files to minify
                        Process File: ../EXT-Alert.js
                        Process File: ../components/AlertInit.js
                        Process File: ../components/AlertDisplay.js
                        Process File: ../components/AlertCommander.js
                        Done
                        @bugsounet
                        EXT-Alert is now installed !
                        added 42 packages in 12s
                        13 packages are looking for funding
                        > EXT-Bring@1.2.2 preinstall
                        Welcome to EXT-Bring v1.2.2
                        No root checking...
                        Checking EXT-Bring: pi/pi
                        Checking OS...
                        > EXT-Bring@1.2.2 postinstall
                        Minify Main code...
                        Process File: ../EXT-Bring.js
                        Process File: ../components/bring-lib.js
                        Done
                        @bugsounet
                        EXT-Bring is now installed !
                        added 50 packages in 14s
                        16 packages are looking for funding
                        > EXT-Browser@1.2.3 preinstall
                        Welcome to EXT-Browser v1.2.3
                        No root checking...
                        Checking EXT-Browser: pi/pi
                        Checking OS...
                        > EXT-Browser@1.2.3 postinstall
                        Minify Main code...
                        Found: 3 files to minify
                        Process File: ../EXT-Browser.js
                        Process File: ../components/BrowserDisplay.js
                        Done
                        @bugsounet
                        EXT-Browser is now installed !
                        added 42 packages in 7s
                        npm ERR! code 255
                        npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
                        npm ERR! command failed
                        npm ERR! command sh -c installer/postinstall.sh -r -m -b
                        npm ERR! Prepare snowboy library...
                        npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
                        npm ERR! Failed!
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
                        > EXT-Librespot@1.2.5 preinstall
                        Welcome to EXT-Librespot v1.2.5
                        No root checking...
                        Checking EXT-Librespot: pi/pi
                        Checking OS...
                        > EXT-Librespot@1.2.5 postinstall
                        Minify Main code...
                        Found: 2 files to minify
                        Process File: ../EXT-Librespot.js
                        Done
                        @bugsounet
                        EXT-Librespot is now installed !
                        added 195 packages in 26s
                        25 packages are looking for funding
                        > EXT-Photos@1.1.3 preinstall
                        Welcome to EXT-Photos v1.1.3
                        No root checking...
                        Checking EXT-Photos: pi/pi
                        Checking OS...
                        > EXT-Photos@1.1.3 postinstall
                        Minify Main code...
                        Process File: ../EXT-Photos.js
                        Done
                        @bugsounet
                        EXT-Photos is now installed !
                        added 42 packages in 8s
                        > EXT-RadioPlayer@1.1.6 preinstall
                        > installer/preinstall.sh -d 'vlc'
                        Welcome to EXT-RadioPlayer v1.1.6
                        No root checking...
                        Checking EXT-RadioPlayer: pi/pi
                        Checking OS...
                        Checking all dependencies...
                        All Dependencies needed are installed !
                        > EXT-RadioPlayer@1.1.6 postinstall
                        Minify Main code...
                        Process File: ../EXT-RadioPlayer.js
                        Done
                        @bugsounet
                        EXT-RadioPlayer is now installed !
                        added 50 packages in 11s
                        14 packages are looking for funding
                        > EXT-ScreenManager@1.1.0 preinstall
                        Welcome to EXT-ScreenManager v1.1.0
                        No root checking...
                        Checking EXT-ScreenManager: pi/pi
                        Checking OS...
                        > EXT-ScreenManager@1.1.0 postinstall
                        Minify Main code
                        Process File: ../EXT-ScreenManager.js
                        Done
                        @bugsounet
                        EXT-ScreenManager is now installed !
                        added 64 packages, and audited 65 packages in 12s
                        > EXT-Spotify@2.3.3 preinstall
                        Welcome to EXT-Spotify v2.3.3
                        No root checking...
                        Checking EXT-Spotify: pi/pi
                        Checking OS...
                        > EXT-Spotify@2.3.3 postinstall
                        Minify Main code...
                        Found: 6 files to minify
                        Process File: ../EXT-Spotify.js
                        Process File: ../components/spotifyLib.js
                        Process File: ../components/spotifyClass.js
                        Process File: ../components/JSPanel.js
                        Process File: ../components/CanvasLyrics.js
                        Done
                        @bugsounet
                        EXT-Spotify is now installed !
                        added 143 packages in 23s
                        48 packages are looking for funding
                        npm ERR! code 255
                        npm ERR! path /home/pi/MagicMirror/modules/Gateway
                        npm ERR! Minify Main code...
                        npm ERR! node:internal/modules/cjs/loader:1051
                        npm ERR!   throw err;
                        npm ERR!   ^
                        npm ERR!
                        npm ERR! Error: Cannot find module 'esbuild'
                        npm ERR! Require stack:
                        npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
                        npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                        npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
                        npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
                        npm ERR!     at require (node:internal/modules/helpers:130:18)
                        npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
                        npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
                        npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                        npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
                        npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
                        npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
                        npm ERR!   code: 'MODULE_NOT_FOUND',
                        npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
                        npm ERR! }
                        npm ERR!
                        npm ERR! Node.js v20.8.0
                        npm ERR! Minify Failed!
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
                        rebuilt dependencies successfully
                        added 9 packages, and audited 10 packages in 3s
                        1 package is looking for funding
                        up to date, audited 1 package in 2s
                        added 47 packages, and audited 48 packages in 8s
                        2 moderate severity vulnerabilities
                        Some issues need review, and may require choosing
                        a different dependency.
                        Run `npm audit` for details.
                        added 4 packages, and audited 5 packages in 2s
                          sdetweil @RIKKO14
                          @RIKKO14 you need the word
                          force
                          added on the end of the upgrade command
                            RIKKO14
                            pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                            bash: $'\E[200~bash' : commande introuvable
                            saving custom.css
                            up to date in 7s
                            up to date in 47s
                            no husky installed.
                            added 334 packages in 3m
                            No root checking...
                            Checking OS...
                            Minify Main code
                            Done
                            @bugsounet
                            added 248 packages, and audited 249 packages in 26s
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            added 158 packages in 16s
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            added 42 packages in 5s
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            added 50 packages in 13s
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            npm ERR! code 255
                            npm ERR! Failed!
                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            added 195 packages in 18s
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            added 50 packages in 9s
                            No root checking...
                            Checking OS...
                            Minify Main code
                            Done
                            @bugsounet
                            added 64 packages, and audited 65 packages in 13s
                            No root checking...
                            Checking OS...
                            Minify Main code...
                            Done
                            @bugsounet
                            added 143 packages in 14s
                            npm ERR! code 255
                            npm ERR!   throw err;
                            npm ERR!   ^
                            npm ERR!
                            npm ERR! }
                            npm ERR!
                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
                            added 9 packages, and audited 10 packages in 2s
                            up to date, audited 1 package in 949ms
                            added 47 packages, and audited 48 packages in 7s
                            pi@raspberrypi:~/MagicMirror $ pm2 stop 0
                            [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                            pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                            npm start
                            [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
                            [05.11.2023 15:59.49.477] [LOG]   Loading config ...
                            [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
                            [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
                            [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
                            [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
                            [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
                            [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
                            [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
                            [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
                            [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
                            [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
                            [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
                            [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
                            [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
                            [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
                            [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
                            [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
                            [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
                            [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
                            [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
                            Require stack:
                            - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
                            [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                            [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                              @RIKKO14 now another module… DHT-Sensor missing a library
                              go to the module folder and
                              see this topic
                                RIKKO14
                                I do
                                cd ~/MagicMirror/modules/MMM-DHT-Sensor
                                npm install
                                then
                                npm start
                                then
                                cd ~/MagicMirror/modules/MMM-GoogleAssistant
                                npm run update
                                npm run refresh
                                then
                                pm2 restart 0
                                then
                                sudo reboot now
                                and finally everything works well
                                thank you for your help
                                  sdetweil @RIKKO14
                                  @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                                  bugsounetB 1 Reply Last reply
                                  • bugsounetB
                                    bugsounet Banned @sdetweil
                                    @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
                                      sdetweil @bugsounet
                                      @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
                                      I check for rebuild not refresh… will fix upgrade
                                      • bugsounetB
                                        @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
                                          sdetweil @bugsounet
                                          @bugsounet @RIKKO14
                                          can either of you run this on your French systems
                                          LC_ALL=C  free -m
                                          should output in english
                                            RIKKO14
                                            @sdetweil Hello,
                                            it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
                                            S M 2 Replies Last reply
