    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 9.9k Views 4 Watching
      RIKKO14
      I do :
      pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      Minimum Node version: v20.8.0
      Installed Node version: v20.8.0
      No Node.js upgrade necessary.
      Minimum npm version: V10.1.0
      Installed npm version: V10.1.0
      No npm upgrade necessary.
      saving custom.css
      upgrading from version 2.25.0 to 2.25.0
      fetching latest revisions
      updating dependencies for active modules with package.json files
      	processing for module EXT-UpdateNotification please wait
      	skipped processing for EXT-UpdateNotification, doing test run
      	processing complete for module EXT-UpdateNotification
      	processing for module MMM-GoogleAssistant please wait
      	skipped processing for MMM-GoogleAssistant, doing test run
      	processing complete for module MMM-GoogleAssistant
      	processing for module EXT-Alert please wait
      	skipped processing for EXT-Alert, doing test run
      	processing complete for module EXT-Alert
      	processing for module EXT-Bring please wait
      	skipped processing for EXT-Bring, doing test run
      	processing complete for module EXT-Bring
      	processing for module EXT-Browser please wait
      	skipped processing for EXT-Browser, doing test run
      	processing complete for module EXT-Browser
      	processing for module EXT-Detector please wait
      	skipped processing for EXT-Detector, doing test run
      	processing complete for module EXT-Detector
      	processing for module EXT-Librespot please wait
      	skipped processing for EXT-Librespot, doing test run
      	processing complete for module EXT-Librespot
      	processing for module EXT-Photos please wait
      	skipped processing for EXT-Photos, doing test run
      	processing complete for module EXT-Photos
      	processing for module EXT-RadioPlayer please wait
      	skipped processing for EXT-RadioPlayer, doing test run
      	processing complete for module EXT-RadioPlayer
      	processing for module EXT-ScreenManager please wait
      	skipped processing for EXT-ScreenManager, doing test run
      	processing complete for module EXT-ScreenManager
      	processing for module EXT-Spotify please wait
      	skipped processing for EXT-Spotify, doing test run
      	processing complete for module EXT-Spotify
      	processing for module Gateway please wait
      	skipped processing for Gateway, doing test run
      	processing complete for module Gateway
      	processing for module MMM-DHT-Sensor please wait
      	skipped processing for MMM-DHT-Sensor, doing test run
      	processing complete for module MMM-DHT-Sensor
      	processing for module MMM-RainForecast-FR please wait
      	skipped processing for MMM-RainForecast-FR, doing test run
      	processing complete for module MMM-RainForecast-FR
      	processing for module MMM-TomTomTraffic please wait
      	skipped processing for MMM-TomTomTraffic, doing test run
      	processing complete for module MMM-TomTomTraffic
      	processing for module MMM-MovieListings please wait
      	skipped processing for MMM-MovieListings, doing test run
      	processing complete for module MMM-MovieListings
      	processing for module MMM-MarineWeather please wait
      	skipped processing for MMM-MarineWeather, doing test run
      	processing complete for module MMM-MarineWeather
      restoring custom.css
      pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
      doing test run = false
      force: ligne 450 : [: -le : opérateur unaire attendu
      saving custom.css
      > magicmirror@2.25.0 postinstall
      > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
      > magicmirror@2.25.0 install-vendor
      > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      up to date in 3s
      > magicmirror@2.25.0 install-fonts
      > echo "Installing fonts ...
      > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
      up to date in 4s
      > magicmirror@2.25.0 prepare
      > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
      no husky installed.
      added 334 packages in 2m
      97 packages are looking for funding
        run `npm fund` for details
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      > EXT-UpdateNotification@2.1.0 preinstall
      > installer/preinstall.sh
      Welcome to EXT-UpdateNotification v2.1.0
      No root checking...
      Checking EXT-UpdateNotification: pi/pi
      Checking MagicMirror: pi/pi
      Checking OS...
      OS Detected: linux-gnueabihf (raspbian 11 aarch64)
      Installing all npm libraries...
      > EXT-UpdateNotification@2.1.0 postinstall
      > installer/postinstall.sh
      Minify Main code
      Found: 8 files to minify
      Process File: ../EXT-UpdateNotification.js
      Process File: ../components/gitCheck.js
      Process File: ../components/loadLibraries.js
      Process File: ../components/npmCheck.js
      Process File: ../components/parseData.js
      Process File: ../components/update.js
      Process File: ../node_helper.js
      Process File: ../components/check.js
      Done
      Support is now moved in a dedicated Server: https://forum.bugsounet.fr
      @bugsounet
      EXT-UpdateNotification is now installed !
      added 248 packages, and audited 249 packages in 50s
      39 packages are looking for funding
      found 0 vulnerabilities
      > MMM-GoogleAssistant@5.4.0 preinstall
      Welcome to MMM-GoogleAssistant v5.4.0
      No root checking...
      Checking MMM-GoogleAssistant: pi/pi
      Checking OS...
      > MMM-GoogleAssistant@5.4.0 postinstall
      > installer/postinstall.sh -m -b
      Minify Main code...
      Found: 27 files to minify
      Process File: ../MMM-GoogleAssistant.js
      Process File: ../components/shellExec.js
      Process File: ../components/searchOnGoogle.js
      Process File: ../components/screenParser.js
      Process File: ../components/recipes.js
      Process File: ../components/proto-loader.js
      Process File: ../components/platform.js
      Process File: ../components/lpcm16.js
      Process File: ../components/googleSearch.js
      Process File: ../components/googleAssistant.js
      Process File: ../components/embedded-assistant.js
      Process File: ../components/conversation.js
      Process File: ../components/configMerge.js
      Process File: ../components/auth.js
      Process File: ../components/assistantSearch.js
      Process File: ../components/assistantResponse.js
      Process File: ../components/assistantConverse.js
      Process File: ../components/activateProcess.js
      Process File: ../components/activateAssistant.js
      Process File: ../components/Hooks.js
      Process File: ../components/Gateway.js
      Process File: ../components/GAConfig.js
      Process File: ../components/BufferToMP3.js
      Process File: ../components/Assistant.js
      Done
      @bugsounet
      MMM-GoogleAssistant is now installed !
      added 158 packages in 32s
      52 packages are looking for funding
      > EXT-Alert@1.2.3 preinstall
      Welcome to EXT-Alert v1.2.3
      No root checking...
      Checking EXT-Alert: pi/pi
      Checking OS...
      > EXT-Alert@1.2.3 postinstall
      Minify Main code...
      Found: 5 files to minify
      Process File: ../EXT-Alert.js
      Process File: ../components/AlertInit.js
      Process File: ../components/AlertDisplay.js
      Process File: ../components/AlertCommander.js
      Done
      @bugsounet
      EXT-Alert is now installed !
      added 42 packages in 12s
      13 packages are looking for funding
      > EXT-Bring@1.2.2 preinstall
      Welcome to EXT-Bring v1.2.2
      No root checking...
      Checking EXT-Bring: pi/pi
      Checking OS...
      > EXT-Bring@1.2.2 postinstall
      Minify Main code...
      Process File: ../EXT-Bring.js
      Process File: ../components/bring-lib.js
      Done
      @bugsounet
      EXT-Bring is now installed !
      added 50 packages in 14s
      16 packages are looking for funding
      > EXT-Browser@1.2.3 preinstall
      Welcome to EXT-Browser v1.2.3
      No root checking...
      Checking EXT-Browser: pi/pi
      Checking OS...
      > EXT-Browser@1.2.3 postinstall
      Minify Main code...
      Found: 3 files to minify
      Process File: ../EXT-Browser.js
      Process File: ../components/BrowserDisplay.js
      Done
      @bugsounet
      EXT-Browser is now installed !
      added 42 packages in 7s
      npm ERR! code 255
      npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
      npm ERR! command failed
      npm ERR! command sh -c installer/postinstall.sh -r -m -b
      npm ERR! Prepare snowboy library...
      npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
      npm ERR! Failed!
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
      > EXT-Librespot@1.2.5 preinstall
      Welcome to EXT-Librespot v1.2.5
      No root checking...
      Checking EXT-Librespot: pi/pi
      Checking OS...
      > EXT-Librespot@1.2.5 postinstall
      Minify Main code...
      Found: 2 files to minify
      Process File: ../EXT-Librespot.js
      Done
      @bugsounet
      EXT-Librespot is now installed !
      added 195 packages in 26s
      25 packages are looking for funding
      > EXT-Photos@1.1.3 preinstall
      Welcome to EXT-Photos v1.1.3
      No root checking...
      Checking EXT-Photos: pi/pi
      Checking OS...
      > EXT-Photos@1.1.3 postinstall
      Minify Main code...
      Process File: ../EXT-Photos.js
      Done
      @bugsounet
      EXT-Photos is now installed !
      added 42 packages in 8s
      > EXT-RadioPlayer@1.1.6 preinstall
      > installer/preinstall.sh -d 'vlc'
      Welcome to EXT-RadioPlayer v1.1.6
      No root checking...
      Checking EXT-RadioPlayer: pi/pi
      Checking OS...
      Checking all dependencies...
      All Dependencies needed are installed !
      > EXT-RadioPlayer@1.1.6 postinstall
      Minify Main code...
      Process File: ../EXT-RadioPlayer.js
      Done
      @bugsounet
      EXT-RadioPlayer is now installed !
      added 50 packages in 11s
      14 packages are looking for funding
      > EXT-ScreenManager@1.1.0 preinstall
      Welcome to EXT-ScreenManager v1.1.0
      No root checking...
      Checking EXT-ScreenManager: pi/pi
      Checking OS...
      > EXT-ScreenManager@1.1.0 postinstall
      Minify Main code
      Process File: ../EXT-ScreenManager.js
      Done
      @bugsounet
      EXT-ScreenManager is now installed !
      added 64 packages, and audited 65 packages in 12s
      > EXT-Spotify@2.3.3 preinstall
      Welcome to EXT-Spotify v2.3.3
      No root checking...
      Checking EXT-Spotify: pi/pi
      Checking OS...
      > EXT-Spotify@2.3.3 postinstall
      Minify Main code...
      Found: 6 files to minify
      Process File: ../EXT-Spotify.js
      Process File: ../components/spotifyLib.js
      Process File: ../components/spotifyClass.js
      Process File: ../components/JSPanel.js
      Process File: ../components/CanvasLyrics.js
      Done
      @bugsounet
      EXT-Spotify is now installed !
      added 143 packages in 23s
      48 packages are looking for funding
      npm ERR! code 255
      npm ERR! path /home/pi/MagicMirror/modules/Gateway
      npm ERR! Minify Main code...
      npm ERR! node:internal/modules/cjs/loader:1051
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR! Error: Cannot find module 'esbuild'
      npm ERR! Require stack:
      npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
      npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
      npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
      npm ERR!     at require (node:internal/modules/helpers:130:18)
      npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
      npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
      npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
      npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
      npm ERR!   code: 'MODULE_NOT_FOUND',
      npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
      npm ERR! }
      npm ERR!
      npm ERR! Node.js v20.8.0
      npm ERR! Minify Failed!
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
      rebuilt dependencies successfully
      added 9 packages, and audited 10 packages in 3s
      1 package is looking for funding
      up to date, audited 1 package in 2s
      added 47 packages, and audited 48 packages in 8s
      2 moderate severity vulnerabilities
      Some issues need review, and may require choosing
      a different dependency.
      Run `npm audit` for details.
      added 4 packages, and audited 5 packages in 2s
        sdetweil @RIKKO14
        @RIKKO14 you need the word
        force
        added on the end of the upgrade command
          RIKKO14
          pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
          bash: $'\E[200~bash' : commande introuvable
          saving custom.css
          up to date in 7s
          up to date in 47s
          no husky installed.
          added 334 packages in 3m
          No root checking...
          Checking OS...
          Minify Main code
          Done
          @bugsounet
          added 248 packages, and audited 249 packages in 26s
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          added 158 packages in 16s
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          added 42 packages in 5s
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          added 50 packages in 13s
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          npm ERR! code 255
          npm ERR! Failed!
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          added 195 packages in 18s
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          added 50 packages in 9s
          No root checking...
          Checking OS...
          Minify Main code
          Done
          @bugsounet
          added 64 packages, and audited 65 packages in 13s
          No root checking...
          Checking OS...
          Minify Main code...
          Done
          @bugsounet
          added 143 packages in 14s
          npm ERR! code 255
          npm ERR!   throw err;
          npm ERR!   ^
          npm ERR!
          npm ERR! }
          npm ERR!
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
          added 9 packages, and audited 10 packages in 2s
          up to date, audited 1 package in 949ms
          added 47 packages, and audited 48 packages in 7s
          pi@raspberrypi:~/MagicMirror $ pm2 stop 0
          [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
          [PM2] [MagicMirror](0) ✓
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
          pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
          npm start
          > magicmirror@2.25.0 start
          [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
          [05.11.2023 15:59.49.477] [LOG]   Loading config ...
          [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
          [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
          [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
          [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
          [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
          [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
          [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
          [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
          [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
          [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
          [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
          [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
          [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
          [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
          [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
          [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
          [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
          [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
          [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
          Require stack:
          - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
              at node:internal/modules/cjs/loader:1084:15
              at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object..js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
          (Use `electron --trace-warnings ...` to show where the warning was created)
          [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
          MESA-LOADER: failed to retrieve device information
          MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          failed to load driver: kms_swrast
          MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          failed to load swrast driver
            @RIKKO14 now another module… DHT-Sensor missing a library
            go to the module folder and
            see this topic
              RIKKO14
              I do
              cd ~/MagicMirror/modules/MMM-DHT-Sensor
              npm install
              then
              npm start
              then
              cd ~/MagicMirror/modules/MMM-GoogleAssistant
              npm run update
              npm run refresh
              then
              pm2 restart 0
              then
              sudo reboot now
              and finally everything works well
              thank you for your help
                sdetweil @RIKKO14
                @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                bugsounetB 1 Reply Last reply Reply Quote 0
                • bugsounetB
                  bugsounet Banned @sdetweil
                  @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
                    sdetweil @bugsounet
                    @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
                    I check for rebuild not refresh… will fix upgrade
                    • bugsounetB
                      @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
                        sdetweil @bugsounet
                        @bugsounet @RIKKO14
                        can either of you run this on your French systems
                        LC_ALL=C  free -m
                        should output in english
                          RIKKO14
                          @sdetweil Hello,
                          it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
                            sdetweil @RIKKO14
                            @RIKKO14 just one command run in terminal
                            returns amount of memory being used
                            my scripts use this an depend on the English text,
                            trying to make sure it comes out in English is all.
                            has no affect on system
                              MMRIZE @RIKKO14
                              @RIKKO14
                              If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.
                                RIKKO14
                                here it is :
                                  sdetweil @RIKKO14
                                  @RIKKO14 thank you! perfect
