    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 10.2k Views 4 Watching
      sdetweil @RIKKO14
      @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
      bugsounetB 1 Reply Last reply
      • bugsounetB
        bugsounet Banned @sdetweil
        @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
          sdetweil @bugsounet
          @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
          I check for rebuild not refresh… will fix upgrade
          • bugsounetB
            @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
              sdetweil @bugsounet
              @bugsounet @RIKKO14
              can either of you run this on your French systems
              LC_ALL=C  free -m
              should output in english
                RIKKO14
                @sdetweil Hello,
                it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
                S M 2 Replies Last reply
                  sdetweil @RIKKO14
                  @RIKKO14 just one command run in terminal
                  returns amount of memory being used
                  my scripts use this an depend on the English text,
                  trying to make sure it comes out in English is all.
                  has no affect on system
                    MMRIZE @RIKKO14
                    @RIKKO14
                    If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.
                      RIKKO14
                      here it is :
                        sdetweil @RIKKO14
                        @RIKKO14 thank you! perfect
