    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 9.3k Views 4 Watching
      RIKKO14 @sdetweil
        RIKKO14 @RIKKO14
        My node version is 20.8.0 but i don’t know to launch my MM…
        MM didn’t start…
          sdetweil @RIKKO14
          @RIKKO14
          do
          pm2 stop all
          npm run install-mm
          npm start
          please confirm results
            RIKKO14
            The result :
            pi@raspberrypi:~/MagicMirror $ pm2 stop all
            npm run install-mm
            npm start
            [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
            > magicmirror@2.25.0 install-mm
            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
            npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
            > magicmirror@2.25.0 postinstall
            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
            > magicmirror@2.25.0 install-vendor
            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 1s
            > magicmirror@2.25.0 install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
            up to date in 1s
            > magicmirror@2.25.0 prepare
            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
            no husky installed.
            up to date in 14s
            > magicmirror@2.25.0 start
            [05.11.2023 14:46.59.755] [LOG]   Starting MagicMirror: v2.25.0
            [05.11.2023 14:46.59.761] [LOG]   Loading config ...
            [05.11.2023 14:46.59.767] [DEBUG] config template file not exists, no envsubst
            [05.11.2023 14:46.59.775] [LOG]   Loading module helpers ...
            [05.11.2023 14:46.59.778] [LOG]   No helper found for module: alert.
            [05.11.2023 14:46.59.800] [LOG]   Initializing new module helper ...
            [05.11.2023 14:46.59.801] [LOG]   Module helper loaded: EXT-UpdateNotification
            [05.11.2023 14:46.59.803] [LOG]   No helper found for module: clock.
            [05.11.2023 14:47.00.090] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.091] [LOG]   Module helper loaded: calendar
            [05.11.2023 14:47.00.098] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.099] [LOG]   Module helper loaded: MMM-GoogleAssistant
            [05.11.2023 14:47.00.103] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.103] [LOG]   Module helper loaded: EXT-Alert
            [05.11.2023 14:47.00.115] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.116] [LOG]   Module helper loaded: EXT-Bring
            [05.11.2023 14:47.00.127] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.127] [LOG]   Module helper loaded: EXT-Browser
            [05.11.2023 14:47.00.142] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.142] [LOG]   Module helper loaded: EXT-Detector
            [05.11.2023 14:47.00.595] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.596] [LOG]   Module helper loaded: EXT-Librespot
            [05.11.2023 14:47.00.599] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.599] [LOG]   Module helper loaded: EXT-Photos
            [05.11.2023 14:47.00.603] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.603] [LOG]   Module helper loaded: EXT-RadioPlayer
            [05.11.2023 14:47.00.638] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.638] [LOG]   Module helper loaded: EXT-ScreenManager
            [05.11.2023 14:47.00.967] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.968] [LOG]   Module helper loaded: EXT-Spotify
            [05.11.2023 14:47.00.975] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.975] [LOG]   Module helper loaded: Gateway
            [05.11.2023 14:47.00.998] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.00.999] [LOG]   Module helper loaded: MMM-DHT-Sensor
            [05.11.2023 14:47.00.999] [LOG]   No helper found for module: MMM-WeatherOrNot.
            [05.11.2023 14:47.01.093] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.01.094] [LOG]   Module helper loaded: MMM-RainForecast-FR
            [05.11.2023 14:47.01.094] [LOG]   No helper found for module: MMM-TomTomTraffic.
            [05.11.2023 14:47.01.594] [LOG]   Initializing new module helper ...
            [05.11.2023 14:47.01.595] [LOG]   Module helper loaded: MMM-MovieListings
            [05.11.2023 14:47.01.600] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
            Require stack:
            - /home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js
                at node:internal/modules/cjs/loader:1084:15
                at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at node:internal/modules/cjs/loader:929:27
                at Function._load (node:electron/js2c/asar_bundle:2:13327)
            at Module.require (node:internal/modules/cjs/loader:1150:19)
                at require (node:internal/modules/cjs/helpers:110:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MarineWeather/node_helper.js:14:15)
                at Module._compile (node:internal/modules/cjs/loader:1271:14)
                at Object..js (node:internal/modules/cjs/loader:1326:10)
                at Module.load (node:internal/modules/cjs/loader:1126:32)
                at node:internal/modules/cjs/loader:967:12
                at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
            (Use `electron --trace-warnings ...` to show where the warning was created)
            [05.11.2023 14:47.01.601] [ERROR] (node:12072) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
            [12072:1105/144701.952277:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
            MESA-LOADER: failed to retrieve device information
            MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
            failed to load driver: kms_swrast
            MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: Ne peut ouvrir le fichier d'objet partagé: Permission non accordée (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
            failed to load swrast driver
            And MM didn’t launch…
              RIKKO14
              If I anderstand my MM is up to date and node is up to date too.
              So Why my MM didn’t launch ?..
                sdetweil @RIKKO14
                @RIKKO14 one command at a time
                show results of each one at a time
                  sdetweil @RIKKO14
                  @RIKKO14
                  yes that module is missing a library
                  if you run my upgrade script with force, it should fix it
                    RIKKO14
                    I do :
                    pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                    Minimum Node version: v20.8.0
                    Installed Node version: v20.8.0
                    No Node.js upgrade necessary.
                    Minimum npm version: V10.1.0
                    Installed npm version: V10.1.0
                    No npm upgrade necessary.
                    saving custom.css
                    upgrading from version 2.25.0 to 2.25.0
                    fetching latest revisions
                    updating dependencies for active modules with package.json files
                    	processing for module EXT-UpdateNotification please wait
                    	skipped processing for EXT-UpdateNotification, doing test run
                    	processing complete for module EXT-UpdateNotification
                    	processing for module MMM-GoogleAssistant please wait
                    	skipped processing for MMM-GoogleAssistant, doing test run
                    	processing complete for module MMM-GoogleAssistant
                    	processing for module EXT-Alert please wait
                    	skipped processing for EXT-Alert, doing test run
                    	processing complete for module EXT-Alert
                    	processing for module EXT-Bring please wait
                    	skipped processing for EXT-Bring, doing test run
                    	processing complete for module EXT-Bring
                    	processing for module EXT-Browser please wait
                    	skipped processing for EXT-Browser, doing test run
                    	processing complete for module EXT-Browser
                    	processing for module EXT-Detector please wait
                    	skipped processing for EXT-Detector, doing test run
                    	processing complete for module EXT-Detector
                    	processing for module EXT-Librespot please wait
                    	skipped processing for EXT-Librespot, doing test run
                    	processing complete for module EXT-Librespot
                    	processing for module EXT-Photos please wait
                    	skipped processing for EXT-Photos, doing test run
                    	processing complete for module EXT-Photos
                    	processing for module EXT-RadioPlayer please wait
                    	skipped processing for EXT-RadioPlayer, doing test run
                    	processing complete for module EXT-RadioPlayer
                    	processing for module EXT-ScreenManager please wait
                    	skipped processing for EXT-ScreenManager, doing test run
                    	processing complete for module EXT-ScreenManager
                    	processing for module EXT-Spotify please wait
                    	skipped processing for EXT-Spotify, doing test run
                    	processing complete for module EXT-Spotify
                    	processing for module Gateway please wait
                    	skipped processing for Gateway, doing test run
                    	processing complete for module Gateway
                    	processing for module MMM-DHT-Sensor please wait
                    	skipped processing for MMM-DHT-Sensor, doing test run
                    	processing complete for module MMM-DHT-Sensor
                    	processing for module MMM-RainForecast-FR please wait
                    	skipped processing for MMM-RainForecast-FR, doing test run
                    	processing complete for module MMM-RainForecast-FR
                    	processing for module MMM-TomTomTraffic please wait
                    	skipped processing for MMM-TomTomTraffic, doing test run
                    	processing complete for module MMM-TomTomTraffic
                    	processing for module MMM-MovieListings please wait
                    	skipped processing for MMM-MovieListings, doing test run
                    	processing complete for module MMM-MovieListings
                    	processing for module MMM-MarineWeather please wait
                    	skipped processing for MMM-MarineWeather, doing test run
                    	processing complete for module MMM-MarineWeather
                    restoring custom.css
                    pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                    doing test run = false
                    force: ligne 450 : [: -le : opérateur unaire attendu
                    saving custom.css
                    up to date in 3s
                    up to date in 4s
                    no husky installed.
                    added 334 packages in 2m
                    97 packages are looking for funding
                      run `npm fund` for details
                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    > EXT-UpdateNotification@2.1.0 preinstall
                    > installer/preinstall.sh
                    Welcome to EXT-UpdateNotification v2.1.0
                    No root checking...
                    Checking EXT-UpdateNotification: pi/pi
                    Checking MagicMirror: pi/pi
                    Checking OS...
                    OS Detected: linux-gnueabihf (raspbian 11 aarch64)
                    Installing all npm libraries...
                    > EXT-UpdateNotification@2.1.0 postinstall
                    > installer/postinstall.sh
                    Minify Main code
                    Found: 8 files to minify
                    Process File: ../EXT-UpdateNotification.js
                    Process File: ../components/gitCheck.js
                    Process File: ../components/loadLibraries.js
                    Process File: ../components/npmCheck.js
                    Process File: ../components/parseData.js
                    Process File: ../components/update.js
                    Process File: ../node_helper.js
                    Process File: ../components/check.js
                    Done
                    Support is now moved in a dedicated Server: https://forum.bugsounet.fr
                    @bugsounet
                    EXT-UpdateNotification is now installed !
                    added 248 packages, and audited 249 packages in 50s
                    39 packages are looking for funding
                    found 0 vulnerabilities
                    > MMM-GoogleAssistant@5.4.0 preinstall
                    Welcome to MMM-GoogleAssistant v5.4.0
                    No root checking...
                    Checking MMM-GoogleAssistant: pi/pi
                    Checking OS...
                    > MMM-GoogleAssistant@5.4.0 postinstall
                    > installer/postinstall.sh -m -b
                    Minify Main code...
                    Found: 27 files to minify
                    Process File: ../MMM-GoogleAssistant.js
                    Process File: ../components/shellExec.js
                    Process File: ../components/searchOnGoogle.js
                    Process File: ../components/screenParser.js
                    Process File: ../components/recipes.js
                    Process File: ../components/proto-loader.js
                    Process File: ../components/platform.js
                    Process File: ../components/lpcm16.js
                    Process File: ../components/googleSearch.js
                    Process File: ../components/googleAssistant.js
                    Process File: ../components/embedded-assistant.js
                    Process File: ../components/conversation.js
                    Process File: ../components/configMerge.js
                    Process File: ../components/auth.js
                    Process File: ../components/assistantSearch.js
                    Process File: ../components/assistantResponse.js
                    Process File: ../components/assistantConverse.js
                    Process File: ../components/activateProcess.js
                    Process File: ../components/activateAssistant.js
                    Process File: ../components/Hooks.js
                    Process File: ../components/Gateway.js
                    Process File: ../components/GAConfig.js
                    Process File: ../components/BufferToMP3.js
                    Process File: ../components/Assistant.js
                    Done
                    @bugsounet
                    MMM-GoogleAssistant is now installed !
                    added 158 packages in 32s
                    52 packages are looking for funding
                    > EXT-Alert@1.2.3 preinstall
                    Welcome to EXT-Alert v1.2.3
                    No root checking...
                    Checking EXT-Alert: pi/pi
                    Checking OS...
                    > EXT-Alert@1.2.3 postinstall
                    Minify Main code...
                    Found: 5 files to minify
                    Process File: ../EXT-Alert.js
                    Process File: ../components/AlertInit.js
                    Process File: ../components/AlertDisplay.js
                    Process File: ../components/AlertCommander.js
                    Done
                    @bugsounet
                    EXT-Alert is now installed !
                    added 42 packages in 12s
                    13 packages are looking for funding
                    > EXT-Bring@1.2.2 preinstall
                    Welcome to EXT-Bring v1.2.2
                    No root checking...
                    Checking EXT-Bring: pi/pi
                    Checking OS...
                    > EXT-Bring@1.2.2 postinstall
                    Minify Main code...
                    Process File: ../EXT-Bring.js
                    Process File: ../components/bring-lib.js
                    Done
                    @bugsounet
                    EXT-Bring is now installed !
                    added 50 packages in 14s
                    16 packages are looking for funding
                    > EXT-Browser@1.2.3 preinstall
                    Welcome to EXT-Browser v1.2.3
                    No root checking...
                    Checking EXT-Browser: pi/pi
                    Checking OS...
                    > EXT-Browser@1.2.3 postinstall
                    Minify Main code...
                    Found: 3 files to minify
                    Process File: ../EXT-Browser.js
                    Process File: ../components/BrowserDisplay.js
                    Done
                    @bugsounet
                    EXT-Browser is now installed !
                    added 42 packages in 7s
                    npm ERR! code 255
                    npm ERR! path /home/pi/MagicMirror/modules/EXT-Detector
                    npm ERR! command failed
                    npm ERR! command sh -c installer/postinstall.sh -r -m -b
                    npm ERR! Prepare snowboy library...
                    npm ERR! installer/postinstall.sh: ligne 40: tsc : commande introuvable
                    npm ERR! Failed!
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_31_50_369Z-debug-0.log
                    > EXT-Librespot@1.2.5 preinstall
                    Welcome to EXT-Librespot v1.2.5
                    No root checking...
                    Checking EXT-Librespot: pi/pi
                    Checking OS...
                    > EXT-Librespot@1.2.5 postinstall
                    Minify Main code...
                    Found: 2 files to minify
                    Process File: ../EXT-Librespot.js
                    Done
                    @bugsounet
                    EXT-Librespot is now installed !
                    added 195 packages in 26s
                    25 packages are looking for funding
                    > EXT-Photos@1.1.3 preinstall
                    Welcome to EXT-Photos v1.1.3
                    No root checking...
                    Checking EXT-Photos: pi/pi
                    Checking OS...
                    > EXT-Photos@1.1.3 postinstall
                    Minify Main code...
                    Process File: ../EXT-Photos.js
                    Done
                    @bugsounet
                    EXT-Photos is now installed !
                    added 42 packages in 8s
                    > EXT-RadioPlayer@1.1.6 preinstall
                    > installer/preinstall.sh -d 'vlc'
                    Welcome to EXT-RadioPlayer v1.1.6
                    No root checking...
                    Checking EXT-RadioPlayer: pi/pi
                    Checking OS...
                    Checking all dependencies...
                    All Dependencies needed are installed !
                    > EXT-RadioPlayer@1.1.6 postinstall
                    Minify Main code...
                    Process File: ../EXT-RadioPlayer.js
                    Done
                    @bugsounet
                    EXT-RadioPlayer is now installed !
                    added 50 packages in 11s
                    14 packages are looking for funding
                    > EXT-ScreenManager@1.1.0 preinstall
                    Welcome to EXT-ScreenManager v1.1.0
                    No root checking...
                    Checking EXT-ScreenManager: pi/pi
                    Checking OS...
                    > EXT-ScreenManager@1.1.0 postinstall
                    Minify Main code
                    Process File: ../EXT-ScreenManager.js
                    Done
                    @bugsounet
                    EXT-ScreenManager is now installed !
                    added 64 packages, and audited 65 packages in 12s
                    > EXT-Spotify@2.3.3 preinstall
                    Welcome to EXT-Spotify v2.3.3
                    No root checking...
                    Checking EXT-Spotify: pi/pi
                    Checking OS...
                    > EXT-Spotify@2.3.3 postinstall
                    Minify Main code...
                    Found: 6 files to minify
                    Process File: ../EXT-Spotify.js
                    Process File: ../components/spotifyLib.js
                    Process File: ../components/spotifyClass.js
                    Process File: ../components/JSPanel.js
                    Process File: ../components/CanvasLyrics.js
                    Done
                    @bugsounet
                    EXT-Spotify is now installed !
                    added 143 packages in 23s
                    48 packages are looking for funding
                    npm ERR! code 255
                    npm ERR! path /home/pi/MagicMirror/modules/Gateway
                    npm ERR! Minify Main code...
                    npm ERR! node:internal/modules/cjs/loader:1051
                    npm ERR!   throw err;
                    npm ERR!   ^
                    npm ERR!
                    npm ERR! Error: Cannot find module 'esbuild'
                    npm ERR! Require stack:
                    npm ERR! - /home/pi/MagicMirror/modules/Gateway/installer/minify.js
                    npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                    npm ERR!     at Module._load (node:internal/modules/cjs/loader:901:27)
                    npm ERR!     at Module.require (node:internal/modules/cjs/loader:1115:19)
                    npm ERR!     at require (node:internal/modules/helpers:130:18)
                    npm ERR!     at Object.<anonymous> (/home/pi/MagicMirror/modules/Gateway/installer/minify.js:6:17)
                    npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1241:14)
                    npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                    npm ERR!     at Module.load (node:internal/modules/cjs/loader:1091:32)
                    npm ERR!     at Module._load (node:internal/modules/cjs/loader:938:12)
                    npm ERR!     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12) {
                    npm ERR!   code: 'MODULE_NOT_FOUND',
                    npm ERR!   requireStack: [ '/home/pi/MagicMirror/modules/Gateway/installer/minify.js' ]
                    npm ERR! }
                    npm ERR!
                    npm ERR! Node.js v20.8.0
                    npm ERR! Minify Failed!
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_33_29_808Z-debug-0.log
                    rebuilt dependencies successfully
                    added 9 packages, and audited 10 packages in 3s
                    1 package is looking for funding
                    up to date, audited 1 package in 2s
                    added 47 packages, and audited 48 packages in 8s
                    2 moderate severity vulnerabilities
                    Some issues need review, and may require choosing
                    a different dependency.
                    Run `npm audit` for details.
                    added 4 packages, and audited 5 packages in 2s
                      sdetweil @RIKKO14
                      @RIKKO14 you need the word
                      force
                      added on the end of the upgrade command
                        RIKKO14
                        pi@raspberrypi:~ $ ^[[200~bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                        bash: $'\E[200~bash' : commande introuvable
                        saving custom.css
                        up to date in 7s
                        up to date in 47s
                        no husky installed.
                        added 334 packages in 3m
                        No root checking...
                        Checking OS...
                        Minify Main code
                        Done
                        @bugsounet
                        added 248 packages, and audited 249 packages in 26s
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        added 158 packages in 16s
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        added 42 packages in 5s
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        added 50 packages in 13s
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        npm ERR! code 255
                        npm ERR! Failed!
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_54_13_403Z-debug-0.log
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        added 195 packages in 18s
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        added 50 packages in 9s
                        No root checking...
                        Checking OS...
                        Minify Main code
                        Done
                        @bugsounet
                        added 64 packages, and audited 65 packages in 13s
                        No root checking...
                        Checking OS...
                        Minify Main code...
                        Done
                        @bugsounet
                        added 143 packages in 14s
                        npm ERR! code 255
                        npm ERR!   throw err;
                        npm ERR!   ^
                        npm ERR!
                        npm ERR! }
                        npm ERR!
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-05T14_55_27_131Z-debug-0.log
                        added 9 packages, and audited 10 packages in 2s
                        up to date, audited 1 package in 949ms
                        added 47 packages, and audited 48 packages in 7s
                        pi@raspberrypi:~/MagicMirror $ pm2 stop 0
                        [PM2] Applying action stopProcessId on app [0](ids: [ '0' ])
                        pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
                        npm start
                        [05.11.2023 15:59.49.467] [LOG]   Starting MagicMirror: v2.25.0
                        [05.11.2023 15:59.49.477] [LOG]   Loading config ...
                        [05.11.2023 15:59.49.483] [DEBUG] config template file not exists, no envsubst
                        [05.11.2023 15:59.49.489] [LOG]   Loading module helpers ...
                        [05.11.2023 15:59.49.492] [LOG]   No helper found for module: alert.
                        [05.11.2023 15:59.49.508] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.511] [LOG]   Module helper loaded: EXT-UpdateNotification
                        [05.11.2023 15:59.49.514] [LOG]   No helper found for module: clock.
                        [05.11.2023 15:59.49.832] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.833] [LOG]   Module helper loaded: calendar
                        [05.11.2023 15:59.49.838] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.839] [LOG]   Module helper loaded: MMM-GoogleAssistant
                        [05.11.2023 15:59.49.841] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.841] [LOG]   Module helper loaded: EXT-Alert
                        [05.11.2023 15:59.49.847] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.847] [LOG]   Module helper loaded: EXT-Bring
                        [05.11.2023 15:59.49.850] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.850] [LOG]   Module helper loaded: EXT-Browser
                        [05.11.2023 15:59.49.863] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.49.863] [LOG]   Module helper loaded: EXT-Detector
                        [05.11.2023 15:59.50.191] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.50.191] [LOG]   Module helper loaded: EXT-Librespot
                        [05.11.2023 15:59.50.193] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.50.194] [LOG]   Module helper loaded: EXT-Photos
                        [05.11.2023 15:59.50.196] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.50.196] [LOG]   Module helper loaded: EXT-RadioPlayer
                        [05.11.2023 15:59.50.216] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.50.216] [LOG]   Module helper loaded: EXT-ScreenManager
                        [05.11.2023 15:59.50.444] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.50.444] [LOG]   Module helper loaded: EXT-Spotify
                        [05.11.2023 15:59.50.453] [LOG]   Initializing new module helper ...
                        [05.11.2023 15:59.50.453] [LOG]   Module helper loaded: Gateway
                        [05.11.2023 15:59.50.458] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-dht-sensor'
                        Require stack:
                        - /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_helper.js:11:16)
                        [05.11.2023 15:59.50.459] [ERROR] (node:17290) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                        [17290:1105/155951.307489:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                          @RIKKO14 now another module… DHT-Sensor missing a library
                          go to the module folder and
                          see this topic
                            RIKKO14
                            I do
                            cd ~/MagicMirror/modules/MMM-DHT-Sensor
                            npm install
                            then
                            npm start
                            then
                            cd ~/MagicMirror/modules/MMM-GoogleAssistant
                            npm run update
                            npm run refresh
                            then
                            pm2 restart 0
                            then
                            sudo reboot now
                            and finally everything works well
                            thank you for your help
                              sdetweil @RIKKO14
                              @RIKKO14 thank you. upgrade script should have done npm install for the dht-sensor module. will check why not
                              bugsounetB 1 Reply Last reply Reply Quote 0
                              • bugsounetB Offline
                                bugsounet Banned @sdetweil
                                @sdetweil that’s why I write +/- the same with npm run refresh for the same problem (some libraries disappear with the change of mode version or need to be rebuilded) but it’s limited to my own modules
                                  sdetweil @bugsounet
                                  @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
                                  I check for rebuild not refresh… will fix upgrade
                                    @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
                                      sdetweil @bugsounet
                                      @bugsounet @RIKKO14
                                      can either of you run this on your French systems
                                      LC_ALL=C  free -m
                                      should output in english
                                        RIKKO14
                                        @sdetweil Hello,
                                        it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
                                          sdetweil @RIKKO14
                                          @RIKKO14 just one command run in terminal
                                          returns amount of memory being used
                                          my scripts use this an depend on the English text,
                                          trying to make sure it comes out in English is all.
                                          has no affect on system
                                            MMRIZE @RIKKO14
                                            @RIKKO14
                                            If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.
