    Module about module updates
    10 Posts 5 Posters 6.5k Views 5 Watching
      chrisfoerg
      Hi, is there a module that shows information about updates for installed modules?
      Thank you very much Christian
      • H
        hutner0502
          Mr.Meeseeks
          https://github.com/Jopyth/MMM-Remote-Control
          Developer branch can update modules and MM, but not identify if there is a module update available.
          CAAAAN DOO!👍
          • T
            tosti007 Module Developer
            Doesn’t the updatenotification already do exactly this? I also checked his code and he does check for every module if there are any commits that haven’t been pulled yet.
            Edit: Oh only just noticed that this post is a month old, don’t know if it already existed at that time.
            If there is anything don’t hesitate to contact me!
            ProfileSwitcher, TouchNotifications
              chrisfoerg @tosti007
              @tosti007 thanks for your answer. It looks like it only notice about the MM application not 3rd modules…
              • T
                tosti007 Module Developer @chrisfoerg
                @chrisfoerg but I believe the code did loop through all of them, will check again later
                • Y
                  yawns Moderator @tosti007
                  • T
                    tosti007 Module Developer @yawns
                    @yawns Checked again, it cycles through all the modules except the default modules. After doing some testing it turns out that in getRemotes the given function never gets called. So the list of “modules to check” is always empty. No idea why since I couldn’t find much of an documentation of simplegit for some reason. I will open a new topic for this.
                    Y 1 Reply Last reply Reply Quote -1
                    • Y
                      @tosti007 said in Module about module updates:
                      My bad, you are absolutely right. Sorry!
                      • T
                        @yawns no problem at all :) if you wouldn’t have said something I also wouldn’t have seen the other problem
