    Alert box location
    7 Posts 4 Posters 4.1k Views 3 Watching
      PointPubMedia
      Hey guys…
      Anyone manage to get the alert box location to be center/center instead of center/top ?
      B 1 Reply Last reply
        bhepler Module Developer @PointPubMedia
        @PointPubMedia Just in case, the name of the position value is “middle_center”. Not “center_center”. Are you getting any errors when you change the position?
        P 1 Reply Last reply
          PointPubMedia @bhepler
          @bhepler I tried… but looks like the position value have no effect on the alert module…
          • MichMichM
            MichMich
            the alert module is a bit of an odd one. It has a specific config option for the position:
                    module: 'alert',
                        position: "right"
            But this will only allow you to change it from center to left or right.
            For more info, check: https://github.com/MichMich/MagicMirror/tree/master/modules/default/alert
              PointPubMedia @MichMich
              @MichMich yeah already saw that… but I would like to display it on the center of the height too!
              My MM is a 42" monitor in portrait… so having the alert at the top is not very usefull!
              Any way the module alert can have another option to put it center/center instead of top/left,right,center ?
              • Y
                yawns Moderator
                I just did a quick test on my laptop.
                Edit ~/MagicMirror/css/custom.css and add the following:
                .ns-box {
                top: 50%;
                This should move the alert box to the vertical center. You can use the config position @MichMich mentioned to move to the horizontal center.
                  PointPubMedia @yawns
                  @yawns AWESOME ;)
                  thanks!
