    Modifying the Config File
    101 Posts 7 Posters 186.2k Views 7 Watching
      sdetweil @BKeyport
      @BKeyport don’t edit ON the pi, use Winscp or Bitvise SSH clients, then you can use your pc editor and keyboard, mouse… and double click to edit, and still have a terminal window via ssh…
      one the wall enclosed, or just developing, its exactly the same. and you can multiple systems open at once…
      I use Notepad++ or VisualStudio code…
      then u have brace matching and indentation matching… REALLY makes life easier…
      AND you can use your PC browser to access MM on the pi, so its all right there… laptop, desktop doesn’t matter…
      bitvise also has a server side(pc) file manager window so you can drag/drop files in either direction (altho you dont usually need to.)…
      all my scripts work thru ssh, MM runs there too… and you can use pm2 just like always…
      • BKeyportB Offline
        @sdetweil Fair enough, I was applying a bit of KISS (Keep It Simple, Stupid) suggesting at least initial edits can be done locally - don’t want to overwhelm.
          sdetweil @BKeyport
          @BKeyport I know, but learning all the commands, keyboard, gui tools, menus, settings, etc, is overwhelming for many people.
            jimb
            Sam, I’m trying to get to the point where I can copy/paste the config where you can take a look at it. It’s been 45 years since I looked at Unix, never Linux.
            IP Config from the OS prompt on the Pi yields -
            “Link/loopback 'all zeros…”
            “inet 127.0.0.0/8 scope host lo”
            NOT a valid IP address, it should be in the range of 192.168. x.x
            hostname command from the Pi gives “rutspi” which is the hostname I assigned as it was building.
            S B 2 Replies Last reply Reply Quote 0
              sdetweil @jimb
              @jimb if that is the only ip address, then it is not on your wifi or Ethernet networks.
              127.0.0.1 is the fake internal only network
              • BKeyportB Offline
                sounds to me like too much tinkering got the network FUBAR.
                I’d reset and start over, personally.
                  jimb
                  Sam, from the Pi I can use the browser to get to the Internet so it has an IP address. I can ping Google from it, too. At this point I think the best thing would be for me to start over with a fresh installation. I don’t want to be a PITA here!
                    sdetweil @jimb
                    @jimb not a PITA. just odd that ip addr didn’t give u all adapters info
                      bhepler Module Developer @jimb
                      @jimb said in Modifying the Config File:
                      This should be the first entry of three in the response when you enter ip addr. The next entry should be your ethernet port, and the final entry should be your wireless LAN. My suggestion is to try this on your pi: ip addr | grep inet
                      Secondly, when Sam told you to switch on SSH, did you go into the config app and do it? You can get to it from the desktop but the fastest way is to type sudo raspi-config and then navigate to “Interface Options”->“SSH”. Make sure it is enabled.
                        jimb
                        Gents, my goal was not to build a watch, only to tell the time. I have bit the bullet and will be building a new image of the OS and setting it up to run from my PC. That way I’ll be able to copy configs for all to peruse, trying to get Magic Mirror up and running. Thanks for your continued support!
                          jimb
                          Sam, et all: I have installed a fresh copy of the OS to a new SD card , booted up the Pi, and installed a new copy of the MM2 files, etc. from Sam’s installation script. The only mistake I made was making the MM auto-install. I attempted SSH into the Pi to modify the config on my PC. Had the same “no connnection” issue I had before. However, I now have the IP address of the Pi and I’m not able to ping it from my PC. When the Pi boots this IP address is displayed in the upper right corner for a few seconds so I know it’s correct. An IP config /all display shows-
                          C:\Users\Owner>ipconfig /all
                          Windows IP Configuration
                          Host Name . . . . . . . . . . . . : DESKTOP-LE5LUCM
                          Primary Dns Suffix . . . . . . . :
                          Node Type . . . . . . . . . . . . : Hybrid
                          IP Routing Enabled. . . . . . . . : No
                          WINS Proxy Enabled. . . . . . . . : No
                          DNS Suffix Search List. . . . . . : attlocal.net
                          Ethernet adapter Ethernet:
                          Connection-specific DNS Suffix . : attlocal.net
                          Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
                          Physical Address. . . . . . . . . : 78-E7-D1-C8-69-02
                          DHCP Enabled. . . . . . . . . . . : Yes
                          Autoconfiguration Enabled . . . . : Yes
                          IPv6 Address. . . . . . . . . . . : 2600:1700:d10:2900::681(Preferred)
                          Lease Obtained. . . . . . . . . . : Wednesday, November 29, 2023 1:44:08 AM
                          Lease Expires . . . . . . . . . . : Thursday, December 28, 2023 6:10:32 PM
                          IPv6 Address. . . . . . . . . . . : 2600:1700:d10:2900:17cb:6c66:31f8:87bb(Preferred)
                          Temporary IPv6 Address. . . . . . : 2600:1700:d10:2900:3974:7e8b:2c4:8999(Preferred)
                          Temporary IPv6 Address. . . . . . : 2600:1700:d10:2900:e81f:6b5c:4ac6:b88d(Deprecated)
                          Temporary IPv6 Address. . . . . . : 2600:1700:d10:2900:f895:4134:2f63:7933(Deprecated)
                          Link-local IPv6 Address . . . . . : fe80::3b70:ff2e:ecd1:4297%12(Preferred)
                          IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred)
                          Subnet Mask . . . . . . . . . . . : 255.255.255.0
                          Lease Obtained. . . . . . . . . . : Wednesday, November 29, 2023 1:44:03 AM
                          Lease Expires . . . . . . . . . . : Saturday, December 2, 2023 1:44:06 PM
                          Default Gateway . . . . . . . . . : fe80::3a3b:c8ff:fe33:13d9%12
                          192.168.1.254
                          DHCP Server . . . . . . . . . . . : 192.168.1.254
                          DHCPv6 IAID . . . . . . . . . . . : 158918609
                          DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-B7-F6-59-78-E7-D1-C8-69-02
                          DNS Servers . . . . . . . . . . . : 2600:1700:d10:2900::1
                          192.168.1.254
                          NetBIOS over Tcpip. . . . . . . . : Enabled
                          Wireless LAN adapter Wi-Fi:
                          Media State . . . . . . . . . . . : Media disconnected
                          Description . . . . . . . . . . . : 802.11n Wireless LAN Card
                          Physical Address. . . . . . . . . : 68-A3-C4-EA-95-83
                          Wireless LAN adapter Local Area Connection* 1:
                          Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
                          Physical Address. . . . . . . . . : 68-A3-C4-EA-95-85
                          Wireless LAN adapter Local Area Connection* 2:
                          Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
                          Physical Address. . . . . . . . . : 68-A3-C4-EA-95-86
                          DHCP Enabled. . . . . . . . . . . : No
                          Wireless LAN adapter Local Area Connection* 11:
                          Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
                          Physical Address. . . . . . . . . : 68-A3-C4-EA-95-84
                          C:\Users\Owner>
                          Does anyone see anything weird?
                          BKeyportB S 2 Replies Last reply Reply Quote 0
                          • BKeyportB Offline
                            BKeyport Module Developer @jimb
                            @jimb that appears to be your windows computer, not the pi.
                              sdetweil @jimb
                              u mean auto start??? install was my script
                              ssh doesn’t work unless you enable it on the pi
                              desktop, menu top left,
                              preferences
                              raspberry pi configuration
                              then the itnerfaces tab, click the slide on the ssh row,
                              then press ok…
                              if latest os, then you don’t have to boot
                              open a terminal window on pi
                              type
                              ip addr
                              you should see like this
                              pi@raspberrypi4:~ $ ip addr
                              1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                                  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                                  inet 127.0.0.1/8 scope host lo
                                     valid_lft forever preferred_lft forever
                                  inet6 ::1/128 scope host
                              2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                                  link/ether dc:a6:32:20:b0:94 brd ff:ff:ff:ff:ff:ff
                                  inet 192.168.2.44/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
                                     valid_lft 50521sec preferred_lft 36219sec
                                  inet6 fe80::a5a6:f1d1:50e7:1c5/64 scope link
                              3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
                                  link/ether dc:a6:32:20:b0:95 brd ff:ff:ff:ff:ff:ff
                              in this setup my wifi (wlan0) is not connected but my ethernet (eth0) is
                                 inet 192.168.2.44
                              doesn’t matter what the PC says…
                              do you have a guest network at home and did u connect the pi to that?
                              can’t connect to it from home network if so… intentional firewall…
                                jimb
                                Sam, the Pi is connected via wireless. Yes, I meant autorun on my first post. I did change the Pi configuration to allow SSH. I have Eero mesh AP’s connected to my home network. I don’t know how to check if access is being blocked to the Pi. Since everything is fresh on the install it makes sense that the network is the culprit. The reason I went with a new install was to enable pasting config, etc. files here on the forum.
                                  sdetweil @jimb
                                  @jimb i understand… if you can use a terminal window on the pi, can you ping xxxx, where xxxx is the hostname or ip address of the windows pc?
                                  what is the output of ip addr ?
                                  i know it stinks, but you can post a pic, third icon from the right above the forum post editor
                                    @jimb I’d also suggest trying my MMM-Config module, which presents a form for config.js including outside modules… all done with discovery of the installed modules and there parms…
                                    some modules cause trouble… but there are ways around with some extra work… it may not be for you… another pile of work to learn, it it doesn’t work…
                                    https://github.com/sdetweil/MMM-Config
                                    it doesn’t help with module install, only configure
                                      jimb
                                      Sam,
                                      OK progress on the network front. I spent some time yesterday on the phone with eero tech support. At rhe end they suggested connecting my PC wirelessly and seeing if I could ping the rasberry. It works. I can ping and SSH/Putty into the pi, but have an additional snag. It accepts the login and sends a password request. BUT, I can’t enter anything- the keyboard is dead at that point.
                                        sdetweil @jimb
                                        @jimb ok, sounds like the wifi network is a guest, not connected to the regular ethernet network…
                                        don’t use putty
                                        open a cmd.exe window
                                        ssh user_name@machine_ip
                                        add one of the tools
                                        winscp or bitvise ssh clients
                                        they will give you a filemanager view of the files and an ssh window ,
                                        per system you connect to…
                                        bitvise also provides a filemanager view of the pc filesystem , so you can drag/drop files in either direction… (you would only do that for logs to pc, of special bug fix file , to pi)
                                          jimb
                                          Sam, success! I have d/l’d the SSH gui program and here is my config.js file. I have deleted my apiKey
                                          			module: "alert",
                                          			module: "updatenotification",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			position: "top_left"
                                          			header: "US Holidays",
                                          						symbol: "calendar-check",
                                          						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                                          			module: "compliments",
                                          			position: "lower_third"
                                          			module: "weather",
                                          				apiVersion: "3.0",
                                          				lat: 33.50872,
                                          				lon: -96.612213,
                                          				weatherEndpoint: "/onecall",
                                          				type: "current",
                                          				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                          				apiKey: "8eca2aec"
                                          			module: "weather",
                                          			header: "Weather Forecast",
                                          				apiVersion: "3.0",
                                          				lat: 33.50872,
                                          				lon: -96.612213,
                                          				type: "forecast",
                                          				apiKey: "8
                                          			module: "newsfeed",
                                          			position: "bottom_bar",
                                          				feeds: [
                                          						title: "New York Times",
                                            sdetweil @jimb
                                            @jimb missing some at the bottom
                                            I assume the apikey with a new line inside is a removal edit problem
                                            always wrap config.js content in code block
                                            paste into editor
                                            blank line above and below
                                            select pasted text
                                            hit button </>
                                            • 4 / 6
